Frequent periods of unresponsiveness for 10 to 20 seconds at least on a fresh KDE install(with some programs)
Hi community,
So, yeah, I have a problem with frequent periods where the main program I was using at that moment would freeze up and not respond to typical(no manual SIGINT or anything like that) like clicking with the mouse or keyboard shortcuts. But the mouse moves and I can start new programs. If the system freezes while using menus in the downright corner of the taskbar, then the bar freezes and I cannot start new programs.
Notes:
  1. A few days ago(but a few days after the symptoms appeared) I built in a new graphics card(RTX 3080 TI).
  2. A few days ago(before I reinstalled Linux) I installed Windows 10 on a separate drive.
  3. There were already some symptoms (but only while using Firefox) on my old Gnome Manjaro, but either only a few days prior to the Windows install or very shortly after it.(I.e. I am not sure)
  4. Tested just with mpc-qt and watching a video just now on a completely fresh install and had problems. Before I could reliably initiate a freeze every time I did anything like clicking in the windows and it had very slow startup times before. This gives me the idea that one of the programs I routinely install might have an issue. I compiled lists with needed packages and needed packages I deem potentially risky in this context, and will like to provide them if you think, that might be an angle.
  5. For thoughts on the NVME see below.
Thoughts on the NVME
As I said I noticed these problems before the reinstall of Linux. While trying to find the problem I thought maybe the NVME is full. Specifically the values from smartctl --test=long -a were concerning. I proceeded to follow these steps from ArchWiki to completely format the disk clear it.
smartctl --test=long -a output now
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-5.15.60-1-MANJARO] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Number:                       Samsung SSD 970 PRO 512GB
Serial Number:                      S5JYNS0N524806M
Firmware Version:                   1B2QEXP7
PCI Vendor/Subsystem ID:            0x144d
IEEE OUI Identifier:                0x002538
Total NVM Capacity:                 512.110.190.592 [512 GB]
Unallocated NVM Capacity:           0
Controller ID:                      4
NVMe Version:                       1.3
Number of Namespaces:               1
Namespace 1 Size/Capacity:          512.110.190.592 [512 GB]
Namespace 1 Utilization:            13.193.367.552 [13,1 GB]
Namespace 1 Formatted LBA Size:     512
Namespace 1 IEEE EUI-64:            002538 550143dc5e
Local Time is:                      Tue Aug 30 19:06:12 2022 CEST
Firmware Updates (0x16):            3 Slots, no Reset required
Optional Admin Commands (0x0037):   Security Format Frmw_DL Self_Test Directvs
Optional NVM Commands (0x005f):     Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat Timestmp
Log Page Attributes (0x03):         S/H_per_NS Cmd_Eff_Lg
Maximum Data Transfer Size:         512 Pages
Warning  Comp. Temp. Threshold:     81 Celsius
Critical Comp. Temp. Threshold:     81 Celsius
Supported Power States
St Op     Max   Active     Idle   RL RT WL WT  Ent_Lat  Ex_Lat
 0 +     6.20W       -        -    0  0  0  0        0       0
 1 +     4.30W       -        -    1  1  1  1        0       0
 2 +     2.10W       -        -    2  2  2  2        0       0
 3 -   0.0400W       -        -    3  3  3  3      210    1200
 4 -   0.0050W       -        -    4  4  4  4     2000    8000
Supported LBA Sizes (NSID 0x1)
Id Fmt  Data  Metadt  Rel_Perf
 0 +     512       0         0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning:                   0x00
Temperature:                        37 Celsius
Available Spare:                    100%
Available Spare Threshold:          10%
Percentage Used:                    4%
Data Units Read:                    37.390.382 [19,1 TB]
Data Units Written:                 50.113.036 [25,6 TB]
Host Read Commands:                 371.657.079
Host Write Commands:                647.574.047
Controller Busy Time:               2.724
Power Cycles:                       1.063
Power On Hours:                     2.299
Unsafe Shutdowns:                   118
Media and Data Integrity Errors:    0
Error Information Log Entries:      3.359
Warning  Comp. Temperature Time:    0
Critical Comp. Temperature Time:    0
Temperature Sensor 1:               37 Celsius
Temperature Sensor 2:               40 Celsius
Error Information (NVMe Log 0x01, 16 of 64 entries)
Num   ErrCount  SQId   CmdId  Status  PELoc          LBA  NSID    VS
  0       3359     0  0x2013  0x4004      -            0     0     -
Values I found interesting:
Because they were around so before:
Namespace 1 Utilization:            511.193.367.552 [something]
Some system infos in a nutshell
  • BTRFS
  • Tried Kernel 5.15. Installed 5.10 and 5.19 now and will try them as well.
  • PSU is currently unable to handle very high spikes in power usage that the 3080s are known for. A better one is on the way. On Windows and with very high computation requirements (i.e. a game) this lead to a complete swift and unorderly “shutdown” from the PSU. Perhaps Linux handles these differently?
The mandatory inxi output:
  Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
    root=UUID=8061d212-23e6-49c1-b2da-b8dfa89f97fe rw rootflags=subvol=@ quiet
    cryptdevice=UUID=23dadd26-f8c0-4173-a251-7efef63ca5ee:luks-23dadd26-f8c0-4173-a251-7efef63ca5ee
    root=/dev/mapper/luks-23dadd26-f8c0-4173-a251-7efef63ca5ee
    udev.log_priority=3
  Console: pty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
    base: Arch Linux
  Type: Desktop Mobo: ASRock model: B550 Steel Legend serial: N/A
    UEFI: American Megatrends v: P1.80 date: 12/01/2020
  Device-1: hidpp_battery_0 model: Logitech G305 Lightspeed Wireless Gaming
    Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  RAM: total: 31.27 GiB used: 3.85 GiB (12.3%)
  Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
    note: est.
  Device-1: DIMM 0 type: no module installed
  Device-2: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 3600 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
    width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-3600C17-16GTZSW serial: N/A
  Device-3: DIMM 0 type: no module installed
  Device-4: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 7 5800X socket: AM4 bits: 64 type: MT MCP arch: Zen 3
    gen: 4 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 2300 high: 3800 min/max: 2200/4850 boost: enabled
    base/boost: 3800/4850 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.1 V ext-clock: 100 MHz cores: 1: 2200 2: 2200 3: 2200 4: 2200
    5: 2200 6: 2200 7: 3800 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
    13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 121422
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    prctl and seccomp
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GA102 [GeForce RTX 3080 Ti] vendor: ASUSTeK driver: nvidia
    v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
    (as of 2022-07) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 0a:00.0 chip-ID: 10de:2208 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 137 s-size: 712x400mm (28.03x15.75")
    s-diag: 817mm (32.15")
  Monitor-1: DP-2 res: 3840x2160 hz: 60 dpi: 138
    size: 708x399mm (27.87x15.71") diag: 813mm (32") modes: N/A
  OpenGL: renderer: NVIDIA GeForce RTX 3080 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA
    515.65.01 direct render: Yes
  Device-1: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel bus-ID: 1-2.2:6 v: kernel chip-ID: 2cc2:0027 pcie:
    gen: 4 class-ID: 0300 speed: 16 GT/s serial: <filter> lanes: 16
    bus-ID: 0a:00.1 chip-ID: 10de:1aef class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
    bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Lautsprecher Teufel GmbH CINEBAR ONE type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  Device-4: Blue Microphones Yeti Stereo Microphone type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.3:10 chip-ID: b58e:9e84
    class-ID: 0300 serial: <filter>
  Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.56 running: yes
  Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0
  IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
    mac: <filter>
  IP v6: <filter> type: noprefixroute scope: global
  IF-ID-2: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
  IP v6: <filter> virtual: stable-privacy scope: link
  IF-ID-3: pvpnksintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
  Message: Output throttled. IPs: 3; Limit: 10; Override: --limit [1-x;-1
    all]
    driver: btusb v: 0.8 bus-ID: 1-2.4:11 chip-ID: 0a12:0001 class-ID: e001
  Device-1: luks-8cb49f2d-9d6b-4133-b0c7-956722c1f552 maj-min: 254:1
    type: LUKS dm: dm-1 size: 3.64 TiB
  Components:
  p-1: sde1 maj-min: 8:65 size: 3.64 TiB
  Device-2: luks-23dadd26-f8c0-4173-a251-7efef63ca5ee maj-min: 254:0
    type: LUKS dm: dm-0 size: 476.62 GiB
  Components:
  p-1: nvme1n1p2 maj-min: 259:5 size: 476.62 GiB
  Local Storage: total: 8.03 TiB used: 3.39 TiB (42.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 1B2QGXA7 temp: 32.9 C scheme: GPT
  SMART: yes health: PASSED on: 26d 16h cycles: 1,062 read-units: 8,998,678
    [4.60 TB] written-units: 5,911,171 [3.02 TB]
  ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 970 PRO 512GB
    lanes: 4 type: SSD serial: <filter> rev: 1B2QEXP7 temp: 36.9 C scheme: GPT
  SMART: yes health: PASSED on: 95d 19h cycles: 1,063 read-units: 37,390,381
    [19.1 TB] written-units: 50,112,666 [25.6 TB]
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
    family: based SSDs size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.3 speed: 6.0 Gb/s type: SSD serial: <filter>
    rev: 1B6Q temp: 30 C
  SMART: yes state: enabled health: PASSED on: 202d 1h cycles: 731
    written: 11.27 TiB Pre-Fail: reallocated sector: 98 threshold: 10
  ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 1TB
    rev: 2B6Q temp: 30 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 72 hrs cycles: 9
    written: 1.1 TiB
  ID-5: /dev/sdc maj-min: 8:32 type: USB vendor: Silicon Motion model: 1000
    size: 58.98 GiB block-size: physical: 512 B logical: 512 B type: N/A
    serial: <filter> scheme: MBR
  ID-6: /dev/sdd maj-min: 8:48 type: USB vendor: Western Digital model: WD
    Elements 2621 drive model: WD20SDRW-11VUUS0 size: 1.82 TiB block-size:
    physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD
    rpm: 5400 serial: <filter> drive serial: <filter> rev: 1026
    drive rev: 01.01A01 temp: 34 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 54d 6h cycles: 257
  ID-7: /dev/sde maj-min: 8:64 type: USB vendor: Western Digital model: WD
    Elements 2620 drive model: WD40NDZW-11A8JS1 family: Elements / My Passport
    (USB, AF) size: 3.64 TiB block-size: physical: 4096 B logical: 512 B
    sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
    drive serial: <filter> rev: 1018 drive rev: 01.01A01 temp: 36 C
    scheme: GPT
  SMART: yes state: enabled health: PASSED on: 354d 19h cycles: 946
  ID-1: / raw-size: 476.62 GiB size: 476.62 GiB (100.00%) used: 10.89 GiB
    (2.3%) fs: btrfs block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-23dadd26-f8c0-4173-a251-7efef63ca5ee label: MJD_ROOT
    uuid: 8061d212-23e6-49c1-b2da-b8dfa89f97fe
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 26 MiB
    (8.7%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1 maj-min: 259:4
    label: NO_LABEL uuid: 894A-D812
  ID-3: /home raw-size: 476.62 GiB size: 476.62 GiB (100.00%) used: 10.89
    GiB (2.3%) fs: btrfs block-size: 4096 B dev: /dev/dm-0 maj-min: 254:0
  ID-4: /run/media/filteredusername/TTT raw-size: 3.64 TiB size: 3.58 TiB
    (98.40%) used: 3.38 TiB (94.5%) fs: ext4 block-size: 4096 B dev: /dev/dm-1
    maj-min: 254:1 mapped: luks-8cb49f2d-9d6b-4133-b0c7-956722c1f552
    label: TTT uuid: 4db3c0c0-9875-4ee3-8967-b9e242488fcd
  ID-5: /var/cache raw-size: 476.62 GiB size: 476.62 GiB (100.00%) used: 10.89
  ID-6: /var/log raw-size: 476.62 GiB size: 476.62 GiB (100.00%) used: 10.89
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: N/A label: N/A
    uuid: N/A
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 232.87 GiB fs: ntfs label: N/A
    uuid: 56689DAA689D88FF
  ID-3: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ntfs
    label: WIN-JON-DESK-EXPANSION uuid: 761A52ED6ECD337B
  ID-4: /dev/sdc1 maj-min: 8:33 size: 3.32 GiB fs: iso9660
  ID-5: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: C80E-8B3F
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
  Hub-2: 1-2:2 info: NEC HighSpeed Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 0409:005a class-ID: 0900
  Device-1: 1-2.1:4 info: Logitech DeLuxe 250 Keyboard type: Keyboard,HID
    power: 100mA chip-ID: 046d:c312 class-ID: 0300
  Device-2: 1-2.2:6 info: Lautsprecher Teufel GmbH CINEBAR ONE
    type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
    rev: 2.0 speed: 12 Mb/s power: 500mA chip-ID: 2cc2:0027 class-ID: 0300
    serial: <filter>
  Device-3: 1-2.3:10 info: Blue Microphones Yeti Stereo Microphone
    rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: b58e:9e84 class-ID: 0300
    serial: <filter>
  Device-4: 1-2.4:11 info: Cambridge Silicon Radio Bluetooth Dongle (HCI
    mode) type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  Device-5: 1-3:3 info: Logitech USB Receiver type: Keyboard,Mouse,HID
    power: 98mA chip-ID: 046d:c53f class-ID: 0300
  Hub-3: 1-6:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-4: 1-6.1:8 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-5: 1-7:7 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 1-10:9 info: ASRock LED Controller type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
    power: 100mA chip-ID: 26ce:01a2 class-ID: 0300 serial: <filter>
  Hub-6: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Device-1: 2-4:2 info: Western Digital Elements 2620 type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 896mA
    chip-ID: 1058:2620 class-ID: 0806 serial: <filter>
  Hub-7: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-2:2 info: Silicon Motion - Taiwan (formerly Feiya ) Flash
    Drive type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
    speed: 480 Mb/s power: 500mA chip-ID: 090c:1000 class-ID: 0806
    serial: <filter>
  Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Device-1: 4-1:2 info: Western Digital Elements 2621 type: Mass Storage
    chip-ID: 1058:2621 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 46.0 C mobo: N/A gpu: nvidia temp: 47 C
  Processes: 379 Uptime: 45m wakeups: 3 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
  Packages: pacman: 1216 lib: 317 flatpak: 0 Shell: Zsh (sudo) v: 5.9
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.20
I hope that the information I provided until now, may prove useful and of course that together we will be able to diagnose and perhaps even solve the problem :+1:
so those freezes were happening also when running gnome? and before installing windows?
open this file:
kate /etc/environment
and add there this line:
QT_LOGGING_RULES='*=false'
save it
it will disable the kwin/qt logs, then reboot;
and reproduce the freeze and then provide logs:
sudo dmesg -l err,warn,emerg,alert
journalctl -b0 -p5 --no-pager
I am very sure, yes!
Alright, I will do my best to reproduce XD
(Un)Fortunately in the last few hours I had no problems, but I did not dare reinstall all my packages yet, either, so that’s what’s gonna happen now.
I hope I can say more tomorrow(Germany).
Thanks for the angle!!! :grin: :pray:
Hi again,
packages installed and freeze documented.
If it is better to include the logs in the opening message I can gladly edit it. For now here notes and data.
Freeze
Where and How
In Firefox. While using the forum. Less than a minute(possibly less than a half) after I started Firefox.
Detailed info will be supplied if helpful
Logs
Dmesg
[    0.246712]   #9 #10 #11 #12 #13 #14 #15
[    0.407860] efifb: Ignoring BGRT: unexpected or invalid BMP data
[    0.888327] ata1.00: supports DRM functions and may not be fully accessible
[    0.891060] ata1.00: supports DRM functions and may not be fully accessible
[    1.368667] ata2.00: supports DRM functions and may not be fully accessible
[    1.372185] ata2.00: supports DRM functions and may not be fully accessible
[    3.348143] ata6: failed to resume link (SControl 0)
[    3.440330] nvme nvme1: missing or invalid SUBNQN field.
[    5.496266] sd 7:0:0:0: [sdd] No Caching mode page found
[    5.496267] sd 7:0:0:0: [sdd] Assuming drive cache: write through
[    5.496857] sd 6:0:0:0: [sdc] No Caching mode page found
[    5.496859] sd 6:0:0:0: [sdc] Assuming drive cache: write through
[    5.513956] sd 8:0:0:0: [sde] No Caching mode page found
[    5.513956] sd 8:0:0:0: [sde] Assuming drive cache: write through
[    8.731569] nvidia: loading out-of-tree module taints kernel.
[    8.731576] nvidia: module license 'NVIDIA' taints kernel.
[    8.731577] Disabling lock debugging due to kernel taint
[    8.992569] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  515.65.01  Wed Jul 20 14:00:58 UTC 2022
[    9.601705] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[   11.777966] usb 1-2.2: 2:1: cannot set freq 48000 to ep 0x3
[   16.805684] kauditd_printk_skb: 40 callbacks suppressed
[   16.992309] usb 1-2.2: 5:0: failed to get current value for ch 0 (-110)
[   27.231618] usb 1-2.2: 2:0: failed to get current value for ch 0 (-110)
[   28.358963] kauditd_printk_skb: 10 callbacks suppressed
[   37.471648] usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
[   42.591829] usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
[   47.711882] usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
[   52.831927] usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
[   57.951780] usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
[   63.071985] usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
[   68.191840] usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
[   73.312072] usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
[   78.435051] usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
[   83.551558] usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
[  104.031611] usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
[  109.151795] usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
[  114.271757] usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
[  119.391549] usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
[  124.512033] usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
[  129.631550] usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
[  134.751639] usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
[  139.871734] usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
[  144.991564] usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
[  150.111860] usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
[  152.590327] process '@/opt/teamspeak3/ts3client_linux_amd64' started with executable stack
[  155.231590] usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
[  160.351706] usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
[  165.471626] usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
[  170.591892] usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
[  171.486618] debugfs: Directory 'card3' with parent 'sound' already present!
[  171.847905] usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
[  171.857808] usb 1-2.2: 2:0: usb_set_interface failed (-32)
[  171.867831] usb 1-2.2: 2:0: usb_set_interface failed (-32)
[  171.884882] usb 1-2.2: 2:1: usb_set_interface failed (-32)
[  171.894484] usb 1-2.2: 2:0: usb_set_interface failed (-32)
[  171.904109] usb 1-2.2: 2:0: usb_set_interface failed (-32)
[  171.919983] usb 1-2.2: 2:1: usb_set_interface failed (-19)
[  171.919987] usb 1-2.2: 2:0: usb_set_interface failed (-19)
[  172.996285] usb 1-2.2: 2:1: cannot set freq 48000 to ep 0x3
Journal
Filtered out my username, may have missed other information
Aug 30 23:29:28 man-jon-desk kernel: Linux version 5.19.1-3-MANJARO (builduser@fv-az196-43) (gcc (GCC) 12.1.1 20220730, GNU ld (GNU Binutils) 2.39) #1 SMP PREEMPT_DYNAMIC Sat Aug 13 06:34:52 UTC 2022
Aug 30 23:29:28 man-jon-desk kernel: Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.19-x86_64 root=UUID=8061d212-23e6-49c1-b2da-b8dfa89f97fe rw rootflags=subvol=@ quiet cryptdevice=UUID=23dadd26-f8c0-4173-a251-7efef63ca5ee:luks-23dadd26-f8c0-4173-a251-7efef63ca5ee root=/dev/mapper/luks-23dadd26-f8c0-4173-a251-7efef63ca5ee udev.log_priority=3
Aug 30 23:29:28 man-jon-desk kernel: Unknown kernel command line parameters "BOOT_IMAGE=/@/boot/vmlinuz-5.19-x86_64 cryptdevice=UUID=23dadd26-f8c0-4173-a251-7efef63ca5ee:luks-23dadd26-f8c0-4173-a251-7efef63ca5ee", will be passed to user space.
Aug 30 23:29:28 man-jon-desk kernel: random: crng init done
Aug 30 23:29:28 man-jon-desk kernel:   #9 #10 #11 #12 #13 #14 #15
Aug 30 23:29:28 man-jon-desk kernel: audit: type=2000 audit(1661894959.176:1): state=initialized audit_enabled=0 res=1
Aug 30 23:29:28 man-jon-desk kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Aug 30 23:29:28 man-jon-desk kernel: SCSI subsystem initialized
Aug 30 23:29:28 man-jon-desk kernel: VFS: Disk quotas dquot_6.6.0
Aug 30 23:29:28 man-jon-desk kernel: Initialise system trusted keyrings
Aug 30 23:29:28 man-jon-desk kernel: Key type blacklist registered
Aug 30 23:29:28 man-jon-desk kernel: integrity: Platform Keyring initialized
Aug 30 23:29:28 man-jon-desk kernel: integrity: Machine keyring initialized
Aug 30 23:29:28 man-jon-desk kernel: Key type asymmetric registered
Aug 30 23:29:28 man-jon-desk kernel: Asymmetric key parser 'x509' registered
Aug 30 23:29:28 man-jon-desk kernel: efifb: Ignoring BGRT: unexpected or invalid BMP data
Aug 30 23:29:28 man-jon-desk kernel: Loading compiled-in X.509 certificates
Aug 30 23:29:28 man-jon-desk kernel: Loaded X.509 cert 'Build time autogenerated kernel key: a79eaf520fee2b4b1cc63b196c2a681703b07612'
Aug 30 23:29:28 man-jon-desk kernel: Key type ._fscrypt registered
Aug 30 23:29:28 man-jon-desk kernel: Key type .fscrypt registered
Aug 30 23:29:28 man-jon-desk kernel: Key type fscrypt-provisioning registered
Aug 30 23:29:28 man-jon-desk kernel: ata1.00: supports DRM functions and may not be fully accessible
Aug 30 23:29:28 man-jon-desk kernel: scsi 0:0:0:0: Direct-Access     ATA      Samsung SSD 870  1B6Q PQ: 0 ANSI: 5
Aug 30 23:29:28 man-jon-desk kernel: sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
Aug 30 23:29:28 man-jon-desk kernel: sd 0:0:0:0: [sda] Write Protect is off
Aug 30 23:29:28 man-jon-desk kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Aug 30 23:29:28 man-jon-desk kernel: sd 0:0:0:0: [sda] supports TCG Opal
Aug 30 23:29:28 man-jon-desk kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Aug 30 23:29:28 man-jon-desk kernel: ata2.00: supports DRM functions and may not be fully accessible
Aug 30 23:29:28 man-jon-desk kernel: scsi 1:0:0:0: Direct-Access     ATA      Samsung SSD 870  2B6Q PQ: 0 ANSI: 5
Aug 30 23:29:28 man-jon-desk kernel: sd 1:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
Aug 30 23:29:28 man-jon-desk kernel: sd 1:0:0:0: [sdb] Write Protect is off
Aug 30 23:29:28 man-jon-desk kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Aug 30 23:29:28 man-jon-desk kernel: sd 1:0:0:0: [sdb] supports TCG Opal
Aug 30 23:29:28 man-jon-desk kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
Aug 30 23:29:28 man-jon-desk kernel: ata6: failed to resume link (SControl 0)
Aug 30 23:29:28 man-jon-desk kernel: ccp 0000:0c:00.1: ccp: unable to access the device: you might be running a broken BIOS.
Aug 30 23:29:28 man-jon-desk kernel: ccp 0000:0c:00.1: psp enabled
Aug 30 23:29:28 man-jon-desk kernel: nvme nvme1: missing or invalid SUBNQN field.
Aug 30 23:29:28 man-jon-desk kernel: Key type encrypted registered
Aug 30 23:29:28 man-jon-desk kernel: scsi 7:0:0:0: Direct-Access     WD       Elements 2621    1026 PQ: 0 ANSI: 6
Aug 30 23:29:28 man-jon-desk kernel: scsi 8:0:0:0: Direct-Access     WD       Elements 2620    1018 PQ: 0 ANSI: 6
Aug 30 23:29:28 man-jon-desk kernel: scsi 6:0:0:0: Direct-Access                                    PQ: 0 ANSI: 4
Aug 30 23:29:28 man-jon-desk kernel: sd 6:0:0:0: [sdc] 123699200 512-byte logical blocks: (63.3 GB/59.0 GiB)
Aug 30 23:29:28 man-jon-desk kernel: sd 7:0:0:0: [sdd] 3906963456 512-byte logical blocks: (2.00 TB/1.82 TiB)
Aug 30 23:29:28 man-jon-desk kernel: sd 8:0:0:0: [sde] Very big device. Trying to use READ CAPACITY(16).
Aug 30 23:29:28 man-jon-desk kernel: sd 8:0:0:0: [sde] 7813969920 512-byte logical blocks: (4.00 TB/3.64 TiB)
Aug 30 23:29:28 man-jon-desk kernel: sd 8:0:0:0: [sde] 4096-byte physical blocks
Aug 30 23:29:28 man-jon-desk kernel: sd 7:0:0:0: [sdd] Write Protect is off
Aug 30 23:29:28 man-jon-desk kernel: sd 6:0:0:0: [sdc] Write Protect is off
Aug 30 23:29:28 man-jon-desk kernel: sd 7:0:0:0: [sdd] No Caching mode page found
Aug 30 23:29:28 man-jon-desk kernel: sd 7:0:0:0: [sdd] Assuming drive cache: write through
Aug 30 23:29:28 man-jon-desk kernel: sd 6:0:0:0: [sdc] No Caching mode page found
Aug 30 23:29:28 man-jon-desk kernel: sd 6:0:0:0: [sdc] Assuming drive cache: write through
Aug 30 23:29:28 man-jon-desk kernel: sd 6:0:0:0: [sdc] Attached SCSI removable disk
Aug 30 23:29:28 man-jon-desk kernel: sd 7:0:0:0: [sdd] Attached SCSI disk
Aug 30 23:29:28 man-jon-desk kernel: sd 8:0:0:0: [sde] Write Protect is off
Aug 30 23:29:28 man-jon-desk kernel: sd 8:0:0:0: [sde] No Caching mode page found
Aug 30 23:29:28 man-jon-desk kernel: sd 8:0:0:0: [sde] Assuming drive cache: write through
Aug 30 23:29:28 man-jon-desk kernel: sd 8:0:0:0: [sde] Attached SCSI disk
Aug 30 23:29:28 man-jon-desk kernel: audit: type=1130 audit(1661894968.243:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:29:28 man-jon-desk kernel: audit: type=1130 audit(1661894968.250:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:29:28 man-jon-desk kernel: audit: type=1130 audit(1661894968.277:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:29:28 man-jon-desk kernel: audit: type=1130 audit(1661894968.367:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-cryptsetup@luks\x2d23dadd26\x2df8c0\x2d4173\x2da251\x2d7efef63ca5ee comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:29:28 man-jon-desk kernel: audit: type=1130 audit(1661894968.387:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-894A\x2dD812 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:29:28 man-jon-desk kernel: nvidia: loading out-of-tree module taints kernel.
Aug 30 23:29:28 man-jon-desk kernel: nvidia: module license 'NVIDIA' taints kernel.
Aug 30 23:29:28 man-jon-desk kernel: Disabling lock debugging due to kernel taint
Aug 30 23:29:28 man-jon-desk kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Aug 30 23:29:29 man-jon-desk kernel:
Aug 30 23:29:29 man-jon-desk kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  515.65.01  Wed Jul 20 14:00:58 UTC 2022
Aug 30 23:29:29 man-jon-desk kernel: audit: type=1130 audit(1661894969.203:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:29:29 man-jon-desk kernel: audit: type=1130 audit(1661894969.280:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:29:29 man-jon-desk kernel: audit: type=1127 audit(1661894969.283:9): pid=609 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Aug 30 23:29:29 man-jon-desk kernel: audit: type=1130 audit(1661894969.283:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:29:29 man-jon-desk kernel: audit: type=1130 audit(1661894969.287:11): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:29:29 man-jon-desk kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Aug 30 23:29:29 man-jon-desk polkitd[626]: Loading rules from directory /etc/polkit-1/rules.d
Aug 30 23:29:29 man-jon-desk polkitd[626]: Loading rules from directory /usr/share/polkit-1/rules.d
Aug 30 23:29:29 man-jon-desk polkitd[626]: Finished loading, compiling and executing 8 rules
Aug 30 23:29:29 man-jon-desk polkitd[626]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Aug 30 23:29:31 man-jon-desk systemd[691]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Aug 30 23:29:31 man-jon-desk systemd[691]: xdg-user-dirs-update.service: Main process exited, code=exited, status=1/FAILURE
Aug 30 23:29:31 man-jon-desk systemd[691]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Aug 30 23:29:31 man-jon-desk systemd[691]: Failed to start Update XDG user dir configuration.
Aug 30 23:29:31 man-jon-desk kernel: usb 1-2.2: 2:1: cannot set freq 48000 to ep 0x3
Aug 30 23:29:31 man-jon-desk systemd[718]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Aug 30 23:29:32 man-jon-desk udisksd[740]: udisks daemon version 2.9.4 starting
Aug 30 23:29:32 man-jon-desk udisksd[740]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Aug 30 23:29:36 man-jon-desk kernel: kauditd_printk_skb: 40 callbacks suppressed
Aug 30 23:29:36 man-jon-desk kernel: audit: type=1131 audit(1661894976.897:50): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:29:37 man-jon-desk kernel: usb 1-2.2: 5:0: failed to get current value for ch 0 (-110)
Aug 30 23:29:38 man-jon-desk kernel: audit: type=1100 audit(1661894978.223:51): pid=756 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="filteredusername" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Aug 30 23:29:38 man-jon-desk kernel: audit: type=1101 audit(1661894978.223:52): pid=756 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="filteredusername" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Aug 30 23:29:38 man-jon-desk kernel: audit: type=1103 audit(1661894978.223:53): pid=756 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="filteredusername" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Aug 30 23:29:38 man-jon-desk kernel: audit: type=1006 audit(1661894978.223:54): pid=756 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
Aug 30 23:29:38 man-jon-desk kernel: audit: type=1300 audit(1661894978.223:54): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffc499e7390 a2=4 a3=7ffc499e70a4 items=0 ppid=668 pid=756 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" key=(null)
Aug 30 23:29:38 man-jon-desk kernel: audit: type=1327 audit(1661894978.223:54): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746831353135393134382D313363622D343839632D623938622D646235623162333039383936002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
Aug 30 23:29:38 man-jon-desk kernel: audit: type=1130 audit(1661894978.230:55): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:29:38 man-jon-desk systemd[758]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[filteredusername] ruser=[<unknown>] rhost=[<unknown>]
Aug 30 23:29:38 man-jon-desk kernel: audit: type=1101 audit(1661894978.233:56): pid=758 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="filteredusername" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:29:38 man-jon-desk kernel: audit: type=1103 audit(1661894978.233:57): pid=758 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="filteredusername" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Aug 30 23:29:39 man-jon-desk polkitd[626]: Registered Authentication Agent for unix-session:2 (system bus name :1.34 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale de_DE.UTF-8)
Aug 30 23:29:39 man-jon-desk backlighthelper[947]: org.kde.powerdevil: no kernel backlight interface found
Aug 30 23:29:39 man-jon-desk wireplumber[1062]: Failed to set scheduler settings: Die Operation ist nicht erlaubt
Aug 30 23:29:39 man-jon-desk wireplumber[1062]: reserve-device plugin is not connected to D-Bus, disabling device reservation
Aug 30 23:29:39 man-jon-desk wireplumber[1062]: SPA handle 'api.libcamera.enum.manager' could not be loaded; is it installed?
Aug 30 23:29:39 man-jon-desk wireplumber[1062]: PipeWire's libcamera SPA missing or broken. libcamera not supported.
Aug 30 23:29:47 man-jon-desk kernel: usb 1-2.2: 2:0: failed to get current value for ch 0 (-110)
Aug 30 23:29:48 man-jon-desk systemd[692]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Aug 30 23:29:48 man-jon-desk kernel: kauditd_printk_skb: 10 callbacks suppressed
Aug 30 23:29:48 man-jon-desk kernel: audit: type=1131 audit(1661894988.447:66): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@964 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:29:48 man-jon-desk kernel: audit: type=1131 audit(1661894988.450:67): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@964 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:29:57 man-jon-desk kernel: usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
Aug 30 23:30:01 man-jon-desk kernel: audit: type=1131 audit(1661895001.937:68): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:30:02 man-jon-desk kernel: audit: type=1334 audit(1661895002.047:69): prog-id=0 op=UNLOAD
Aug 30 23:30:02 man-jon-desk kernel: audit: type=1334 audit(1661895002.047:70): prog-id=0 op=UNLOAD
Aug 30 23:30:02 man-jon-desk kernel: audit: type=1334 audit(1661895002.047:71): prog-id=0 op=UNLOAD
Aug 30 23:30:02 man-jon-desk kernel: usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
Aug 30 23:30:07 man-jon-desk kernel: usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
Aug 30 23:30:12 man-jon-desk kernel: usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
Aug 30 23:30:18 man-jon-desk kernel: usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
Aug 30 23:30:23 man-jon-desk kernel: usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
Aug 30 23:30:23 man-jon-desk kernel: audit: type=1701 audit(1661895023.820:72): auid=1000 uid=1000 gid=1000 ses=2 pid=1308 comm="firefox" exe="/usr/lib/firefox/firefox" sig=11 res=1
Aug 30 23:30:23 man-jon-desk kernel: audit: type=1334 audit(1661895023.823:73): prog-id=20 op=LOAD
Aug 30 23:30:23 man-jon-desk kernel: audit: type=1334 audit(1661895023.823:74): prog-id=21 op=LOAD
Aug 30 23:30:23 man-jon-desk kernel: audit: type=1334 audit(1661895023.823:75): prog-id=22 op=LOAD
Aug 30 23:30:23 man-jon-desk kernel: audit: type=1130 audit(1661895023.823:76): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-1309-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:30:23 man-jon-desk systemd-coredump[1310]: Process 1308 (firefox) of user 1000 dumped core.
                                                     Module linux-vdso.so.1 with build-id 51212fcf87a210a557b605b00d7465cd19ca6edc
                                                     Module libGLX.so.0 with build-id 1d664a1f03d6c5c9ac997c4b73f3e8a11424cc74
                                                     Module libGLdispatch.so.0 with build-id 9901dca23d6ccd49929b5f44c81cd671f1ec6757
                                                     Module libvdpau.so.1 with build-id fccd021ff13c37ebf7144d184a3250624e086f52
                                                     Module libGL.so.1 with build-id a3025d7d2cce51ecb2d47c076bfddefbf7e081f0
                                                     Module nvidia_drv_video.so with build-id 8976d88c463676c8a7a27a4fa06ab51a4f428200
                                                     Module libdrm.so.2 with build-id 39847bc84bc769f632f8f599a62fdcc98c9270cd
                                                     Module libva.so.2 with build-id 86d5ae6b358ba79962131649d99e42e1ba669501
                                                     Module libva-drm.so.2 with build-id 58df7fa92e899fee0c784db7a9fc68bb107156b6
                                                     Module libxcb-glx.so.0 with build-id 71d5b6691f53a235696da49ffa2178d643ecc228
                                                     Module librt.so.1 with build-id 837ea1d121976e9fa94acdf79939b387a32531db
                                                     Module libplds4.so with build-id 35c8b19ee309f8a4c2a4409568d2ab4f11a6557a
                                                     Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
                                                     Module libdbus-glib-1.so.2 with build-id 9b483ffff76251ff057e007a0b960bff84ce34a8
                                                     Module libnssutil3.so with build-id 36c34a5ab8de68047e7886fe56da7ccf6722f465
                                                     Module libnss3.so with build-id 87abb242025e6e243d6974b3a9da26166884533a
                                                     Module libsmime3.so with build-id e80b1eacbb0979a1355fd008847c6eef060e83e3
                                                     Module libssl3.so with build-id 94040772bf0029a13562ab6314237dc26ea29a60
                                                     Module libplc4.so with build-id d3b585736c213f75d6d1071f8db9a6219f1dd429
                                                     Module libasound.so.2 with build-id aefb908044b1b408df406f1a9bab9bba486c0e94
                                                     Module libxul.so with build-id 3bbdbf34b8993b86340f840ae98cccd9ed6425fc
                                                     Module libmozwayland.so with build-id d10ccd85e5bd875d6a89f6f07578976b26ea27f7
                                                     Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
                                                     Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
                                                     Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
                                                     Module libcap.so.2 with build-id 1f87347b85b55db2f75a2ecea5cb45d846dc7093
                                                     Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
                                                     Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
                                                     Module libsystemd.so.0 with build-id f53e01cd7b3e5ff8757530ed7a65324ae12df5c8
                                                     Module liblzma.so.5 with build-id d08f5868cd5adcc6b7c53bf1725aac65bd4539cd
                                                     Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
                                                     Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
                                                     Module libXau.so.6 with build-id 60db1eac70f819bea9d4c366603c1583067510b4
                                                     Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
                                                     Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
                                                     Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
                                                     Module libblkid.so.1 with build-id fb2c5d3c17aac74758a3eb80a2bc1c16bcf183b1
                                                     Module libpthread.so.0 with build-id b966d4b239433c89ca36c0938381e2d92cd47639
                                                     Module libxml2.so.2 with build-id 8cdf00fa954d9a27f2f184c4d354cb14677446ac
                                                     Module libjson-glib-1.0.so.0 with build-id 58decebd2c409d59b07f926ae4c513281918bc4d
                                                     Module libsqlite3.so.0 with build-id e35d23d9eef4b99c931412b3a1355e333fcb10a5
                                                     Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
                                                     Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
                                                     Module libstemmer.so.0 with build-id 013b48e71279a5ec55e3021fc0bd8fb10a08bae5
                                                     Module libatspi.so.0 with build-id 87bca381f073faea3b0ffd1ab06f5f8f204e24cf
                                                     Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
                                                     Module libtiff.so.5 with build-id 5f020a8eb30e12c2e4012d0cb50da9480c7b5d34
                                                     Module libjpeg.so.8 with build-id 8e6d3f3e8f438912b561c43b6e7f66e6e5e097d0
                                                     Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
                                                     Module libpixman-1.so.0 with build-id d2170a3ac106c2a68597bf7910ab04b1cdd69c14
                                                     Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
                                                     Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
                                                     Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
                                                     Module libXrender.so.1 with build-id 42e386d2acf3cde61081959d9671ca74acfb3edc
                                                     Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
                                                     Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
                                                     Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
                                                     Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
                                                     Module libmount.so.1 with build-id 9064fc3620c42e6f7aed38119f0a3ec39fca9a37
                                                     Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
                                                     Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
                                                     Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
                                                     Module libXinerama.so.1 with build-id 8198240259261b612189e89c9fcfc902b025b382
                                                     Module libXrandr.so.2 with build-id 154e55f082ee9e685d0794c98c5b76ffe9c8868e
                                                     Module libXcomposite.so.1 with build-id 13228d108b290268d88510db494daefd5521cda0
                                                     Module libXdamage.so.1 with build-id a99dbe3fc2b01da9fbdd90d5ad00621f9022379f
                                                     Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
                                                     Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
                                                     Module libwayland-egl.so.1 with build-id dd02a2af320297e68308cc698f75828529271a57
                                                     Module libwayland-cursor.so.0 with build-id 46a637dbcbb02d6712a201f177377b66598b9121
                                                     Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
                                                     Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
                                                     Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
                                                     Module libtracker-sparql-3.0.so.0 with build-id 75ab4f2e3b5c479b5c4fc62793bf398ee28f4ab7
                                                     Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
                                                     Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
                                                     Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
                                                     Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
                                                     Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
                                                     Module libatk-1.0.so.0 with build-id c2de8b4fcbd9681cef225fe3956a9608a2a664bb
                                                     Module libgdk_pixbuf-2.0.so.0 with build-id b2822dc16bd1470683ce421978ad142c4f3c3f89
                                                     Module libcairo-gobject.so.2 with build-id 9927090dddfb180365695a8f37d1cac89463f109
                                                     Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
                                                     Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
                                                     Module libpangoft2-1.0.so.0 with build-id 4a5a975bc9e397294c88738430515901a51c304c
                                                     Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
                                                     Module libharfbuzz.so.0 with build-id 236ab65053439e673a39fcb7aadedb28b17a338a
                                                     Module libpango-1.0.so.0 with build-id a971a5fed3b8b9cf076fe5edb9a9f04ced3da211
                                                     Module libpangocairo-1.0.so.0 with build-id 37f75358f8778498bcc26a1658107953d9495255
                                                     Module libgio-2.0.so.0 with build-id 7a769ec24a9a705d04ee0297730032f70ed0835b
                                                     Module libgobject-2.0.so.0 with build-id a7515bd8cd51064d187953c0f506a43958de31a6
                                                     Module libglib-2.0.so.0 with build-id 1340f3a762b2293ebf6d725edf0eb14839f85317
                                                     Module libgmodule-2.0.so.0 with build-id abd986222e2cf12fc7324cb0182dfc2c8f2269c0
                                                     Module libgdk-3.so.0 with build-id 4a9a6d5ddd18f22c56c05773208f8808cefacab6
                                                     Module libgtk-3.so.0 with build-id 48baf44dfd4d51f8c2b81d852eb44de692c16b19
                                                     Module libmozgtk.so with build-id 8027a58caeba8263184a5eed62b27555d21c7736
                                                     Module libmozsqlite3.so with build-id 8d0f4ebe7c073f9b72bab3afb37b00c4b7a15652
                                                     Module liblgpllibs.so with build-id 33615eeab36653f9841f2828e10c6aebbc2463fb
                                                     Module libnspr4.so with build-id 64bc745fdf99e414eeda94b9345af6fa6fcce329
                                                     Module libmozsandbox.so with build-id 3c9db5fb3562abc2e78e76bf80291ded455f1f38
                                                     Module ld-linux-x86-64.so.2 with build-id 5492655bffbf172ed8a07f285f760ead38f09404
                                                     Module libc.so.6 with build-id 7d4293a9bbe1f068ab7ae807c2d9377395eb5b41
                                                     Module libgcc_s.so.1 with build-id 308aed8b7d7e38f5efa23f75c25601668c1fc009
                                                     Module libm.so.6 with build-id efeea58692a42176201df89f034aa4295a77ce74
                                                     Module libstdc++.so.6 with build-id e0dd3ec5b0a62b122b4141c956c0b33a4d719144
                                                     Module firefox with build-id 2b8aea238365eb224accff3ca8a61933202c6214
                                                     Stack trace of thread 1308:
                                                     #0  0x00007f78ce01c814 XDisplayString (libX11.so.6 + 0x2b814)
                                                     #1  0x00007f78c1368a1d __vaDriverInit_1_13 (nvidia_drv_video.so + 0xda1d)
                                                     #2  0x00007f78c1006c8a n/a (libva.so.2 + 0x3c8a)
                                                     #3  0x00007f78c100cbe1 vaInitialize (libva.so.2 + 0x9be1)
                                                     #4  0x00007f78c98a4117 n/a (libxul.so + 0x8533117)
                                                     #5  0x00007f78c98a4d29 n/a (libxul.so + 0x8533d29)
                                                     #6  0x00007f78c5874b4e n/a (libxul.so + 0x4503b4e)
                                                     #7  0x00007f78c5872955 n/a (libxul.so + 0x4501955)
                                                     #8  0x00007f78c5865be5 n/a (libxul.so + 0x44f4be5)
                                                     #9  0x00007f78c5864ead n/a (libxul.so + 0x44f3ead)
                                                     #10 0x000055609800a972 n/a (firefox + 0x55972)
                                                     #11 0x00007f78cfe1e2d0 n/a (libc.so.6 + 0x232d0)
                                                     #12 0x00007f78cfe1e38a __libc_start_main (libc.so.6 + 0x2338a)
                                                     #13 0x000055609801a0a5 _start (firefox + 0x650a5)
Aug 30 23:30:23 man-jon-desk kernel: audit: type=1131 audit(1661895023.950:77): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-1309-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:30:24 man-jon-desk kernel: audit: type=1334 audit(1661895024.043:78): prog-id=0 op=UNLOAD
Aug 30 23:30:24 man-jon-desk kernel: audit: type=1334 audit(1661895024.043:79): prog-id=0 op=UNLOAD
Aug 30 23:30:24 man-jon-desk kernel: audit: type=1334 audit(1661895024.043:80): prog-id=0 op=UNLOAD
Aug 30 23:30:28 man-jon-desk kernel: usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
Aug 30 23:30:33 man-jon-desk kernel: usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
Aug 30 23:30:38 man-jon-desk kernel: usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
Aug 30 23:30:43 man-jon-desk kernel: usb 1-2.2: 2:0: cannot get min/max values for control 2 (id 2)
Aug 30 23:31:04 man-jon-desk kernel: usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
Aug 30 23:31:09 man-jon-desk kernel: usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
Aug 30 23:31:14 man-jon-desk kernel: usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
Aug 30 23:31:19 man-jon-desk kernel: usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
Aug 30 23:31:24 man-jon-desk kernel: usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
Aug 30 23:31:25 man-jon-desk kernel: audit: type=1111 audit(1661895085.700:81): pid=632 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-delete uuid=cbb8e505-d59f-47f5-bbc3-c6722127217b name=50726F746F6E2056504E20444523313134 pid=1911 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Aug 30 23:31:25 man-jon-desk kernel: audit: type=1111 audit(1661895085.740:82): pid=632 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-add uuid=42f12c80-9d38-47ef-b57c-d0fb2513ae3e name="pvpn-ipv6leak-protection" pid=1955 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Aug 30 23:31:25 man-jon-desk kernel: audit: type=1130 audit(1661895085.753:83): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:31:25 man-jon-desk kernel: audit: type=1111 audit(1661895085.783:84): pid=632 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-add uuid=b6576769-9865-4f96-a6c7-5509358baa6f name="pvpn-routed-killswitch" pid=1967 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Aug 30 23:31:25 man-jon-desk kernel: audit: type=1111 audit(1661895085.817:85): pid=632 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-deactivate uuid=1ac9367e-4edc-42b1-acab-052db243ade0 name="pvpn-killswitch" pid=1911 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Aug 30 23:31:25 man-jon-desk kernel: audit: type=1111 audit(1661895085.837:86): pid=632 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-add uuid=c0607e30-6441-4a3f-b02b-61a3ab7fc9e9 name=50726F746F6E2056504E20444523313233 pid=1911 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Aug 30 23:31:25 man-jon-desk kernel: audit: type=1111 audit(1661895085.880:87): pid=632 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-activate uuid=c0607e30-6441-4a3f-b02b-61a3ab7fc9e9 name=50726F746F6E2056504E20444523313233 pid=1911 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Aug 30 23:31:25 man-jon-desk nm-openvpn[1983]: DEPRECATED OPTION: --cipher set to 'AES-256-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-256-CBC' to --data-ciphers or change --cipher 'AES-256-CBC' to --data-ciphers-fallback 'AES-256-CBC' to silence this warning.
Aug 30 23:31:25 man-jon-desk nm-openvpn[1983]: OpenVPN 2.5.7 [git:makepkg/a0f9a3e9404c8321+] x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on May 31 2022
Aug 30 23:31:25 man-jon-desk nm-openvpn[1983]: library versions: OpenSSL 1.1.1q  5 Jul 2022, LZO 2.10
Aug 30 23:31:26 man-jon-desk nm-openvpn[1983]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Aug 30 23:31:26 man-jon-desk nm-openvpn[1983]: TCP/UDP: Preserving recently used remote address: [AF_INET]194.126.177.14:80
Aug 30 23:31:26 man-jon-desk nm-openvpn[1983]: UDP link local: (not bound)
Aug 30 23:31:26 man-jon-desk nm-openvpn[1983]: UDP link remote: [AF_INET]194.126.177.14:80
Aug 30 23:31:26 man-jon-desk nm-openvpn[1983]: NOTE: UID/GID downgrade will be delayed because of --client, --pull, or --up-delay
Aug 30 23:31:26 man-jon-desk nm-openvpn[1983]: WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1602', remote='link-mtu 1634'
Aug 30 23:31:26 man-jon-desk nm-openvpn[1983]: WARNING: 'tun-mtu' is used inconsistently, local='tun-mtu 1500', remote='tun-mtu 1532'
Aug 30 23:31:26 man-jon-desk nm-openvpn[1983]: [node-de-17.protonvpn.net] Peer Connection Initiated with [AF_INET]194.126.177.14:80
Aug 30 23:31:27 man-jon-desk nm-openvpn[1983]: NOTE: setsockopt TCP_NODELAY=1 failed
Aug 30 23:31:27 man-jon-desk nm-openvpn[1983]: TUN/TAP device proton0 opened
Aug 30 23:31:27 man-jon-desk nm-openvpn[1983]: /usr/lib/nm-openvpn-service-openvpn-helper --debug 0 1977 --bus-name org.freedesktop.NetworkManager.openvpn.Connection_5 --tun -- proton0 1500 1553 10.22.0.2 255.255.0.0 init
Aug 30 23:31:27 man-jon-desk nm-openvpn[1983]: GID set to nm-openvpn
Aug 30 23:31:27 man-jon-desk nm-openvpn[1983]: UID set to nm-openvpn
Aug 30 23:31:27 man-jon-desk nm-openvpn[1983]: Initialization Sequence Completed
Aug 30 23:31:27 man-jon-desk kernel: audit: type=1111 audit(1661895087.313:88): pid=632 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-activate uuid=1ac9367e-4edc-42b1-acab-052db243ade0 name="pvpn-killswitch" pid=1911 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Aug 30 23:31:27 man-jon-desk kernel: audit: type=1111 audit(1661895087.350:89): pid=632 uid=0 auid=4294967295 ses=4294967295 msg='op=connection-delete uuid=b6576769-9865-4f96-a6c7-5509358baa6f name="pvpn-routed-killswitch" pid=1993 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Aug 30 23:31:29 man-jon-desk kernel: usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
Aug 30 23:31:34 man-jon-desk kernel: usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
Aug 30 23:31:35 man-jon-desk kernel: audit: type=1131 audit(1661895095.767:90): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 30 23:31:39 man-jon-desk kernel: usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
Aug 30 23:31:45 man-jon-desk kernel: usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
Aug 30 23:31:50 man-jon-desk kernel: usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
Aug 30 23:31:52 man-jon-desk kernel: process '@/opt/teamspeak3/ts3client_linux_amd64' started with executable stack
Aug 30 23:31:55 man-jon-desk kernel: usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
Aug 30 23:32:00 man-jon-desk kernel: usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
Aug 30 23:32:05 man-jon-desk kernel: usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
Aug 30 23:32:10 man-jon-desk kernel: usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
Aug 30 23:32:11 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Aug 30 23:32:11 man-jon-desk kernel: usb 1-2.2: 2:1: cannot set freq 44100 to ep 0x3
Aug 30 23:32:11 man-jon-desk kernel: usb 1-2.2: 2:0: usb_set_interface failed (-32)
Aug 30 23:32:11 man-jon-desk kernel: usb 1-2.2: 2:1: usb_set_interface failed (-32)
Aug 30 23:32:12 man-jon-desk kernel: usb 1-2.2: 2:1: usb_set_interface failed (-19)
Aug 30 23:32:12 man-jon-desk kernel: usb 1-2.2: 2:0: usb_set_interface failed (-19)
Aug 30 23:32:12 man-jon-desk wireplumber[1062]: can't open control for card hw:2: Datei oder Verzeichnis nicht gefunden
Aug 30 23:32:13 man-jon-desk kernel: usb 1-2.2: 2:1: cannot set freq 48000 to ep 0x3
Aug 30 23:32:35 man-jon-desk sudo[2460]: filteredusername : TTY=pts/2 ; PWD=/home/filteredusername ; USER=root ; COMMAND=/usr/bin/dmesg -l -l err,warn,emerg,alert
Aug 30 23:32:35 man-jon-desk kernel: audit: type=1100 audit(1661895155.690:91): pid=2460 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="filteredusername" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 30 23:32:35 man-jon-desk kernel: audit: type=1101 audit(1661895155.690:92): pid=2460 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="filteredusername" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 30 23:32:35 man-jon-desk kernel: audit: type=1110 audit(1661895155.690:93): pid=2460 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 30 23:32:35 man-jon-desk kernel: audit: type=1105 audit(1661895155.690:94): pid=2460 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 30 23:32:35 man-jon-desk kernel: audit: type=1106 audit(1661895155.693:95): pid=2460 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 30 23:32:35 man-jon-desk kernel: audit: type=1104 audit(1661895155.693:96): pid=2460 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 30 23:32:40 man-jon-desk kernel: audit: type=1101 audit(1661895160.710:97): pid=2468 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="filteredusername" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 30 23:32:40 man-jon-desk kernel: audit: type=1110 audit(1661895160.710:98): pid=2468 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 30 23:32:40 man-jon-desk kernel: audit: type=1105 audit(1661895160.710:99): pid=2468 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 30 23:32:40 man-jon-desk sudo[2468]: filteredusername : TTY=pts/2 ; PWD=/home/filteredusername ; USER=root ; COMMAND=/usr/bin/dmesg -l err,warn,emerg,alert
Aug 30 23:32:40 man-jon-desk kernel: audit: type=1106 audit(1661895160.713:100): pid=2468 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 30 23:32:40 man-jon-desk kernel: audit: type=1104 audit(1661895160.713:101): pid=2468 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 30 23:33:37 man-jon-desk sudo[2516]: filteredusername : TTY=pts/2 ; PWD=/home/filteredusername ; USER=root ; COMMAND=/usr/bin/dmesg -l err,warn,emerg,alert
Aug 30 23:33:37 man-jon-desk kernel: audit: type=1101 audit(1661895217.420:102): pid=2516 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="filteredusername" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 30 23:33:37 man-jon-desk kernel: audit: type=1110 audit(1661895217.420:103): pid=2516 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 30 23:33:37 man-jon-desk kernel: audit: type=1105 audit(1661895217.420:104): pid=2516 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 30 23:33:37 man-jon-desk kernel: audit: type=1106 audit(1661895217.420:105): pid=2516 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Aug 30 23:33:37 man-jon-desk kernel: audit: type=1104 audit(1661895217.420:106): pid=2516 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
Just a little side note:
Yes Windows and Linux handle power consumption differently. Instand crashing the whole OS, Linux tries always to crash only the correspondent application/library. Without going to into a lot of details: The assumption is right that if the nvidia card reach peak and the PSU cannot deliver the power, Linux will not crash, but rather discard it, what lead the application to crash.
Maybe you can set coolbits and set a strict limit to the card.
Here is a tool:
pamac build gwe
Or a flatpak install in your home folder:
flatpak --user remote-add --if-not-exists flathub https://flathub.org/repo/flathub.flatpakrepo
flatpak --user install flathub com.leinardi.gwe
flatpak run com.leinardi.gwe
Normally it should create a desktop icon automatically.
That could be a factor - a little swap is better than none at all - but since you are using btrfs - remember to take it into consideration when creating a swap file
the firefox crashing is a known bug:
removing the driver/s should help you with that
also you are running on the 5.19 kernel, switch to 5.15 and test with it
and in the logs/dmesg theres really nothing
Yeah, I thought so too. I wasn’t sure about the coredump, because I still do not fully understand what these are for, but I get the impression that they’re some kind of stacktrace like you get from Java for example.
That was a thought I had as well, but I reproduced the error with swap as well(not on this installation but on Monday). I will inevitably add swap, because I like hibernation.
That is a nice idea, I did not know there was a nice tool like that. I’ll read myself in in any case and probably do that, do you know if the tool defines those settings on the hardware itself, or if it’s on the driver level instead(i.e. will it effect Windows), because in that case I would be willing to possibly wait a few days for the new PSU, so that I don’t have to revert the settings then.
Interesting so hardware acceleration is already provided by nvidia-utils, which comes with the nvidia driver as well.
But libva is installed regardless of which driver is installed for the gpu.
Since libva is installed automatically even if nvidia drivers are used, do you think that would be worth mentioning somewhere and should be changed?
You have a lot of these lines. You should try to figure out if you have a USB device causing this (maybe a sound card?). You should also limit your systemd journal size so it doesn’t fill your hard drive.
Additionally I get the feeling that firefox is just kind of expanding its bug onto the responisveness of other programs in use at the same time. I will try and test that.
Oh yeah, sorry. I even know which one. It should be the soundbar from Teufel. It’s listed under device 3 in inxi. Apparently it only accepts samplerates of 48000Hz and there might be additional issues(i.e. the usb_set_interface failed one for example). I will probably open a new thread for that soon, but I wanted to focus on the freezes first. If you think they might be related, then by all means, please inform me so. Just for testing I will reboot with it plugged out to see if that changes anything.
Journal size
I did not know I could do that, probably a good idea, thx. I will see about doing that.
I was about to reply that the issue persists, but I noticed that I have many many libva packages installed. Will take care of them now, but will also put it in here:
Installed libva packages
libva-vdpau-driver lib32-libva-vdpau-driver
lib32-libva-mesa-driver
lib32-libva-intel-driver
lib32-libva
libva-mesa-driver
libva-intel-driver
libva
pamac info libva
Version                   : 2.15.0-1
Beschreibung              : Video Acceleration (VA) API for Linux
URL                       : https://01.org/linuxmedia/vaapi
Lizenzen                  : MIT
Paketquelle               : extra
Installierte Größe        : 917,5 kB
Gruppen                   : --
Hängt ab von              : libdrm libgl libx11 libxext libxfixes wayland
Optionale Abhängigkeiten  : intel-media-driver: backend for Intel GPUs (>= Broadwell) [Installiert]
                            libva-vdpau-driver: backend for Nvidia and AMD GPUs
                            libva-intel-driver: backend for Intel GPUs (<= Haswell) [Installiert]
Benötigt von              : avidemux-cli chromium ffmpeg ffmpeg4.4 handbrake intel-media-driver intel-media-sdk lib32-libva libva-intel-driver mpv
Optional fĂĽr              : --
Stellt bereit             : libva-drm.so=2-64 libva-glx.so=2-64 libva-wayland.so=2-64 libva-x11.so=2-64 libva.so=2-64
Ersetzt                   : --
Konflikt mit              : --
Packer                    : Maxime Gauduin <alucryd@archlinux.org>
Erstelldatum              : Do 30 Jun 2022 17:14:30 CEST
Installiert am            : Di 16 Aug 2022 14:19:15 CEST
Installationsgrund        : Installiert als Abhängigkeit für ein anderes Paket
Validiert von             : Signature
Dateisicherungen          : /etc/libva.conf
Could remove only lib32-libva-mesa-driver libva-mesa-driver without removing other packages.
It says libva depends on wayland, so should I only use it with Wayland possibly? Or is there perhaps another package that provides libva, that I should use instead. Alternatively I could try and switch to Wayland altogether. Just haven’t done it before, but I could try.
according to the link you should remove only these 2:
dont know if removing the mesa drivers was a good idea…
also you are on kde + nvidia, so using wayland is a no no, you would be probably not even enter the desktop and if you would it would be really messy …
did you disconnected the usb and testet without it?
On Wayland: Yeah, I thought I had read something along those lines.
On mesa: I can reinstall them, no problem(and did so now). I thought I should because removing just
did not solve the issue with firefox.
Whoops, did not do the usb thing yet. Be back in a moment!
I disconnected and rebooted. The lines in the journal are indeed gone, but that did not solve the firefox issue
Aside: I am responding from chromium as my fallback browser today.
so we know its not related to the usb errors …
does the freezes happens only in firefox?
Ah sorry.
It does not affect chromium at least. But mpc-qt is still very slow and takes forever to start.
I’ll try it without firefox running in a moment and then edit this post.
Edit
Had to reboot since I couldn’t even kill firefox with Ksysguard(may try htop next time).
MPC-QT did not manage to start playing video in over 3 minutes, so yes the problem persists in other applications. But it’s just the video. The interface itself responds and can close mpc.
