I have no idea, I can switch back to Gnome, if you think that we can solve that more easily.
Just now I did not have any audio on KDE either, even though I already installed wireplumber and pipewire. After around 8 minutes I suddenly had audio
so you already installed kde? and so far no freezes? disable the indexer from system settings and test with vlc/firefox for freezes after you disabled it, and also open ksystemguard and monitor the process table
Thanks, a good idea. I disabled it and will test now. Note: Firefox is not synced yet and in “retail” settings
I have to report: I have freezes sometimes in Firefox, sometimes in Plasma itself, when I try to change volume for example
I saw absolutely nothing on ksysguard. Not on CPU, nor RAM nor Disk IO
did gnome when you just installed it worked normally - except the audio issue - without freezes?
how is the nvidia connected? via cable or directly plugged into motherboard?
Apart from audio gnome worked fine, though I did not test it extensively after the install, because of the audio.
The card is plugged directly into the motherboard
have not idea what it could be… lets add some parameters to the kernel, so open this:
kate /etc/default/grub
and in this line: GRUB_CMDLINE_LINUX_DEFAULT
inside the quotes add these 2 parameters:
idle=nomwait processor.max_cstate=1
dont remove anything from there, just add it to the existing parameters, then save the file and update grub:
sudo update-grub
reboot and test
Audio was there from the beginning but firefox froze again
and post again dmesg:
sudo dmesg -l err,warn,emerg,alert,crit
dmesg
[ 0.140125] #9 #10 #11 #12 #13 #14 #15
[ 0.239187] efifb: Ignoring BGRT: unexpected or invalid BMP data
[ 0.244548] nvme nvme1: missing or invalid SUBNQN field.
[ 0.719197] ata1.00: supports DRM functions and may not be fully accessible
[ 0.721780] ata1.00: supports DRM functions and may not be fully accessible
[ 1.193931] ata2.00: supports DRM functions and may not be fully accessible
[ 1.197161] ata2.00: supports DRM functions and may not be fully accessible
[ 3.173588] ata6: failed to resume link (SControl 0)
[ 4.881297] sd 6:0:0:0: [sdc] No Caching mode page found
[ 4.881298] sd 6:0:0:0: [sdc] Assuming drive cache: write through
[ 5.015095] sd 7:0:0:0: [sdd] No Caching mode page found
[ 5.015097] sd 7:0:0:0: [sdd] Assuming drive cache: write through
[ 5.733103] sd 8:0:0:0: [sde] No Caching mode page found
[ 5.733105] sd 8:0:0:0: [sde] Assuming drive cache: write through
[ 8.413501] nvidia: loading out-of-tree module taints kernel.
[ 8.413508] nvidia: module license 'NVIDIA' taints kernel.
[ 8.413509] Disabling lock debugging due to kernel taint
[ 8.537422] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.65.01 Wed Jul 20 14:00:58 UTC 2022
[ 9.153588] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 11.034454] usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
[ 16.042460] kauditd_printk_skb: 46 callbacks suppressed
[ 16.241022] usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
[ 21.360970] usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
[ 26.481006] usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
[ 27.257792] kauditd_printk_skb: 14 callbacks suppressed
[ 31.600839] usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
[ 46.960993] usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
[ 52.081059] usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
[ 62.961176] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 68.080845] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 73.200783] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 78.320407] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 83.441200] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 88.560613] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 93.680801] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 98.800964] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 103.921133] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 109.041030] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 114.160952] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 119.280812] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 124.400969] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 125.432930] debugfs: Directory 'card3' with parent 'sound' already present!
[ 129.520923] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 132.766169] debugfs: Directory 'card3' with parent 'sound' already present!
[ 134.641052] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 139.760747] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 144.880620] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 150.000692] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 155.120478] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 157.253562] Bluetooth: hci0: command 0x0c52 tx timeout
[ 160.240552] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 165.360756] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 170.480987] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 175.600827] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 180.720832] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 185.841138] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 190.960800] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 196.080824] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 201.200972] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 206.320828] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 211.440798] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 216.560945] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 221.680772] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 226.800852] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 227.429206] debugfs: Directory 'card3' with parent 'sound' already present!
[ 231.549592] debugfs: Directory 'card3' with parent 'sound' already present!
[ 231.920894] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 237.040820] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 242.160533] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
[ 247.280545] usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
and journal if it helps
journal
Sep 01 15:59:04 man-jon-desk kernel: Linux version 5.15.60-1-MANJARO (builduser@fv-az462-678) (gcc (GCC) 12.1.1 20220730, GNU ld (GNU Binutils) 2.39) #1 SMP PREEMPT Thu Aug 11 13:14:05 UTC 2022
Sep 01 15:59:04 man-jon-desk kernel: Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64 root=UUID=428dcc39-14a9-4e2c-ba7b-e8482d468f93 rw rootflags=subvol=@ quiet cryptdevice=UUID=7cecd1d3-bc54-4e89-92ad-a80f4b151998:luks-7cecd1d3-bc54-4e89-92ad-a80f4b151998 root=/dev/mapper/luks-7cecd1d3-bc54-4e89-92ad-a80f4b151998 udev.log_priority=3
Sep 01 15:59:04 man-jon-desk kernel: Unknown kernel command line parameters "BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64 cryptdevice=UUID=7cecd1d3-bc54-4e89-92ad-a80f4b151998:luks-7cecd1d3-bc54-4e89-92ad-a80f4b151998", will be passed to user space.
Sep 01 15:59:04 man-jon-desk kernel: #9 #10 #11 #12 #13 #14 #15
Sep 01 15:59:04 man-jon-desk kernel: audit: type=2000 audit(1662040736.183:1): state=initialized audit_enabled=0 res=1
Sep 01 15:59:04 man-jon-desk kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Sep 01 15:59:04 man-jon-desk kernel: SCSI subsystem initialized
Sep 01 15:59:04 man-jon-desk kernel: VFS: Disk quotas dquot_6.6.0
Sep 01 15:59:04 man-jon-desk kernel: Initialise system trusted keyrings
Sep 01 15:59:04 man-jon-desk kernel: Key type blacklist registered
Sep 01 15:59:04 man-jon-desk kernel: Key type asymmetric registered
Sep 01 15:59:04 man-jon-desk kernel: Asymmetric key parser 'x509' registered
Sep 01 15:59:04 man-jon-desk kernel: efifb: Ignoring BGRT: unexpected or invalid BMP data
Sep 01 15:59:04 man-jon-desk kernel: nvme nvme1: missing or invalid SUBNQN field.
Sep 01 15:59:04 man-jon-desk kernel: Loading compiled-in X.509 certificates
Sep 01 15:59:04 man-jon-desk kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 6fb82619edb0db410569d5b8f8e43f2d52acc95c'
Sep 01 15:59:04 man-jon-desk kernel: Key type ._fscrypt registered
Sep 01 15:59:04 man-jon-desk kernel: Key type .fscrypt registered
Sep 01 15:59:04 man-jon-desk kernel: Key type fscrypt-provisioning registered
Sep 01 15:59:04 man-jon-desk kernel: ata1.00: supports DRM functions and may not be fully accessible
Sep 01 15:59:04 man-jon-desk kernel: scsi 0:0:0:0: Direct-Access ATA Samsung SSD 870 1B6Q PQ: 0 ANSI: 5
Sep 01 15:59:04 man-jon-desk kernel: sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
Sep 01 15:59:04 man-jon-desk kernel: sd 0:0:0:0: [sda] Write Protect is off
Sep 01 15:59:04 man-jon-desk kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Sep 01 15:59:04 man-jon-desk kernel: sd 0:0:0:0: [sda] supports TCG Opal
Sep 01 15:59:04 man-jon-desk kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Sep 01 15:59:04 man-jon-desk kernel: ata2.00: supports DRM functions and may not be fully accessible
Sep 01 15:59:04 man-jon-desk kernel: scsi 1:0:0:0: Direct-Access ATA Samsung SSD 870 2B6Q PQ: 0 ANSI: 5
Sep 01 15:59:04 man-jon-desk kernel: sd 1:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
Sep 01 15:59:04 man-jon-desk kernel: sd 1:0:0:0: [sdb] Write Protect is off
Sep 01 15:59:04 man-jon-desk kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Sep 01 15:59:04 man-jon-desk kernel: sd 1:0:0:0: [sdb] supports TCG Opal
Sep 01 15:59:04 man-jon-desk kernel: sd 1:0:0:0: [sdb] Attached SCSI disk
Sep 01 15:59:04 man-jon-desk kernel: ata6: failed to resume link (SControl 0)
Sep 01 15:59:04 man-jon-desk kernel: ccp 0000:0c:00.1: ccp: unable to access the device: you might be running a broken BIOS.
Sep 01 15:59:04 man-jon-desk kernel: Key type encrypted registered
Sep 01 15:59:04 man-jon-desk kernel: scsi 6:0:0:0: Direct-Access WD Elements 2621 1026 PQ: 0 ANSI: 6
Sep 01 15:59:04 man-jon-desk kernel: sd 6:0:0:0: [sdc] 3906963456 512-byte logical blocks: (2.00 TB/1.82 TiB)
Sep 01 15:59:04 man-jon-desk kernel: sd 6:0:0:0: [sdc] Write Protect is off
Sep 01 15:59:04 man-jon-desk kernel: sd 6:0:0:0: [sdc] No Caching mode page found
Sep 01 15:59:04 man-jon-desk kernel: sd 6:0:0:0: [sdc] Assuming drive cache: write through
Sep 01 15:59:04 man-jon-desk kernel: sd 6:0:0:0: [sdc] Attached SCSI disk
Sep 01 15:59:04 man-jon-desk kernel: scsi 7:0:0:0: Direct-Access WD Elements 2620 1018 PQ: 0 ANSI: 6
Sep 01 15:59:04 man-jon-desk kernel: sd 7:0:0:0: [sdd] Very big device. Trying to use READ CAPACITY(16).
Sep 01 15:59:04 man-jon-desk kernel: sd 7:0:0:0: [sdd] 7813969920 512-byte logical blocks: (4.00 TB/3.64 TiB)
Sep 01 15:59:04 man-jon-desk kernel: sd 7:0:0:0: [sdd] 4096-byte physical blocks
Sep 01 15:59:04 man-jon-desk kernel: sd 7:0:0:0: [sdd] Write Protect is off
Sep 01 15:59:04 man-jon-desk kernel: sd 7:0:0:0: [sdd] No Caching mode page found
Sep 01 15:59:04 man-jon-desk kernel: sd 7:0:0:0: [sdd] Assuming drive cache: write through
Sep 01 15:59:04 man-jon-desk kernel: sd 7:0:0:0: [sdd] Attached SCSI disk
Sep 01 15:59:04 man-jon-desk kernel: scsi 8:0:0:0: Direct-Access PQ: 0 ANSI: 4
Sep 01 15:59:04 man-jon-desk kernel: sd 8:0:0:0: [sde] 123699200 512-byte logical blocks: (63.3 GB/59.0 GiB)
Sep 01 15:59:04 man-jon-desk kernel: sd 8:0:0:0: [sde] Write Protect is off
Sep 01 15:59:04 man-jon-desk kernel: sd 8:0:0:0: [sde] No Caching mode page found
Sep 01 15:59:04 man-jon-desk kernel: sd 8:0:0:0: [sde] Assuming drive cache: write through
Sep 01 15:59:04 man-jon-desk kernel: sd 8:0:0:0: [sde] Attached SCSI removable disk
Sep 01 15:59:04 man-jon-desk kernel: random: cryptsetup: uninitialized urandom read (2 bytes read)
Sep 01 15:59:04 man-jon-desk kernel: random: lvm: uninitialized urandom read (4 bytes read)
Sep 01 15:59:04 man-jon-desk kernel: audit: type=1130 audit(1662040744.195:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:04 man-jon-desk systemd-random-seed[460]: Kernel entropy pool is not initialized yet, waiting until it is.
Sep 01 15:59:04 man-jon-desk kernel: audit: type=1130 audit(1662040744.198:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:04 man-jon-desk kernel: audit: type=1130 audit(1662040744.222:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:04 man-jon-desk kernel: audit: type=1130 audit(1662040744.245:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:04 man-jon-desk kernel: audit: type=1130 audit(1662040744.325:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-cryptsetup@luks\x2d7cecd1d3\x2dbc54\x2d4e89\x2d92ad\x2da80f4b151998 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:04 man-jon-desk kernel: audit: type=1130 audit(1662040744.358:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-894A\x2dD812 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:04 man-jon-desk kernel: random: crng init done
Sep 01 15:59:04 man-jon-desk kernel: audit: type=1130 audit(1662040744.605:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:04 man-jon-desk kernel: nvidia: loading out-of-tree module taints kernel.
Sep 01 15:59:04 man-jon-desk kernel: nvidia: module license 'NVIDIA' taints kernel.
Sep 01 15:59:04 man-jon-desk kernel: Disabling lock debugging due to kernel taint
Sep 01 15:59:04 man-jon-desk kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Sep 01 15:59:04 man-jon-desk kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.65.01 Wed Jul 20 14:00:58 UTC 2022
Sep 01 15:59:05 man-jon-desk kernel: audit: type=1130 audit(1662040745.202:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:05 man-jon-desk kernel: audit: type=1130 audit(1662040745.218:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:05 man-jon-desk kernel: audit: type=1127 audit(1662040745.218:11): pid=628 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:05 man-jon-desk kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Sep 01 15:59:05 man-jon-desk polkitd[644]: Loading rules from directory /etc/polkit-1/rules.d
Sep 01 15:59:05 man-jon-desk polkitd[644]: Loading rules from directory /usr/share/polkit-1/rules.d
Sep 01 15:59:05 man-jon-desk polkitd[644]: Finished loading, compiling and executing 7 rules
Sep 01 15:59:05 man-jon-desk polkitd[644]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Sep 01 15:59:07 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 15:59:07 man-jon-desk systemd[709]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Sep 01 15:59:07 man-jon-desk systemd[732]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Sep 01 15:59:07 man-jon-desk systemd[732]: xdg-user-dirs-update.service: Main process exited, code=exited, status=1/FAILURE
Sep 01 15:59:07 man-jon-desk systemd[732]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Sep 01 15:59:07 man-jon-desk systemd[732]: Failed to start Update XDG user dir configuration.
Sep 01 15:59:08 man-jon-desk udisksd[748]: udisks daemon version 2.9.4 starting
Sep 01 15:59:08 man-jon-desk udisksd[748]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Sep 01 15:59:12 man-jon-desk kernel: kauditd_printk_skb: 46 callbacks suppressed
Sep 01 15:59:12 man-jon-desk kernel: audit: type=1131 audit(1662040752.328:52): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:12 man-jon-desk kernel: usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
Sep 01 15:59:13 man-jon-desk kernel: audit: type=1100 audit(1662040753.852:53): pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="filteredusername" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:13 man-jon-desk kernel: audit: type=1101 audit(1662040753.852:54): pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="filteredusername" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:13 man-jon-desk kernel: audit: type=1103 audit(1662040753.852:55): pid=769 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="filteredusername" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:13 man-jon-desk kernel: audit: type=1006 audit(1662040753.852:56): pid=769 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
Sep 01 15:59:13 man-jon-desk kernel: audit: type=1300 audit(1662040753.852:56): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffc8e59aec0 a2=4 a3=7ffc8e59abd4 items=0 ppid=683 pid=769 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" key=(null)
Sep 01 15:59:13 man-jon-desk kernel: audit: type=1327 audit(1662040753.852:56): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746836616465363039632D336536332D346562352D396232372D366133336133396439393639002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
Sep 01 15:59:13 man-jon-desk kernel: audit: type=1130 audit(1662040753.858:57): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:13 man-jon-desk systemd[771]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[filteredusername] ruser=[<unknown>] rhost=[<unknown>]
Sep 01 15:59:13 man-jon-desk kernel: audit: type=1101 audit(1662040753.862:58): pid=771 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="filteredusername" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:13 man-jon-desk kernel: audit: type=1103 audit(1662040753.862:59): pid=771 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="filteredusername" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Sep 01 15:59:15 man-jon-desk polkitd[644]: Registered Authentication Agent for unix-session:2 (system bus name :1.34 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale de_DE.UTF-8)
Sep 01 15:59:15 man-jon-desk backlighthelper[964]: org.kde.powerdevil: no kernel backlight interface found
Sep 01 15:59:15 man-jon-desk wireplumber[1047]: Failed to set scheduler settings: Die Operation ist nicht erlaubt
Sep 01 15:59:15 man-jon-desk wireplumber[1047]: reserve-device plugin is not connected to D-Bus, disabling device reservation
Sep 01 15:59:15 man-jon-desk wireplumber[1047]: SPA handle 'api.libcamera.enum.manager' could not be loaded; is it installed?
Sep 01 15:59:15 man-jon-desk wireplumber[1047]: PipeWire's libcamera SPA missing or broken. libcamera not supported.
Sep 01 15:59:17 man-jon-desk kernel: usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
Sep 01 15:59:22 man-jon-desk kernel: usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
Sep 01 15:59:24 man-jon-desk systemd[733]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Sep 01 15:59:24 man-jon-desk kernel: kauditd_printk_skb: 14 callbacks suppressed
Sep 01 15:59:24 man-jon-desk kernel: audit: type=1131 audit(1662040764.225:70): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@964 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:24 man-jon-desk kernel: audit: type=1131 audit(1662040764.228:71): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@964 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:27 man-jon-desk kernel: usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
Sep 01 15:59:37 man-jon-desk kernel: audit: type=1131 audit(1662040777.372:72): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 15:59:37 man-jon-desk kernel: audit: type=1334 audit(1662040777.482:73): prog-id=0 op=UNLOAD
Sep 01 15:59:37 man-jon-desk kernel: audit: type=1334 audit(1662040777.482:74): prog-id=0 op=UNLOAD
Sep 01 15:59:37 man-jon-desk kernel: audit: type=1334 audit(1662040777.482:75): prog-id=0 op=UNLOAD
Sep 01 15:59:43 man-jon-desk kernel: usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
Sep 01 15:59:45 man-jon-desk udisksd[748]: Mounted /dev/sde1 at /run/media/filteredusername/MANJARO_KDE_2137 on behalf of uid 1000
Sep 01 15:59:47 man-jon-desk kernel: Bluetooth: hci0: command 0x0c52 tx timeout
Sep 01 15:59:48 man-jon-desk kernel: usb 1-2.1: 2:0: cannot get min/max values for control 2 (id 2)
Sep 01 15:59:59 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:00:01 man-jon-desk udisksd[748]: Mounted /dev/dm-1 at /run/media/filteredusername/TTT on behalf of uid 1000
Sep 01 16:00:01 man-jon-desk udisksd[748]: Unlocked device /dev/sdd1 as /dev/dm-1
Sep 01 16:00:04 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:00:09 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:00:14 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:00:19 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:00:24 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:00:29 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:00:35 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:00:35 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:00:38 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:00:40 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:00:43 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:00:45 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:00:50 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:00:55 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:01:00 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:01:01 man-jon-desk anacron[1234]: Anacron started on 2022-09-01
Sep 01 16:01:01 man-jon-desk anacron[1234]: Will run job `cron.daily' in 33 min.
Sep 01 16:01:01 man-jon-desk anacron[1234]: Will run job `cron.weekly' in 53 min.
Sep 01 16:01:01 man-jon-desk anacron[1234]: Will run job `cron.monthly' in 73 min.
Sep 01 16:01:01 man-jon-desk anacron[1234]: Jobs will be executed sequentially
Sep 01 16:01:05 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:01:10 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:01:16 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:01:17 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:01:21 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:01:21 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:01:26 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:01:28 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:01:31 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:01:33 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:01:36 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:01:41 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:01:46 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:01:51 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:01:56 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:02:02 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:02:07 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:02:12 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:02:17 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:02:22 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:02:27 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:02:32 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:02:37 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:02:42 man-jon-desk kernel: audit: type=1701 audit(1662040962.662:76): auid=1000 uid=1000 gid=1000 ses=2 pid=1305 comm="firefox" exe="/usr/lib/firefox/firefox" sig=11 res=1
Sep 01 16:02:42 man-jon-desk kernel: audit: type=1334 audit(1662040962.665:77): prog-id=20 op=LOAD
Sep 01 16:02:42 man-jon-desk kernel: audit: type=1334 audit(1662040962.665:78): prog-id=21 op=LOAD
Sep 01 16:02:42 man-jon-desk kernel: audit: type=1334 audit(1662040962.665:79): prog-id=22 op=LOAD
Sep 01 16:02:42 man-jon-desk kernel: audit: type=1130 audit(1662040962.665:80): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-1306-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 16:02:42 man-jon-desk systemd-coredump[1307]: [🡕] Process 1305 (firefox) of user 1000 dumped core.
Module /usr/lib/firefox/libmozsandbox.so with build-id 3c9db5fb3562abc2e78e76bf80291ded455f1f38
Module linux-vdso.so.1 with build-id 15c48e8c72ad1b981d55e5c548007224f45150b1
Module libGLX.so.0 with build-id 1d664a1f03d6c5c9ac997c4b73f3e8a11424cc74
Module libGLdispatch.so.0 with build-id 9901dca23d6ccd49929b5f44c81cd671f1ec6757
Module libvdpau.so.1 with build-id fccd021ff13c37ebf7144d184a3250624e086f52
Module libGL.so.1 with build-id a3025d7d2cce51ecb2d47c076bfddefbf7e081f0
Module nvidia_drv_video.so with build-id 8976d88c463676c8a7a27a4fa06ab51a4f428200
Module libdrm.so.2 with build-id 39847bc84bc769f632f8f599a62fdcc98c9270cd
Module libva.so.2 with build-id 86d5ae6b358ba79962131649d99e42e1ba669501
Module libva-drm.so.2 with build-id 58df7fa92e899fee0c784db7a9fc68bb107156b6
Module libxcb-glx.so.0 with build-id 71d5b6691f53a235696da49ffa2178d643ecc228
Module librt.so.1 with build-id 837ea1d121976e9fa94acdf79939b387a32531db
Module libplds4.so with build-id 35c8b19ee309f8a4c2a4409568d2ab4f11a6557a
Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
Module libdbus-glib-1.so.2 with build-id 9b483ffff76251ff057e007a0b960bff84ce34a8
Module libnssutil3.so with build-id 36c34a5ab8de68047e7886fe56da7ccf6722f465
Module libnss3.so with build-id 87abb242025e6e243d6974b3a9da26166884533a
Module libsmime3.so with build-id e80b1eacbb0979a1355fd008847c6eef060e83e3
Module libssl3.so with build-id 94040772bf0029a13562ab6314237dc26ea29a60
Module libplc4.so with build-id d3b585736c213f75d6d1071f8db9a6219f1dd429
Module libasound.so.2 with build-id aefb908044b1b408df406f1a9bab9bba486c0e94
Module libxul.so with build-id 3bbdbf34b8993b86340f840ae98cccd9ed6425fc
Module libmozwayland.so with build-id d10ccd85e5bd875d6a89f6f07578976b26ea27f7
Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 1f87347b85b55db2f75a2ecea5cb45d846dc7093
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module libsystemd.so.0 with build-id f53e01cd7b3e5ff8757530ed7a65324ae12df5c8
Module liblzma.so.5 with build-id d08f5868cd5adcc6b7c53bf1725aac65bd4539cd
Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libXau.so.6 with build-id 60db1eac70f819bea9d4c366603c1583067510b4
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libblkid.so.1 with build-id fb2c5d3c17aac74758a3eb80a2bc1c16bcf183b1
Module libpthread.so.0 with build-id b966d4b239433c89ca36c0938381e2d92cd47639
Module libxml2.so.2 with build-id 8cdf00fa954d9a27f2f184c4d354cb14677446ac
Module libjson-glib-1.0.so.0 with build-id 58decebd2c409d59b07f926ae4c513281918bc4d
Module libsqlite3.so.0 with build-id e35d23d9eef4b99c931412b3a1355e333fcb10a5
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libstemmer.so.0 with build-id 013b48e71279a5ec55e3021fc0bd8fb10a08bae5
Module libatspi.so.0 with build-id 87bca381f073faea3b0ffd1ab06f5f8f204e24cf
Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
Module libtiff.so.5 with build-id 5f020a8eb30e12c2e4012d0cb50da9480c7b5d34
Module libjpeg.so.8 with build-id 8e6d3f3e8f438912b561c43b6e7f66e6e5e097d0
Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
Module libpixman-1.so.0 with build-id d2170a3ac106c2a68597bf7910ab04b1cdd69c14
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libXrender.so.1 with build-id 42e386d2acf3cde61081959d9671ca74acfb3edc
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libmount.so.1 with build-id 9064fc3620c42e6f7aed38119f0a3ec39fca9a37
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libXinerama.so.1 with build-id 8198240259261b612189e89c9fcfc902b025b382
Module libXrandr.so.2 with build-id 154e55f082ee9e685d0794c98c5b76ffe9c8868e
Module libXcomposite.so.1 with build-id 13228d108b290268d88510db494daefd5521cda0
Module libXdamage.so.1 with build-id a99dbe3fc2b01da9fbdd90d5ad00621f9022379f
Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
Module libwayland-egl.so.1 with build-id dd02a2af320297e68308cc698f75828529271a57
Module libwayland-cursor.so.0 with build-id 46a637dbcbb02d6712a201f177377b66598b9121
Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libtracker-sparql-3.0.so.0 with build-id 75ab4f2e3b5c479b5c4fc62793bf398ee28f4ab7
Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
Module libatk-1.0.so.0 with build-id c2de8b4fcbd9681cef225fe3956a9608a2a664bb
Module libgdk_pixbuf-2.0.so.0 with build-id b2822dc16bd1470683ce421978ad142c4f3c3f89
Module libcairo-gobject.so.2 with build-id 9927090dddfb180365695a8f37d1cac89463f109
Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libpangoft2-1.0.so.0 with build-id 4a5a975bc9e397294c88738430515901a51c304c
Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
Module libharfbuzz.so.0 with build-id 236ab65053439e673a39fcb7aadedb28b17a338a
Module libpango-1.0.so.0 with build-id a971a5fed3b8b9cf076fe5edb9a9f04ced3da211
Module libpangocairo-1.0.so.0 with build-id 37f75358f8778498bcc26a1658107953d9495255
Module libgio-2.0.so.0 with build-id 7a769ec24a9a705d04ee0297730032f70ed0835b
Module libgobject-2.0.so.0 with build-id a7515bd8cd51064d187953c0f506a43958de31a6
Module libglib-2.0.so.0 with build-id 1340f3a762b2293ebf6d725edf0eb14839f85317
Module libgmodule-2.0.so.0 with build-id abd986222e2cf12fc7324cb0182dfc2c8f2269c0
Module libgdk-3.so.0 with build-id 4a9a6d5ddd18f22c56c05773208f8808cefacab6
Module libgtk-3.so.0 with build-id 48baf44dfd4d51f8c2b81d852eb44de692c16b19
Module libmozgtk.so with build-id 8027a58caeba8263184a5eed62b27555d21c7736
Module libmozsqlite3.so with build-id 8d0f4ebe7c073f9b72bab3afb37b00c4b7a15652
Module liblgpllibs.so with build-id 33615eeab36653f9841f2828e10c6aebbc2463fb
Module libnspr4.so with build-id 64bc745fdf99e414eeda94b9345af6fa6fcce329
Module ld-linux-x86-64.so.2 with build-id 5492655bffbf172ed8a07f285f760ead38f09404
Module libc.so.6 with build-id 7d4293a9bbe1f068ab7ae807c2d9377395eb5b41
Module libgcc_s.so.1 with build-id 308aed8b7d7e38f5efa23f75c25601668c1fc009
Module libm.so.6 with build-id efeea58692a42176201df89f034aa4295a77ce74
Module libstdc++.so.6 with build-id e0dd3ec5b0a62b122b4141c956c0b33a4d719144
Module firefox with build-id 2b8aea238365eb224accff3ca8a61933202c6214
Stack trace of thread 1305:
#0 0x00007f2ad628f814 XDisplayString (libX11.so.6 + 0x2b814)
#1 0x00007f2ac95cda1d __vaDriverInit_1_13 (nvidia_drv_video.so + 0xda1d)
#2 0x00007f2ac9275c8a n/a (libva.so.2 + 0x3c8a)
#3 0x00007f2ac927bbe1 vaInitialize (libva.so.2 + 0x9be1)
#4 0x00007f2ad1b09117 n/a (libxul.so + 0x8533117)
#5 0x00007f2ad1b09d29 n/a (libxul.so + 0x8533d29)
#6 0x00007f2acdad9b4e n/a (libxul.so + 0x4503b4e)
#7 0x00007f2acdad7955 n/a (libxul.so + 0x4501955)
#8 0x00007f2acdacabe5 n/a (libxul.so + 0x44f4be5)
#9 0x00007f2acdac9ead n/a (libxul.so + 0x44f3ead)
#10 0x000055b794c94972 n/a (firefox + 0x55972)
#11 0x00007f2ad807e2d0 n/a (libc.so.6 + 0x232d0)
#12 0x00007f2ad807e38a __libc_start_main (libc.so.6 + 0x2338a)
#13 0x000055b794ca40a5 _start (firefox + 0x650a5)
Sep 01 16:02:42 man-jon-desk kernel: audit: type=1131 audit(1662040962.828:81): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-1306-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 16:02:42 man-jon-desk kernel: audit: type=1334 audit(1662040962.935:82): prog-id=0 op=UNLOAD
Sep 01 16:02:42 man-jon-desk kernel: audit: type=1334 audit(1662040962.935:83): prog-id=0 op=UNLOAD
Sep 01 16:02:42 man-jon-desk kernel: audit: type=1334 audit(1662040962.935:84): prog-id=0 op=UNLOAD
Sep 01 16:02:43 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:02:48 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:02:53 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:02:58 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:03:03 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:03:08 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:03:08 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:03:10 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:03:13 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:03:18 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:03:24 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:03:29 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:03:29 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:03:34 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:03:38 man-jon-desk sudo[1736]: filteredusername : TTY=pts/1 ; PWD=/home/filteredusername ; USER=root ; COMMAND=/usr/bin/dmesg -l err,warn,emerg,alert,crit
Sep 01 16:03:38 man-jon-desk kernel: audit: type=1100 audit(1662041018.645:85): pid=1736 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="filteredusername" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:03:38 man-jon-desk kernel: audit: type=1101 audit(1662041018.645:86): pid=1736 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="filteredusername" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:03:38 man-jon-desk kernel: audit: type=1110 audit(1662041018.645:87): pid=1736 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:03:38 man-jon-desk kernel: audit: type=1105 audit(1662041018.645:88): pid=1736 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:03:38 man-jon-desk kernel: audit: type=1106 audit(1662041018.662:89): pid=1736 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:03:38 man-jon-desk kernel: audit: type=1104 audit(1662041018.662:90): pid=1736 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:03:39 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:03:43 man-jon-desk sudo[1751]: filteredusername : TTY=pts/1 ; PWD=/home/filteredusername ; USER=root ; COMMAND=/usr/bin/dmesg -l err,warn,emerg,alert,crit
Sep 01 16:03:43 man-jon-desk kernel: audit: type=1101 audit(1662041023.435:91): pid=1751 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="filteredusername" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:03:43 man-jon-desk kernel: audit: type=1110 audit(1662041023.435:92): pid=1751 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:03:43 man-jon-desk kernel: audit: type=1105 audit(1662041023.435:93): pid=1751 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:03:43 man-jon-desk kernel: audit: type=1106 audit(1662041023.438:94): pid=1751 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:03:44 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:03:46 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:03:49 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:03:54 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:03:59 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:04:04 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:04:08 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:04:10 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:04:14 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:04:15 man-jon-desk wireplumber[1047]: Unable to load mixer: Die Wartezeit für die Verbindung ist abgelaufen
Sep 01 16:04:20 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:04:24 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:04:25 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:04:29 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:04:30 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:04:35 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:04:40 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:04:45 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:04:45 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:04:51 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:04:55 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:04:56 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:05:01 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:05:06 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:05:06 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:05:09 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:05:11 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:05:11 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:05:13 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:05:16 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:05:21 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:05:26 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:05:32 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:05:33 man-jon-desk sudo[1954]: filteredusername : TTY=pts/1 ; PWD=/home/filteredusername ; USER=root ; COMMAND=/usr/bin/journalctl -b4 -p0
Sep 01 16:05:33 man-jon-desk kernel: kauditd_printk_skb: 1 callbacks suppressed
Sep 01 16:05:33 man-jon-desk kernel: audit: type=1101 audit(1662041133.872:96): pid=1954 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="filteredusername" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:05:33 man-jon-desk kernel: audit: type=1110 audit(1662041133.872:97): pid=1954 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:05:33 man-jon-desk kernel: audit: type=1105 audit(1662041133.872:98): pid=1954 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:05:33 man-jon-desk kernel: audit: type=1106 audit(1662041133.888:99): pid=1954 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:05:33 man-jon-desk kernel: audit: type=1104 audit(1662041133.888:100): pid=1954 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:05:37 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:05:37 man-jon-desk sudo[1960]: filteredusername : TTY=pts/1 ; PWD=/home/filteredusername ; USER=root ; COMMAND=/usr/bin/journalctl -b4 -p2
Sep 01 16:05:37 man-jon-desk kernel: audit: type=1101 audit(1662041137.848:101): pid=1960 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="filteredusername" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:05:37 man-jon-desk kernel: audit: type=1110 audit(1662041137.848:102): pid=1960 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:05:37 man-jon-desk kernel: audit: type=1105 audit(1662041137.848:103): pid=1960 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:05:42 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:05:44 man-jon-desk kernel: audit: type=1106 audit(1662041144.355:104): pid=1960 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:05:44 man-jon-desk kernel: audit: type=1104 audit(1662041144.355:105): pid=1960 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:05:47 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:05:48 man-jon-desk sudo[1977]: filteredusername : TTY=pts/1 ; PWD=/home/filteredusername ; USER=root ; COMMAND=/usr/bin/journalctl -b4 -p2 --no-pager
Sep 01 16:05:48 man-jon-desk kernel: audit: type=1101 audit(1662041148.288:106): pid=1977 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="filteredusername" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:05:48 man-jon-desk kernel: audit: type=1110 audit(1662041148.288:107): pid=1977 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:05:48 man-jon-desk kernel: audit: type=1105 audit(1662041148.288:108): pid=1977 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:05:48 man-jon-desk kernel: audit: type=1106 audit(1662041148.292:109): pid=1977 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:05:48 man-jon-desk kernel: audit: type=1104 audit(1662041148.292:110): pid=1977 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:05:52 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:05:55 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:05:57 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:06:02 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:06:07 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:06:12 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:06:16 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:06:18 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:06:18 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:06:23 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:06:28 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:06:33 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:06:38 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:06:43 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:06:48 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:06:53 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:06:59 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:07:01 man-jon-desk sudo[1995]: filteredusername : TTY=pts/1 ; PWD=/home/filteredusername ; USER=root ; COMMAND=/usr/bin/journalctl -b4 -p5 --no-pager
Sep 01 16:07:01 man-jon-desk kernel: audit: type=1101 audit(1662041221.402:111): pid=1995 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="filteredusername" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:07:01 man-jon-desk kernel: audit: type=1110 audit(1662041221.402:112): pid=1995 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:07:01 man-jon-desk kernel: audit: type=1105 audit(1662041221.402:113): pid=1995 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:07:01 man-jon-desk kernel: audit: type=1106 audit(1662041221.405:114): pid=1995 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:07:01 man-jon-desk kernel: audit: type=1104 audit(1662041221.405:115): pid=1995 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:07:04 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:07:09 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:07:14 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:07:19 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:07:24 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:07:29 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:07:34 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:07:40 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 44100 to ep 0x3
Sep 01 16:07:45 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:07:50 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:07:55 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:07:59 man-jon-desk kernel: debugfs: Directory 'card3' with parent 'sound' already present!
Sep 01 16:08:00 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:08:05 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:08:10 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:08:15 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:08:20 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:08:21 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:08:21 man-jon-desk kernel: usb 1-2.1: 2:0: usb_set_interface failed (-32)
Sep 01 16:08:21 man-jon-desk kernel: usb 1-2.1: 2:1: usb_set_interface failed (-32)
Sep 01 16:08:21 man-jon-desk kernel: usb 1-2.1: 2:1: usb_set_interface failed (-19)
Sep 01 16:08:21 man-jon-desk kernel: usb 1-2.1: 2:0: usb_set_interface failed (-19)
Sep 01 16:08:21 man-jon-desk wireplumber[1047]: error pcm info: Kein passendes Gerät gefunden
Sep 01 16:08:21 man-jon-desk wireplumber[1047]: error iterating devices: Kein passendes Gerät gefunden
Sep 01 16:08:22 man-jon-desk kernel: usb 1-2.1: 2:1: cannot set freq 48000 to ep 0x3
Sep 01 16:08:32 man-jon-desk kernel: audit: type=1100 audit(1662041312.085:116): pid=2168 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="filteredusername" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
Sep 01 16:08:32 man-jon-desk kernel: audit: type=1101 audit(1662041312.085:117): pid=2168 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="filteredusername" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
Sep 01 16:08:32 man-jon-desk polkitd[644]: Operator of unix-session:2 successfully authenticated as unix-user:filteredusername to gain ONE-SHOT authorization for action org.kde.ktexteditor.katetextbuffer.savefile for system-bus-name::1.78 [kate /etc/default/grub] (owned by unix-user:filteredusername)
Sep 01 16:08:53 man-jon-desk polkitd[644]: Operator of unix-session:2 successfully authenticated as unix-user:filteredusername to gain ONE-SHOT authorization for action org.kde.ktexteditor.katetextbuffer.savefile for system-bus-name::1.78 [kate /etc/default/grub] (owned by unix-user:filteredusername)
Sep 01 16:08:53 man-jon-desk kernel: audit: type=1100 audit(1662041333.045:118): pid=2186 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="filteredusername" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
Sep 01 16:08:53 man-jon-desk kernel: audit: type=1101 audit(1662041333.045:119): pid=2186 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="filteredusername" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
Sep 01 16:09:14 man-jon-desk sudo[2219]: filteredusername : TTY=pts/1 ; PWD=/home/filteredusername ; USER=root ; COMMAND=/usr/bin/update-grub
Sep 01 16:09:14 man-jon-desk kernel: audit: type=1101 audit(1662041354.188:120): pid=2219 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="filteredusername" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:09:14 man-jon-desk kernel: audit: type=1110 audit(1662041354.192:121): pid=2219 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:09:14 man-jon-desk kernel: audit: type=1105 audit(1662041354.192:122): pid=2219 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:09:15 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/nvme0n1p1
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: /dev/nvme0n1p1 type not recognised; skipping
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/nvme0n1p1
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: /dev/nvme0n1p1 type not recognised; skipping
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: os detected by /usr/lib/os-probes/50mounted-tests.orig
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/nvme0n1p2
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: mounted using GRUB ntfs filesystem driver
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/05efi
Sep 01 16:09:16 man-jon-desk root[2574]: 05efi: debug: /dev/nvme0n1p2 is ntfs partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10freedos
Sep 01 16:09:16 man-jon-desk root[2574]: 10freedos: debug: /dev/nvme0n1p2 is not a FAT partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/10qnx
Sep 01 16:09:16 man-jon-desk root[2574]: 10qnx: debug: /dev/nvme0n1p2 is not a QNX4 partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20macosx
Sep 01 16:09:16 man-jon-desk macosx-prober[2680]: debug: /dev/nvme0n1p2 is not an HFS+ partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/20microsoft
Sep 01 16:09:16 man-jon-desk root[2574]: 20microsoft: debug: Skipping legacy bootloaders on UEFI system
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/30utility
Sep 01 16:09:16 man-jon-desk root[2574]: 30utility: debug: /dev/nvme0n1p2 is not a FAT partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/40lsb
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/70hurd
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/80minix
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/83haiku
Sep 01 16:09:16 man-jon-desk root[2574]: 83haiku: debug: /dev/nvme0n1p2 is not a BeFS partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro.orig
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/90solaris
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: running subtest /usr/lib/os-probes/mounted/efi
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/nvme0n1p2
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: mounted using GRUB ntfs filesystem driver
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/05efi
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/10freedos
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/10qnx
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/20macosx
Sep 01 16:09:16 man-jon-desk macosx-prober[2726]: debug: /dev/nvme0n1p2 is not an HFS+ partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/20microsoft
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/30utility
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/40lsb
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/70hurd
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/80minix
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/83haiku
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/90linux-distro.orig
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/90solaris
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: running subtest /usr/lib/os-probes/mounted/efi
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/05efi on mounted /dev/nvme1n1p1
Sep 01 16:09:16 man-jon-desk root[2574]: 05efi: debug: /dev/nvme1n1p1 is a FAT32 partition
Sep 01 16:09:16 man-jon-desk root[2574]: 05efi: debug: /dev/nvme1n1p1 partition scheme is gpt
Sep 01 16:09:16 man-jon-desk root[2574]: 05efi: debug: /dev/nvme1n1p1 partition type is 21686148-6449-6e6f-744e-656564454649
Sep 01 16:09:16 man-jon-desk root[2574]: 05efi: debug: /dev/nvme1n1p1 is not a ESP partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/10freedos on mounted /dev/nvme1n1p1
Sep 01 16:09:16 man-jon-desk root[2574]: 10freedos: debug: /dev/nvme1n1p1 is a FAT32 partition
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/10qnx on mounted /dev/nvme1n1p1
Sep 01 16:09:16 man-jon-desk root[2574]: 10qnx: debug: /dev/nvme1n1p1 is not a QNX4 partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/20macosx on mounted /dev/nvme1n1p1
Sep 01 16:09:16 man-jon-desk macosx-prober[2785]: debug: /dev/nvme1n1p1 is not an HFS+ partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/20microsoft on mounted /dev/nvme1n1p1
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/30utility on mounted /dev/nvme1n1p1
Sep 01 16:09:16 man-jon-desk root[2574]: 30utility: debug: /dev/nvme1n1p1 is a FAT32 partition
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/40lsb on mounted /dev/nvme1n1p1
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/70hurd on mounted /dev/nvme1n1p1
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/80minix on mounted /dev/nvme1n1p1
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/83haiku on mounted /dev/nvme1n1p1
Sep 01 16:09:16 man-jon-desk root[2574]: 83haiku: debug: /dev/nvme1n1p1 is not a BeFS partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro on mounted /dev/nvme1n1p1
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro.orig on mounted /dev/nvme1n1p1
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/90solaris on mounted /dev/nvme1n1p1
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/nvme1n1p2
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: /dev/nvme1n1p2 is a LUKS partition; skipping
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/nvme1n1p2
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: /dev/nvme1n1p2 is a LUKS partition; skipping
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sdb1
Sep 01 16:09:16 man-jon-desk root[2574]: 05efi: debug: /dev/sdb1 is ntfs partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: 10freedos: debug: /dev/sdb1 is not a FAT partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: 10qnx: debug: /dev/sdb1 is not a QNX4 partition: exiting
Sep 01 16:09:16 man-jon-desk macosx-prober[2855]: debug: /dev/sdb1 is not an HFS+ partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: 30utility: debug: /dev/sdb1 is not a FAT partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: 83haiku: debug: /dev/sdb1 is not a BeFS partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/sdb1
Sep 01 16:09:16 man-jon-desk macosx-prober[2899]: debug: /dev/sdb1 is not an HFS+ partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sdc1
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: /dev/sdc1 is a LUKS partition; skipping
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/sdc1
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: /dev/sdc1 is a LUKS partition; skipping
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sdc2
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: /dev/sdc2 is a LUKS partition; skipping
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/sdc2
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: /dev/sdc2 is a LUKS partition; skipping
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sdc3
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: /dev/sdc3 is a LUKS partition; skipping
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/sdc3
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: /dev/sdc3 is a LUKS partition; skipping
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sdc4
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: /dev/sdc4 is a LUKS partition; skipping
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/sdc4
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: /dev/sdc4 is a LUKS partition; skipping
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sdd1
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: /dev/sdd1 is a LUKS partition; skipping
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/sdd1
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: /dev/sdd1 is a LUKS partition; skipping
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/05efi on mounted /dev/sde1
Sep 01 16:09:16 man-jon-desk root[2574]: 05efi: debug: /dev/sde1 is iso9660 partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/10freedos on mounted /dev/sde1
Sep 01 16:09:16 man-jon-desk root[2574]: 10freedos: debug: /dev/sde1 is not a FAT partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/10qnx on mounted /dev/sde1
Sep 01 16:09:16 man-jon-desk root[2574]: 10qnx: debug: /dev/sde1 is not a QNX4 partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/20macosx on mounted /dev/sde1
Sep 01 16:09:16 man-jon-desk macosx-prober[3039]: debug: /dev/sde1 is not an HFS+ partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/20microsoft on mounted /dev/sde1
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/30utility on mounted /dev/sde1
Sep 01 16:09:16 man-jon-desk root[2574]: 30utility: debug: /dev/sde1 is not a FAT partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/40lsb on mounted /dev/sde1
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/70hurd on mounted /dev/sde1
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/80minix on mounted /dev/sde1
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/83haiku on mounted /dev/sde1
Sep 01 16:09:16 man-jon-desk root[2574]: 83haiku: debug: /dev/sde1 is not a BeFS partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro on mounted /dev/sde1
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/90linux-distro.orig on mounted /dev/sde1
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/mounted/90solaris on mounted /dev/sde1
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on /dev/sde2
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: mounted using GRUB fat filesystem driver
Sep 01 16:09:16 man-jon-desk root[2574]: 05efi: debug: /dev/sde2 is a FAT partition (mounted by GRUB)
Sep 01 16:09:16 man-jon-desk root[2574]: 05efi: debug: /dev/sde2 partition scheme is dos
Sep 01 16:09:16 man-jon-desk root[2574]: 05efi: debug: /dev/sde2 partition type is 0xef
Sep 01 16:09:16 man-jon-desk root[2574]: 05efi: debug: running subtest /usr/lib/os-probes/mounted/efi/10elilo
Sep 01 16:09:16 man-jon-desk root[2574]: 05efi: debug: running subtest /usr/lib/os-probes/mounted/efi/20microsoft
Sep 01 16:09:16 man-jon-desk root[2574]: 10freedos: debug: /dev/sde2 is a FAT partition (mounted by GRUB)
Sep 01 16:09:16 man-jon-desk root[2574]: 10qnx: debug: /dev/sde2 is not a QNX4 partition: exiting
Sep 01 16:09:16 man-jon-desk macosx-prober[3107]: debug: /dev/sde2 is not an HFS+ partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: 30utility: debug: /dev/sde2 is a FAT partition (mounted by GRUB)
Sep 01 16:09:16 man-jon-desk root[2574]: 83haiku: debug: /dev/sde2 is not a BeFS partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests.orig on /dev/sde2
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests.orig: debug: mounted using GRUB fat filesystem driver
Sep 01 16:09:16 man-jon-desk macosx-prober[3175]: debug: /dev/sde2 is not an HFS+ partition: exiting
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: btrfs volume uuid=428dcc39-14a9-4e2c-ba7b-e8482d468f93 partition=/dev/mapper/luks-7cecd1d3-bc54-4e89-92ad-a80f4b151998
Sep 01 16:09:16 man-jon-desk root[2574]: os-prober: debug: running /usr/lib/os-probes/50mounted-tests on btrfs /dev/mapper/luks-7cecd1d3-bc54-4e89-92ad-a80f4b151998
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: begin btrfs processing for 428dcc39-14a9-4e2c-ba7b-e8482d468f93
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: btrfs volume 428dcc39-14a9-4e2c-ba7b-e8482d468f93 mounted
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: begin btrfs processing for 428dcc39-14a9-4e2c-ba7b-e8482d468f93 subvol=@
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: begin btrfs processing for 428dcc39-14a9-4e2c-ba7b-e8482d468f93 subvol=@home
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: begin btrfs processing for 428dcc39-14a9-4e2c-ba7b-e8482d468f93 subvol=@cache
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: begin btrfs processing for 428dcc39-14a9-4e2c-ba7b-e8482d468f93 subvol=@log
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: begin btrfs processing for 428dcc39-14a9-4e2c-ba7b-e8482d468f93 subvol=manual-snapshots/after-first-install/root-only-2022-09-01
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: begin btrfs processing for 428dcc39-14a9-4e2c-ba7b-e8482d468f93 subvol=manual-snapshots/after-first-install/home-only-2022-09-01
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: begin btrfs processing for 428dcc39-14a9-4e2c-ba7b-e8482d468f93 subvol=manual-snapshots/after-first-install/var-cache-only-2022-09-01
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: begin btrfs processing for 428dcc39-14a9-4e2c-ba7b-e8482d468f93 subvol=manual-snapshots/after-first-install/var-log-only-2022-09-01
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: begin btrfs processing for 428dcc39-14a9-4e2c-ba7b-e8482d468f93 subvol=timeshift-btrfs/snapshots/2022-09-01_15-03-29/@
Sep 01 16:09:16 man-jon-desk root[2574]: 50mounted-tests: debug: begin btrfs processing for 428dcc39-14a9-4e2c-ba7b-e8482d468f93 subvol=@swap
Sep 01 16:09:17 man-jon-desk kernel: audit: type=1106 audit(1662041357.102:123): pid=2219 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:09:17 man-jon-desk kernel: audit: type=1104 audit(1662041357.102:124): pid=2219 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
Sep 01 16:09:21 man-jon-desk systemd-logind[645]: System is rebooting.
Sep 01 16:09:21 man-jon-desk kernel: audit: type=1131 audit(1662041361.738:125): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 16:09:21 man-jon-desk kernel: audit: type=1131 audit(1662041361.742:126): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 16:09:21 man-jon-desk kernel: audit: type=1131 audit(1662041361.742:127): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 16:09:21 man-jon-desk polkitd[644]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.34, object path /org/kde/PolicyKit1/AuthenticationAgent, locale de_DE.UTF-8) (disconnected from bus)
Sep 01 16:09:21 man-jon-desk sddm[683]: Authentication error: "Process crashed"
Sep 01 16:09:21 man-jon-desk sddm[683]: Auth: sddm-helper crashed (exit code 15)
Sep 01 16:09:21 man-jon-desk sddm[683]: Auth: sddm-helper exited with 15
Sep 01 16:09:21 man-jon-desk kglobalaccel5[870]: The X11 connection broke: I/O error (code 1)
Sep 01 16:09:21 man-jon-desk kernel: audit: type=1131 audit(1662041361.748:128): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 16:09:21 man-jon-desk kernel: audit: type=1131 audit(1662041361.758:129): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 16:09:21 man-jon-desk udisksd[748]: udisks daemon version 2.9.4 exiting
Sep 01 16:09:21 man-jon-desk kernel: audit: type=1131 audit(1662041361.762:130): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 16:09:21 man-jon-desk kernel: audit: type=1131 audit(1662041361.775:131): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 16:09:21 man-jon-desk kernel: audit: type=1131 audit(1662041361.792:132): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 16:09:21 man-jon-desk kernel: audit: type=1130 audit(1662041361.818:133): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 16:09:21 man-jon-desk kernel: audit: type=1131 audit(1662041361.818:134): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Sep 01 16:09:22 man-jon-desk systemd-coredump[3614]: Failed to connect to coredump service: Connection refused
Sep 01 16:09:22 man-jon-desk sddm[683]: Signal received: SIGTERM
Sep 01 16:09:22 man-jon-desk systemd[771]: xdg-document-portal.service: Main process exited, code=exited, status=20/n/a
Sep 01 16:09:22 man-jon-desk systemd[771]: xdg-document-portal.service: Failed with result 'exit-code'.
Sep 01 16:09:22 man-jon-desk systemd[771]: xdg-permission-store.service: Main process exited, code=exited, status=1/FAILURE
Sep 01 16:09:22 man-jon-desk systemd[771]: xdg-permission-store.service: Failed with result 'exit-code'.
Sep 01 16:09:22 man-jon-desk wireplumber[1047]: stopped by signal: Beendet
Sep 01 16:09:22 man-jon-desk wireplumber[1047]: disconnected from pipewire
Sep 01 16:09:22 man-jon-desk systemd[772]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[filteredusername] ruser=[<unknown>] rhost=[<unknown>]
Sep 01 16:09:23 man-jon-desk sddm[683]: QProcess: Destroyed while process ("/usr/lib/sddm/sddm-helper") is still running.
post output also from this:
sudo dmesg | grep -E 'error|failed'
there are som failed services in the logs … and alot logs related to disk … youre using btrfs, could you try reinstalling again but using ext4 file system without any encryption and see if that helped
Yes, reinstalling is no problem.
here is the dmesg
dmesg
[ 0.000000] tsc: Fast TSC calibration failed
[ 3.173588] ata6: failed to resume link (SControl 0)
[ 7.774570] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[ 7.777544] systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 7.778105] systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 7.778450] systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 7.789389] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of a failed condition check (ConditionKernelVersion=<5.6).
[ 8.480170] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 17.005765] audit: type=1103 audit(1662042245.261:59): pid=770 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="filteredusername" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 207.618081] firefox[1229]: segfault at d8 ip 00007f35275e8814 sp 00007ffe79c52d18 error 4 in libX11.so.6.4.0[7f35275d9000+8b000]
so try reintalling with ext4
already on it
booted
so disable again the indexer and test
until now no problems, with the indexer in this boot. a moment
There do not seem to be any problems.
That is of course fantastic, but also possibly a bit unfortunate.
I will try to reinstall with LUKS(EXT4) to see if only btrfs is the problem. Be back in a few
I don’t have audio. So, I guess that means I will have to make do without LUKS for now.
Any idea, if the issue might be fixed in the next stable update?
