Frequent periods of unresponsiveness for 10 to 20 seconds at least on a fresh KDE install(with some programs)
So, in that case I would do a reinstall and install the packages one after the other. Perhaps even reboot in between. Sound good?
if the freezes were related only to running videos you could try the 470 version of nvidia, but audio is also affected, so probably a kernel thing …
that really doesnt sound that good to me, to much of work … you could try downgrading the kernel+nvidia …post output from:
ls -hl /var/cache/pacman/pkg | grep linux | grep nvidia
I already tried the 470xx version. I had only a blackscreen then, and had to revert via a chroot.
I have never downgraded a kernel before. Would have thought that would make only more problems.
But we can try no problem. You probably mean stay in 5.15 but a lower version in that right.
-rw-r--r-- 1 root root   37M 11. Aug 17:29 linux510-nvidia-515.65.01-2-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   438 11. Aug 17:29 linux510-nvidia-515.65.01-2-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root   39M 16. Aug 14:22 linux515-nvidia-515.65.01-2-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   39M 12. Aug 01:03 linux518-nvidia-515.65.01-2-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   438 12. Aug 01:03 linux518-nvidia-515.65.01-2-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root   39M 13. Aug 16:49 linux519-nvidia-515.65.01-6-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   438 13. Aug 16:49 linux519-nvidia-515.65.01-6-x86_64.pkg.tar.zst.sig
post output from this:
ls -hl /var/cache/pacman/pkg | grep nvidia
the command before was not correct
No problem
-rw-r--r-- 1 root root   43M 16. Aug 14:22 lib32-nvidia-utils-515.65.01-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root  212M 16. Aug 14:22 nvidia-utils-515.65.01-2-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   76M 11. Aug 17:29 linux510-5.10.136-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   438 11. Aug 17:29 linux510-5.10.136-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root  130M 12. Aug 01:03 linux518-5.18.17-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   438 12. Aug 01:03 linux518-5.18.17-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root  180M 13. Aug 16:49 linux519-5.19.1-3-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   438 13. Aug 16:49 linux519-5.19.1-3-x86_64.pkg.tar.zst.sig
well theres nothing to downgrade to, since its a fresh install, the packages that are downloaded are the latest …
since you are on btrfs, didnt you created a snapshot/timeshift before updating ?
not manually, but I’ll take a look
I have however, now that you mention it, a complete backup of my system before the first reinstall.
I’ll take a look in that cache as well.
But not from the cache. That’s in its own subvolume unfortunately
A kernel from a 64-bit Laptop should work as well right?
I’ll take a look
well if you have a backup, you can restore the snapshot, and then dont update the following:
linux515-nvidia
nvidia-utils
lib32-nvidia-utils
linux515
That would be the complete last resort, yes.
ls /var/cache/pacman/pkg -hl | grep linux
-rw-r--r-- 1 root root   19M 12. Mai 20:38 archlinux-appstream-data-20220512-1-any.pkg.tar.zst
-rw-r--r-- 1 root root   19M 27. Jul 09:43 archlinux-appstream-data-20220727-1-any.pkg.tar.zst
-rw-r--r-- 1 root root   310 27. Jul 09:43 archlinux-appstream-data-20220727-1-any.pkg.tar.zst.sig
-rw-r--r-- 1 root root  1,1M 25. Apr 01:02 archlinux-keyring-20220424-1-any.pkg.tar.zst
-rw-r--r-- 1 root root  1,1M 28. Jul 18:43 archlinux-keyring-20220727-1-any.pkg.tar.zst
-rw-r--r-- 1 root root   119 28. Jul 18:43 archlinux-keyring-20220727-1-any.pkg.tar.zst.sig
-rw-r--r-- 1 root root  385K  6. Aug 22:11 lib32-util-linux-2.38.1-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   119  6. Aug 22:11 lib32-util-linux-2.38.1-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root  386K 29. Mär 01:04 lib32-util-linux-2.38-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root  100M 16. Jun 19:55 linux515-5.15.48-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   438 16. Jun 19:55 linux515-5.15.48-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root  101M 11. Aug 20:35 linux515-5.15.60-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   438 11. Aug 20:35 linux515-5.15.60-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root  2,1M 16. Jun 19:55 linux515-r8168-8.049.02-59-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   438 16. Jun 19:55 linux515-r8168-8.049.02-59-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root  2,2M 11. Aug 20:35 linux515-r8168-8.050.03-4-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   438 11. Aug 20:35 linux515-r8168-8.050.03-4-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root  117M 28. Mär 17:44 linux516-5.16.18-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   438 28. Mär 17:44 linux516-5.16.18-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root  119M 15. Jun 12:34 linux517-5.17.15-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   438 15. Jun 12:34 linux517-5.17.15-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root   33M 15. Jun 12:34 linux517-headers-5.17.15-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   438 15. Jun 12:34 linux517-headers-5.17.15-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root  2,0M 15. Jun 12:34 linux517-r8168-8.049.02-20-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   438 15. Jun 12:34 linux517-r8168-8.049.02-20-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root  1,2M 11. Mai 00:17 linux-api-headers-5.17.5-2-any.pkg.tar.zst
-rw-r--r-- 1 root root  1,2M  2. Aug 19:44 linux-api-headers-5.18.15-1-any.pkg.tar.zst
-rw-r--r-- 1 root root   215  2. Aug 19:44 linux-api-headers-5.18.15-1-any.pkg.tar.zst.sig
-rw-r--r-- 1 root root  134M 13. Mai 16:35 linux-firmware-20220509.b19cbdc-1-any.pkg.tar.zst
-rw-r--r-- 1 root root   310 13. Mai 16:35 linux-firmware-20220509.b19cbdc-1-any.pkg.tar.zst.sig
-rw-r--r-- 1 root root  130M 15. Jul 16:25 linux-firmware-20220708.be7798e-1-any.pkg.tar.zst
-rw-r--r-- 1 root root   310 15. Jul 16:25 linux-firmware-20220708.be7798e-1-any.pkg.tar.zst.sig
-rw-r--r-- 1 root root   35K 13. Mai 16:35 linux-firmware-whence-20220509.b19cbdc-1-any.pkg.tar.zst
-rw-r--r-- 1 root root   34K 15. Jul 16:25 linux-firmware-whence-20220708.be7798e-1-any.pkg.tar.zst
-rw-r--r-- 1 root root   310 15. Jul 16:25 linux-firmware-whence-20220708.be7798e-1-any.pkg.tar.zst.sig
-rw-r--r-- 1 root root  2,5M  6. Aug 21:06 util-linux-2.38.1-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   119  6. Aug 21:06 util-linux-2.38.1-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root  2,5M 29. Mär 01:04 util-linux-2.38-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   119 29. Mär 01:04 util-linux-2.38-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root  360K  6. Aug 21:06 util-linux-libs-2.38.1-1-x86_64.pkg.tar.zst
-rw-r--r-- 1 root root   119  6. Aug 21:06 util-linux-libs-2.38.1-1-x86_64.pkg.tar.zst.sig
-rw-r--r-- 1 root root  361K 29. Mär 01:04 util-linux-libs-2.38-1-x86_64.pkg.tar.zst
Oh, problem. The Laptop does not have an Nvidia card and therefore no drivers
i have no idea if manjaro provides older packages for download…
so you found them… so thats a problem, you would not be able to downgrade since you have only this:
linux515-5.15.60
so if you have the backup from before installing the updates, use it, and then dont upgrade the packages mentioned above …
I’ll take a short look which versions are installed in the backup, but perhaps that is indeed the only way.
Any idea, on wether or not, or when, I’ll be able to do a new install then. I do want to try KDE :unamused: :sweat_smile:
you can do again a fresh install from the same iso:
then take a backup of it, and run update without the packages, to see if it was really because of them …
That is a very good idea thx. :grinning:
And I will try that before the backup
yes do a fresh install again, then back it up, and run update from add/remove software with the blacklisted:
linux515-nvidia
nvidia-utils
lib32-nvidia-utils
linux515
Alright, we’ll see then how it goes. Till tomorrow probably XD And already thanks for the help until now, btw. :smiley: :+1: :pray:
Is an update of those packages forbidden now, or are they just not checked. In other words: If I install something that depends on newer versions of these packages, what will happen?
