Fn key with brightness
After fresh install manjaro the “Fn” key with brightness works fine, but then i did an update with pamac and reboot laptop. Then the “Fn” combination for brightness stop working.
Why and how to fix it?
Hello, it looks like this is a recurring issue on your end:
I’d recommend you take a look at the link below and update your post accordingly:
Just a couple of ideas:
  1. Please provide the output of the file /var/log/pacman.log, relevant to the latest update. This will help other users in figuring out what changed on your system.
  2. Depending on your hardware, you may or may not need to add an acpi kernel parameter. Sometimes, acpi kernel parameters have to do with the proper functioning of the function keys. See below:
Hope the above helps!
