Hello,
since the update from 13.07.2021 (I guess), the brightness for my laptop screen cant’be changed:
- Using FN-F5 / F6 the onscreen slider (ref. screenshot)
shows up and I can the values between 0% and 13%; higher values are not possible, the brightness does not change. - Using SystemSettings > Hardware > Energy > EnergySavings, I can change the values for “powered”, “onBattery” and “onBattery, while low” between 0 and 100% but the brightness does not change…
I found something similar here and there, but I don’t see the solution or my knowledge is to poor, to follow.
$ xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 309mm x 173mm
1920x1080 60.00*+
1680x1050 60.00
1280x1024 60.00
1440x900 60.00
1280x800 60.00
1280x720 60.00
1024x768 60.00
800x600 60.00
640x480 60.00
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
DisplayPort-0 disconnected (normal left inverted right x axis y axis)
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
