Installed flatpak with pamac install flatpak libpamac-flatpak-plugin
Don’t tend to use flatpaks unless I have to but the only way I can get Proton Mail and Proton Pass installed on the two arch-based systems I’ve tried is through flathub, when I open both apps all I get is the titlebar and a white screen
Decided to try some other flatpaks to see if I got the same thing, and this is the weird part
If I install browser flatpaks the only ones that don’t display the same behaviour are firefox-based, any others just the titlebar and white screen, they also won’t close, I have to list their processes with the ps command and kill them all
The other few apps I installed just to see if the work opened fine, seems to only be affecting the Proton app and non-Firefox based browsers
I tried removing and reinstalling all the apps and flatpak itself, same issue, also tried sudo flatpak repair --resintall-all, made no difference
Incidentally, I’ve been ‘test-driving’ a variety of distros because I want to get away from opensuse as my ‘daliy driver’ cos I really don’t like the way it’s gone with Leap 16, the only two distros I’ve experienced this issue with are the two Arch-based ones I’ve tried, Manjaro and Endeavour
Makes me wonder if it’s a known issue with Arch-based systems, did find a lot of posts about flatpak issues when I searched the forum but the closest one to this was one about ‘apps not working’, where they weren’t opening at all
I did wonder if it might be GPU related, though I’d expect more wide-ranging issues if it was down to the card
This machine has an Nvidia card, a Geforce GTX 1070 that’s always ran well enough on both the opensource and proprietary drivers on a range of distros
