Exhaustive System Information
Kernel: 5.10.84-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=9233c369-278a-4a71-902a-847c12b1df08 rw text apparmor=1
Desktop: Cinnamon 5.0.7 tk: GTK 3.24.30 vt: 7 dm: LightDM 1.30.0
Type: Laptop System: COMPUMAX S.A.S. product: RAPID v: 0.1
serial: <superuser required> Chassis: type: 9 v: 0.1
Mobo: COMPUMAX S.A.S. model: RAPID v: FAB1 serial: <superuser required>
UEFI-[Legacy]: Phoenix v: 1.03.CX date: 10/16/2012
ID-1: BAT0 charge: 41.6 Wh (96.1%) condition: 43.3/48.8 Wh (88.6%)
volts: 12.7 min: 11.1 model: ODM MB45II type: Li-ion serial: <filter>
status: Charging
RAM: total: 4.68 GiB used: 2.9 GiB (62.1%)
RAM Report:
Info: model: Intel Celeron B800 bits: 64 type: MCP arch: Sandy Bridge
family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 2 MiB
desc: 1x2 MiB
Speed (MHz): avg: 981 high: 1163 min/max: 800/1500 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1163 2: 799
bogomips: 5988
Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear
mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Elite Systems driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0106 class-ID: 0300
Device-2: Acer HD Webcam type: USB driver: uvcvideo bus-ID: 1-1.3:3
chip-ID: 5986:014d class-ID: 0e02
Display: x11 server: X.Org 1.21.1.2 driver: loaded: modesetting
alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: LVDS-1 res: 1366x768 hz: 60 dpi: 112
size: 309x174mm (12.2x6.9") diag: 355mm (14")
OpenGL: renderer: Mesa DRI Intel HD Graphics 2000 (SNB GT1)
v: 3.3 Mesa 21.2.5 compat-v: 3.0 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Elite Systems driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1e20 class-ID: 0403
Sound Server-1: ALSA v: k5.10.84-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Realtek RTL8188CE 802.11b/g/n WiFi Adapter driver: rtl8192ce
v: kernel port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8176 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
vendor: Elite Systems driver: r8169 v: kernel port: 2000 bus-ID: 02:00.0
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 149.05 GiB used: 52.71 GiB (35.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS545016B9A300
size: 149.05 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: C60F scheme: MBR
ID-1: / raw-size: 98.58 GiB size: 96.53 GiB (97.92%) used: 52.71 GiB (54.6%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Manjaro
uuid: 9233c369-278a-4a71-902a-847c12b1df08
ID-1: swap-1 type: file size: 8 GiB used: 780 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sda2 maj-min: 8:2 size: 50.47 GiB fs: ntfs label: Doors 8.1
uuid: 01D7F101AB73BFF0
Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.3:3 info: Acer HD Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:014d
class-ID: 0e02
Device-2: 1-1.4:4 info: Realtek USB 2.0 multicard reader
type: Mass Storage driver: ums-realtek interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 0bda:0158 class-ID: 0806
serial: <filter>
Hub-3: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Silicon Labs USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 10c4:8108 class-ID: 0301
Device-2: 3-2:3 info: CASUE USB Keyboard type: Keyboard,HID
power: 100mA chip-ID: 2a7a:6a18 class-ID: 0300
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 65.0 C mobo: N/A
Processes: 221 Uptime: 1h 7m wakeups: 1 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1463 lib: 399 pkg: 0 flatpak: 0
Shell: Bash v: 5.1.12 running-in: gnome-terminal inxi: 3.3.11
Everytime I start my computer and log in, there is a 1x1 unnamed window with a settings cog icon, at first I ignored it, but now I’m getting suspicious of this window (as in, malicious kind of suspicious).
I’ve tried identifying what PID it has using xdotool getwindowpid which returns
[xproot@xproot-lappy ~]$ xdotool getwindowpid 65011715
window 65011715 has no pid associated with it.
I also tried xprop _NET_WM_PID | sed 's/_NET_WM_PID(CARDINAL) = //' which returns
_NET_WM_PID: not found.
now both of these commands work with regular windows, yet it doesn’t work with this? just adds more suspicion to me.
Anyone could bring up a solution? How to find what is making this window? I originally thought it was kde-connect-indicator since it started appearing as soon I added that to startup applications but removing it from it doesn’t help.
