error: file `/boot/vmlinuz-X.XX-x86_64’ not found.
error: you need to load the kernel first.
Press any key to continue…
So i installed the iso file and boot my system
I opened the terminal
I pasted ‘’‘sudo manjaro-chroot -a"’
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sda1]
--> mount: [/mnt]
mount: /mnt: /dev/sda1 already mounted on /mnt.
dmesg(1) may have more information after failed mount system call.
mount: /mnt/sys: sys already mounted on /sys.
I pasted
mhwd-kernel -li
error: could not open file /var/lib/pacman/local/clang-15.0.7-2/desc: No such file or directory
* linux515
resolving dependencies...
Packages (1) clang-15.0.7-2
Total Installed Size: 194.90 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [####################################] 100%
(1/1) checking package integrity [####################################] 100%
(1/1) loading package files [####################################] 100%
Optional dependencies for clang
openmp: OpenMP support in clang with -fopenmp
python: for scan-view and git-clang-format [installed]
llvm: referenced by some clang headers [installed]
ldconfig: File /usr/lib/libKF5Kirigami2.so.5.104.0 is empty, not checked.
ldconfig: File /usr/lib/libSDL2-2.0.so is empty, not checked.
ldconfig: File /usr/lib/libpoppler-cpp.so is empty, not checked.
ldconfig: file /usr/lib/libLLVM-15.so is truncated
(1/2) Arming ConditionNeedsUpdate...
(2/2) Refreshing PackageKit...
Error connecting: Could not connect: No such file or directory
error: command failed to execute correctly
warning: python-webencodings-0.5.1-9 is up to date -- reinstalling
warning: python-wheel-0.38.4-1 is up to date -- reinstalling
warning: python-yaml-6.0-1 is up to date -- reinstalling
warning: qca-qt5-2.3.5-2 is up to date -- reinstalling
warning: qrencode-4.1.1-2 is up to date -- reinstalling
warning: qt5-base-5.15.8+kde+r185-1 is up to date -- reinstalling
warning: qt5-declarative-5.15.8+kde+r24-2 is up to date -- reinstalling
warning: qt5-graphicaleffects-5.15.8-1 is up to date -- reinstalling
warning: qt5-imageformats-5.15.8+kde+r9-1 is up to date -- reinstalling
warning: qt5-multimedia-5.15.8+kde+r2-1 is up to date -- reinstalling
warning: qt5-quickcontrols-5.15.8-1 is up to date -- reinstalling
xorg-xdpyinfo-1.3.3-4 xorg-xhost-1.0.9-1 xorg-xinit-1.4.2-1 xorg-xkbcomp-1.4.6-1
xorg-xkill-1.0.6-1 xorg-xmessage-1.0.6-1 xorg-xmodmap-1.0.11-1 xorg-xprop-1.2.6-1
xorg-xrandr-1.5.2-1 xorg-xrdb-1.2.1-1 xorg-xset-1.2.5-1 xorg-xsetroot-1.1.3-1
xorgproto-2022.2-1 xvidcore-1.3.7-2 xxhash-0.8.1-4 xz-5.4.2-1 yakuake-22.12.3-1
zbar-0.23.90-1 zeromq-4.3.4-2 zimg-3.0.4-1 zlib-1:1.2.13-2 zsh-5.9-3
zsh-autosuggestions-0.7.0-1 zsh-completions-0.34.0-3 zsh-history-substring-search-1.0.2-1
zsh-syntax-highlighting-0.7.1-1 zsh-theme-powerlevel10k-1.17.0-1 zstd-1.5.4-1
zvbi-0.2.41-1 zxing-cpp-2.0.0-2
Total Download Size: 147.92 MiB
Total Installed Size: 9019.90 MiB
Net Upgrade Size: 400.06 MiB
:: Retrieving packages...
adobe-source-han-sans-cn-fonts-2.004-1-any.pkg.tar.zst failed to download
Total ( 1/267) 147.9 MiB 4.01 GiB/s 00:00 [####################################] 100%
error: failed retrieving file 'adobe-source-han-sans-cn-fonts-2.004-1-any.pkg.tar.zst' from mnvoip.mm.fcix.net : Could not resolve host: mnvoip.mm.fcix.net
warning: too many errors from mnvoip.mm.fcix.net, skipping for the remainder of this transaction
error: failed retrieving file 'adobe-source-han-sans-cn-fonts-2.004-1-any.pkg.tar.zst' from download.nus.edu.sg : Could not resolve host: download.nus.edu.sg
warning: too many errors from mirror.aarnet.edu.au, skipping for the remainder of this transaction
error: failed retrieving file 'adobe-source-han-sans-cn-fonts-2.004-1-any.pkg.tar.zst' from mirror.kamtv.ru : Could not resolve host: mirror.kamtv.ru
warning: too many errors from mirror.kamtv.ru, skipping for the remainder of this transaction
warning: failed to retrieve some files
error: failed to commit transaction (invalid url for server)
I noticed that my laptop speaker isn’t functioning again and also the microphone . This was before the OS crash though. Nothing is wrong with the speaker. I don’t really know what caused it, Can you help me with that?
no, you do it back from your system, no need to boot into live usb…
and for audio, try with different kernel, if you are running 5.15 try with the 6.1, and the 6.2…
