ldconfig: File /usr/lib/libOpenEXR-3_1.so.30.6.1 is empty, not checked.
ldconfig: File /usr/lib/libOpenEXRUtil-3_1.so.30.6.1 is empty, not checked.
ldconfig: File /usr/lib/libIex-3_1.so.30.6.1 is empty, not checked.
ldconfig: File /usr/lib/libIlmThread-3_1.so.30.6.1 is empty, not checked.
ldconfig: File /usr/lib/libOpenEXRCore-3_1.so.30.6.1 is empty, not checked.
What should I do?
its from this package: openexr
… and the overwrite command from above should get rid of this issue, unless the package is installed from aur, so post formatted output from:
pacman -Qm
Hi. This is the output
ceph-libs 15.2.17-1
electron18 18.3.15-4
manjaro-documentation-en 20181009-1
manjaro-firmware 20160419-1
noto-fonts-compat 20151217-1
python-pep517 0.13.0-1
yay-git 11.2.0.r7.g6f60892-1
you can remove these:
sudo pacman -R ceph-libs manjaro-documentation-en manjaro-firmware noto-fonts-compat python-pep517
then reinstall this:
sudo pacman -S openexr --overwrite '*'
then check again with:
sudo ldconfig
and it should be empty…
I have done it but It’s not gone
This is the output again
looks like those are old libraries, post output from:
pacman -Qs openexr
local/openexr 3.1.7-1
A high dynamic-range image file format library
so remove them:
sudo rm /usr/lib/libOpenEXR-3_1.so.30.6.1
sudo rm /usr/lib/libOpenEXRUtil-3_1.so.30.6.1
sudo rm /usr/lib/libIex-3_1.so.30.6.1
sudo rm /usr/lib/libIlmThread-3_1.so.30.6.1
sudo rm /usr/lib/libOpenEXRCore-3_1.so.30.6.1
check again with:
sudo ldconfig
if its empty, reboot and rerun update:
sudo pacman -Syu
any errors?
No errors.
so thats it
This is the current kernel version on my system
Currently running: 5.15.105-1-MANJARO (linux515)
* linux515
this how to install the kernel right
sudo mhwd-kernel -i linux6.1
This is related to the sound & mic issues that i mentioned earlier and you suggested that i upgrade my kernel
you can install them from system settings/kernel, or via command:
sudo mhwd-kernel -i linux61
reboot, and it should automatically boot with the newer kernel, just to be sure, check with:
uname -r
if you are running it…
during the installation… some warnings were logged in the console. I don’t know if i should be worried
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
==> Starting build: '6.1.22-1-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'qla1280'
This is the output for uname -r
5.15.105-1-MANJARO
those warnings are normal…
post output from:
mhwd-kernel -li
and do you have grub menu shown during boot?
* linux515
* linux61
yeah " Welcome to GRUB!"
so reboot, and in the grub menu advanced options, select the kernel 6.1 (not the fallback one), verify again with:
uname -r
and test audio
The audio is still not working.
This is the output of the command uname -r
6.1.22-1-MANJARO
