Failing to connect to a wifi network after update in a fresh Manjaro installation
Yesterday i installed Manjaro on my dad’s laptop’s, the laptop is a MacbookPro 12 (God forgive me for using Apple’s sh*t)
Just after installing Manjaro, everything is working fine and the WiFi is working perfectly.
This is the system info just after installing Manjaro WITHOUT DOING ANY UPDATES
MacBookPro12 system info before update
  Kernel: 6.9.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=51064ded-d89d-44c5-9be0-2bc2280d41cd rw quiet
    cryptdevice=UUID=1113a48c-6761-442c-b27a-743541c16dd0:luks-1113a48c-6761-442c-b27a-743541c16dd0
    root=/dev/mapper/luks-1113a48c-6761-442c-b27a-743541c16dd0 splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A wm: kwin_x11 with: krunner
    dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Laptop System: Apple product: MacBookPro12,1 v: 1.0 serial: <filter>
    Chassis: type: 9 v: Mac-E43C1C25D4880AD6 serial: <filter>
  Mobo: Apple model: Mac-E43C1C25D4880AD6 v: MacBookPro12,1 serial: <filter>
    uuid: 500fe0d5-9f10-52a4-b2b2-a3cbb397611f UEFI: Apple
    v: MBP121.88Z.0177.B00.1806051659 date: 06/05/2018
  ID-1: BAT0 charge: 45.6 Wh (76.6%) condition: 59.5/74.8 Wh (79.6%)
    volts: 12.8 min: 11.4 model: DP bq20z451 type: Li-ion serial: N/A
    status: charging cycles: 466
  Info: model: Intel Core i5-5257U socket: BGA1168 (U3E1) note: check bits: 64
    type: MT MCP arch: Broadwell gen: core 5 level: v3 note: check
    built: 2015-18 process: Intel 14nm family: 6 model-id: 0x3D (61)
    stepping: 4 microcode: 0x2F
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 800 min/max: 500/3100 base/boost: 3100/2700 scaling:
    driver: intel_cpufreq governor: schedutil volts: 1.0 V ext-clock: 25 MHz
    cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 21611
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Intel Iris Graphics 6100 vendor: Apple driver: i915 v: kernel
    arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
    empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:162b
    class-ID: 0300
  Display: unspecified server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
    s-diag: 798mm (31.43") monitors: <missing: xrandr>
  Monitor-1: eDP-1 model: Apple Color LCD built: 2014 res: 2560x1600
    dpi: 227 gamma: 1.2 size: 286x179mm (11.26x7.05") diag: 337mm (13.3")
    ratio: 16:10 modes: 2560x1600
    device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.3-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Graphics 6100 (BDW
    GT3) device-ID: 8086:162b memory: 3.74 GiB unified: yes
  API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu
    name: Intel Iris Graphics 6100 (BDW GT3) driver: mesa intel
    v: 24.1.3-manjaro1.1 device-ID: 8086:162b surfaces: xcb,xlib
  Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
    class-ID: 0403
  Device-3: Broadcom 720p FaceTime HD Camera driver: N/A pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:1570 class-ID: 0480
  API: ALSA v: k6.9.10-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.1 status: n/a (root, process) with:
  Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
    driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 03:00.0 chip-ID: 14e4:43ba class-ID: 0280
  Device-1: Apple Bluetooth Host Controller driver: btusb,hid-generic,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2
    chip-ID: 05ac:8290 class-ID: fe01
  Local Storage: total: 233.76 GiB used: 12.25 GiB (5.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0256G
    size: 233.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: SA0Q scheme: GPT
  ID-1: / raw-size: 233.46 GiB size: 228.74 GiB (97.98%)
    used: 12.25 GiB (5.4%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
    maj-min: 254:0 mapped: luks-1113a48c-6761-442c-b27a-743541c16dd0
    used: 448 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
  System Temperatures: cpu: 71.0 C pch: 66.5 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 8 GiB available: 7.66 GiB used: 2.49 GiB (32.5%) igpu: 64 MiB
  Processes: 213 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.05 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: pm: pacman pkgs: 1197 libs: 355 tools: pamac pm: flatpak pkgs: 0
    Compilers: N/A Shell: Sudo (sudo) v: 1.9.15p5 default: Bash v: 5.2.26
    running-in: konsole inxi: 3.3.35
Then i updated the system (500+MB of updates) and restarted. I mean here the updates you install after setting up a fresh Manjaro copy. Now the WiFi is working and the networks are visible, but i cannot connect to my home network. These updates did something wrong.
MacBookPro12 system info after update
  Kernel: 6.9.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    udev.log_priority=3
  ID-1: BAT0 charge: 39.6 Wh (66.8%) condition: 59.3/74.8 Wh (79.4%)
    volts: 11.2 min: 11.4 model: DP bq20z451 type: Li-ion serial: N/A
    status: discharging cycles: 466
  Speed (MHz): avg: 2701 high: 2704 min/max: 500/3100 base/boost: 3100/2700
    scaling: driver: intel_cpufreq governor: schedutil volts: 1.0 V
    ext-clock: 25 MHz cores: 1: 2700 2: 2700 3: 2704 4: 2701 bogomips: 21606
    vulnerable
    affected
    class-ID: 0300
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.5-manjaro1.1
    v: 24.1.5-manjaro1.1 device-ID: 8086:162b surfaces: xcb,xlib
    class-ID: 0403
  API: ALSA v: k6.9.12-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.2 status: n/a (root, process) with:
  IF: wlp3s0 state: down mac: <filter>
  Local Storage: total: 233.76 GiB used: 12.82 GiB (5.5%)
    used: 12.82 GiB (5.6%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
  System Temperatures: cpu: 85.0 C pch: 77.5 C mobo: N/A
  Memory: total: 8 GiB available: 7.66 GiB used: 1.6 GiB (20.8%) igpu: 64 MiB
  Processes: 200 Power: uptime: 2m states: freeze,mem,disk suspend: deep
    tool: systemctl
  Packages: pm: pacman pkgs: 1198 libs: 355 tools: pamac pm: flatpak pkgs: 0
To recap
Before updates: WiFi working and i can connect to my home network and the internet working correctly
After updates: WiFi working but i cannot connect to my home network although i can see all the routers around me. It keeps telling me “network deactivated” after trying to connect for a while.
Maybe something is wrong with the updated WiFi driver if it was ever updated.
There are several topics about similar mac/broadcom wifi cards, see if something helps. Probably the b43 firmware would be the first to test, or broadcom-wl
I tried several solutions before writing this post but none worked, will do my best again.
Hi did you find any solution? I have the same problem.
Work fine first installation then update and wifi don’t connect.
Nope, didn’t find a solution, i am using an external wifi adapter on the laptop.
