MacBook Pro (2011) "No WiFi Adapter Found"
Finally, after trying various Linux-distributions that did not run on this MacBook (Ubuntu, Linux Mint an Fedora) Manjaro did the trick. However, the WiFi-adapter is not found. These are the network adapters (wired internet works just fine):
  Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
    v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
    chip-ID: 14e4:16b4
  IF: enp2s0f0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Broadcom BCM4331 802.11a/b/g/n driver: N/A pcie: speed: 2.5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 14e4:4331
I installed the broadcom-wl-dkms package, that I hoped would solve these issues (according to …some… other source). But still no luck. Thanks for any help resolving this, and thanks for making a distribution that works (so far) on an old MacBook. I’ve tried a couple of other distros that didn’t work.
First install the b43-firmware package from the AUR, then reboot, this should get it to work even without the dkms pkg you installed.
Also see 2009 macbook pro install fail - #4 by cscs and the linked B43 driver seems to be installed, but no place to check "enable wifi" in new install? - #43 by 6x12 or check other threads about Mac’s broadcom issues:
Search results for 'b43 @6x12' - Manjaro Linux Forum
please post the full output of the mandatory
without knowing what model etc… it’s just digging in the dark
Thanks for the help. I tried installing the package using the instructions here:
(can’t include links in my posts, it says, reformatting a bit)
wiki. manjaro. org/ index.php / Arch_User_Repository
This is what I get:
pamac search -a b43-firmware         ✔  12s 
** Message: 10:26:56.053: aur_plugin.vala:317: downloading AUR data
Failed to read AUR data from /var/tmp/pamac/packages-meta-ext-v1.json.gz : Error opening file /var/tmp/pamac/packages-meta-ext-v1.json.gz: No such file or directory
Here is the output:
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
    chip-ID: 14e4:16b4 class-ID: 0200
  Device-2: Broadcom BCM4331 802.11a/b/g/n driver: N/A modules: bcma pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 14e4:4331
    class-ID: 0280
You need to enable AUR support in pamac-manager GUI first:
Open “Add/Remove software” >> click the 3 dots >> pick ‘Preferences’ >> pick ‘Third Party’ tab >> Enable AUR support.
Then open “Add/Remove software”, search for b43-firmware, hit install.
Sorry for not reading everything beforehand. I’m getting tired of this trying-to-run-linux-on-a-mac. I think I’ve been trying this for about 10-12 hours now.
I got this working now. I had to uninstall the broadcom-wl-dkms-package (can’t remember exactly why I installed it in the first place) to make it work.
Thanks for the help. This MacBook seems to work like a charm running Manjaro now.
https://wiki.archlinux.org/title/MacBookPro8,x
Lots of useful info there if you run into any further problems.
[quote=“MrLavender, post:8, topic:146683, full:true”]
[/quote]Thanks for the link. :+1:
