As mentioned I’m getting this error during shutdown process. As I need to clone my system with all apps and updates installed I’m trying to get it as perfect as I can.
Is this issue solvable? I have systemd 246
Seems like I’m dealing with an unresolved issue
Yep. Just ignore it until it gets resolved and go ahead and clone…
Also, I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (I just want to avoid even more subjective opinions being posted and confusing you even more)
P.S. In the future, please mark a solution like this:
