I did manage to boot into LIVE image and use chroot
. Here are requested outputs. Once I invoked chroot
and root into the local system, the inxi
didnāt seem to give me much information about a system a computer, so I provided an additional output when inxi
was invoked on a LIVE image
journalctl --boot=-1 --priority=3 --catalog --no-pager
Jul 01 18:51:33 macbookpro kernel: usb 1-4: unable to read config index 0 descriptor/all
Jul 01 18:51:33 macbookpro kernel: usb 1-4: can't read configurations, error -110
Jul 01 18:51:59 macbookpro bluetoothd[1278]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Unknown Command (0x01)
Jul 01 18:51:59 macbookpro bluetoothd[1278]: Failed to set mode: Blocked through rfkill (0x12)
Jul 01 18:52:07 macbookpro wpa_supplicant[1371]: bgscan simple: Failed to enable signal strength monitoring
Jul 01 19:28:13 macbookpro lightdm[1796]: gkr-pam: unable to locate daemon control file
Jul 02 02:28:04 macbookpro dbus-broker-launch[1274]: Activation request for 'org.bluez' failed.
Jul 02 02:28:04 macbookpro pulseaudio[1965]: org.bluez.BatteryProviderManager1.UnregisterBatteryProvider() Failed: org.freedesktop.DBus.Error.NameHasNoOwner:Could not activate remote peer 'org.bluez': activation request failed: unit is invalid
Jul 02 02:28:06 macbookpro systemd-coredump[5547]: Failed to send coredump datagram: Connection refused
Jul 02 02:28:09 macbookpro kernel: nouveau 0000:02:00.0: fb: trapped read at 004012f800 on channel 2 [1fa1a000 Xorg[1394]] engine 05 [PFIFO] client 08 [PFIFO_READ] subclient 01 [SEMAPHORE] reason 00000000 [PT_NOT_PRESENT]
Jul 02 02:28:10 macbookpro kernel: nouveau 0000:02:00.0: fb: trapped read at 004012f800 on channel 2 [1fa1a000 Xorg[1394]] engine 05 [PFIFO] client 08 [PFIFO_READ] subclient 01 [SEMAPHORE] reason 00000000 [PT_NOT_PRESENT]
Jul 02 02:28:11 macbookpro kernel: nouveau 0000:02:00.0: gr: TRAP_CCACHE 00000001 [FAULT]
Jul 02 02:28:11 macbookpro kernel: nouveau 0000:02:00.0: gr: TRAP_CCACHE 00000080 00000000 00000000 00000000 00000000 00000004 00000000
Jul 02 02:28:11 macbookpro kernel: nouveau 0000:02:00.0: gr: 00200000 [] ch 2 [001fa1a000 Xorg[1394]] subc 3 class 8297 mthd 0f04 data 00000000
Jul 02 02:28:11 macbookpro kernel: nouveau 0000:02:00.0: fb: trapped read at 0020200000 on channel 2 [1fa1a000 Xorg[1394]] engine 00 [PGRAPH] client 05 [CCACHE] subclient 00 [CB] reason 00000000 [PT_NOT_PRESENT]
Jul 02 02:28:22 macbookpro dbus-broker-launch[1274]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Jul 02 02:28:23 macbookpro dbus-broker-launch[1274]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
inxi --admin --verbosity=8 --filter -no-host --width
run from a terminal without chroot
Host: manjaro Kernel: 6.9.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 14.1.1 clocksource: hpet avail: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
lang=en_US keytable=gb tz=UTC lang=en_GB keytable=gb tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2405 quiet
systemd.show_status=1 splash apparmor=1 security=apparmor driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 rdinit=/vtoy/vtoy
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver dm: LightDM v: 1.32.0
Type: Laptop System: Apple product: MacBookPro5,3 v: 1.0 serial: <filter>
Chassis: type: 10 v: Mac-F22587C8 serial: <filter>
Mobo: Apple model: Mac-F22587C8 serial: N/A
uuid: 56f03bfc-b24b-6c41-ab17-3a23a64f790e UEFI: Apple
v: MBP53.88Z.00AC.B03.0906151647 date: 06/15/09
ID-1: BAT0 charge: 37.9 Wh (97.9%) condition: 38.7/70.9 Wh (54.7%)
volts: 12.3 min: 10.9 model: SMP bq20z451 type: Li-ion serial: N/A
status: full cycles: 680
System RAM: total: 4 GiB available: 3.57 GiB used: 1.19 GiB (33.3%)
Array-1: capacity: 32 GiB note: check slots: 2 modules: 2 EC: None
Device-1: DIMM0 type: DDR3 detail: synchronous size: 2 GiB speed: 1067 MT/s
volts: N/A width (bits): data: 65506 total: N/A manufacturer: 0x802C
part-no: 0x31364A53463235363634485A2D3147314631 serial: <filter>
Device-2: DIMM0 type: DDR3 detail: synchronous size: 2 GiB speed: 1067 MT/s
Slot: 3 type: PCIe status: available length: short volts: 3.3 bus-ID: N/A
Info: model: Intel Core2 Duo T9600 socket: U2E1 bits: 64 type: MCP SMP
arch: Penryn level: v1 built: 2008 process: Intel 45nm family: 6
model-id: 0x17 (23) stepping: 0xA (10) microcode: 0xA0B
Topology: cpus: 1x cores: 2 smt: <unsupported> cache:
L1: 2x 128 KiB (256 KiB) desc: d-2x32 KiB; i-2x32 KiB L2: 2x 6 MiB (12 MiB)
desc: 1x6 MiB
Speed (MHz): avg: 1596 min/max: 1596/2793 base/boost: 2800/2800 scaling:
driver: acpi-cpufreq governor: schedutil volts: 1.6 V ext-clock: 266 MHz
cores: 1: 1596 2: 1596 bogomips: 11148
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est flexpriority fpu fxsr ht
lahf_lm lm mca mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge
pni pse pse36 pti rep_good sep smx sse sse2 sse4_1 ssse3 syscall tm tm2
tpr_shadow tsc vme vmx vnmi vpid xsave xtpr
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT disabled
Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
Device-1: NVIDIA G96CM [GeForce 9600M GT] vendor: Apple driver: nouveau
v: kernel non-free: series: 340.xx status: legacy (EOL~2019-12-xx) last:
release: 340.108 kernel: 5.4 xorg: 1.20 arch: Tesla process: 40-80nm
built: 2006-2013 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 ports:
active: LVDS-1 empty: DP-1 bus-ID: 02:00.0 chip-ID: 10de:0647
class-ID: 0300 temp: 58.0 C
Device-2: NVIDIA C79 [GeForce 9400M] vendor: Apple driver: nouveau
built: 2006-2013 ports: active: none off: LVDS-2 empty: none
bus-ID: 03:00.0 chip-ID: 10de:0863 class-ID: 0300 temp: 58.0 C
Device-3: Apple Built-in iSight driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 05ac:8507
Display: x11 server: X.org v: 1.21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,vesa dri: nouveau gpu: nouveau
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1440x900 s-size: <missing: xdpyinfo>
Monitor-1: LVDS-1 pos: primary model: Apple Color LCD built: 2009
res: 1440x900 hz: 60 dpi: 111 gamma: 1.2 chroma: red: x: 0.639 y: 0.329
green: x: 0.310 y: 0.612 blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
size: 331x207mm (13.03x8.15") diag: 390mm (15.4") ratio: 16:10
modes: 1440x900, 1152x864, 1024x768, 800x600, 640x480, 720x400, 640x400,
640x350
EDID-Warnings: 1: parse_edid: unknown flag 1
Monitor-2: LVDS-1 mapped: LVDS-1-2 model: Apple Color LCD built: 2009
res: 1440x900 dpi: 111 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green:
640x350
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 egl: 1.4
drv: nouveau device: 1 egl: 1.4 drv: nouveau device: 2 drv: swrast gbm:
egl: 1.4 drv: nouveau surfaceless: egl: 1.4 drv: nouveau x11: egl: 1.4
drv: nouveau inactive: wayland
API: OpenGL v: 4.5 compat-v: 3.3 vendor: mesa v: 24.1.3-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: NV96 device-ID: 10de:0647
memory: 494.1 MiB unified: no
Device-1: NVIDIA MCP79 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 00:08.0 chip-ID: 10de:0ac0 class-ID: 0403
API: ALSA v: k6.9.10-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.1 status: n/a (root, process) with:
Device-1: NVIDIA MCP79 Ethernet driver: forcedeth v: kernel port: 31e0
bus-ID: 00:0a.0 chip-ID: 10de:0ab0 class-ID: 0200
IF: enp0s10 state: down mac: <filter>
Device-2: Broadcom BCM4322 802.11a/b/g/n Wireless LAN
vendor: Apple AirPort Extreme driver: b43-pci-bridge v: N/A modules: ssb
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14e4:432b
class-ID: 0280
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Device-1: Apple Bluetooth USB Host Controller driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.1:3 chip-ID: 05ac:8217
Local Storage: total: 494.64 GiB used: 165.8 GiB (33.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9500420ASG
family: Momentus 7200.4 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 2.6 speed: 1.5 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: APM2 temp: 33 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 298d 15h cycles: 14183
Old-Age: g-sense error rate: 1249 Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-2: /dev/sdb maj-min: 8:16 vendor: Corsair model: Voyager Mini 3.0
size: 28.88 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 000A
scheme: GPT
Optical-1: /dev/sr0 vendor: ā ā ā ā ā ā ā ā model: DVD-R UJ-868 rev: KB19
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: /mnt/mac raw-size: 454.29 GiB size: 446.09 GiB (98.19%)
used: 165.8 GiB (37.2%) fs: ext4 block-size: 4096 B dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: d100e4ed-e6c4-4cd0-98c3-aa5b0f9de50d
ID-1: /dev/dm-0 maj-min: 254:0 mapped: ventoy size: 3.3 GiB fs: iso9660
ID-2: /dev/sda1 maj-min: 8:1 size: 400 MiB fs: vfat label: NO_LABEL
uuid: 4E17-119A
ID-3: /dev/sda3 maj-min: 8:3 size: 11.08 GiB fs: swap label: N/A
uuid: 10a3333b-63ed-4157-809b-af8846b9aab1
ID-4: /dev/sdb1 maj-min: 8:17 size: 28.84 GiB fs: exfat label: Ventoy
uuid: 89FB-3BB5
ID-5: /dev/sdb2 maj-min: 8:18 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 83A6-E98E
Hub-1: 1-0:1 info: full speed or root hub ports: 7 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
Device-1: 1-5:2 info: Apple Built-in IR Receiver type: HID
driver: appleir,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 05ac:8242 class-ID: 0300
Device-2: 1-6:3 info: Apple Internal Keyboard/Trackpad (ISO)
type: keyboard,HID,mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 40mA
chip-ID: 05ac:0237 class-ID: 0301
Hub-2: 2-0:1 info: full speed or root hub ports: 5 rev: 1.1
Hub-3: 2-1:2 info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046
Bluetooth) ports: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
chip-ID: 0a5c:4500 class-ID: 0900
Device-1: 2-1.1:3 info: Apple Bluetooth USB Host Controller type: bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 chip-ID: 05ac:8217 class-ID: fe01 serial: <filter>
Hub-4: 3-0:1 info: full speed or root hub ports: 7 rev: 2.0
Device-1: 3-1:2 info: Corsair Voyager Mini 3.0 type: mass storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 300mA chip-ID: 1b1c:1a0c class-ID: 0806
serial: <filter>
Device-2: 3-4:3 info: Apple Built-in iSight type: video driver: uvcvideo
interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 05ac:8507 class-ID: 0e02 serial: <filter>
Hub-5: 4-0:1 info: full speed or root hub ports: 5 rev: 2.0
Device-1: 4-5:3 info: Apple Internal Memory Card Reader type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 05ac:8403 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 56.0 C mobo: N/A
Fan Speeds (rpm): N/A
GPU: device: nouveau temp: 59.0 C mV: 900.00 device: nouveau temp: 58.0 C
Packages: pm: pacman pkgs: 1162 libs: 332 tools: pamac pm: flatpak pkgs: 0
1: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
2: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
3: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
4: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
5: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
6: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
7: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
8: https://mirror.init7.net/manjaro/stable/$repo/$arch
9: https://muug.ca/mirror/manjaro/stable/$repo/$arch
10: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
11: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
12: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
13: https://mirror.23m.com/manjaro/stable/$repo/$arch
14: https://manjaro.kurdy.org/stable/$repo/$arch
15: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
16: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
17: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
18: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
19: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
20: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
21: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
22: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
23: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
24: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
25: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
26: https://mirror.easyname.at/manjaro/stable/$repo/$arch
27: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
28: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
29: https://repos.silknet.com/manjaro/stable/$repo/$arch
30: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
31: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
32: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
33: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
34: http://manjaro.grena.ge/stable/$repo/$arch
35: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
36: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
37: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
38: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
39: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
40: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
41: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
42: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
43: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
44: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
45: http://manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
46: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
47: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
48: https://mirrors.netix.net/manjaro/stable/$repo/$arch
49: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
50: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
51: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
52: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
53: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
54: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
55: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
56: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
57: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
58: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
59: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
60: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
61: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
62: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
63: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
64: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
65: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
66: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
67: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
68: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
69: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
70: https://mirrors2.manjaro.org/stable/$repo/$arch
71: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
72: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
73: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
74: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
75: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
76: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
77: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
78: https://mirror.dc.uz/manjaro/stable/$repo/$arch
79: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
80: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
81: https://mirrors.manjaro.org/repo/stable/$repo/$arch
82: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
83: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
84: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
85: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
86: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
87: https://manjaro.ynh.ovh/stable/$repo/$arch
88: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
89: http://mirror.fcix.net/manjaro/stable/$repo/$arch
90: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
91: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
92: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
93: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
94: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
95: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
96: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
97: http://manjaro.mirror.ac.za/stable/$repo/$arch
98: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
99: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
100: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
101: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
102: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
103: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
104: https://mirror.zetup.net/manjaro/stable/$repo/$arch
105: https://mirror.seahost.de/manjaro/stable/$repo/$arch
106: https://mirror.funami.tech/manjaro/stable/$repo/$arch
107: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
108: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
109: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
110: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
111: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
112: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
113: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
114: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
115: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
116: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
117: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
118: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
119: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
120: https://mirror.koddos.net/manjaro/stable/$repo/$arch
121: https://linorg.usp.br/manjaro/stable/$repo/$arch
122: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
123: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
124: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
125: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
126: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
127: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
128: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
129: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
130: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
131: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 189
1: cpu: 1.6% command: Xorg pid: 1219 mem: 80.8 MiB (2.2%)
2: cpu: 0.8% command: [kworker/u8:1-loop2] pid: 11 mem: 0.00 MiB (0.0%)
3: cpu: 0.4% command: [kworker/u8:7-events_unbound] pid: 70
4: cpu: 0.3% command: gpg-agent pid: 996 mem: 4.24 MiB (0.1%)
5: cpu: 0.3% command: xfwm4 pid: 1504 mem: 85.1 MiB (2.3%)
Memory top: 5 of 189
1: mem: 85.1 MiB (2.3%) command: xfwm4 pid: 1504 cpu: 0.3%
2: mem: 80.8 MiB (2.2%) command: Xorg pid: 1219 cpu: 1.6%
3: mem: 60.7 MiB (1.6%) command: xfdesktop pid: 1581 cpu: 0.1%
4: mem: 58.2 MiB (1.5%) command: xfce4-session pid: 1433 cpu: 0.0%
5: mem: 57.5 MiB (1.5%) command: nm-applet pid: 1633 cpu: 0.0%
Processes: 189 Power: uptime: 13m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 1.38 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 256 default: graphical tool: systemctl
Compilers: N/A Shell: Bash (su) v: 5.2.26 running-in: xfce4-terminal
inxi: 3.3.35
run after invoking chroot
12System:
12Kernel 6.9.10-1-MANJARO 12arch x86_64 12bits 64 12compiler N/A 12clocksource N/A
12Desktop Xfce 12v Cannot 12tools 12avail light-locker 12dm N/A 12Distro Manjaro
12base Arch Linux
12Machine:
12Message No machine data: try newer kernel. Is dmidecode installed? Try -M
--dmidecode.
12Battery:
12Message No /sys data found.
12Memory:
12System RAM 12total N/A 12available N/A 12used N/A
12RAM Report 12message No RAM data found using udevadm.
12PCI Slots:
12Unknown-error Unknown dmidecode error. Unable to generate data.
I have also a an output from dmesg
if itās important. I didnāt included it because I am not sure if I would share personal info.
thanks
