I’m working on a friend’s machine that’s running Manjaro. He hasn’t done any updates in months so I just did all of the updates. Everything looked like it updated successfully until it finally got to building Google Chrome and it just hung for 30 minutes, so I rebooted.
Upon reboot, there’s a bunch of “[FAILED] Failed to start …” lines and there are so many, the top few have already scrolled off the screen
I cannot CTRL + ALT + F2 or CTRL + ALT + F3
I CAN get to the GRUB menu, but I’m not sure what to do here. If I choose any of the Manjaro options, I just end up back at the “[FAILED] Failed to start…” screen.
That all worked, except for “update-grub” which gave me “command not found”.
I rebooted and I’m right back to the list of “[FAILED] Failed to start…” messages. So now I’m stuck. I’ll take a photo of the screen in a minute and post it here.
Also … it is usually suggested to separate repo and AUR updates.
I dont know what you actually did … but if you held the power button down then that could cause any number of issues depending on what exactly was going on at the time.
Please don’t gratuitously post any images. They take up space in the forum database, they cannot be copied from, and they cannot be indexed.
Your root filesystem is most likely hosed. Boot up from the USB stick, and without mounting your root filesystem, run a full fsck on it. See the man page for options.
Thanks for your suggestion, I’ll try that next. As for the image, I’ve been on this forum for a while and I fully understand that images are worse than text you can actually index and copy/paste. However, I have never seen such a screen before and in this case, I thought a picture was worth 1000 words.
Well, if your filesystem is clean, then it is the files themselves which are damaged. It will be virtually impossible to fix this without reinstalling, which is probably going to be the easiest and quickest solution.
Furthermore, given that this was an unmaintained and un-updated system, its owner will probably be better off running a point-release distribution. Manjaro is high-maintenance, and there’s no way around that.
So, it doesn’t seem like anything is wrong with the disk. But I also didn’t build this machine so I don’t know why Manjaro is on /dev/sda2. Apparently there is no /dev/sda1. Does that matter?
It may have been there in the past, or it could be an unformatted bios_grub partition in case the partition table is GPT but the machine boots in legacy BIOS mode. It either way doesn’t matter.
