I have tried everything I can think of to address this slow internet. It happens on multiple different distros not just Manjaro. I tried Kubuntu, Pop! OS and Manjaro all with the same results, slow internet. My windows 11 partition has no issues so it’s not hardware. I even tried installing the drivers from Intel with no positive result. I knoiw this is an issue with other people with the same hardware so what is it?
*-network:0
description: Wireless interface
product: Tiger Lake PCH CNVi WiFi
vendor: Intel Corporation
physical id: 14.3
bus info: pci@0000:00:14.3
logical name: wlo1
version: 11
serial: b0:3c:dc:6b:d2:67
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=6.6.26-1-MANJARO firmware=77.ad46c98b.0 QuZ-a0-hr-b0-77.u ip=10.0.0.31 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: iomemory:440-43f irq:16 memory:4402124000-4402127fff
*-network:1
description: Ethernet interface
product: Ethernet Connection (14) I219-V
physical id: 1f.6
bus info: pci@0000:00:1f.6
logical name: enp0s31f6
version: 11
serial: c8:7f:54:17:e6:15
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=6.6.26-1-MANJARO duplex=full firmware=0.4-4 ip=10.0.0.135 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:153 memory:a1300000-a131ffff
Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: G10CES v: 1.0 serial:
UEFI: American Megatrends v: G10CES.304 date: 01/18/2024
Info: 6-core model: 11th Gen Intel Core i5-11400F bits: 64 type: MT MCP
arch: Rocket Lake rev: 1 cache: L1: 480 KiB L2: 3 MiB L3: 12 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/4400 cores: 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 801 12: 800
bogomips: 62232
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
driver: nvidia v: 550.67 arch: Ampere pcie: speed: 16 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:2504
Device-2: EMEET HD Webcam C960 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 1-4:3 chip-ID: 328f:006d
Display: server: X.Org v: 21.1.12 with: Xwayland v: 23.2.6
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1080 s-dpi: 94
cscs
23 April 2024 22:05
2
Welcome to manjaro,
How do you know that?
Do you have links to similar bug reports or something?
cmcgale:
slow internet
What do you mean by that?
Webpages load slowly in your browser?
Packages are slow to download/install/update?
Have you used any tools to measure the performance or to find any errors?
To begin it probably makes sense to include system information.
Something like
inxi -Farz
The following guide may also be helpful, including how to format code, etc.
Difficulty: ★☆☆☆☆
Strong of its many members, the Manjaro support forum can provide you help whenever you have an issue with your Manjaro installation. But in order to work efficiently, we shall also ask you to follow three major points.
Provide context
Simply signaling an issue is rarely enough to understand how it occurred. It is thus important to provide details on how it happened:
Detail prior actions leading to the issue.
List solutions and guides you already tried, with links whene…
Thank you for the response. When I mention slow internet I mean download speeds cap at 50Mbps when downloading from steam. When I do a speed test via oracle I get Gig speeds so now I’m starting to think it may be Steam. Here is the info you requested.
[cmcgale@chris-rogstrixg10cesg10ces ~]$ inxi -Farz
root=UUID=50a4a8a6-2011-486f-b62f-b14a5121cb0e rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
serial: uuid:
Info: model: 11th Gen Intel Core i5-11400F bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x5E
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3481 high: 4333 min/max: 800/4400 scaling:
driver: intel_pstate governor: powersave cores: 1: 4277 2: 4219 3: 4312
4: 4117 5: 4299 6: 2224 7: 1548 8: 4163 9: 2161 10: 3582 11: 4333 12: 2540
bogomips: 62232
Type: retbleed mitigation: Enhanced IBRS
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW
loop
driver: nvidia v: 550.67 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 328f:006d
class-ID: 0102 serial:
Display: x11 server: X.Org v: 21.1.12 with: Xwayland v: 23.2.6
screens: 1
Screen-1: 0 s-res: 2560x1080 s-dpi: 94 s-size: 692x292mm (27.24x11.50")
s-diag: 751mm (29.57")
Monitor-1: Unknown-1 mapped: DP-0 res: 2560x1080 dpi: 94
size: 690x291mm (27.17x11.46") modes: 2560x1080
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.67
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 550.67 device-ID: 10de:2504
surfaces: xcb,xlib
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Device-3: EMEET HD Webcam C960 driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.6.26-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
IF: wlo1 state: up mac:
Device-2: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fa class-ID: 0200
IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac:
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 8087:0026
class-ID: e001
Local Storage: total: 1.38 TiB used: 114.49 GiB (8.1%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial:
fw-rev: 111110WD temp: 61.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1002 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 21106000 temp: 34.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 model: BALLY TECHNOLOGIES LICENSING
size: 7.46 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: fw-rev: PMAP
scheme: MBR
ID-1: / raw-size: 472.1 GiB size: 463.62 GiB (98.20%)
used: 114.45 GiB (24.7%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 48.3 MiB (18.9%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:4
System Temperatures: cpu: 65.0 C mobo: N/A gpu: nvidia temp: 38 C
Fan Speeds (rpm): cpu: 700 gpu: nvidia fan: 42%
Packages: 1316 pm: pacman pkgs: 1308 libs: 434 tools: pamac pm: flatpak
pkgs: 8
1: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
2: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
5: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
6: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://muug.ca/mirror/manjaro/stable/$repo/$arch
8: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
9: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
10: http://mirror.fcix.net/manjaro/stable/$repo/$arch
11: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
12: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
13: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
14: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
15: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
16: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
17: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
18: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
19: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
Memory: total: 32 GiB available: 31.19 GiB used: 5.56 GiB (17.8%)
Processes: 328 Power: uptime: 1h 35m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
running-in: konsole inxi: 3.3.34
cscs
23 April 2024 22:51
4
If it is only steam have you tried setting the region?
(image taken from a search-result guide that may contain other general tips like ‘clear steam download cache’ ; https://www.howtogeek.com/900728/is-steams-download-speed-slow-8-ways-to-speed-it-up/ )
I tried changing the download region with no success. I also shut off “Throttles downloads while streaming” with no effect.
Hi @cmcgale and welcome to the Manjaro community.
Just a little housekeeping…
As a new user, please take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit. To that end, some or all these links will be invaluable:
And last, but not least, the Stable Update Announcements , which you should check frequently for important update related information. Occasionally an issue might be directly related to a particular update; it’s always best to check those announcements.
Cheers.
I switched servers on Steam to somewhere in Africa and boom, normal download speed. My apologies for wasting everyone’s time. Thank you soundofthunder, I will be more cognizant about house keeping in the future.
system
Closed
25 April 2024 11:14
8
