Hi,
So recently I’ve been experiencing random shutdowns. This is an issue that has started recently (within the last couple of days). I am not sure what is causing the shutdowns, hence my post here. What happens is that I’ll be playing a game through Steam and the computer will just entirely shut off, causing me to have to turn it on again. This has happened while playing Yakuza: Like A Dragon, and Deep Rock Galactic (using a Dualsense controller - both through wired and bluetooth connections - if that’s relevant; the other games were played with a Switch Pro Controller). It is possible that this is an overheating issue but I’m sceptical for a few reasons. Firstly: it only seems to happen shortly after waking from sleep - I have rebooted and had multi-hour long play sessions with zero issue. If overheating was the issue I’d expect more occurrences while doing that. Secondly: I have played similarly taxing games - Elden Ring, and Yakuza 6 - with zero issue in this regard. If it is an overheating issue however, I’m not sure how I would diagnose this. I have installed psensor but it doesn’t seem to maintain its tracking between boots.
System information
Kernel: 5.15.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=5f3efe5f-831f-4026-b90d-b6217f39312a rw quiet apparmor=1
security=apparmor resume=UUID=efd40c91-0454-4925-9ac4-dcc2a4049aec
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2423
date: 08/10/2021
Device-1: ps-controller-battery-4c:b9:9b:c9:b8:de model: N/A serial: N/A
charge: N/A status: charging
RAM: total: 15.53 GiB used: 5.3 GiB (34.1%)
RAM Report:
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 gen: 4
built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x21 (33)
stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3116 high: 3810 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2870 2: 2866
3: 3622 4: 2871 5: 3590 6: 2870 7: 3587 8: 2864 9: 3810 10: 2922 11: 2868
12: 2874 13: 2907 14: 2873 15: 3594 16: 2871 bogomips: 121423
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Gigabyte driver: nvidia
v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 07:00.0 chip-ID: 10de:2182 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 75 s-size: 650x371mm (25.59x14.61")
s-diag: 748mm (29.47")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 75
size: 649x369mm (25.55x14.53") diag: 747mm (29.39") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 515.57 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 1-7.1:6 chip-ID: 054c:0ce6 pcie:
gen: 3 class-ID: 0300 speed: 8 GT/s lanes: 16 bus-ID: 07:00.1
chip-ID: 10de:1aeb class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Sony DualSense wireless controller (PS5) type: USB
driver: playstation,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.15.55-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0
chip-ID: 8086:15f3 class-ID: 0200
IF: enp6s0 state: down mac: <filter>
driver: playstation,snd-usb-audio,usbhid bus-ID: 1-7.1:6 chip-ID: 054c:0ce6
class-ID: 0300
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-5:2
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
Local Storage: total: 4.9 TiB used: 3.93 TiB (80.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: N/A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: RKT343.4 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10EZEX-00BN5A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM004-2CV104
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5425 serial: <filter> rev: 0001 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Transcend model: TS128GMTS600
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 5B scheme: GPT
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-224DB rev: SB01
dev-links: cdrom
ID-1: / raw-size: 221.02 GiB size: 216.49 GiB (97.95%)
used: 187.13 GiB (86.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 5f3efe5f-831f-4026-b90d-b6217f39312a
label: NO_LABEL uuid: 251A-D8CB
ID-3: /run/media/****/7EC853B9C8536F01 raw-size: 117.57 GiB
size: 117.57 GiB (100.00%) used: 116.19 GiB (98.8%) fs: ntfs dev: /dev/sdc3
maj-min: 8:35 label: N/A uuid: 7EC853B9C8536F01
ID-4: /run/media/****/CA46087746086713 raw-size: 500 MiB
size: 500 MiB (100.00%) used: 452.6 MiB (90.5%) fs: ntfs dev: /dev/sdc4
maj-min: 8:36 label: N/A uuid: CA46087746086713
ID-5: /run/media/****/Hard Disc raw-size: 931.51 GiB
size: 931.51 GiB (100.00%) used: 800.34 GiB (85.9%) fs: ntfs dev: /dev/sda1
maj-min: 8:1 label: Hard Disc uuid: 1802E79302E77462
ID-6: /run/media/****/Hard Disc 2 Electric Boogaloo raw-size: 3.64 TiB
size: 3.64 TiB (100.00%) used: 2.85 TiB (78.3%) fs: ntfs dev: /dev/sdb2
maj-min: 8:18 label: Hard Disc 2 Electric Boogaloo uuid: DC0CC57C0CC55266
ID-1: swap-1 type: partition size: 17.15 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: efd40c91-0454-4925-9ac4-dcc2a4049aec
ID-1: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sdc1 maj-min: 8:33 size: 350 MiB fs: ntfs
label: System Reserved uuid: 68EA5126EA50F1B4
ID-3: /dev/sdc2 maj-min: 8:34 size: 860.1 MiB fs: vfat label: N/A
uuid: 19E7-1960
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-5:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 1-6:3 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:1939 class-ID: 0300 serial: <filter>
Hub-2: 1-7:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-7.1:6 info: Sony DualSense wireless controller (PS5)
type: Audio,HID driver: playstation,snd-usb-audio,usbhid interfaces: 4
rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 054c:0ce6 class-ID: 0300
Device-2: 1-7.4:7 info: Alcor Micro Multi Flash Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
chip-ID: 058f:6366 class-ID: 0806 serial: <filter>
Device-3: 1-9:5 info: SteelSeries ApS Rival 100 Gaming Mouse
type: HID,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 130mA chip-ID: 1038:1702 class-ID: 0301
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-3:2 info: ROCCAT Ryos MK Keyboard type: Keyboard,HID
driver: ryos,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 1e7d:3138 class-ID: 0300
Hub-7: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 48 C
Processes: 380 Uptime: 1h 42m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6
Packages: 1524 pacman: 1498 lib: 437 flatpak: 16 snap: 10 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.19
Any help would be appreciated - like I said, I don’t think it’s an overheating issue but it could be and I don’t want to entirely discount the possibility
