D1Ck3n
2 November 2020 11:23
1
Hi everyone,
this is really strange: i did a reset with timeshift to a yesterday and now i get the following error @ boot:
error: symbol 'grub_calloc' not found.
Entering rescue mode...
i found some stuff online on this topic but most of the time it was for dualboot or other distros. i want to get sure that i dont break my system.
doe anyone have a clue how to fix that?
best regards
Alfy
2 November 2020 12:41
2
if i recall when i had this after a previous update i had to go into my bios/uefi and select Manjaro as the boot option.
I’m not sure why it changed, it may have been to do with the “boot hole” vulnerability patch.
D1Ck3n
5 November 2020 15:02
3
you mean just go into BIOS and change boot order from UEFI to legacy?
Alfy
5 November 2020 20:32
4
no, i just had to reselect the uefi option.
selecting legacy will cause it not to boot.
D1Ck3n
5 November 2020 22:38
5
mhhh that is strange, i switched to UEFI Only but it seems not to work
but i got another Boot option to choose that works:
strange is, i can use it to boot direktly in in but i cant choose it in my boot order
D1Ck3n
9 November 2020 13:45
6
okay, nevermind! i fixed my issue
changed prio to the right one
