Error mount partion
An error occurred while accessing ‘hamo’, the system responded: The requested operation has failed: Error mounting /dev/sdb3 at /run/media/a/hamo: Unknown error when mounting /dev/sdb3
sudo mkdir /mnt/temp
sudo mount -t ntfs3 -o ro /dev/sdb3 /mnt/temp
After running this command it works but the problem is here
  • I have to repeat the command every time I open the system
  • The other problem is that after this, I cannot create folders
sudo mkdir newFolder
mkdir: cannot create directory ‘newFolder’: Read-only file system
Hi @hamo,
That error suggests 1 of 3 things:
  1. Either the disk, or the partition is damaged, in which case, replacing it would be neccessary; or
  2. and I can’t remember #3 just now. It’ll come to me; and
  3. the drive is mounted as read-only, and considering:
… the -o ro in the command, it is most likely that. Try changing the command to:
sudo mount -t ntfs3 -o rw /dev/sdb3 /mnt/temp
However, this:
Should only be necessary for the mount command, not the mkdir command, unless you’re trying to use a live environment, in which case you’re going to have a very bad time, as a live environment isn’t persistent.
So first make sure you’re not trying to use a live environment.
mount: /mnt/temp: wrong fs type, bad option, bad superblock on /dev/sdb3, missing codepage or helper program, or other error.
dmesg(1) may have more information after failed mount system call.
mount: (hint) your fstab has been modified, but systemd still uses
the old version; use ‘systemctl daemon-reload’ to reload.
Hmmm…
I’ve seen many issues with the in-kernel ntfs3 drivers, so let’s try moving to ntfs-3g instead. Install is from the extra repositories:
pamac install ntfs-3g
And then try mounting with the following command:
sudo mount -t ntfs-3g -o rw /dev/sdb3 /mnt/temp
if that didn’t work, please provide the output of:
parted --list
:bangbang: Tip: :bangbang:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Your problem is the system mount folder and permissions - and perhaps the ntfs3 driver specified.
You’re mounting it read-only, so of course you cannot create folders.
Also, don’t use ntfs3 — use ntfs-3g instead.
As for (pseudo-)persistence, please read these two tutorials below… :point_down:
