Hello,
Intro
First of all I’m aware of all the topics that talk about this issue (69108, 43831, 51718, 52490, and 45150), but none of them include a solution to my instance of it.
Config
I have 2 keyboard layouts installed: “English (US)” and “Spanish”, I’ve installed “English (US)” when I installed the system and “Spanish” through “System Settings” => “Keyboard” => “Layouts”.
Issue
Sometimes when I boot up the computer and log in an error message appears reading:
Error activating XKB configuration
There can be various reasons for that.If you report this situation as a bug, include the results of
xprop -root | grep XKB
gsettings get org.gnome.libgnomekbd.keyboard model
gsettings get org.gnome.libgnomekbd.keyboard layouts
gsettings get org.gnome.libgnomekbd.keyboard options
Here’s the result of those commands:
_XKB_RULES_NAMES_BACKUP(STRING) = “evdev”, “”, “us”, “”, “”
_XKB_RULES_NAMES(STRING) = “evdev”, “”, “us”, “”, “”
[‘us’, ‘es’]
[‘grp\tgrp:win_space_toggle’]
If that message does appears:
I would only have the default keyboard layout installed (“English (US)”) under “System Settings” => “Keyboard” => “Layouts”.
The lightdm greeter displays the text “us” next to a keyboard icon:
https://paste.pics/7eb2ccfd8e83c32c04059e83eb062c9b
If the message does not appear: -
I would have both “English (US)” and “Spanish” as installed keyboard layouts.
The lightdm greeter displays the keyboard icon but no text next to it:
https://paste.pics/b8346213db3eae0dc5c0b543dd02a3b9 -
Running
xprop -root | grep XKBnow outputs this:
_XKB_RULES_NAMES_BACKUP(STRING) = “evdev”, “pc105”, “us,es”, “qwerty”, “grp:win_space_toggle”
_XKB_RULES_NAMES(STRING) = “evdev”, “pc105”, “us,es”, “,”, “grp:win_space_toggle”
- All other commands return the same outputs.
Running the following command does fix the issue whenever it happens:
setxkbmap -model pc105 -layout us,es -option grp:win_space_toggle
However I shouldn’t have to manually run a command (or add it to the .bashrc file) for keyboard layouts to work.
Restarting the system does fix the issue sometimes.
I did reinstall the whole system the first time this happen to me, the results were the same (won’t do that again at this point).
I had Manjaro installed on this machine before with the same keyboard layout config and without any issues.
System info
- Desktop: Cinnamon 4.8.6
- Kernel: 5.4.124
Any help or pointers on what could be causing this would be greatly appreciated.
inxi output:
Kernel: 5.4.124-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=df7a105e-6ebc-4a94-bb06-ba9156e9161c rw quiet apparmor=1
security=apparmor resume=UUID=bd9d7dac-f62e-4ec5-bc1d-7a6957726858
udev.log_priority=3
Desktop: Cinnamon 4.8.6 tk: GTK 3.24.29 vt: 7 dm: LightDM 1.30.0
Type: Laptop System: LENOVO product: 20NB001SUS v: ThinkPad E590
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20NB001SUS v: SDK0J40697 WIN serial: <filter>
UEFI: LENOVO v: R0YET36W (1.19 ) date: 10/21/2019
ID-1: BAT0 charge: 23.8 Wh (61.0%) condition: 39.0/45.7 Wh (85.4%)
volts: 12.3 min: 11.1 model: Celxpert 01AV448 type: Li-poly serial: <filter>
status: Charging cycles: 230
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M560
status: Discharging
RAM: total: 15.36 GiB used: 6.77 GiB (44.1%)
Info: Quad Core model: Intel Core i7-8565U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: DE cache: L2: 8 MiB bogomips: 32012
Speed: 829 MHz min/max: 400/4600 MHz Core speeds (MHz): 1: 829 2: 841 3: 900
4: 868 5: 833 6: 890 7: 806 8: 851
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-6:4 chip-ID: 5986:2113 class-ID: 0e02
Display: x11 server: X.Org 1.20.11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.4.124-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
vendor: Lenovo driver: r8168 v: 8.048.03-NAPI modules: r8169 port: 2000
bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: 2000
bus-ID: 05:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
IF-ID-1: br-5c6b28891bc3 state: down mac: <filter>
IF-ID-2: br-73a94807038e state: down mac: <filter>
IF-ID-3: br-799aab51ed78 state: down mac: <filter>
IF-ID-4: docker0 state: down mac: <filter>
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 476.94 GiB used: 281.52 GiB (59.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 rotation: SSD serial: <filter> rev: 0108ADLA scheme: GPT
ID-1: / raw-size: 459.75 GiB size: 451.53 GiB (98.21%)
used: 281.52 GiB (62.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: df7a105e-6ebc-4a94-bb06-ba9156e9161c
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 4879-6B7A
ID-1: swap-1 type: partition size: 16.89 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: bd9d7dac-f62e-4ec5-bc1d-7a6957726858
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-6:4 info: Acer SunplusIT Integrated Camera type: Video
Device-3: 1-8:5 info: Synaptics Metallica MOH Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 06cb:00a2 class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 45.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 3300
Processes: 289 Uptime: 2h 04m wakeups: 8 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1475 lib: 474
flatpak: 0 Shell: Bash v: 5.1.8 running-in: gnome-terminal inxi: 3.3.04
Thank you for your time ![]()
