Everything that has happened in this older post is happening to me right now:
The checkbox to enable wifi and airplane mode from the network tab completely disappeared for me in kde. I upgraded kernel from 5.10 to 5.11 but that didn’t fix the issue.
The last time I used the wifi - I turned it off and then tried turning it on after about 10 seconds, which caused the UI to freeze for a few seconds and the wifi showed some error notification “Wireless Interface - The wifi network could not be found” (I think this was the error but I cant remember for certain). I was unable…
However, the solution that this user has found is not working for me, since my Acer Swift SF514-54T doesnt have the BIOS option to enable/disable wireless, so I’m at a loss.
Please help if there’s anything you know about this issue. Thank you all
Olli
May 7, 2023, 12:36pm
2
what’s the actual status ? a new update for stable has been released today, are you on stable and already updated ?
please post the basic infos of
inxi --admin --verbosity=7 --filter --width
use the option of preformatted text and paste the infos inside it
sadly I cant copy and paste because I cant connect to the internet at all on my laptop, but my Kernel is
Kernel: 5.15.94-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
my desktop is:
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8
If you need any other info, please lmk.
That system has obviously not been updated in a long time. We’ve been on Plasma 5.27.4 for a month now — from the 2023-04-11 update on, to be precise.
You’ll have to use a chroot
from the live USB to update your system. Manjaro is a (curated) rolling-release distro and you are supposed to keep it updated. You cannot expect us to offer support for an outdated installation.
Olli
May 7, 2023, 1:18pm
7
do you have access via a wired ethernet? you’ll need it to download a actual live-iso and either chroot your system and update it afterwards or do a new install.
as @Aragorn explained if you don’t update a rolling release regulary and the system is too long outdated you’ll run in pitty problems
even after a fresh install of the latest manjaro update provided by the website, the problem still remains, no WiFi or Airplane mode.
I’m at a loss, I have no clue what could be causing this at all, system is now fully up-to-date.
Olli
May 7, 2023, 2:15pm
9
okay if your up-to-date we can look further. please provide the full output of the command below that we can see what hardware is running
here you go:
Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=e73f02d1-cf79-4dba-ac9e-e5c77a165935 rw quiet splash
resume=UUID=8d5b43b4-4259-4e56-b8a0-56298d848b61 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Swift SF514-54T v: V1.21
Mobo: IL model: Yebisu_IL v: V1.21 serial: <superuser required>
UEFI: Insyde v: 1.21 date: 01/18/2021
ID-1: BAT0 charge: 33.5 Wh (100.0%) condition: 33.5/56.0 Wh (59.9%)
volts: 16.2 min: 15.4 model: SMP KT00407008 AP18C7M type: Li-ion
serial: <filter> status: full cycles: 389
RAM: total: 7.45 GiB used: 1.21 GiB (16.2%)
Info: model: Intel Core i5-1035G1 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xB8
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 1208 high: 1268 min/max: 400/3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 1200 2: 1200 3: 1200
4: 1200 5: 1200 6: 1200 7: 1268 8: 1200 bogomips: 19048
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep sgx sgx_lc sha_ni smap smep split_lock_detect ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
driver: i915 v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56
class-ID: 0300
Device-2: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 3-6:3
chip-ID: 04f2:b5c5 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: AU Optronics 0x253d built: 2018 res: 1920x1080
dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel UHD Graphics (ICL GT1)
direct-render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
driver: sof-audio-pci-intel-icl
alternate: snd_hda_intel,snd_sof_pci_intel_icl bus-ID: 00:1f.3
chip-ID: 8086:34c8 class-ID: 0401
API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-10:5
chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 238.47 GiB used: 8.48 GiB (3.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
model: RBUSNS8154P3256GJ1 size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: E8FK12.3 temp: 24.9 C scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 224.71 GiB (97.97%) used: 8.48 GiB (3.8%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: e73f02d1-cf79-4dba-ac9e-e5c77a165935
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: B7D2-F135
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 8d5b43b4-4259-4e56-b8a0-56298d848b61
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-5:2 info: LighTuning EgisTec Touch Fingerprint Sensor
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 1c7a:0570 class-ID: 0000 serial: <filter>
Device-2: 3-6:3 info: Chicony HD WebCam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b5c5
Device-3: 3-9:4 info: Raydium Touch System type: HID
driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 96mA chip-ID: 2386:433b class-ID: 0300
Device-4: 3-10:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 47.0 C mobo: N/A
Processes: 281 Uptime: 13m wakeups: 117 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1155 libs: 350 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
that is absolutely everything that came out of the command, lmk if you need anything else
Olli
May 7, 2023, 2:31pm
11
yes, there is still this error message
please post the output of the following command
nmcli device wifi list
is your router in the list ?
nothing was output with that command. Could the system be completely void of any driver regarding wifi?
Olli
May 7, 2023, 2:36pm
13
rfkill
ID TYPE DEVICE SOFT HARD
0 bluetooth hci0 unblocked unblocked
Olli
May 7, 2023, 2:43pm
15
what’s the output of
systemctl status NetworkManager.service
and
ip link show
for sytemctl:
● NetworkManager.service - Network Manager
Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; preset: disabled)
Active: active (running) since Sun 2023-05-07 22:08:08 AWST; 38min ago
Docs: man:NetworkManager(8)
Main PID: 467 (NetworkManager)
Tasks: 4 (limit: 9116)
Memory: 14.8M
CPU: 100ms
CGroup: /system.slice/NetworkManager.service
└─467 /usr/bin/NetworkManager --no-daemon
May 07 22:08:12 schlime9k-swiftsf51454t NetworkManager[467]: <info> [1683468492.4278] modem-manager: ModemManager available
May 07 22:08:12 schlime9k-swiftsf51454t NetworkManager[467]: <info> [1683468492.4285] device (lo): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
May 07 22:08:12 schlime9k-swiftsf51454t NetworkManager[467]: <info> [1683468492.4286] device (lo): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
May 07 22:08:12 schlime9k-swiftsf51454t NetworkManager[467]: <info> [1683468492.4288] device (lo): Activation: successful, device activated.
May 07 22:08:12 schlime9k-swiftsf51454t NetworkManager[467]: <info> [1683468492.4290] manager: startup complete
May 07 22:08:34 schlime9k-swiftsf51454t NetworkManager[467]: <info> [1683468514.7063] agent-manager: agent[b375806a477dad31,:1.34/org.kde.plasma.networkmanagement/1000]: agent registered
May 07 22:11:57 schlime9k-swiftsf51454t NetworkManager[467]: <info> [1683468717.2502] manager: sleep: sleep requested (sleeping: no enabled: yes)
May 07 22:11:57 schlime9k-swiftsf51454t NetworkManager[467]: <info> [1683468717.2503] manager: NetworkManager state is now ASLEEP
May 07 22:20:56 schlime9k-swiftsf51454t NetworkManager[467]: <info> [1683469256.5267] manager: sleep: wake requested (sleeping: yes enabled: yes)
May 07 22:20:56 schlime9k-swiftsf51454t NetworkManager[467]: <info> [1683469256.5268] manager: NetworkManager state is now DISCONNECTED
and for the ip link show:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
Olli
May 7, 2023, 3:06pm
18
well your wifi-hardware is not physical detected. please check the following first:
1.) a lot of laptops do have a physical switch to turn wifi on/off. please check if there is one existing and it is turned on.
2.) other laptops do have a function-key combination to turn on/off wifi. please check this also. maybe you need to take a look to the manual of your laptop to find this.
my laptop does have a FN combo however it does nothing, tested the commands you gave me witht the combo pressed and its the same results.
this might be because the actual wifi reciever is damaged in some way, but i doubt that, this laptop is in pretty good condition despit being a couple years old
Olli
May 7, 2023, 3:31pm
21
another pitty might be the firmware. try
sudo pacman -S linux-firmware
reboot and check if there are changes
apparently database file for core, extra, community, multilib doesnt exist, and “linux-firmware” isn’t found…
