I have an Aspire A715-72G, latest BIOS running Manjaro GNOME with kernel 5.16.5-1. GNOME did something strange where it wouldn’t boot into the desktop, so I had to reinstall Manjaro. Since that happened, my trackpad will not work. Checked the trackpad setting in GNOME and its’ turned on. I went into BIOS and set the trackpad setting from “advanced” to “basic” but that didn’t solve the problem. The trackpad shows up under libinput, but does not function.
I tried booting into Manjaro using a USB stick and the trackpad still does not work. It was working fine a few days ago, before GNOME wouldn’t boot. Not sure what to do. Any help would be greatly appreciated.
inxi:
Host: nick-aspirea71572g Kernel: 5.16.5-1-MANJARO x86_64 bits: 64
compiler: gcc v: 11.1.0 parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=d0e669e0-ea5c-4eb7-9cbf-3308ee357b46 rw quiet splash apparmor=1
security=apparmor resume=UUID=f825f695-933e-4827-b4bc-a49116c71ba6
udev.log_priority=3
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: Acer product: Aspire A715-72G v: V1.26
serial: <superuser required>
Mobo: CFL model: Charmeleon_CFS v: V1.26 serial: <superuser required>
UEFI: Insyde v: 1.26 date: 03/27/2019
ID-1: BAT1 charge: 43.9 Wh (100.0%) condition: 43.9/48.9 Wh (89.6%)
volts: 17.0 min: 15.2 model: LG PABAS0241231 type: Li-ion serial: 41167
status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
serial: 4051-32-e7-8c-6c charge: 55% (should be ignored) rechargeable: yes
status: Discharging
RAM: total: 7.61 GiB used: 2.68 GiB (35.2%)
RAM Report:
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 800 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 52815
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36
pti pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630]
vendor: Acer Incorporated ALI driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 510.47.03
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c8c
class-ID: 0300
Device-3: Quanta HD Webcam type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:a060 class-ID: 0e02 serial: 200901010001
Display: x11 server: X.org 1.21.1.3 compositor: gnome-shell driver:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.16.5-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: no
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 06:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0f1 state: down mac: 98:28:a6:28:d5:93
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel bus-ID: 07:00.0
chip-ID: 168c:003e class-ID: 0280
IF: wlp7s0 state: up mac: 00:f4:8d:89:e4:e5
IP v4: 10.201.105.253/24 type: dynamic noprefixroute scope: global
broadcast: 10.201.105.255
IP v6: fe80::360a:fec0:346f:fb16/64 type: noprefixroute scope: link
WAN IP: 172.85.116.2
Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-14:5
chip-ID: 04ca:3016 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 119.24 GiB used: 14.46 GiB (12.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: HFS128G39TND-N210A
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: EJ89N72401030A330 rev: 1P10 scheme: GPT
ID-1: / raw-size: 110.15 GiB size: 107.86 GiB (97.92%)
used: 14.46 GiB (13.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: d0e669e0-ea5c-4eb7-9cbf-3308ee357b46
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 2130-A303
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: f825f695-933e-4827-b4bc-a49116c71ba6
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-4:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-5:3 info: Quanta HD Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0408:a060
Device-3: 1-8:4 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04f3:0c03 class-ID: 0000
Device-4: 1-14:5 info: Lite-On type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 04ca:3016
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 41.0 C pch: 50.0 C mobo: N/A
Packages: pacman: 1207 lib: 335 flatpak: 0
1: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
2: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
3: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 305
1: cpu: 16.4% command: librewolf pid: 1730 mem: 501.7 MiB (6.4%)
2: cpu: 5.0% command: librewolf pid: 2207 mem: 238.1 MiB (3.0%)
3: cpu: 4.8% command: nautilus pid: 3375 mem: 87.9 MiB (1.1%)
4: cpu: 3.9% command: xorg pid: 725 mem: 152.5 MiB (1.9%)
5: cpu: 3.7% command: gnome-shell pid: 835 mem: 288.0 MiB (3.6%)
Memory top: 5 of 305
1: mem: 501.7 MiB (6.4%) command: librewolf pid: 1730 cpu: 16.4%
2: mem: 288.0 MiB (3.6%) command: gnome-shell pid: 835 cpu: 3.7%
3: mem: 238.1 MiB (3.0%) command: librewolf pid: 2207 cpu: 5.0%
4: mem: 208.4 MiB (2.6%) command: librewolf pid: 2489 cpu: 0.3%
5: mem: 193.4 MiB (2.4%) command: librewolf pid: 2011 cpu: 1.2%
Processes: 305 Uptime: 44m wakeups: 5 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 Shell: Zsh v: 5.8 running-in: gnome-terminal
inxi: 3.3.12
