Hello, I just got a new ASUS MB169B+ monitor and I am wondering why night color is only on on my laptop display. Also how to do I add a application menu bar panel to the external monitor when every time i try to add it, the panel automatically goes to my laptop monitor and I can’t move it.
Update: I figured out how to move the panel to the external monitor by right clicking it editing it, and dragging “Screen Edge”. Still have the Night Color problem though.
Welcome to Manjaro!
Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… -
An
inxi --admin --verbosity=7 --filter --no-host --widthwould be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command) -
The output to
xrandrwould be helpful too!
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel you have, …
Output to inxi --admin --verbosity=7 --filter --no-host --width is:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=41b5e77f-aea6-4e67-93a5-664479adb001 rw quiet
cryptdevice=UUID=77b502ae-f416-426b-aedc-de4e854f3e72:luks-77b502ae-f416-426b-aedc-de4e854f3e72
root=/dev/mapper/luks-77b502ae-f416-426b-aedc-de4e854f3e72 apparmor=1
security=apparmor
resume=/dev/mapper/luks-7e5bc572-cfd3-4207-8901-a1f3959d6bc0
udev.log_priority=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 82DQ v: Lenovo V14-ARE serial: <filter>
Chassis: type: 10 v: Lenovo V14-ARE serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40697WIN serial: <filter>
UEFI: LENOVO v: DZCN33WW date: 09/24/2020
ID-1: BAT0 charge: 33.4 Wh condition: 33.4/35.3 Wh (95%) volts: 8.5/7.6
model: CPT-COS L16C2PB1 type: Li-poly serial: <filter> status: Full
cycles: 6
RAM: total: 7.21 GiB used: 3.84 GiB (53.2%)
Info: 6-Core model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64
type: MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600106 L2 cache: 3 MiB bogomips: 28462
Speed: 1397 MHz min/max: 1400/2375 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1397 3: 1397 4: 1397 5: 1397 6: 1397
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: disabled, RSB filling
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus ID: 03:00.0
chip ID: 1002:1636 class ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 1-3:4
chip ID: 04f2:b624 class ID: 0e02 serial: <filter>
Device-3: DisplayLink ASUSTEK MB169B+ type: USB driver: usbfs bus ID: 4-1:2
chip ID: 17e9:ff0b class ID: fe01 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: amdgpu,ati,modesetting alternate: fbdev,vesa display ID: :0
screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
s-diag: 1052mm (41.4")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
Monitor-2: DVI-I-1-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.39.0 5.9.16-1-MANJARO LLVM 11.0.1)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 03:00.1
chip ID: 1002:1637 class ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus ID: 03:00.5
chip ID: 1022:15e2 class ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 03:00.6 chip ID: 1022:15e3 class ID: 0403
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel bus ID: 01:00.0
chip ID: 168c:003e class ID: 0280
Device-2: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
bus ID: 3-3:3 chip ID: 0cf3:e300 class ID: e001
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus ID: 3-3:3 chip ID: 0cf3:e300 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 853.2 GiB used: 183.71 GiB (21.5%)
model: PC SN520 SDAPMUW-256G-1101 size: 238.47 GiB block size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 rotation: SSD
serial: <filter> rev: 20290001 temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS500G2B0A
size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 90WD scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Generic model: SD MMC MS PRO
size: 119.08 GiB block size: physical: 512 B logical: 512 B rotation: SSD
serial: <filter> rev: 1.00 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Samsung
model: Flash Drive FIT size: 29.88 GiB block size: physical: 512 B
logical: 512 B rotation: SSD serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw size: 229.37 GiB size: 224.77 GiB (97.99%)
used: 75.57 GiB (33.6%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-77b502ae-f416-426b-aedc-de4e854f3e72 label: N/A
uuid: 41b5e77f-aea6-4e67-93a5-664479adb001
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 480 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 02D5-A444
ID-3: /home/<filter>/pCloudDrive raw size: N/A size: 8 GiB
used: 248.4 MiB (3.0%) fs: fuse source: ERR-102 label: N/A uuid: N/A
ID-4: /media/SystemBackup raw size: 232.83 GiB size: 228.18 GiB (98.00%)
used: 107.86 GiB (47.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
label: SystemBackup uuid: fe8f544c-218e-473c-b9f1-9dd7377320ff
ID-5: /run/timeshift/backup raw size: 232.83 GiB size: <superuser required>
used: <superuser required> fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 8.8 GiB used: 44.2 MiB (0.5%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-7e5bc572-cfd3-4207-8901-a1f3959d6bc0 label: N/A
uuid: a3c4745a-3fbd-40e1-9d38-a4bb513d2d09
ID-1: /dev/sda2 maj-min: 8:2 size: 232.93 GiB fs: ext4 label: VirtualBoxETC
uuid: e8075768-a6e2-4484-9437-be58ae3505fa
ID-2: /dev/sdb1 maj-min: 8:17 size: 119.07 GiB fs: exfat label: Backup
uuid: 3534-6433
ID-3: /dev/sdc1 maj-min: 8:33 size: 2.46 GiB fs: iso9660
label: Kubuntu 20.04.2.0 LTS amd64 uuid: 2021-02-09-19-24-16-00
ID-4: /dev/sdc2 maj-min: 8:34 size: 3.9 MiB fs: vfat label: N/A
uuid: 54C5-9C6C
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-1:2 info: Maxxter Telink Wireless Receiver type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 248a:8367 class ID: 0301
Hub-2: 1-2:3 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip ID: 2109:2813 class ID: 0900
Device-1: 1-3:4 info: Chicony Integrated Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 04f2:b624 class ID: 0e02
serial: <filter>
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003 class ID: 0900
Hub-4: 2-2:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip ID: 2109:0813 class ID: 0900
Device-1: 2-2.4:3
info: Silicon Motion - Taiwan (formerly Feiya ) Flash Drive
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s
chip ID: 090c:1000 class ID: 0806 serial: <filter>
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-2:2 info: Realtek USB2.0-CRW type: Mass Storage
driver: ums-realtek interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 0bda:0177 class ID: 0806 serial: <filter>
Device-2: 3-3:3 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 0cf3:e300
class ID: e001
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 4-1:2 info: DisplayLink ASUSTEK MB169B+ type: Video driver: usbfs
interfaces: 2 rev: 3.2 speed: 5 Gb/s chip ID: 17e9:ff0b class ID: fe01
serial: <filter>
System Temperatures: cpu: 47.4 C mobo: N/A gpu: amdgpu temp: 37.0 C
Processes: 313 Uptime: 14h 50m wakeups: 2 Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.0.1 Packages: 1516 pacman: 1499 lib: 424 flatpak: 6
snap: 11 Shell: Bash v: 5.1.0 running in: konsole inxi: 3.3.01 `
My screens are (via xrandr):
Screen 0: minimum 320 x 200, current 3840 x 1080, maximum 16384 x 16384
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 309mm x 173mm
1920x1080 60.01*+
1680x1050 60.01
1280x1024 60.01
1440x900 60.01
1280x800 60.01
1280x720 60.01
1024x768 60.01
800x600 60.01
640x480 60.01
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
DVI-I-1-1 connected 1920x1080+1920+0 (normal left inverted right x axis y axis) 344mm x 193mm
1920x1080 59.99*+
1280x1024 75.02 60.02
1366x768 60.00
1024x768 75.03 70.07 60.00
In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.instead of like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.(as that makes both our lives much easier)
No need to do anything right now as I’m an editor here on this site and have fixed it for you already. However, in the future I might not see your post so review my edits by pushing the orange pencil above the post I just fixed.
Kernel: 5.9.16-1-MANJAROis EOL. Try upgrading to 5.4 LTS (Long Term Support) and 5.10 (LTS candidate) in that order. -
What’s the output of
grep --after-context=7 "NightColor" ~/.config/kwinrc? -
Can you plug the external monitor in another port than the DisplayLink and see if that works?
How do I change to kernal 5.4 without breaking my system. Somehow the kernal got updated to 5.9 with a package install or something. And how do I keep the system from changing the kernal without my knowledge?
Please read this:
Please read this:
@Fabby So, I already use timeshift. And so I should install a new kernal and I should be using the Linux 5.4.93_rt51-1 kernal?
Sorry for not being clear:
I meant to say: Install both, try them both and even if only one is working, keep them both and get rid of 5.9 after your testing of both 5.4 and 5.10
Which one you end up using is up to you.
Also don’t forget to answer:
Okay, so the output of grep --after-context=7 "NightColor" ~/.config/kwinrc is:
[NightColor]
Active=true
Mode=Constant
NightTemperature=2400
[Plugins]
kwin4_effect_dimscreenEnabled=true
And the external monitor is a usb monitor. Sorry if I don’t understand what you mean.
Also I tried installing kernal 5.4 rebooted and choose to use 5.4 in the grub but it would not start.
Update: Also trying kernal 5.10, the system starts but on startup I get Error: DisplayLInk service did not start and the monitor does not work.
@Fabby I tried to update to 5.4 from the terminal this time and my system would not start at all with 5.4 or 5.9 anymore so I had to use timeshift to go back to yesterday’s snapshot.
The only thing left for you to do then is to file a bug with the correct KDE team because I think it’s because you only have a USB monitor because I’ve never seen this with VGA / HDMI / … monitors.
@Fabby okay, but i am stuck with the 5.9 kernal then?
No! Anything except 5.9 is what you have to keep…
For more information on kernel management:
https://www.kernel.org/
@Fabby Why does kernal 5.4 not boot on my computer then?
- When using a rolling release like Manjaro, Kernel management is something you need to take into account. Some will work, others might not.
- With the information you’ve provided, no one can tell you why 5.4 doesn’t boot.
- This conversation has now become off-topic from the original problem.
Okay, well thanks.
