Is it possible KDE see two displays as a unified one?
The new kernel 5.91 enables 5k resolution that’s for each display you have 2560*2880 resolution.
But KDE still see this two as separated displays. In the following screen shot you can see that the following problems.
- When expanding to full screen, app will expand to the left/ right, if it is in the left/right side.
- The image in the center is broken, you will see double vision with 2 cm distance, but in the screenshot it is not broken(strange, what you got is not what you see).
- the wall paper will not see the desktop as a unified one display, it only engages the primary one. You can see this when you change wallpaper.
- The log out screen will appear on both left and right. However the log in screen see the two as one.
Will add pic later because I am not allowed to attach pic or link as new user.
