Hello everyone, I’ve installed i3 manjaro today but when I turn on my laptop i see the display screen witcht flash black i change kernel but nothing changed the song doesn’t work also but i already have the same problem with kde manjaro (just explain me for the display) thank you everyone if you want more information about my system tell me
look :
https://drive.google.com/drive/folders/1ccLTdvRLIOqA_M-N6zeuctzsggP5hgFZ
Please provide info in text form only…
Hello,
yes sorry i’m new on linux but how i can provide info for the display ? i just send video for view what is my problem
My laptop it’s an XPS 13 9315 also if you need more information can you tell me what command can i uses ?
Welcome to Manjaro!
- Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
- Please press the three dots … below your post and then press the
- If you give us information about your system, we can see what we’re talking about and make better suggestions.
- You can do this by using
inxi
in a terminal or in console.
- Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
- Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
- Copy the output from inxi (including the command) and paste it into your post.
- To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
(Wisdom lies in reading)
Kernel: 6.0.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=05767329-5bb7-42c9-9687-90ce0ea8caad rw quiet
cryptdevice=UUID=3faf3676-acd0-4f8e-8152-daaedd784b2d:luks-3faf3676-acd0-4f8e-8152-daaedd784b2d
root=/dev/mapper/luks-3faf3676-acd0-4f8e-8152-daaedd784b2d apparmor=1
security=apparmor udev.log_priority=3 i915.enable_psr=0 i915.enable_dc=0
i915.enable_fbc=0
Desktop: i3 v: 4.21.1 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: Dell product: XPS 9315 v: N/A
Mobo: Dell model: 02GGG1 v: A00 serial: <superuser required> UEFI: Dell
v: 1.3.0 date: 08/16/2022
ID-1: BAT0 charge: 46.2 Wh (91.3%) condition: 50.6/50.2 Wh (100.6%)
volts: 12.8 min: 11.6 model: BYD DELL G9FHC26 type: Li-poly serial: <filter>
status: discharging
RAM: total: 15.26 GiB used: 1.88 GiB (12.3%)
Info: model: 12th Gen Intel Core i5-1230U bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x424
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1610 high: 1700 min/max: 400/4400:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 1700 2: 1700 3: 631
4: 1700 5: 1700 6: 1700 7: 1700 8: 1700 9: 1700 10: 1700 11: 1700 12: 1700
bogomips: 40560
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes
vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt
xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-UP4 GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:46aa class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-7e568 driver:
X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57")
Monitor-1: eDP-1 model: Sharp 0x1548 built: 2021 res: 1920x1200 hz: 60
dpi: 169 gamma: 1.2 size: 288x180mm (11.34x7.09") diag: 340mm (13.4")
ratio: 16:10 modes: 1920x1200
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel vendor: Dell driver: N/A bus-ID: 0000:00:05.0
chip-ID: 8086:465d class-ID: 0480
Device-2: Intel vendor: Dell driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:51cc class-ID: 0401
Sound API: ALSA v: k6.0.8-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.59 running: no
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
chip-ID: 8087:0033 class-ID: e001
Device-1: luks-3faf3676-acd0-4f8e-8152-daaedd784b2d maj-min: 254:0
type: LUKS dm: dm-0 size: 476.64 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 476.64 GiB
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 10.32 GiB (2.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Phison
model: ESE2A044-512 NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 2 type: SSD serial: <filter>
rev: 19010008 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 10.32 GiB (2.2%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-3faf3676-acd0-4f8e-8152-daaedd784b2d label: N/A
uuid: 05767329-5bb7-42c9-9687-90ce0ea8caad
used: 484 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: B627-E77E
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-3:2 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 27c6:63ac class-ID: ef00 serial: <filter>
Device-2: 3-4:3 info: Intel USB Bridge type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8086:0b63
class-ID: 0000
Device-3: 3-10:4 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Use of uninitialized value $unit in concatenation (.) or string at /usr/bin/inxi line 24166.
Use of uninitialized value $value in concatenation (.) or string at /usr/bin/inxi line 24166.
Src: /sys System Temperatures: cpu: 37.0 C mobo: N/A
Power: 12v: N/A 5v: 5 3.3v: N/A vbat: N/A
Processes: 257 Uptime: 17m wakeups: 3710 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1103 libs: 331 tools: pamac,yay Shell: Bash
v: 5.1.16 running-in: urxvtd inxi: 3.3.23
Thank you for helping me ! if you need another information tell me
another information about systemctl status lightdm.service
● lightdm.service - Light Display Manager
Loaded: loaded (/usr/lib/systemd/system/lightdm.service; enabled; preset: disabled)
Active: active (running) since Mon 2022-12-05 20:32:42 CET; 3min 14s ago
Docs: man:lightdm(1)
Main PID: 589 (lightdm)
Tasks: 26 (limit: 18716)
Memory: 248.3M
CPU: 9.298s
CGroup: /system.slice/lightdm.service
├─589 /usr/bin/lightdm
└─663 /usr/lib/Xorg :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswit>
déc. 05 20:32:42 lorisp systemd[1]: Starting Light Display Manager...
déc. 05 20:32:42 lorisp systemd[1]: Started Light Display Manager.
déc. 05 20:32:51 lorisp lightdm[740]: pam_unix(lightdm-greeter:session): session opened for user light>
déc. 05 20:32:52 lorisp lightdm[813]: pam_systemd_home(lightdm:auth): systemd-homed is not available: >
déc. 05 20:33:06 lorisp lightdm[813]: gkr-pam: unable to locate daemon control file
déc. 05 20:33:06 lorisp lightdm[813]: gkr-pam: stashed password to try later in open session
déc. 05 20:33:06 lorisp lightdm[813]: pam_unix(lightdm:session): session opened for user loris(uid=100>
déc. 05 20:33:06 lorisp lightdm[813]: gkr-pam: unlocked login keyring ```
why lightdm.service is disable ?
It is not disabled - it is enabled and even running
and a session for some user has been opened
From the two files that you posted
via your link
(the .mov in particular)
it looks like the update was still in progress.
Did it finish?
Let it finish.
i see this topic about arch and i915 module because i think it’s the problem can you help me about this ? Intel graphics - ArchWiki
Can you help me just just changed kernel and you can see
output of journalctl -xe :
déc. 11 20:18:49 lorisp kernel: drm_atomic_nonblocking_commit+0x17/0x70
déc. 11 20:18:49 lorisp kernel: drm_atomic_helper_page_flip+0x63/0xd0
déc. 11 20:18:49 lorisp kernel: drm_mode_page_flip_ioctl+0x5a9/0x600
déc. 11 20:18:49 lorisp kernel: ? drm_mode_cursor2_ioctl+0x10/0x10
déc. 11 20:18:49 lorisp kernel: drm_ioctl_kernel+0xca/0x170
déc. 11 20:18:49 lorisp kernel: ? drm_mode_addfb_ioctl+0x10/0x10
déc. 11 20:18:49 lorisp kernel: drm_ioctl+0x231/0x410
déc. 11 20:18:49 lorisp kernel: __x64_sys_ioctl+0x91/0xd0
déc. 11 20:18:49 lorisp kernel: do_syscall_64+0x5c/0x90
déc. 11 20:18:49 lorisp kernel: ? syscall_exit_to_user_mode+0x1b/0x40
déc. 11 20:18:49 lorisp kernel: ? do_syscall_64+0x6b/0x90
déc. 11 20:18:49 lorisp kernel: drm_atomic_check_only+0x5ae/0xa00
déc. 11 20:18:49 lorisp kernel: entry_SYSCALL_64_after_hwframe+0x63/0xcd
déc. 11 20:18:49 lorisp kernel: RIP: 0033:0x7f750075cc0f
déc. 11 20:18:49 lorisp kernel: Code: 00 48 89 44 24 18 31 c0 48 8d 44 24 60 c7 04 24 10 00 00 00 48 8>
déc. 11 20:18:49 lorisp kernel: RSP: 002b:00007ffcc8f073f0 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
déc. 11 20:18:49 lorisp kernel: RAX: ffffffffffffffda RBX: 000055a9a6aff8f0 RCX: 00007f750075cc0f
déc. 11 20:18:49 lorisp kernel: RDX: 00007ffcc8f07480 RSI: 00000000c01864b0 RDI: 0000000000000010
déc. 11 20:18:49 lorisp kernel: RBP: 00007ffcc8f07480 R08: 0000000000000b71 R09: 0000000000000003
déc. 11 20:18:49 lorisp kernel: R10: 000055a9a69a0010 R11: 0000000000000246 R12: 00000000c01864b0
déc. 11 20:18:49 lorisp kernel: R13: 0000000000000010 R14: 000055a9a69de8b0 R15: 000000000000012d
déc. 11 20:18:49 lorisp kernel: </TASK>
déc. 11 20:18:49 lorisp kernel: ---[ end trace 0000000000000000 ]---
déc. 11 20:18:49 lorisp kernel: ------------[ cut here ]------------
déc. 11 20:18:49 lorisp kernel: i915 0000:00:02.0: drm_WARN_ON(new_crtc_state->do_async_flip && !plane>
déc. 11 20:18:49 lorisp kernel: WARNING: CPU: 2 PID: 614 at drivers/gpu/drm/i915/display/intel_display>
déc. 11 20:18:49 lorisp kernel: Modules linked in: tls rfcomm ccm cmac algif_hash algif_skcipher af_al>
déc. 11 20:18:49 lorisp kernel: intel_cstate intel_uncore pcspkr psmouse ucsi_acpi tpm_crb typec_ucsi>
déc. 11 20:18:49 lorisp kernel: intel_ishtp intel_rapl_common mei_me clk_tps68470 int3403_thermal int>
déc. 11 20:18:49 lorisp kernel: CPU: 2 PID: 614 Comm: Xorg Tainted: G W 6.0.11-1-MANJA>
déc. 11 20:18:49 lorisp kernel: Hardware name: Dell Inc. XPS 9315/02GGG1, BIOS 1.3.0 08/16/2022
déc. 11 20:18:49 lorisp kernel: RIP: 0010:intel_atomic_check+0x2da6/0x2f80 [i915]
déc. 11 20:18:49 lorisp kernel: Code: 48 8b 5f 50 48 85 db 75 03 48 8b 1f e8 23 fc 34 f9 48 c7 c1 b8 7>
déc. 11 20:18:49 lorisp kernel: RSP: 0018:ffffb2c2c0c1fb30 EFLAGS: 00010282
déc. 11 20:18:49 lorisp kernel: RAX: 0000000000000000 RBX: ffff8be882449990 RCX: 0000000000000027
déc. 11 20:18:49 lorisp kernel: RDX: ffff8bebff6a1668 RSI: 0000000000000001 RDI: ffff8bebff6a1660
déc. 11 20:18:49 lorisp kernel: RBP: ffffb2c2c0c1fbd8 R08: 0000000000000000 R09: ffffb2c2c0c1f9b8
déc. 11 20:18:49 lorisp kernel: R10: 0000000000000003 R11: ffffffffbb6c8d60 R12: ffffffffbab78f90
déc. 11 20:18:49 lorisp kernel: R13: ffff8be88755c300 R14: ffff8be884108800 R15: 0100000000000009
déc. 11 20:18:49 lorisp kernel: FS: 00007f74ffde50c0(0000) GS:ffff8bebff680000(0000) knlGS:0000000000>
déc. 11 20:18:49 lorisp kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
déc. 11 20:18:49 lorisp kernel: CR2: 00007f74f66f0000 CR3: 000000011877e004 CR4: 0000000000f70ee0
déc. 11 20:18:49 lorisp kernel: PKRU: 55555554
déc. 11 20:18:49 lorisp kernel: Call Trace:
déc. 11 20:18:49 lorisp kernel: <TASK>
déc. 11 20:18:49 lorisp kernel: RBP: 00007ffcc8f07480 R08: 0000000000000b74 R09: 0000000000000003
look for dmesg output :
sp_common regmap_sdw_mbq snd_soc_rt1316_sdw snd_soc_intel_sof_maxim_common snd_sof_probes regmap_sdw intel_ishtp_hid snd_soc_dmic btusb btrtl btbcm btintel spi_pxa2xx_platform dw_dmac btmtk bluetooth 8250_dw ecdh_generic dell_laptop dell_wmi dell_smbios mei_pxp mei_hdcp dell_wmi_descriptor ledtrig_audio iTCO_wdt dcdbas intel_pmc_bxt intel_rapl_msr iTCO_vendor_support intel_tcc_cooling x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul polyval_clmulni polyval_generic gf128mul ghash_clmulni_intel aesni_intel crypto_simd cryptd rapl
[ 2622.327304] intel_cstate intel_uncore pcspkr psmouse ucsi_acpi tpm_crb typec_ucsi uas tpm_tis tpm_tis_core typec usb_storage tpm roles rng_core wmi mac_hid i2c_hid_acpi i2c_hid intel_hid sparse_keymap int3400_thermal acpi_thermal_rel acpi_tad acpi_pad snd_hda_codec_hdmi squashfs qrtr loop vfat fat snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel soundwire_generic_allocation soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi iwlmvm soundwire_bus snd_soc_core mac80211 snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel libarc4 snd_intel_dspcfg snd_intel_sdw_acpi snd_hda_codec iwlwifi snd_hda_core snd_hwdep i915 snd_pcm processor_thermal_device_pci cfg80211 spi_nor processor_thermal_device processor_thermal_rfim video mtd snd_timer drm_buddy intel_skl_int3472_tps68470 processor_thermal_mbox rfkill tps68470_regulator intel_ish_ipc processor_thermal_rapl snd ttm
[ 2622.327365] intel_ishtp intel_rapl_common mei_me clk_tps68470 int3403_thermal intel_lpss_pci i2c_i801 drm_display_helper soundcore cec mei int340x_thermal_zone intel_gtt intel_lpss thunderbolt idma64 intel_skl_int3472_discrete i2c_smbus igen6_edac crypto_user fuse bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 nvme nvme_core nvme_common serio_raw atkbd libps2 vivaldi_fmap spi_intel_pci xhci_pci crc32c_intel spi_intel vmd xhci_pci_renesas i8042 serio
[ 2622.327402] CPU: 0 PID: 614 Comm: Xorg Tainted: G W 6.0.11-1-MANJARO #1 8e15ceada3efdbc5315e82c99bdae698b808ac92
[ 2622.327408] Hardware name: Dell Inc. XPS 9315/02GGG1, BIOS 1.3.0 08/16/2022
[ 2622.327410] RIP: 0010:intel_atomic_check+0x2da6/0x2f80 [i915]
[ 2622.327541] Code: 48 8b 5f 50 48 85 db 75 03 48 8b 1f e8 23 fc 34 f9 48 c7 c1 b8 71 d8 c0 48 89 da 48 c7 c7 24 98 da c0 48 89 c6 e8 ab ca 72 f9 <0f> 0b e9 f8 d8 ff ff 99 f7 ff 89 c7 89 c8 29 f8 99 f7 fe e9 1c f8
[ 2622.327544] RSP: 0018:ffffb2c2c0c1fb50 EFLAGS: 00010286
[ 2622.327547] RAX: 0000000000000000 RBX: ffff8be882449990 RCX: 0000000000000027
[ 2622.327550] RDX: ffff8bebff621668 RSI: 0000000000000001 RDI: ffff8bebff621660
[ 2622.327551] RBP: ffffb2c2c0c1fbf8 R08: 0000000000000000 R09: ffffb2c2c0c1f9d8
[ 2622.327553] R10: 0000000000000003 R11: ffffffffbb6bc610 R12: ffffffffbab78f90
[ 2622.327554] R13: ffff8be899d47b00 R14: ffff8be89905c000 R15: 0100000000000009
[ 2622.327557] FS: 00007f74ffde50c0(0000) GS:ffff8bebff600000(0000) knlGS:0000000000000000
[ 2622.327559] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 2622.327561] CR2: 00007f79fb6b5b48 CR3: 000000011877e001 CR4: 0000000000f70ef0
[ 2622.327564] PKRU: 55555554
[ 2622.327565] Call Trace:
[ 2622.327569] <TASK>
[ 2622.327574] drm_atomic_check_only+0x5ae/0xa00
[ 2622.327583] drm_atomic_nonblocking_commit+0x17/0x70
[ 2622.327591] drm_atomic_helper_page_flip+0x63/0xd0
[ 2622.327598] drm_mode_page_flip_ioctl+0x5a9/0x600
[ 2622.327604] ? drm_mode_cursor2_ioctl+0x10/0x10
[ 2622.327608] drm_ioctl_kernel+0xca/0x170
[ 2622.327613] drm_ioctl+0x231/0x410
[ 2622.327616] ? drm_mode_cursor2_ioctl+0x10/0x10
[ 2622.327621] __x64_sys_ioctl+0x91/0xd0
[ 2622.327626] do_syscall_64+0x5c/0x90
[ 2622.327634] ? syscall_exit_to_user_mode+0x1b/0x40
[ 2622.327638] ? do_syscall_64+0x6b/0x90
[ 2622.327642] ? do_syscall_64+0x6b/0x90
[ 2622.327646] entry_SYSCALL_64_after_hwframe+0x63/0xcd
[ 2622.327652] RIP: 0033:0x7f750075cc0f
[ 2622.327655] Code: 00 48 89 44 24 18 31 c0 48 8d 44 24 60 c7 04 24 10 00 00 00 48 89 44 24 08 48 8d 44 24 20 48 89 44 24 10 b8 10 00 00 00 0f 05 <89> c2 3d 00 f0 ff ff 77 18 48 8b 44 24 18 64 48 2b 04 25 28 00 00
[ 2622.327658] RSP: 002b:00007ffcc8f073f0 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[ 2622.327661] RAX: ffffffffffffffda RBX: 000055a9a6aff8f0 RCX: 00007f750075cc0f
[ 2622.327663] RDX: 00007ffcc8f07480 RSI: 00000000c01864b0 RDI: 0000000000000010
[ 2622.327665] RBP: 00007ffcc8f07480 R08: 000000000000f43f R09: 0000000000000004
[ 2622.327667] R10: 0000000000000010 R11: 0000000000000246 R12: 00000000c01864b0
[ 2622.327669] R13: 0000000000000010 R14: 000055a9a69de8b0 R15: 000000000000012c
[ 2622.327673] </TASK>
[ 2622.327674] ---[ end trace 0000000000000000 ]---
[ 2622.573069] audit: type=1101 audit(1670788454.979:237): pid=4050 uid=1000 auid=1000 ses=2 subj=unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="loris" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2622.573645] audit: type=1110 audit(1670788454.979:238): pid=4050 uid=1000 auid=1000 ses=2 subj=unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2622.573762] audit: type=1105 audit(1670788454.979:239): pid=4050 uid=1000 auid=1000 ses=2 subj=unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success
Any idea ?
especially:
915.enable_psr=0 i915.enable_dc=0 i915.enable_fbc=0
Did you do this? Did you add these parameters?
It might be the reason … but I don’t know.
If you just installed and it immediately started acting up/not working - why not just try something else.
I3 is a community edition and I do not know anything about it.
Try a different kernel - but you said that you did that.
I have no clue!
Yess i add these parameters (915.enable_psr=0 i915.enable_dc=0 i915.enable_fbc=0) in /etc/default/grub but still not working, sometimes lightdm does not work anymore and I have a black screen without being able to connect when I touch some of its parameters or when I change the kernel
I really don’t see what more I can do I went back to KDE because it works well but it bothers me I would really like to switch to i3
Maybe it’s because i have procesor i5 intel 12th generation ?
If KDE edition works but this doesn’t, then it is some component of this i3 edition
or the kernel used
or your parameters …
I simply don’t know.
I have the impression that the i915 module does not work when I use I3wm I am waiting for help from others if possible thanks i turn on KDE for now…
Ok so i think i have a solution !!! step by step so if you use a laptop XPS 13 9315 with 12th generation intel you need to configure your kernel parameters with : 915.enable_psr=0 i915.enable_dc=0 i915.enable_fbc=0
exactly how you say @Nachlese but you need to add i915.force_probe=pci_id you can use this command : lspci -nn | grep VGA | sed -n "s/^.\+\[8086:\([[:alnum:]]\{4\}\)\].\+$/\1/p"
for see your id and replace with it. You can also upgrade kernel to linux60 if you want more information just see :
https://wiki.archlinux.org/title/intel_graphics
Thank All ! i think it’s the solution i dont see flickering with this
