Disabling IPv6 not working
Hi all,
I am trying to disable IPv6, following this tutorial:
https://wiki.archlinux.org/title/IPv6#Disable_IPv6
I need to disable IPv6 because when using Wireguard (wireguard-tools), I have ip leakage.
Disabling at kernel is ok (ipv6.disable=1), but this solution is not convenient, because I need the IPv6 stack to be enable.
Setting ipv6.disable_ipv6=1 at Grub level does not work, i cant still see a IPv6 address assigned
I tried to set and edit /etc/sysctl.d/40-ipv6.conf, it does not work neither
Note that I managed to set the privacy settings, adding and editing
/etc/NetworkManager/conf.d/ip6-privacy.conf
I am testing all this config using internet cable direct from router, no VPN
So I think I am doing something wrong or forgetting something.
Could you please let me know why ipv6 cant be disabled ?
using Linux 6.9.3-3-MANJARO KDE
Thanks
Hi @Chani266,
Please provide the output for:
cat /etc/sysctl.d/40-ipv6.conf
:bangbang: Tip :bangbang:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
for example:
right click the NetworkManager applet → choose Connection Settings from the menu that comes up → choose your connection → go to IPv6 settings tab → set the Method to disabled
→ no IPv6 addresses will be assigned or requested from the router anymore
You have the wrong command
ipv6.disable=1
is the correct one
That is not what the wiki says.
Alternatively, adding ipv6.disable_ipv6=1 instead will keep the IPv6 stack functional but will not assign IPv6 addresses to any of your network devices.
The above completely disables it and any way it was stated that ipv6.disable_ipv6=1 did not work?
Yes, it was stated.
Without further evidence I’m inclined to trust the wiki more :man_shrugging:
and: he said he needs the IPv6 stack to stay (enabled).
What I described is exactly what I did myself on my own system - the result is as described:
no IPv6 addresses present or assigned
without disabling the stack at boot time
Enable IPv6 Privacy Extensions
net.ipv6.conf.all.use_tempaddr = 2
net.ipv6.conf.default.use_tempaddr = 2
net.ipv6.conf.enp4s0.use_tempaddr = 2
net.ipv6.conf.wlo1.use_tempaddr = 2
Disable IPv6
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.enp4s0.disable_ipv6 = 1
net.ipv6.conf.wlo1.disable_ipv6 = 1
OK, you obviously didn’t read this:
But anyway, I don’t have that file:
$ cat /etc/sysctl.d/40-ipv6.conf
Yet, I don’t have ipv6 addresses:
$ ip a
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether e0:d5:5e:6a:9b:65 brd ff:ff:ff:ff:ff:ff
    altname enp0s31f6
    inet 10.0.0.20/24 brd 10.0.0.255 scope global dynamic noprefixroute eno1
       valid_lft 597384sec preferred_lft 597384sec
And I use the ipv6.disable_ipv6=1 kernel parameter method. So, you can try that. As a prerequisite, ensure you have the install-grub package installed:
pamac install install-grub
To do so, open /etc/default/grub for editing.
sudo nano /etc/default/grub
And in the line starting with GRUB_CMDLINE_LINUX_DEFAULT insert ipv6.disable_ipv6=1 before the closing quotation mark. So that the line is somewhat similar to:
GRUB_CMDLINE_LINUX_DEFAULT="[...] ipv6.disable_ipv6=1 [...]"
Save, Ctrl+O, and Exir nano, Ctrl+X.
Then reinstall/update grub:
sudo install-grub
And reboot if there were no errors.
Why another package?
Isn’t
sudo update-grub
enough?
or, alternatively:
sudo grub-mkconfig -o /boot/grub/grub.cfg
This will disable the stack completely - something he said he did not want, but what he tried to do anyway.
I’m not :100: sure whether it is or not. I’d rather play it safe.
Because this:
Is much easier than:
Not according to how I understand it:
right
this will keep the stack:
ipv6.disable_ipv6=1
and this will not:
ipv6.disable=1
update-grub is essentially the same as
I have never even heard of
install-grub
and do not even have it installed
Hi, I did read, but mistake ` with -
Thanks for highlighting it to me
Here is my grub, I already have this setting
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="Manjaro-G"
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3 ipv6.disable_ipv6=1"
GRUB_CMDLINE_LINUX="ipv6.disable_ipv6=1"
and I used update-grub to update
I still have a ipv6 address
Hi,
ipv6.disable=1 works
ipv6.disable_ipv6=1 does not
What about my proposed solution - using NetworkManager interface to disable IPv6 ?
I know it works here.
Look up the difference between
and
GRUB_CMDLINE_LINUX=
and when which is used - it matters where you put your variables
Hi, sorry for late reply
It does not work
ip a shows me inet 6 address, ip.me confirms the same ipv6 address
Edit: it works !! needed a restart after setting “disabled”
hi, I actually put it in both because putting it in GRUB_CMDLINE_LINUX_DEFAULT= does not work
I still have IPv6 address assigned (checked with ip a)
Just for the sake of testing - I did
 $ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
    link/ether 04:7b:cb:46:36:c4 brd ff:ff:ff:ff:ff:ff
    inet 172.30.30.20/24 brd 172.30.30.255 scope global noprefixroute enp1s0
    inet6 fe80::d8b9:bf24:c29c:40a3/64 scope link noprefixroute
3: vmnet1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 1000
    link/ether 00:50:56:c0:00:01 brd ff:ff:ff:ff:ff:ff
    inet 192.168.191.1/24 brd 192.168.191.255 scope global vmnet1
    inet6 fe80::250:56ff:fec0:1/64 scope link proto kernel_ll
4: vmnet8: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UNKNOWN group default qlen 1000
    link/ether 00:50:56:c0:00:08 brd ff:ff:ff:ff:ff:ff
    inet 172.16.204.1/24 brd 172.16.204.255 scope global vmnet8
    inet6 fe80::250:56ff:fec0:8/64 scope link proto kernel_ll
created a file /etc/99-disable-ipv6.conf
 $ cat 99-disable-ipv6.conf
Save the file and reload the config
sudo sysctl --system
Then once more
 $ ip a
I cannot say for your system - but for mine the disable ipv6 config works totally painless…
Good!
I will not argue this.
The difference is (supposed to be):
Options in GRUB_CMDLINE_LINUX are always effective.
Options in GRUB_CMDLINE_LINUX_DEFAULT are effective ONLY during normal boot (NOT during recovery mode).
Any time you change anything, you need to update-grub and then reboot to become effective.
Just changing it without updating the grub config won’t have any effect.
But it is solved without any of this - that is what I understood.
