I do update-grub and reboot everytime, yes
Strnage that it does not work with me
but your solution works, I will test it further
Thanks !
Thanks !
Thanks, I will try it !
The OP has marked their own post as the solution. The solution seems to be βIt worksβ β but just what works has not been specified.
For the sake of clarity for those reading later, I recommend the OP please specify the particulars, and mark whosoevers post that first suggested it, as the actual solution.
Pending that, I have removed the marked Solution.
The solution given by @Nachlese worked
Disabling IPv6 from Network Manager Settings
(Choose Connection β Configure β IPv6 Tab β Disabled)
Thank you.
As you have still neglected to mark the @Nachlese post as the solution, Iβve taken the liberty of doing that for you.
Cheers.
