inxi --full --verbosity=7 --filter --no-host
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A Desktop: Xfce 4.14.2
tk: Gtk 3.24.20 info: xfce4-panel, plank wm: Openbox 3.6.1
dm: LightDM 1.30.0, LXDM Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20NE0002US v: ThinkPad E495
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20NE0002US serial: <filter> UEFI: LENOVO
v: R11ET32W (1.12 ) date: 12/23/2019
ID-1: BAT0 charge: 39.3 Wh condition: 43.4/45.7 Wh (95%) volts: 12.4/11.1
model: SMP 01AV447 type: Li-poly serial: <filter> status: Charging
cycles: 24
RAM: total: 5.75 GiB used: 3.76 GiB (65.5%)
Topology: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen+ rev: 1 L2 cache: 2048 KiB bogomips: 33552
Speed: 1614 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz):
1: 1763 2: 1451 3: 1710 4: 2036 5: 1276 6: 1231 7: 1271 8: 1231
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
Device-1: AMD Picasso vendor: Lenovo ThinkPad E595 driver: amdgpu v: kernel
bus ID: 05:00.0 chip ID: 1002:15d8
Device-2: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo
bus ID: 3-2:3 chip ID: 5986:2113
Display: x11 server: X.Org 1.20.9 compositor: picom v: git-2c9e7
driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
resolution: 2560x1440~60Hz s-dpi: 96
OpenGL: renderer: AMD RAVEN (DRM 3.38.0 5.8.11-1-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.8 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Lenovo ThinkPad E595 driver: snd_hda_intel v: kernel
bus ID: 05:00.1 chip ID: 1002:15de
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo ThinkPad E595 driver: snd_rn_pci_acp3x v: kernel
bus ID: 05:00.5 chip ID: 1022:15e2
Device-3: AMD Family 17h HD Audio vendor: Lenovo ThinkPad E595
driver: snd_hda_intel v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.8.11-1-MANJARO
vendor: Lenovo ThinkPad E595 driver: r8169 v: kernel port: 2000
bus ID: 02:00.0 chip ID: 10ec:8168
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel port: 2000
bus ID: 04:00.0 chip ID: 8086:2526
IF: wlp4s0 state: up mac: <filter>
Device-3: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
bus ID: 3-1:2 chip ID: 8087:0025
WAN IP: No WAN IP found. Connected to web? SSL issues? Try --no-dig
Local Storage: total: 238.47 GiB used: 87.37 GiB (36.6%)
ID-1: /dev/nvme0n1 model: UMIS RPJTJ256MED1OWX size: 238.47 GiB
speed: 15.8 Gb/s lanes: 2 serial: <filter> rev: 1331.1.0 scheme: GPT
ID-1: / size: 62.50 GiB used: 32.19 GiB (51.5%) fs: ext4
dev: /dev/nvme0n1p8 label: N/A uuid: 345ab08f-72aa-490a-bdd8-cf012b3ce078
ID-2: /boot/efi size: 256.0 MiB used: 266 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p5 label: N/A uuid: 115D-756B
ID-3: /home size: 62.95 GiB used: 55.17 GiB (87.6%) fs: ext4
dev: /dev/nvme0n1p6 label: N/A uuid: b41b5a60-6984-4d8a-8f6a-da0670432fc9
ID-1: swap-1 type: partition size: 8.00 GiB used: 14.0 MiB (0.2%)
priority: -2 dev: /dev/nvme0n1p7 label: N/A
uuid: f636c589-0c06-40af-b397-40b10cb76695
ID-1: /dev/nvme0n1p1 size: 260.0 MiB fs: vfat label: SYSTEM uuid: 7EB5-BC64
ID-2: /dev/nvme0n1p2 size: 16.0 MiB fs: <superuser/root required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 size: 100.51 GiB fs: ntfs label: Windows
uuid: 08D6B943D6B93234
ID-4: /dev/nvme0n1p4 size: 1000.0 MiB fs: ntfs label: WinRE_DRV
uuid: E240BA0440B9DF89
Hub: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-2:2 info: SteelSeries ApS SteelSeries Rival 100 Gaming Mouse
type: HID,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s chip ID: 1038:1702
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 3-1:2 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
chip ID: 8087:0025
Device-2: 3-2:3 info: Acer SunplusIT Integrated Camera type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 5986:2113
Hub: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 52.9 C mobo: 0.0 C gpu: amdgpu temp: 52 C
Fan Speeds (RPM): cpu: 3300
Processes: 255 Uptime: 1h 19m Init: systemd v: 246 Compilers: gcc: 10.2.0
alt: 5 clang: 10.0.1 Packages: pacman: 1449 Shell: Zsh v: 5.8
running in: termite inxi: 3.1.05
~ journalctl -u NetworkManager | tail -100 | grep dhcp
Oct 09 12:33:07 bar-pc NetworkManager[688]: <info> [1602235987.0578] dhcp4 (wlp4s0): option requested_static_routes => '1'
Oct 09 12:33:07 bar-pc NetworkManager[688]: <info> [1602235987.0578] dhcp4 (wlp4s0): option requested_subnet_mask => '1'
Oct 09 12:33:07 bar-pc NetworkManager[688]: <info> [1602235987.0578] dhcp4 (wlp4s0): option requested_time_offset => '1'
Oct 09 12:33:07 bar-pc NetworkManager[688]: <info> [1602235987.0578] dhcp4 (wlp4s0): option requested_wpad => '1'
Oct 09 12:33:07 bar-pc NetworkManager[688]: <info> [1602235987.0578] dhcp4 (wlp4s0): option routers => '10.0.0.138'
Oct 09 12:33:07 bar-pc NetworkManager[688]: <info> [1602235987.0578] dhcp4 (wlp4s0): option subnet_mask => '255.255.255.0'
Oct 09 12:33:07 bar-pc NetworkManager[688]: <info> [1602235987.0578] dhcp4 (wlp4s0): state changed extended -> extended
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.0426] dhcp4 (wlp4s0): canceled DHCP transaction
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.0427] dhcp4 (wlp4s0): state changed extended -> done
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.2658] dhcp4 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4601] dhcp4 (wlp4s0): option dhcp_lease_time => '3600'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4602] dhcp4 (wlp4s0): option domain_name => 'Home'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4602] dhcp4 (wlp4s0): option domain_name_servers => '10.0.0.138'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4603] dhcp4 (wlp4s0): option expiry => '1602239998'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4603] dhcp4 (wlp4s0): option ip_address => '10.0.0.12'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4604] dhcp4 (wlp4s0): option requested_broadcast_address => '1'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4604] dhcp4 (wlp4s0): option requested_domain_name => '1'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4604] dhcp4 (wlp4s0): option requested_domain_name_servers => '1'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4604] dhcp4 (wlp4s0): option requested_domain_search => '1'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4604] dhcp4 (wlp4s0): option requested_host_name => '1'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4605] dhcp4 (wlp4s0): option requested_interface_mtu => '1'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4605] dhcp4 (wlp4s0): option requested_ms_classless_static_routes => '1'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4605] dhcp4 (wlp4s0): option requested_nis_domain => '1'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4605] dhcp4 (wlp4s0): option requested_nis_servers => '1'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4606] dhcp4 (wlp4s0): option requested_ntp_servers => '1'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4606] dhcp4 (wlp4s0): option requested_rfc3442_classless_static_routes => '1'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4606] dhcp4 (wlp4s0): option requested_root_path => '1'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4606] dhcp4 (wlp4s0): option requested_routers => '1'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4607] dhcp4 (wlp4s0): option requested_static_routes => '1'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4607] dhcp4 (wlp4s0): option requested_subnet_mask => '1'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4607] dhcp4 (wlp4s0): option requested_time_offset => '1'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4607] dhcp4 (wlp4s0): option requested_wpad => '1'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4607] dhcp4 (wlp4s0): option routers => '10.0.0.138'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4608] dhcp4 (wlp4s0): option subnet_mask => '255.255.255.0'
Oct 09 12:39:58 bar-pc NetworkManager[688]: <info> [1602236398.4608] dhcp4 (wlp4s0): state changed unknown -> bound
Oct 09 12:40:00 bar-pc NetworkManager[688]: <info> [1602236400.1547] dhcp6 (wlp4s0): activation: beginning transaction (timeout in 45 seconds)
Oct 09 12:40:45 bar-pc NetworkManager[688]: <warn> [1602236445.0692] dhcp6 (wlp4s0): request timed out
Oct 09 12:40:45 bar-pc NetworkManager[688]: <info> [1602236445.0692] dhcp6 (wlp4s0): state changed unknown -> timeout
Oct 09 12:40:45 bar-pc NetworkManager[688]: <info> [1602236445.0693] dhcp6 (wlp4s0): canceled DHCP transaction
Oct 09 12:40:45 bar-pc NetworkManager[688]: <info> [1602236445.0693] dhcp6 (wlp4s0): state changed timeout -> done
Example of the problem:
~ ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=117 time=66.4 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=117 time=51.6 ms
^C
--- 8.8.8.8 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1002ms
rtt min/avg/max/mdev = 51.597/59.021/66.446/7.424 ms
~ ping www.example.com
ping: www.example.com: Name or service not known
In the mean time I have to
sudo systemctl restart systemd-resolved && sudo systemctl stop systemd-resolved
every couple of minutes.
