am very new to Manjaro and new to linux on the whole. I have recently installend the KDE manjaro and for some reason I need to run startx everry time i boot. The installation went fine with no errors and Iam only shown cli like command interface at boot.
I am running an 11th Gen Intel® Core™ i7-1165G7 and GeForce MX450, I am also dual booting with windows. My kernel is Linux 5.15.84-1 and Manjaro 22.0.0, i am also running with the propietary driver for my gpu.
If you require any further information please let me know and also how I can provide it.
Thank You.
brahma
December 22, 2022, 11:41am
2
provide system info, and use formatting, click this icon in editor: </>, and copy the following output there:
inxi -Fazv7
mhwd -l -li
and after you installed, the first time you booted, it worked? or it started to happen later?
Since this is posted under the Kde Plasma section, I’m going to presume that’s what you’re using.
Please provide the output of:
systemctl status sddm
Tip:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Alternatively , paste the text you wish to format as terminal output, select all pasted text, and click the </> button on the taskbar. This will indent the whole pasted section with one TAB , causing it to render the same way as described above.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Also , if your language isn’t English, please prepend any and all terminal commands with LC_ALL=C
. For example:
LC_ALL=C bluetoothctl
inxi -Fazv7
Kernel: 5.15.84-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=a8dfa126-3705-43dc-ab87-ba9dc12d183c rw quiet apparmor=1
security=apparmor resume=UUID=f176355b-8b5c-4760-be44-41408b12d4bb
Desktop: Budgie v: 10.6.4 info: budgie-panel wm: kwin_x11 dm: 1: LightDM
v: 1.32.0 note: stopped 2: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Micro-Star product: Modern 14 B11SB v: REV:1.0
Mobo: Micro-Star model: MS-14D2 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: E14D2IMS.114 date: 06/25/2021
ID-1: BAT1 charge: 25.6 Wh (76.0%) condition: 33.7/52.4 Wh (64.2%)
volts: 11.7 min: 11.4 model: MSI Corp. MS-14D2 type: Li-ion serial: N/A
status: N/A
RAM: total: 15.33 GiB used: 2.39 GiB (15.6%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xA6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1817 high: 3118 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 1243 2: 1275 3: 2559
4: 2200 5: 3118 6: 1449 7: 1320 8: 1378 bogomips: 44864
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand
rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce MX450] vendor: Micro-Star MSI
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2e:00.0
chip-ID: 10de:1f97 class-ID: 0302
Device-3: Acer HD Webcam type: USB driver: uvcvideo bus-ID: 3-6:6
chip-ID: 5986:211c class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositors: 1: kwin_x11 2: budgie-wm driver: X: loaded: modesetting,nvidia
unloaded: nouveau alternate: fbdev,nv,vesa dri: iris gpu: i915
display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: BOE Display 0x06df built: 2016 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Micro-Star MSI
driver: sof-audio-pci-intel-tgl bus-ID: 3-3:4
alternate: snd_hda_intel,snd_sof_pci_intel_tgl chip-ID: 12d1:3a07
bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0300 serial: <filter>
class-ID: 0401
Device-2: Huawei USB-C HEADSET type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k5.15.84-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
bus-ID: 3-10:7 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 476.94 GiB used: 20.62 GiB (4.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AI1
lanes: 4 type: SSD serial: <filter> rev: ECFK52.8 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 106.65 GiB size: 104.42 GiB (97.91%)
used: 20.62 GiB (19.8%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
label: N/A uuid: a8dfa126-3705-43dc-ab87-ba9dc12d183c
ID-2: /boot/efi raw-size: 301 MiB size: 300.3 MiB (99.79%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6
label: NO_LABEL uuid: E523-4AE1
ID-1: swap-1 type: partition size: 19.53 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: f176355b-8b5c-4760-be44-41408b12d4bb
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: SYSTEM
uuid: 86A0-9413
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 333.51 GiB fs: ntfs
label: Windows uuid: B8AE7A54AE7A0AE0
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 1.02 GiB fs: ntfs label: N/A
uuid: AACAEBF7CAEBBDA7
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 15.51 GiB fs: ntfs
label: BIOS_RVY uuid: FE6CA40C6CA3BDB1
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:2 info: Areson Corp 2.4G Receiver type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 25a7:fa23 class-ID: 0301
Device-2: 3-2:3 info: Winbond Gaming Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
power: 400mA chip-ID: 0416:c345 class-ID: 0300
Device-3: 3-3:4 info: Huawei USB-C HEADSET type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 12d1:3a07 class-ID: 0300
serial: <filter>
Device-4: 3-5:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-5: 3-6:6 info: Acer HD Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:211c
class-ID: 0e02
Device-6: 3-10:7 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 44.0 C mobo: N/A
Processes: 323 Uptime: 3m wakeups: 1 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1255
pm: pacman pkgs: 1242 libs: 335 tools: pamac pm: flatpak pkgs: 10 pm: snap
pkgs: 3 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.24
mhwd -l -li
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2021.11.04 false PCI
> 0000:2e:00.0 (0302:10de:1f97) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-470xx-prime 2021.11.04 false PCI
video-nvidia 2021.11.04 false PCI
video-nvidia-470xx 2021.11.04 false PCI
> 0000:00:02.0 (0300:8086:9a49) Display controller Intel Corporation:
video-vesa 2017.03.12 true PCI
Yes, it happened the first time I booted, btw i installed sddm and it no longer go to tty but when i login though sddm it only shows blank screen with cursor.
sddm.service - Simple Desktop Display Manager
Loaded: loaded (/usr/lib/systemd/system/sddm.service; enabled; preset: dis>
Active: active (running) since Thu 2022-12-22 19:40:23 WIB; 6min ago
Docs: man:sddm(1)
man:sddm.conf(5)
Main PID: 720 (sddm)
Tasks: 19 (limit: 18817)
Memory: 186.1M
CPU: 4.047s
CGroup: /system.slice/sddm.service
├─ 720 /usr/bin/sddm
└─1090 /usr/lib/Xorg -nolisten tcp -background none -seat seat0 vt>
Dec 22 19:40:52 Wilbert-Laptop sddm-helper[1133]: gkr-pam: unable to locate dae>
Dec 22 19:40:52 Wilbert-Laptop sddm-helper[1133]: [PAM] returning.
Dec 22 19:40:52 Wilbert-Laptop sddm-helper[1133]: gkr-pam: stashed password to >
Dec 22 19:40:52 Wilbert-Laptop sddm[720]: Authenticated successfully
Dec 22 19:40:52 Wilbert-Laptop sddm-helper[1133]: pam_unix(sddm:session): sessi>
Dec 22 19:40:52 Wilbert-Laptop sddm[720]: Auth: sddm-helper exited successfully
Dec 22 19:40:52 Wilbert-Laptop sddm[720]: Greeter stopped.
Dec 22 19:40:53 Wilbert-Laptop sddm-helper[1133]: gkr-pam: unlocked login keyri>
Dec 22 19:40:53 Wilbert-Laptop sddm-helper[1133]: Starting: "/usr/share/sddm/sc>
Dec 22 19:40:53 Wilbert-Laptop sddm[720]: Session started
I just installed it and when i rebooted with it and login it only shows blank screen
Try:
systemctl enable sddm.service
Followed by a reboot.
It worked, thank youu so much
system
Closed
December 25, 2022, 3:09am
9
