Dell Inspiron 5720 works with kernel 5.13 only
I am trying to use an old (2013) laptop I have: it is a Dell Inspiron 5720 with Intel® Centrino® Wireless 2230 device.
I tried with the following ISO
manjaro-kde-21.1.6-211017-linux513.iso
and all is fine up to the moment of updating the system to the latest rolling release where I get so many errors that I cannot count (all referred to PGP)
It seems because the kernel 5.13 was no more supported in the following versions
I also tried to downgrade to kernel 5.10 but the whole networking part is no more recongnized
I also tried kernel 5.15 and no way of have the networking (both LAN and wifi) working (not even recognized by the OS)
How can I find which kernel is able to support that same component that seemed to be recognized only by kernel 5.13 ???
Any help is more than welcome
Try to install manjaro-kde-22.1.0-230421-linux61.iso
By look at the journal or kernel messages and investigate what the module reports.
Since it is an old hardware I bet it is no more supported on 6.1, but I will try it
Please post your system info as outlined here:
  Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=2fcb8cd7-13b2-4152-bbda-ee8ff03e23fb rw quiet splash
    resume=UUID=177e13ed-fa9a-46c1-8aff-39a7fdc4b3e6 udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Portable System: Dell product: Inspiron 5720 v: N/A
    serial: <superuser required> Chassis: type: 8 v: 0.1
  Mobo: Dell model: 023HTX v: A00 serial: <superuser required> UEFI: Dell
    v: A19 date: 04/18/2014
  ID-1: BAT0 charge: 25.5 Wh (100.0%) condition: 25.5/48.8 Wh (52.1%)
    volts: 12.3 min: 11.1 model: SDI Dell type: Li-ion serial: <filter>
    status: full
  RAM: total: 7.62 GiB used: 1.12 GiB (14.7%)
  Info: model: Intel Core i5-3210M bits: 64 type: MT MCP arch: Ivy Bridge
    gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
    model-id: 0x3A (58) stepping: 9 microcode: 0x21
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1199 high: 1200 min/max: 1200/3100 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1200 2: 1197 3: 1200
    4: 1200 bogomips: 19963
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
    ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
    pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
    xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
    v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
    active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
    chip-ID: 8086:0166 class-ID: 0300
  Device-2: Microdia Laptop_Integrated_Webcam_E4HD type: USB driver: uvcvideo
    bus-ID: 1-1.5:4 chip-ID: 0c45:644b class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
    s-diag: 485mm (19.11") monitors: <missing: xrandr>
  Monitor-1: LVDS-1 model: Seiko Epson 0x544b built: 2011 res: 1600x900
    dpi: 106 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
    ratio: 16:9 modes: 1600x900
  API: OpenGL v: 4.2 Mesa 23.0.2 renderer: Mesa Intel HD Graphics 4000 (IVB
    GT2) direct-render: Yes
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
    class-ID: 0403
  API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: alsamixer,amixer
  Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl
  Device-1: Broadcom BCM43142 802.11b/g/n vendor: Dell Wireless 1704 802.11n +
    BT 4.0 driver: bcma-pci-bridge v: N/A modules: bcma pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 14e4:4365 class-ID: 0280
  WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
  Device-1: Broadcom BCM43142 Bluetooth 4.0 type: USB driver: btusb v: 0.8
    bus-ID: 2-1.5:3 chip-ID: 0a5c:21d7 class-ID: fe01 serial: <filter>
  Local Storage: total: 938.97 GiB used: 8.47 GiB (0.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10JPVX-00JC3T0
    type: HDD rpm: 5400 serial: <filter> rev: 1A01 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston model: DT 101 G2
    size: 7.46 GiB block-size: physical: 512 B logical: 512 B type: N/A
    serial: <filter> rev: PMAP scheme: MBR
  Optical-1: /dev/sr0 vendor: TSSTcorp model: DVD+-RW SN-208BB rev: D300
    dev-links: cdrom
  ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%) used: 8.47 GiB (0.9%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: 2fcb8cd7-13b2-4152-bbda-ee8ff03e23fb
    used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 7CD3-54E4
    dev: /dev/sda3 maj-min: 8:3 label: swap
    uuid: 177e13ed-fa9a-46c1-8aff-39a7fdc4b3e6
  ID-1: /dev/sdb1 maj-min: 8:17 size: 1.1 GiB fs: <superuser required>
    label: N/A uuid: N/A
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.3:3 info: Realtek RTS5129 Card Reader Controller
    interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
    class-ID: ff00 serial: <filter>
  Device-2: 1-1.5:4 info: Microdia Laptop_Integrated_Webcam_E4HD type: Video
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 2-1.5:3 info: Broadcom BCM43142 Bluetooth 4.0 type: Bluetooth
    driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:21d7
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-1:3 info: Toshiba Kingston DataTraveler 102/2.0 / HEMA Flash
    Drive 2 GB PNY Attache 4GB Stick type: Mass Storage driver: usb-storage
    interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA chip-ID: 0930:6545
    class-ID: 0806 serial: <filter>
  Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 69.0 C mobo: 38.0 C sodimm: SODIMM C
  Processes: 178 Uptime: 3m wakeups: 1 Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
  pkgs: 1155 libs: 350 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
  default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.26
00:00.0 Host bridge: Intel Corporation 3rd Gen Core processor DRAM Controller (rev 09)
	Subsystem: Dell Device 0564
	Kernel driver in use: ivb_uncore
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09)
	Kernel driver in use: i915
	Kernel modules: i915
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
00:16.0 Communication controller: Intel Corporation 7 Series/C216 Chipset Family MEI Controller #1 (rev 04)
	Kernel driver in use: mei_me
	Kernel modules: mei_me
00:1a.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #2 (rev 04)
	Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller (rev 04)
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 1 (rev c4)
	Kernel driver in use: pcieport
00:1d.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation HM77 Express Chipset LPC Controller (rev 04)
	Kernel driver in use: lpc_ich
	Kernel modules: lpc_ich
00:1f.2 IDE interface: Intel Corporation 7 Series Chipset Family 4-port SATA Controller [IDE mode] (rev 04)
	Kernel driver in use: ata_piix
	Kernel modules: ata_piix, pata_acpi, ata_generic
00:1f.3 SMBus: Intel Corporation 7 Series/C216 Chipset Family SMBus Controller (rev 04)
	Kernel driver in use: i801_smbus
	Kernel modules: i2c_i801
00:1f.5 IDE interface: Intel Corporation 7 Series Chipset Family 2-port SATA Controller [IDE mode] (rev 04)
01:00.0 Network controller: Broadcom Inc. and subsidiaries BCM43142 802.11b/g/n (rev 01)
	Subsystem: Dell Wireless 1704 802.11n + BT 4.0
	Kernel driver in use: bcma-pci-bridge
	Kernel modules: bcma
e[1me[31m> e[mInstalled PCI configs:
           video-linux            2018.05.04                true            PCI
e[1me[31mWarning: e[mNo installed USB configs!
In few moments I will upload the same when I install the other ISO
You’re not the first who have had issues with Broadcom chips, especially this one. Please search the forum Search results for 'BCM43142' - Manjaro Linux Forum
  Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=d40331a5-ebde-4737-a2dd-3f690aecac8f rw quiet apparmor=1
  security=apparmor resume=UUID=3fa1ed7f-a012-4034-bd41-8d80188e799f
  udev.log_priority=3
  Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Portable System: Dell product: Inspiron 5720 v: N/A serial: <filter>
  Chassis: type: 8 v: 0.1 serial: <filter>
  Mobo: Dell model: 023HTX v: A00 serial: <filter> UEFI: Dell v: A19
  date: 04/18/2014
  status: Full
  RAM: total: 7.63 GiB used: 1.01 GiB (13.2%)
  Info: Dual Core model: Intel Core i5-3210M bits: 64 type: MT MCP
  arch: Ivy Bridge family: 6 model-id: 3A (58) stepping: 9 microcode: 21
  cache: L2: 3 MiB bogomips: 19962
  Speed: 1198 MHz min/max: 1200/3100 MHz Core speeds (MHz): 1: 1198 2: 1197
  3: 1197 4: 1197
  constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
  erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida
  lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat
  pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand
  rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
  tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
  Type: l1tf
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
  loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
  s-diag: 485mm (19.1")
  Monitor-1: LVDS-1 res: 1600x900 hz: 60 dpi: 106 size: 382x215mm (15.0x8.5")
  diag: 438mm (17.3")
  OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
  v: 4.2 Mesa 21.2.3 compat-v: 3.0 direct render: Yes
  class-ID: 0403
  Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.38 running: yes
  vendor: Dell Wireless 1704 802.11n + BT 4.0 driver: wl v: kernel
  modules: bcma bus-ID: 01:00.0 chip-ID: 14e4:4365 class-ID: 0280
  Local Storage: total: 938.97 GiB used: 8.27 GiB (0.9%)
  dev-links: cdrom
  ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%) used: 8.27 GiB (0.9%)
  uuid: d40331a5-ebde-4737-a2dd-3f690aecac8f
  used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
  uuid: F5B0-B776
  ID-3: /run/media/edo/Red raw-size: 7.45 GiB size: 7.24 GiB (97.15%)
  used: 1.9 MiB (0.0%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: Red
  uuid: c1d4f493-2d25-4a7e-b7b6-ffad4b4945ad
  uuid: 3fa1ed7f-a012-4034-bd41-8d80188e799f
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 3-1:2 info: Toshiba Kingston DataTraveler 102/2.0 / HEMA Flash
  Drive 2 GB / PNY Attache 4GB Stick
  type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
  speed: 480 Mb/s power: 200mA chip-ID: 0930:6545 class-ID: 0806
  serial: <filter>
  Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 53.0 C mobo: 34.0 C sodimm: SODIMM C
  Fan Speeds (RPM): cpu: 2591
  Processes: 206 Uptime: 5m wakeups: 1 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: N/A Packages: pacman: 1199 lib: 331 flatpak: 0 Shell: Zsh
  v: 5.8 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.07
	Kernel driver in use: wl
	Kernel modules: bcma, wl
   network-broadcom-wl            2018.10.07                true            PCI
I know about it that is why I was surprised to have it perfectly working with version 21 kernel 5.13
The mhwd is quite different if you noticed
5.13 has been EOL (End Of Life) for well over a year.
You still have other supported kernels to try as well as checking the forum search results I linked above.
  • 4.19 LTS (Long Term Support)
  • 5.4 LTS
  • 5.10 LTS
  • 6.2 stable
  • 6.3 stable
Tomorrow I will go thru the search list you suggested but so far only the version with 5.13 is able to recognize, without any intervention, that chip
Quite weird 5.10 and 5.15 are not able to
have the same setup as yours (except being a 15" - 5520), have no issues whatsoever with all hardware working. install using a latest ISO. should not be a issue. i’m on 5.15 and have tried 6.1 with no issues
As far as I know you dont have the BCM43142, but a tiny different model
If I am wrong then there is something very strange I am not getting
Sofar I think I have tried almsot all comibineation of 5.10, 5.15, 6.1 versions and the only that allows the wireless working is just 5.13 (Manajaro 21 Pahvo) and by the way none of them recognize the etherenet so the LAN device
So much weird!!!
oops, i thought you said you had Intel® Centrino® Wireless 2230 which i have, which has no issues, even among other intel wireless cards, it is one of the best supported.
broadcom chipsets however, are can of worms in linux.
The commercial name is Centrino etc but the truth is it is a BCM43142 :frowning:
you can try this though, you can download a broadcom wireless drivers from a manjaro repo (drivers for all LTS kernels and latest main-line kernels are available). see;
https://packages.manjaro.org/?query=broadcom-wl
so select the relevant package for the kernel of your choice and locate the file in;
https://repo.ialab.dsu.edu/manjaro/stable/extra/x86_64/
download it (*.zst). move file into the laptop and install using
$ sudo pacman -U /path/to/*-broadcom-wl-*.pkg.tar.zst
I just prepared a new USB from the latest ISO:
sudo dd if=./manjaro-kde-22.1.0-230421-linux61.iso of=/dev/sdc status=progress oflag=sync bs=128M
then I downloaded the package on my Manjaro desktop
sudo pacman -Sw linux61-broadcom-wl
then I copied into an USB drive to install it on the notebook
sudo pacman -U ./linux61-broadcom-wl
this is the result for inxi -v7azy
    root=UUID=fd319043-7f14-4e7e-be19-1586bac69e6a rw quiet splash
    resume=UUID=ddacba28-f8de-474f-bf5a-63b503d12b58 udev.log_priority=3
    status: full
  RAM: total: 7.62 GiB used: 1.2 GiB (15.7%)
  Speed (MHz): avg: 1197 high: 1198 min/max: 1200/3100 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1197 2: 1198 3: 1197
    4: 1197 bogomips: 19962
    vulnerable
    class-ID: 0403
    tools: pw-cli,wpctl
    BT 4.0 driver: N/A modules: bcma, wl pcie: gen: 1 speed: 2.5 GT/s lanes: 1
  Local Storage: total: 960.38 GiB used: 7.65 GiB (0.8%)
    model: DataTraveler 3.0 size: 28.87 GiB block-size: physical: 512 B
    logical: 512 B type: N/A serial: <filter> rev: 0000 scheme: MBR
    dev-links: cdrom
  ID-1: / raw-size: 922.42 GiB size: 906.86 GiB (98.31%) used: 7.65 GiB (0.8%)
    uuid: fd319043-7f14-4e7e-be19-1586bac69e6a
    uuid: F196-B2AC
    uuid: ddacba28-f8de-474f-bf5a-63b503d12b58
  ID-1: /dev/sdb1 maj-min: 8:17 size: 28.86 GiB fs: ext4 label: Testing
    uuid: 85cc15b7-2e8f-4eb9-96dd-e8374c603e02
  Device-1: 4-1:2 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50
    type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s
    power: 144mA chip-ID: 0951:1666 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 52.0 C mobo: 35.0 C sodimm: SODIMM C
  Fan Speeds (RPM): cpu: 0
  Processes: 163 Uptime: 27m wakeups: 1 Init: systemd v: 252 default: graphical
  pkgs: 1123 libs: 325 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
and this is the result for mhwd
e[1me[31m> e[m0000:01:00.0 (0280:14e4:4365) Network controller Broadcom:
   network-broadcom-wl            2018.10.07               false            PCI
e[1me[31m> e[m0000:00:02.0 (0300:8086:0166) Display controller Intel Corporation:
and this is the lspci -k
Neither the ethernet or the wireless are working: now I am trying to undersand which chipset is the ethernet
alright some more investigation is due;
seems like kernel modules are not loaded;
run;
$ grep blacklist /etc/modprobe.d/*
if you get results;
blacklist bcm43xx
blacklist bcma
you will have to remove those lines from files within /etc/modprobe.d/* and reboot
I will test it as soon as my last attempt ends…
…30 more minutes
In my last attempt i got to a point similar to kernel 5.13
I started with creating an image of the last version but with kernel 5.15 (had to look for it in sourceforgenet since it was not available on the main site !!!)
  sudo dd if=./manjaro-kde-22.1.0-minimal-230421-linux515.iso of=/dev/sdc status=progress oflag=sync bs=128M
After that the wifi was perfectly installed by default (no way of installing the ethernet card for now)
I could update all the packages and so far all i working great
The weird thing is that if I grep the modprobe as you suggested I keep seeing the following:
grep blacklist /etc/modprobe.d/*                                                               ✔️
blacklist b43
blacklist b43legacy
blacklist ssb
blacklist bcm43xx
blacklist brcm80211
blacklist brcmfmac
blacklist brcmsmac
blacklist bcma
Why is it working anyway ?
