When entering session and tapping the key “decrease brightness”, it decreases the brightness to the minimum level and then I must adjust it upwards. It only happens at first time on session using this button; after, not.
I don’t know if this is a Gnome’s or Manjaro’s issue, so I’m asking here because I didn’t find out where to report it for Gnome.
Update with more info from below comments
Hardware and software:
Kernel: 5.10.68-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=65cbfdc0-188f-4605-a559-d0dd7bf066ce rw quiet splash apparmor=1
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Laptop System: LENOVO product: 82L7 v: IdeaPad 5 Pro 14ACN6
serial: <filter> Chassis: type: 10 v: IdeaPad 5 Pro 14ACN6 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <filter> UEFI: LENOVO
v: GECN24WW(V1.08) date: 07/23/2021
ID-1: BAT1 charge: 51.3 Wh (90.6%) condition: 56.6/56.5 Wh (100.2%)
volts: 12.6 min: 11.5
model: 0x43 0x65 0x6C 0x78 0x70 0x65 0x 0x4C 0x32 0x30 0x43 0x33 0x50 0x5650
type: Li-ion serial: <filter> status: Discharging cycles: 5
RAM: total: 13.59 GiB used: 2.04 GiB (15.0%)
Info: 6-Core model: AMD Ryzen 5 5600U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 family: 19 (25) model-id: 50 (80) stepping: 0
microcode: A50000B cache: L2: 3 MiB bogomips: 55108
Speed: 1397 MHz min/max: 1600/2300 MHz boost: enabled Core speeds (MHz):
1: 1397 2: 1397 3: 1397 4: 1396 5: 1397 6: 1395 7: 1396 8: 1396 9: 1397
10: 1396 11: 1397 12: 1396
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 13d3:56fb class-ID: fe01 serial: <filter>
Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: amdgpu note: n/a (using device driver) - try sudo/root display-ID: 0
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.68-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.2 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 04:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x bus-ID: 04:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.68-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.37 running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel bus-ID: 01:00.0
chip-ID: 168c:003e class-ID: 0280
Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 3-4:2 chip-ID: 0cf3:e300 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 4 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 220.53 GiB (46.2%)
model: PC SN530 SDBPMPZ-512G-1101 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21160001 temp: 33.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 220.53 GiB (47.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 65cbfdc0-188f-4605-a559-d0dd7bf066ce
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 42ED-D6BB
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 1-3:2 info: IMC Networks Integrated Camera type: Video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-4:2 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: Bluetooth
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 48.0 C mobo: N/A gpu: amdgpu temp: 37.0 C
Processes: 325 Uptime: 1h 5m wakeups: 1839 Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1287
lib: 339 flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal
inxi: 3.3.06
Errors on startup:
[FAILED] Failed to start Load/Save ·ness of backlight:acpi_video0.
[FAILED] Failed to start Load/Save Screen Backlight Brightness of backlight:amdgpu_b10.
Trying to run backlight:acpi_video0:
systemctl status systemd-backlight@backlight:acpi_video0.service
× systemd-backlight@backlight:acpi_video0.service - Load/Save Screen Backlight Brightness of backlight:acpi_video0
Loaded: loaded (/usr/lib/systemd/system/systemd-backlight@.service; static)
Active: failed (Result: exit-code) since Wed 2021-09-29 15:47:03 CEST; 10min ago
Docs: man:systemd-backlight@.service(8)
Process: 743 ExecStart=/usr/lib/systemd/systemd-backlight load backlight:acpi_video0 (code=exited, status=1/FAILURE)
Main PID: 743 (code=exited, status=1/FAILURE)
CPU: 3ms
ira 29 15:47:03 ideaPad systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:acpi_video0...
ira 29 15:47:03 ideaPad systemd-backlight[743]: Failed to get backlight or LED device 'backlight:acpi_video0': No such device
ira 29 15:47:03 ideaPad systemd[1]: systemd-backlight@backlight:acpi_video0.service: Main process exited, code=exited, status=1/FAILURE
ira 29 15:47:03 ideaPad systemd[1]: systemd-backlight@backlight:acpi_video0.service: Failed with result 'exit-code'.
ira 29 15:47:03 ideaPad systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:acpi_video0.
Trying to run backlight:amdgpu_b10:
systemctl status systemd-backlight@backlight:amdgpu_b10.service
○ systemd-backlight@backlight:amdgpu_b10.service - Load/Save Screen Backlight Brightness of backlight:amdgpu_b10
Active: inactive (dead)
May this help? [SOLVED] Failed to start Load/Save Screen Backlight Brightness / Laptop Issues / Arch Linux Forums
