Porru
September 29, 2021, 1:44pm
1
I didn’t find out the cause of this, neither when it happens, but sometimes cursor is not there on startup, so I can’t use the system as expected and I have to reboot. Then, the next time, it appears.
May have something to see with Decrease brightness button decreases to minimum brightness level, on first use on session
This is happening on Manjaro Gnome, Kernel 5.10. In the linked post is data about hard- and software used.
Hanzel
September 30, 2021, 4:24pm
2
Just to clarify, with cursor, does this mean the cursor in the password field to input text or your mouse cursor?
The next successful boot look at the errors in the previous boot log with this command:
journalctl --boot -1 --priority=err
Porru
October 1, 2021, 9:29am
3
The mouse button that is used for clicking elements.
I’ll paste the output of that command when able, thanks!
Porru
October 4, 2021, 5:04pm
4
-- Journal begins at Sun 2021-09-05 18:48:51 CEST, ends at Mon 2021-10-04 19:03:26 CEST. --
urr 04 18:59:17 ideaPad kernel: i2c_hid i2c-MSFT0004:00: HID over i2c has not been provided an Int IRQ
urr 04 18:59:17 ideaPad kernel: i2c_hid i2c-ITE8353:00: HID over i2c has not been provided an Int IRQ
urr 04 18:59:17 ideaPad kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
urr 04 18:59:18 ideaPad nmbd[609]: [2021/10/04 18:59:18.092144, 0] ../../source3/nmbd/nmbd.c:902(main)
urr 04 18:59:18 ideaPad nmbd[609]: nmbd version 4.15.0 started.
urr 04 18:59:18 ideaPad nmbd[609]: Copyright Andrew Tridgell and the Samba Team 1992-2021
urr 04 18:59:18 ideaPad nmbd[609]: [2021/10/04 18:59:18.093634, 0] ../../lib/util/become_daemon.c:150(daemon_status)
urr 04 18:59:18 ideaPad nmbd[609]: daemon_status: daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...
urr 04 18:59:18 ideaPad nmbd[609]: [2021/10/04 18:59:18.093966, 0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
urr 04 18:59:18 ideaPad nmbd[609]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
urr 04 18:59:18 ideaPad kernel: acp_pdm_mach acp_pdm_mach.0: snd_soc_register_card(acp) failed: -517
urr 04 18:59:19 ideaPad systemd-backlight[709]: Failed to get backlight or LED device 'backlight:acpi_video0': No such device
urr 04 18:59:19 ideaPad systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:acpi_video0.
urr 04 18:59:19 ideaPad systemd-backlight[710]: amdgpu_bl0: Failed to write system 'brightness' attribute: Invalid argument
urr 04 18:59:19 ideaPad systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0.
urr 04 18:59:20 ideaPad pipewire-media-session[911]: can't make factory instance: No such file or directory
urr 04 18:59:21 ideaPad bluetoothd[699]: Failed to set mode: Blocked through rfkill (0x12)
urr 04 18:59:21 ideaPad systemd[722]: Failed to start Application launched by gnome-session-binary.
urr 04 18:59:29 ideaPad smbd[1679]: [2021/10/04 18:59:29.804038, 0] ../../source3/smbd/server.c:1738(main)
urr 04 18:59:29 ideaPad smbd[1679]: smbd version 4.15.0 started.
urr 04 18:59:29 ideaPad smbd[1679]: Copyright Andrew Tridgell and the Samba Team 1992-2021
urr 04 18:59:48 ideaPad nmbd[609]: [2021/10/04 18:59:48.790997, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
urr 04 18:59:48 ideaPad nmbd[609]: Packet send failed to 192.168.0.255(137) ERRNO=Network is unreachable
urr 04 18:59:48 ideaPad nmbd[609]: [2021/10/04 18:59:48.791261, 0] ../../source3/nmbd/nmbd_packets.c:1639(retransmit_or_expire_response_records)
urr 04 18:59:48 ideaPad nmbd[609]: retransmit_or_expire_response_records: Failed to resend packet id 30142 to IP 192.168.0.255 on subnet 192.168.0.102
Another day:
journalctl --boot -1 --priority=err ✔
-- Journal begins at Sun 2021-09-05 18:48:51 CEST, ends at Wed 2021-10-06 11:20>
urr 06 11:18:12 ideaPad kernel: i2c_hid i2c-ITE8353:00: HID over i2c has not be>
urr 06 11:18:12 ideaPad kernel: i2c_hid i2c-MSFT0004:00: HID over i2c has not b>
urr 06 11:18:12 ideaPad kernel: sp5100-tco sp5100-tco: Watchdog hardware is dis>
urr 06 11:18:12 ideaPad nmbd[511]: [2021/10/06 11:18:12.989070, 0] ../../sourc>
urr 06 11:18:12 ideaPad nmbd[511]: nmbd version 4.15.0 started.
urr 06 11:18:12 ideaPad nmbd[511]: Copyright Andrew Tridgell and the Samba Te>
urr 06 11:18:13 ideaPad nmbd[511]: [2021/10/06 11:18:13.427313, 0] ../../lib/u>
urr 06 11:18:13 ideaPad nmbd[511]: daemon_status: daemon 'nmbd' : No local IP>
urr 06 11:18:13 ideaPad nmbd[511]: [2021/10/06 11:18:13.427796, 0] ../../sourc>
urr 06 11:18:13 ideaPad nmbd[511]: NOTE: NetBIOS name resolution is not suppo>
urr 06 11:18:13 ideaPad kernel: acp_pdm_mach acp_pdm_mach.0: snd_soc_register_c>
urr 06 11:18:15 ideaPad systemd-backlight[748]: Failed to get backlight or LED >
urr 06 11:18:15 ideaPad systemd-backlight[749]: amdgpu_bl0: Failed to write sys>
urr 06 11:18:15 ideaPad systemd[1]: Failed to start Load/Save Screen Backlight >
urr 06 11:18:17 ideaPad pipewire-media-session[936]: can't make factory instanc>
urr 06 11:18:17 ideaPad bluetoothd[721]: Failed to set mode: Blocked through rf>
urr 06 11:18:24 ideaPad smbd[1532]: [2021/10/06 11:18:24.545804, 0] ../../sour>
urr 06 11:18:24 ideaPad smbd[1532]: smbd version 4.15.0 started.
urr 06 11:18:24 ideaPad smbd[1532]: Copyright Andrew Tridgell and the Samba T>
urr 06 11:18:48 ideaPad nmbd[511]: [2021/10/06 11:18:48.857933, 0] ../../sourc>
urr 06 11:18:48 ideaPad nmbd[511]: *****
Porru
November 14, 2021, 11:07am
5
Here is more:
-- Journal begins at Sun 2021-09-05 18:48:51 CEST, ends at Sun 2021-11-14 12:07:01 CET. --
aza 14 12:05:01 ideaPad kernel: i2c_hid i2c-MSFT0004:00: HID over i2c has not been provided an Int IRQ
aza 14 12:05:01 ideaPad kernel: i2c_hid i2c-ITE8353:00: HID over i2c has not been provided an Int IRQ
aza 14 12:05:01 ideaPad kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
aza 14 12:05:01 ideaPad systemd[1]: Failed to start pkgfile database update.
aza 14 12:05:01 ideaPad nmbd[519]: [2021/11/14 12:05:01.993197, 0] ../../source3/nmbd/nmbd.c:902(main)
aza 14 12:05:01 ideaPad nmbd[519]: nmbd version 4.15.0 started.
aza 14 12:05:01 ideaPad nmbd[519]: Copyright Andrew Tridgell and the Samba Team 1992-2021
aza 14 12:05:02 ideaPad nmbd[519]: [2021/11/14 12:05:02.389349, 0] ../../lib/util/become_daemon.c:150(daemon_status)
aza 14 12:05:02 ideaPad nmbd[519]: daemon_status: daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...
aza 14 12:05:02 ideaPad nmbd[519]: [2021/11/14 12:05:02.390064, 0] ../../source3/nmbd/nmbd_subnetdb.c:252(create_subnets)
aza 14 12:05:02 ideaPad nmbd[519]: NOTE: NetBIOS name resolution is not supported for Internet Protocol Version 6 (IPv6).
aza 14 12:05:02 ideaPad kernel: acp_pdm_mach acp_pdm_mach.0: snd_soc_register_card(acp) failed: -517
aza 14 12:05:04 ideaPad systemd-backlight[785]: Failed to get backlight or LED device 'backlight:acpi_video0': No such device
aza 14 12:05:04 ideaPad systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:acpi_video0.
aza 14 12:05:06 ideaPad pipewire-media-session[973]: ms.mod.alsa-monitor: can't make factory instance: No such file or directory
aza 14 12:05:06 ideaPad bluetoothd[748]: Failed to set mode: Blocked through rfkill (0x12)
aza 14 12:05:07 ideaPad systemd[795]: Failed to start Application launched by gnome-session-binary.
aza 14 12:05:15 ideaPad smbd[1671]: [2021/11/14 12:05:15.808948, 0] ../../source3/smbd/server.c:1738(main)
aza 14 12:05:15 ideaPad smbd[1671]: smbd version 4.15.0 started.
aza 14 12:05:15 ideaPad smbd[1671]: Copyright Andrew Tridgell and the Samba Team 1992-2021
aza 14 12:05:21 ideaPad pipewire-media-session[973]: Failed to start HFP/HSP backend native
aza 14 12:05:21 ideaPad nmbd[519]: [2021/11/14 12:05:21.116577, 0] ../../source3/nmbd/nmbd.c:60(terminate)
aza 14 12:05:21 ideaPad nmbd[519]: Got SIGTERM: going down...
aza 14 12:05:21 ideaPad gdm[477]: Gdm: Failed to contact accountsservice: Errorea org.freedesktop.Accounts(r)en StartServiceByName deia egitean: Refusing activation, D-Bus is shutting down.
aza 14 12:05:21 ideaPad systemd-coredump[1835]: Failed to connect to coredump service: Connection refused
