Hello!
In gnome, every full screen app misses the cursor and idk the reason, Flameshot - Minecraft - any sort of full screen app
if there is a fix for that i would appreciate telling me
What does that mean, exactly? ![]()
- A sincere effort to use modest and proper language and grammar is a sign of respect toward the community that will certainly be appreciated and is quite likely to elicit positive responses. Please refrain from using so-called “textspeak”, “netspeak”, “leetspeak” and all other forms of internet slang.
Please see:
Why being rude?? i thought it’s a popular bug which many ppl faces
the mouse cursor goes away and doesn’t show up
I’m not.
The Ministry quote (redacted) was just having a bit of fun.
What is? You haven’t described what your issue is.
i can’t describe
it’s how i said when i go full screen the cursor is gone this is annoying
also there is some performance drops
Please provide your system information.
I met the same bug btw I use Arch Linux.
What’s your version of linux kernel , mutter version, gnome and GPU driver?
I build mutter and gnome-shell from AUR thus they are from the latest commit of the code. I thought it’s a bug introduced recently. But when I revert to a older commit of mutter, the problem doesn’t disappear.
I will report it to mutter.
Do you use the gnome extension soft-brightness? I found it’s the cause: Mouse Coursor invisible after login · Issue #45 · F-i-f/soft-brightness · GitHub
