A few days ago the latest version of cura in manjaro’s repository was 4.12, which less buggy, but still a pain to use it.
The 4.12 version had no materials and in case you wanted to rotate your print with the “select the face” rotate feature, it would simply crash. I wanted the latest version anyway, so I downloaded the AppImage from cura website, chmod-ed it to execute with chmod +x cura.AppImage and executed it. It instantly gave me a crash report every time it finished loading all the resources. The only thing you could do was to send report or close, those buttons closing cura, making it unusable. The only thing I could do about it was to stick with 1.12 and install muanually the materials.
I updated to cura 4.13.0 from the official manjaro repos but still the same thing as the AppImage. I can’t tell if I did something wrong since all I did was to install cura with sudo pacman -S cura command. I applied the reinstall approach too which didn’t solve my situation.
Here the logs:
Error traceback:
File "/usr/lib/python3.10/site-packages/cura/Settings/ExtruderManager.py", line 425, in getExtruderHasQualityForMaterial
active_material_node = active_variant_node.materials[extruder_stack.material.getMetaDataEntry("base_file")]
KeyError: 'empty_material'
Logs:
Thread 0x00007f7f830fe640 (most recent call first):
File "/usr/lib/cura/plugins/RemovableDriveOutputDevice/RemovableDrivePlugin.py", line 61 in _updateThread
File "/usr/lib/python3.10/threading.py", line 946 in run
File "/usr/lib/python3.10/threading.py", line 1009 in _bootstrap_inner
File "/usr/lib/python3.10/threading.py", line 966 in _bootstrap
Thread 0x00007f7f838ff640 (most recent call first):
File "/usr/lib/cura/plugins/USBPrinting/USBPrinterOutputDeviceManager.py", line 87 in _updateThread
Thread 0x00007f7f927fc640 (most recent call first):
File "/usr/lib/python3.10/site-packages/UM/Backend/Backend.py", line 165 in _storeStderrToLogThread
Thread 0x00007f7f92ffd640 (most recent call first):
File "/usr/lib/python3.10/site-packages/UM/Backend/Backend.py", line 153 in _storeOutputToLogThread
Thread 0x00007f7fcb7fe640 (most recent call first):
File "/usr/lib/python3.10/threading.py", line 320 in wait
File "/usr/lib/python3.10/threading.py", line 460 in acquire
File "/usr/lib/python3.10/site-packages/UM/JobQueue.py", line 98 in _nextJob
File "/usr/lib/python3.10/site-packages/UM/JobQueue.py", line 124 in run
Thread 0x00007f7fd0833640 (most recent call first):
Thread 0x00007f7fd1034640 (most recent call first):
File "/usr/lib/python3.10/site-packages/cura/Machines/ContainerTree.py", line 181 in run
File "/usr/lib/python3.10/site-packages/UM/JobQueue.py", line 133 in run
Thread 0x00007f7fd1835640 (most recent call first):
Current thread 0x00007f7ff4d4b740 (most recent call first):
File "/usr/lib/python3.10/site-packages/cura/CrashHandler.py", line 396 in _logInfoWidget
File "/usr/lib/python3.10/site-packages/cura/CrashHandler.py", line 182 in _createDialog
File "/usr/lib/python3.10/site-packages/cura/CrashHandler.py", line 86 in __init__
File "/usr/bin/cura", line 162 in exceptHook
File "/usr/lib/python3.10/site-packages/UM/Qt/ListModel.py", line 105 in setItems
File "/usr/lib/python3.10/site-packages/cura/Machines/Models/ExtrudersModel.py", line 234 in __updateExtruders
File "/usr/lib/python3.10/site-packages/UM/Qt/QtApplication.py", line 396 in exec_
File "/usr/lib/python3.10/site-packages/cura/CuraApplication.py", line 877 in run
File "/usr/bin/cura", line 236 in <module>
There is also no manjaro wiki to explain about installing something else or configuring it manually. Can’t tell what to do.
My system:
❯ inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=339a98e9-3ea4-4316-b188-618c0130b3a3 rw udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 81W8 v: Lenovo IdeaPad S145-15IIL
serial: <superuser required> Chassis: type: 10 v: Lenovo IdeaPad S145-15IIL
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: DKCN26WW date: 03/04/2020
ID-1: BAT0 charge: 25.4 Wh (93.0%) condition: 27.3/30.0 Wh (90.9%)
volts: 8.6 min: 7.5 model: SMP L16M2PB1 type: Li-poly serial: <filter>
status: Charging cycles: 105
RAM: total: 7.57 GiB used: 4.42 GiB (58.4%)
RAM Report:
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xA6
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1104 high: 1166 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 1166 2: 1108 3: 1059
4: 1085 bogomips: 9524
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel Iris Plus Graphics G1 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 13d3:5a08 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 238.47 GiB used: 46.12 GiB (19.3%)
model: PC SN520 SDAPMUW-256G-1101 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: 20240001 temp: 44.9 C scheme: MBR
ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
used: 46.12 GiB (19.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 339a98e9-3ea4-4316-b188-618c0130b3a3
used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 7F5E-2F02
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: IMC Networks Integrated Camera type: Video
Device-2: 1-9:3 info: [Maxxter] Optical Gaming Mouse [Xtrem]
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 18f8:0f97 class-ID: 0300
Device-3: 1-10:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 41.0 C mobo: N/A
Processes: 199 Uptime: 58m wakeups: 9 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1135 lib: 355
Shell: Zsh v: 5.8 running-in: xfce4-terminal inxi: 3.3.12
