opt
16 December 2020 22:51
1
Hi!
I have installed Manjaro recently. I have installed some basic programs like Chromium browser, FileZilla, messenger, Sublime Text, and some others. Each of them was installed from AUR or official repositories. So, I think it is not malware.
My processor: Intel® Core™ i5-7300HQ CPU @ 2.50GHz. 4 cores
Sometimes almost 4 cores load to 100%.
But there are no applications that can load the processor.
Screenshots from KSysGuard from Process Table and System Load tabs:
CPU loading is sorted descending in the screenshot on the Process Table tab.
Also, sudo top command shows the same results.
As a result, minimize/maximize window takes 3 seconds, open PNG takes 15 seconds, close heavy application takes 15 seconds, etc…
Why my processor loads so hard?
Or why the sum of loading percents on the Process Table tab is below than loading of cores of the processor on the System Load tab?
How can I solve it?
Thanks in advance!
Hi!
Before anyone else says it, here you’ll find how to provide good information!
The output of inxi -Fazy
could be useful in this situation.
Now, I had a similar issue and discovered that one of the cores on my CPU was always busy handling ACPI interrupts.
Run and post the output of this command: grep . -r /sys/firmware/acpi/interrupts/
and look for excessive high values. The numbers you see should be 0 or little over 100, if you see something in the order of thousands we maybe found your problem and I’ll tell you how to solve it!
Looks like KDE to me. By recently you mean from the iso 20.2-201203?
Could be related to this:
That doesnt cover everything though …
If you have been bitten by the bugged installer profile
(that erroneously included user-manager which then fell back on user-manager-git which then pulled in a lot of kde-dev packages instead of the regular ones)
Then you probably need to get them all …
That list should probably include:
attica-git karchive-git kauth-git kbookmarks-git kcodecs-git kcompletion-git kconfig-git kconfigwidgets-git kcoreaddons-git kcrash-git kdbusaddons-git kglobalaccel-git …
opt
17 December 2020 13:57
4
Hi! Thanks for the answer.
Command inxi -Fazy
output:
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=e6d4c353-0a86-45be-8360-28bcb2aa92c6 rw quiet udev.log_priority=3
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Acer product: Nitro AN515-51 v: V1.13 serial: <filter>
Mobo: KBL model: Freed_KLS v: V1.13 serial: <filter> UEFI: Insyde v: 1.13
date: 12/26/2017
ID-1: BAT1 charge: 42.8 Wh condition: 42.8/48.9 Wh (88%) volts: 16.6/15.2
model: COMPAL PABAS0241231 type: Li-ion serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Info: Quad Core model: Intel Core i5-7300HQ bits: 64 type: MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: DE
L2 cache: 6144 KiB
bogomips: 20004
Speed: 955 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900
Type: l1tf
Device-1: Intel HD Graphics 630 vendor: Acer Incorporated ALI driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:591b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile]
vendor: Acer Incorporated ALI driver: nouveau v: kernel bus ID: 01:00.0
chip ID: 10de:1c8d
Device-3: Quanta HD Webcam type: USB driver: uvcvideo bus ID: 1-9:4
chip ID: 0408:a060 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11
driver: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.2.3
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a171
Device-2: NVIDIA GP107GL High Definition Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel port: 4000 bus ID: 02:00.0
chip ID: 168c:003e
vendor: Acer Incorporated ALI driver: r8168 v: 8.048.03-NAPI modules: r8169
port: 3000 bus ID: 03:00.1 chip ID: 10ec:8168
IF: enp3s0f1 state: down mac: <filter>
Local Storage: total: 931.51 GiB used: 66.77 GiB (7.2%)
ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-21Z10T0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 1A02 scheme: GPT
ID-1: / raw size: 200.93 GiB size: 196.78 GiB (97.93%)
used: 66.77 GiB (33.9%) fs: ext4 dev: /dev/sda6
System Temperatures: cpu: 41.5 C mobo: 29.8 C gpu: nouveau temp: 40.0 C
Processes: 182 Uptime: 11m Memory: 7.66 GiB used: 1.21 GiB (15.8%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1183 lib: 338
Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.08
About ACPI interrupts:
Command grep . -r /sys/firmware/acpi/interrupts/
output:
/sys/firmware/acpi/interrupts/gpe2F: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe23: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe5D: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe51: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe1F: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe13: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe4D: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe41: 0 EN enabled unmasked
/sys/firmware/acpi/interrupts/gpe7B: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe0F: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe03: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe3D: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe31: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe6B: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe2D: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe21: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe5B: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe1D: 0 invalid unmasked
/sys/firmware/acpi/interrupts/ff_pwr_btn: 0 EN enabled unmasked
/sys/firmware/acpi/interrupts/gpe78: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe11: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe4B: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe0D: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe68: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe01: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe3B: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe58: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe2B: 0 invalid unmasked
/sys/firmware/acpi/interrupts/ff_rt_clk: 0 disabled unmasked
/sys/firmware/acpi/interrupts/ff_pmtimer: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe48: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe1B: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe76: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe38: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe0B: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe66: 5 EN enabled unmasked
/sys/firmware/acpi/interrupts/gpe28: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe56: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe18: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe46: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe74: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe08: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe36: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe64: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe26: 0 invalid unmasked
/sys/firmware/acpi/interrupts/error: 0
/sys/firmware/acpi/interrupts/gpe54: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe16: 0 invalid unmasked
/sys/firmware/acpi/interrupts/sci: 7
/sys/firmware/acpi/interrupts/gpe44: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe7E: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe72: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe06: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe34: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe6E: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe62: 0 EN enabled unmasked
/sys/firmware/acpi/interrupts/gpe24: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe5E: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe52: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe14: 2 EN enabled unmasked
/sys/firmware/acpi/interrupts/gpe4E: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe42: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe7C: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe70: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe04: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe3E: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe32: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe6C: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe60: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe2E: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe22: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe5C: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe50: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe1E: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe79: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe12: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe4C: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe40: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe7A: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe0E: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe69: 0 disabled unmasked
/sys/firmware/acpi/interrupts/gpe02: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe3C: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe30: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe6A: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe59: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe2C: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe20: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe5A: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe49: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe1C: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe77: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe10: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe4A: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe39: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe0C: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe67: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe00: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe3A: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe_all: 7
/sys/firmware/acpi/interrupts/gpe29: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe57: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe2A: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe19: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe47: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe1A: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe75: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe09: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe37: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe0A: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe65: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe27: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe55: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe17: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe45: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe7F: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe73: 0 invalid unmasked
/sys/firmware/acpi/interrupts/ff_gbl_lock: 0 EN enabled unmasked
/sys/firmware/acpi/interrupts/gpe07: 0 invalid unmasked
/sys/firmware/acpi/interrupts/sci_not: 0
/sys/firmware/acpi/interrupts/gpe35: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe6F: 0 EN enabled unmasked
/sys/firmware/acpi/interrupts/gpe63: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe25: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe5F: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe53: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe15: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe4F: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe43: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe7D: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe71: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe05: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe3F: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe33: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe6D: 0 disabled unmasked
/sys/firmware/acpi/interrupts/ff_slp_btn: 0 invalid unmasked
/sys/firmware/acpi/interrupts/gpe61: 0 EN enabled unmasked
So, there are no big values. That’s not my problem.
opt
17 December 2020 14:03
5
By recently I mean ISO from 20-1-200911. I downloaded ISO a long time ago, but installed Manjaro about a week ago. So, what I have to do? Update Manjaro to the latest version?
opt
30 December 2020 13:26
7
The problem isn’t solved. Sometimes I can’t even open Manjaro menu, it takes more than 10 seconds, CPU loading at this moment on 2 and 4 CPU core near 100%.
Hello @opt
I would assume that your problem is related to the kernel and therefore . Since Kernel 5.9 is EOL already, upgrade to 5.10 or use an LTS Kernel like 5.4: https://www.kernel.org/
Maybe also the Graphic Acceleration of the KDE Desktop can cause this. Disable all Effects there to see if this is the problem. Since (as i think) it could compute the graphic effects on the cpu instead on the gpu.
PS: I changed the category, since it is KDE related.
Run htop in konsole. Press f6(sort by), choose percent_cpu in the left hand column with the up/down arrows. htop should re-sort with the programs that are putting the biggest load on the cpu at the top. Watch for a few seconds/minutes to see which programs are loading you down. It should give you a starting point.
