Could not open folder tags
Hi,
For some time every opening of the File Dialog is preceded by the subject message. It’s just an annoyance, yet I’d like to get rid of it. I was not able to discover exactly this case. I can’t even guess what the tags folder is :slight_smile:
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
Thanks! Are you really sure you want all of this? Some uuids below cleaned up manually, if it makes any difference :slight_smile: . DE: KDE + i3-gaps.
ᐅ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: i3bar wm: i3 4.19.1 vt: 1
  Type: Desktop Mobo: MSI model: H61M-E23(B3)(MS-7680) v: 2.0 serial: <filter>
  BIOS: American Megatrends v: 12.3 date: 01/10/2013
  RAM: total: 11.59 GiB used: 3.98 GiB (34.3%)
  Info: Dual Core model: Intel Celeron G530 bits: 64 type: MCP
  arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
  cache: L2: 2 MiB bogomips: 9581
  Speed: 1885 MHz min/max: 1600/2400 MHz Core speeds (MHz): 1: 1885 2: 1730
  Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov constant_tsc
  cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est flexpriority
  flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear mmx monitor msr
  mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni
  popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2
  ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi
  vpid xsave xsaveopt xtopology xtpr
  Type: l1tf
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
  vendor: Micro-Star MSI driver: i915 v: kernel bus-ID: 00:02.0
  chip-ID: 8086:0102 class-ID: 0300
  Display: x11 server: X.Org 1.20.11 driver: loaded: intel
  unloaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1280x1024 s-dpi: 96 s-size: 338x270mm (13.3x10.6")
  s-diag: 433mm (17")
  Monitor-1: VGA1 res: 1280x1024 hz: 60 dpi: 96 size: 340x270mm (13.4x10.6")
  diag: 434mm (17.1")
  OpenGL: renderer: Mesa DRI Intel HD Graphics 2000 (SNB GT1)
  v: 3.3 Mesa 21.1.2 compat-v: 3.0 direct render: Yes
  vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
  chip-ID: 8086:1c20 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.30 running: yes
  vendor: Micro-Star MSI driver: r8168 v: 8.048.03-NAPI modules: r8169
  port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  IF-ID-1: br-5fae108757f3 state: down mac: <filter>
  IF-ID-2: docker0 state: down mac: <filter>
  driver: btusb v: 0.8 bus-ID: 1-1.1:3 chip-ID: 0a12:0001 class-ID: fe01
  Permissions: Unable to run lvs. Root privileges required.
  Local Storage: total: 2.73 TiB used: 2.45 TiB (89.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD30EFRX-68EUZN0
  size: 2.73 TiB block-size: physical: 4096 B logical: 512 B speed: <unknown>
  rotation: 5400 rpm serial: <filter> rev: 0A82 scheme: GPT
  ID-1: / raw-size: 48.83 GiB size: 47.81 GiB (97.92%) used: 33.55 GiB (70.2%)
  fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
  ID-2: /home raw-size: 2.68 TiB size: 2.66 TiB (99.21%)
  used: 2.42 TiB (91.1%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: HomeS
  ID-1: swap-1 type: partition size: 512 MiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sda2 maj-min: 8:2 label: N/A
  ID-1: /dev/sda1 maj-min: 8:1 size: 1024 KiB fs: <superuser required>
  label: N/A uuid: N/A
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
  speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.1:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
  type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
  Device-2: 1-1.2:4 info: MosArt Wireless Keyboard/Mouse type: Keyboard,Mouse
  driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
  power: 100mA chip-ID: 062a:4101 class-ID: 0301
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  System Temperatures: cpu: 29.8 C mobo: 27.8 C
  Processes: 225 Uptime: 1d 11h 25m wakeups: 0 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: pacman: 1843
  lib: 450 flatpak: 0 Shell: Zsh v: 5.8 running-in: lxterminal inxi: 3.3.04
~ ᐅ
I can’t either - but KDE employs some indexing functionality which makes it possible to tag files for easier retrieval.
I am not a KDE user - so I have no indepth knowledge - my guess is that you have been altering a setting which instructs the indexer and file dialog to search for tags as well as filenames.
  1. inxi looks good.
  2. Can you post a screenshot of the File Dialog and also one of your file manager? (Do you have any other than Dolphin in use?)
  3. Does this also happen under a newly created user? (E.G. llama2)
:thinking:
Do you really want a screenshot? It’s a plain message dialog with an OK button. It pops up ahead of any KDE File Dialog (with Okular, Konqueror, Gwenview, etc.; not with Geany, for instance).
With another (specially created) user the subj won’t happen.
So you have an issue in your user profile and finding out which exact setting you changed is going to take weeks if not months, so we’re going to do the following:
  • Verify that the new user has access to the same groups as your old one by executing groups and comparing the output of both users.
    groups llama
    groups llama2
    (Where obviously, llama is your old user and llama2 is your new one.)
    E.G. if llama is a member of operator and llama2 isn’t, execute:
    usermod --append --groups operator llama2
  • Copy all data files from your old profile into your new one
    cp --verbose --recursive --preserve=time-stamps /home/llama/Documents/* /home/llama2/Documents/
    If that worked and you had no errors, remove the documents from your old user:
    rm --recursive /home/llama/Documents/*
    repeat for:
    • Pictures
    • Videos
    • Music
    • .thunderbird
    • .mozilla/firefox/
    • Templates, and everything else that is important to you.
    • Linux games like Battle of Wesnoth have their game data stored under ~/.local/share/ E.G. ~/.local/share/wesnoth/
    After everything has been copied over, disable the old user so you cannot accidentally log on:
    usermod --lock llama
    If you would have theming going on, don’t do everything in one day but do this at the rate of 1 application / theme / whatever per day and if the same issue crops up again, roll back your last change and thus you’ve now pinpointed the exact setting that made your old user misbehave. :thinking:
  • in 1 month delete the entire home directory of your old user, but don’t delete the user itself so that in 6 months time files still owned by that user will still show up under its username.
  • If you ever migrate to a new machine, just don’t migrate the old user: only the new one.
  • From now on, start making backups so you can roll back and never have to do this again:
Are you prescribing a shave with a guillotine for my running nose? I’ll have to assume the proper attitude first, I’m afraid :smile:
Your comment rang a bell :slight_smile: . A while ago I turned off File Search (baloo_file process) in a not-so-successful attempt to diminish the CPU load. I turned it back on; no more trouble with the tags folder.
Now the real question reads like this: how should I turn off File Search the right way?
No, I’m prescribing a quick shave with a shaver instead of epilation with a tweezer.
:man_shrugging:
Try: balooctl purge
or/and disable baloo and then balooctl purge
maybe: rm ~/file.desktop ??? I don’t know what helped me.
Sometimes it’s quicker, easier, less messy and in general better to start from scratch than it is to troubleshoot something…and that amount of effort and time spent varies from situation to situation and person to person.
You’re telling the wrong person. I’m not OP and I agree.
:man_shrugging:
Yeah, just left it out there.
