Everything vanished from the Manjaro menu (you know that appears when you click on that).
There are only three group:
All Applications - this is empty
Places - works as usual
Recent Files - works as usual
And no more. How can i get back the old menu?
I restarted the system, now i can’t log in. Message something like this: “Failed strat session”
Now i writing form my backup system.
What would be the solution to restore the menu panel?
How can i log in again?
Please read this: [HowTo] Provide System Information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command) but as you can’t seem to log in through the GUI, try Ctrl+Alt+F2 to go to TTY2 and provide the information from there.
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
The exact error message please?
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
