Hello thanks for the reply.
I didn’t find any help here but I know a little bit of MarkDown language so I tried my best to answer all your questions.
The output of the commands are as follows.
networkctl status --all
mrkk ~ ✓ networkctl status --all
WARNING: systemd-networkd is not running, output will be incomplete.
Failed to query link bit rates: Unit dbus-org.freedesktop.network1.service not found.
Failed to query link DHCP leases: Unit dbus-org.freedesktop.network1.service not found.
● 1: lo
Link File: n/a
Network File: n/a
State: n/a (unmanaged)
Online state: unknown
Type: loopback
Hardware Address: 00:00:00:00:00:00
MTU: 65536
QDisc: noqueue
IPv6 Address Generation Mode: eui64
Number of Queues (Tx/Rx): 1/1
Address: 127.0.0.1
::1
● 2: enp5s0
Link File: /usr/lib/systemd/network/99-default.link
Network File: n/a
Type: ether
Path: pci-0000:05:00.0
Driver: r8169
Vendor: Realtek Semiconductor Co., Ltd.
Model: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (Onboard Ethernet)
Hardware Address: b4:2e:99:e1:f7:bf (GIGA-BYTE TECHNOLOGY CO.,LTD.)
MTU: 1500 (min: 68, max: 9194)
ip addr
mrkk ~ ✓ ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp5s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether b4:2e:99:e1:f7:bf brd ff:ff:ff:ff:ff:ff
3: pvpnksintrf0: <BROADCAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc noqueue state UNKNOWN group default qlen 1000
link/ether 26:31:62:c4:87:01 brd ff:ff:ff:ff:ff:ff
inet 100.85.0.1/24 brd 100.85.0.255 scope global noprefixroute pvpnksintrf0
inet6 fdeb:446c:912d:8da::/64 scope global noprefixroute
inet6 fe80::69ed:121f:5742:a309/64 scope link noprefixroute
inet6 fe80::dd8a:7de3:fab9:6495/64 scope link
4: ipv6leakintrf0: <BROADCAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc noqueue state UNKNOWN group default qlen 1000
link/ether d6:d7:48:75:c1:a1 brd ff:ff:ff:ff:ff:ff
inet6 fe80::21be:a268:a8be:f2b2/64 scope link noprefixroute
inet6 fe80::7062:c31c:6b49:f4ce/64 scope link
5: pvpnroutintrf0: <BROADCAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc noqueue state UNKNOWN group default qlen 1000
link/ether e6:a0:2f:b9:80:71 brd ff:ff:ff:ff:ff:ff
inet 100.85.0.1/24 brd 100.85.0.255 scope global noprefixroute pvpnroutintrf0
inet6 fe80::f2cf:89a7:1d13:27ca/64 scope link noprefixroute
inet6 fe80::dc20:7af1:73c2:663a/64 scope link
6: wlp0s20f0u7: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:1e:a6:99:75:b5 brd ff:ff:ff:ff:ff:ff
inet 192.168.43.64/24 brd 192.168.43.255 scope global dynamic noprefixroute wlp0s20f0u7
valid_lft 3457sec preferred_lft 3457sec
inet 192.168.43.65/24 brd 192.168.43.255 scope global secondary dynamic noprefixroute wlp0s20f0u7
valid_lft 3465sec preferred_lft 3015sec
inet6 2402:3a80:1a48:1809:1496:b52d:8bfb:da89/64 scope global noprefixroute
inet6 2402:3a80:1a48:1809:7454:2f3f:ab59:b21f/64 scope global mngtmpaddr noprefixroute
inet6 fe80::d8be:ea65:5ad7:c2c7/64 scope link
inet6 fe80::268:fcbb:f22d:edf0/64 scope link noprefixroute
ip route
mrkk ~ ✓ ip route
0.0.0.0/1 dev pvpnroutintrf0 proto static scope link metric 97
default via 100.85.0.1 dev pvpnksintrf0 proto static metric 98
default via 192.168.43.1 dev wlp0s20f0u7 proto dhcp src 192.168.43.65 metric 3006
100.85.0.0/24 dev pvpnroutintrf0 proto kernel scope link src 100.85.0.1 metric 97
100.85.0.0/24 dev pvpnksintrf0 proto kernel scope link src 100.85.0.1 metric 98
128.0.0.0/2 dev pvpnroutintrf0 proto static scope link metric 97
192.0.0.0/4 dev pvpnroutintrf0 proto static scope link metric 97
192.168.43.0/24 dev wlp0s20f0u7 proto dhcp scope link src 192.168.43.65 metric 3006
208.0.0.0/6 dev pvpnroutintrf0 proto static scope link metric 97
212.0.0.0/13 dev pvpnroutintrf0 proto static scope link metric 97
212.8.0.0/17 dev pvpnroutintrf0 proto static scope link metric 97
212.8.128.0/18 dev pvpnroutintrf0 proto static scope link metric 97
212.8.192.0/19 dev pvpnroutintrf0 proto static scope link metric 97
212.8.224.0/20 dev pvpnroutintrf0 proto static scope link metric 97
212.8.240.0/21 dev pvpnroutintrf0 proto static scope link metric 97
212.8.248.0/23 dev pvpnroutintrf0 proto static scope link metric 97
212.8.250.0/25 dev pvpnroutintrf0 proto static scope link metric 97
212.8.250.128/27 dev pvpnroutintrf0 proto static scope link metric 97
212.8.250.160/28 dev pvpnroutintrf0 proto static scope link metric 97
212.8.250.176/29 dev pvpnroutintrf0 proto static scope link metric 97
212.8.250.184/30 dev pvpnroutintrf0 proto static scope link metric 97
212.8.250.188/31 dev pvpnroutintrf0 proto static scope link metric 97
212.8.250.190 dev pvpnroutintrf0 proto static scope link metric 97
212.8.250.192/26 dev pvpnroutintrf0 proto static scope link metric 97
212.8.251.0/24 dev pvpnroutintrf0 proto static scope link metric 97
212.8.252.0/22 dev pvpnroutintrf0 proto static scope link metric 97
212.9.0.0/16 dev pvpnroutintrf0 proto static scope link metric 97
212.10.0.0/15 dev pvpnroutintrf0 proto static scope link metric 97
212.12.0.0/14 dev pvpnroutintrf0 proto static scope link metric 97
212.16.0.0/12 dev pvpnroutintrf0 proto static scope link metric 97
212.32.0.0/11 dev pvpnroutintrf0 proto static scope link metric 97
212.64.0.0/10 dev pvpnroutintrf0 proto static scope link metric 97
212.128.0.0/9 dev pvpnroutintrf0 proto static scope link metric 97
213.0.0.0/8 dev pvpnroutintrf0 proto static scope link metric 97
214.0.0.0/7 dev pvpnroutintrf0 proto static scope link metric 97
216.0.0.0/5 dev pvpnroutintrf0 proto static scope link metric 97
224.0.0.0/3 dev pvpnroutintrf0 proto static scope link metric 97
I connected the wifi using:
nmcli dev wifi list
sudo nmcli dev wifi connect <Network SSID>
It’s not like I’m connecting it for the first time. I just never had the issue previously. I always connect with my android device
The contents of /etc/resolv.conf are as follows
# Generated by resolvconf
nameserver 192.168.43.1
nameserver 2402:3a80:1fff:40::4
nameserver 2001:4860:4860::6464
One thing I wanted to say that this file is changing every time I’m rebooting the Computer.
Answer to your suggestion
I know I’m just asking if it’s the problem of DNS or something.
Thank you waiting for your reply
