Conky Showcase 2022
This thread is the continuation of the Conky Showcase 2021 and the same rules apply:
Share your conky thread
Share what ever you use for conky - just remember - credit where credit is due.
Basic guidelines
If your conky script is based on another conky - your header should use something like this
conky.config = {
-- original author https://github.com/altinukshini/conky_blue
-- modified by linux-aarhus
When you post large amounts of code
  1. Use code fence - select your code and click the </> in the post toolbar
  2. Use the details tag - select your fenced code and click :gear: → Hide details
Below screenshot credit @ManjaroDevOps :
My Gotham Conky mod, edited color and added distro name and logo icon. Icon below screenshot in case you want it for your conky.
Edit: Changed color of distro name and position of logo in conky.
Source
use_xft yes
xftfont 123:size=8
xftalpha 0.1
update_interval 1
total_run_times 0
own_window yes
own_window_type desktop
own_window_transparent yes
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
own_window_colour 000000
own_window_argb_visual yes
own_window_argb_value 0
double_buffer yes
#minimum_size 250 5
#maximum_width 500
draw_shades no
draw_outline no
draw_borders no
draw_graph_borders no
default_color white
default_shade_color red
default_outline_color green
alignment top_right
gap_x -80
gap_y 10
no_buffers yes
uppercase no
cpu_avg_samples 2
net_avg_samples 1
override_utf8_locale yes
use_spacer yes
minimum_size 0 0
TEXT
${voffset 10}${color EAEAEA}${font GE Inspira:pixelsize=120}${time %I:%M}${font}${voffset -84}${offset 10}${color 039F4A}${font GE Inspira:pixelsize=42}${time %d} ${voffset -15}${color EAEAEA}${font GE Inspira:pixelsize=22}${time  %B} ${time %Y}${font}${voffset 24}${font GE Inspira:pixelsize=58}${offset -148}${time %A}${font}
${voffset 1}${offset 12}${font Ubuntu:pixelsize=12}${color 039F4A}HD ${offset 9}$color${fs_free /} / ${fs_size /}${offset 30}${color 039F4A}RAM ${offset 9}$color$mem / $memmax${offset 30}${color 039F4A}CPU ${offset 9}$color${cpu cpu0}%
${voffset 1}${offset 150}${font GE Inspira:pixelsize=32}${color EAEAEA}Manjaro Linux${alignc}
${image /home/marcs/Pictures/Icons/manjaro-icon.png -p 95,148 -s 56x56}${alignc}
manjaro-icon
Minimalist
Another minimum conky. :grinning:
Edit: Changed Font
Changed up this conky: Elegance-beam conky variant
Note: If you want to make the conky background semi-transparent change the below settings to:
From: own_window_transparent = true, To: own_window_transparent = false,
Then adjust the below value to the desired transparency level for your wallpaper.
Adj: own_window_argb_value = 80,
Summary
conky.config = {
	alignment = 'top_right',
	background = false,
	border_inner_margin = 15,
	border_width = 5,
	default_color = 'ffffff',  --ffffff # grey 5f5f5f 3F3F3F 183149 3B3B3B 26211F
	double_buffer = true,
	draw_borders = false,
	draw_graph_borders = false,
	draw_outline = false,
	draw_shades = false,
	gap_x = 25,
	gap_y = 25,
	maximum_width = 370,
	override_utf8_locale = true,
    own_window = true,
    own_window_class = 'Conky',
    own_window_type = 'normal',
	own_window_hints = 'undecorated,below,skip_taskbar,skip_pager,sticky',
	own_window_argb_visual = true,
	own_window_argb_value = 150,
	text_buffer_size = 8000,
	total_run_times = 0,
	update_interval = 1,
	uppercase = false,
	use_xft = true,
	xftalpha = 1,
	short_units = false,
	font = 'GE Inspira:style=Light:pixelsize=16',
	color1 = '00C75C',
	color2 = '005929',
	color3 = '005929',
conky.text = [[
${font GE Inspira:pixelsize=150}${alignr}${color1}${time %H}
${voffset -35}${alignr}${color2}${time %M}
${voffset -90}${color3}${font GE Inspira:pixelsize=25}${alignr}${time %A}  |  ${alignr}${time %B %d, %Y}${color}${font}
${color6}${font GE Inspira:size=14}RESOURCES ${hr}$font
cpu1 ${alignr}${cpu cpu1}%
cpu2 ${alignr}${cpu cpu2}%
cpu3 ${alignr}${cpu cpu3}%
cpu4 ${alignr}${cpu cpu4}%
cpu5 ${alignr}${cpu cpu5}%
cpu6 ${alignr}${cpu cpu6}%
cpu7 ${alignr}${cpu cpu7}%
cpu8 ${alignr}${cpu cpu8}%
ram ${alignr}${mem} / ${memmax}
system  ${alignr}${fs_used_perc /}% / ${fs_size /}
${voffset 30}${font Raleway:pixelsize=18}${alignr}${color3}Manjaro Linux${color}
${image /home/marcs/Pictures/Icons/manjaro-icon.png -p 110,617 -s 56x56}${alignr}
Conky is beautiful in the desktop view. But if you open any maximized size window on the desktop, you won’t see the Conky, also do not see CPU/Memory monitoring …
I would put Conky/widget in the panel that always shows.
Thank you, I thought about that but did not like how it looked with the border. But it is easy enough for someone to change should they want to use this conky.
New Conky Mod! :slight_smile:
Original Conky: QNRB
Note: You will notice some of the items not working, this is due to conky not being able to pull the info as I am running Manjaro in a VM.
Summary
conky.config = {
  console_bar_fill   = '»',
  console_bar_unfill = ' ',
  alignment = 'top_left',
  background = false,
  border_width = 2,
  cpu_avg_samples = 2,
  -- define Manjaro colours:
  default_color = '#00C75C',  -- Ubuntu Orange
  color1 = '#709080',         -- Kakhi
  color2 = '#b4b4b4',         -- Light Grey
  color3 = '#00EE6E',         -- Light Green
  color4 = '#005929',         -- White
  color5 = '#00C75C',         -- Black
  color6 = '#ffffff',         -- Light aubergine
  font = 'GE Inspira:size=11',
  default_outline_color = '#1abc9c',  -- Same HTML as current terminal
  default_shade_color = '#1abc9c',  -- Same HTML as current terminal
  draw_graph_borders = true,
  extra_newline = false,
  format_human_readable=true,
  gap_x = 20,
  gap_y = 40,
  minimum_height = 300,
  minimum_width = 300,
  net_avg_samples = 2,
  no_buffers = true,
  out_to_console = false,
  out_to_ncurses = false,
  out_to_stderr = false,
  out_to_x = true,
  own_window = true,
  own_window_class = 'conky',
  own_window_type = 'desktop',
  -- set transparency:
  own_window_argb_value = 140,
  show_graph_range = false,
  show_graph_scale = false,
  stippled_borders = 0,
  update_interval = 1.0,
  uppercase = false,
  use_spacer = 'none',
  use_xft = true,
conky.text = [[
${image /home/marcs/Pictures/Icons/manjaro-icon.png -p 50,28 -s 43x43}${alignc}
${color6}${font :size=18}${alignc}    Manjaro Linux
${color6}${hr}$font
${color5}ARCH:${color}${alignr}$machine
${color5}UPTIME:${color}${alignr}$uptime_short
${color5}KERNEL:${color}${alignr}$kernel
${color6}${font :size=12}CPU & CORES ${hr}$font
${color5}CPU:${color}${alignr}AMD Ryzen 7 3800X
${color6} 01 - 04:${color4}${goto 100}${cpu cpu1}% ${goto 150}${cpu cpu2 }% ${goto 200}${cpu cpu3 }% ${goto 250}${cpu cpu4 }%
${color6} 05 - 08:${color4}${goto 100}${cpu cpu5}% ${goto 150}${cpu cpu6 }% ${goto 200}${cpu cpu7 }% ${goto 250}${cpu cpu8 }%
${color5}CPU Load: ${color4}$cpu% ${color3}$cpubar
${voffset -5}${color1}${cpugraph cpu0 -l -t}${voffset -5}
${color5}CPU Freq: ${color4}$freq_g GHz ${alignr}${color5}CPU Temp: ${color4}${acpitemp}°C
${color6}${font :size=12}MEMORY ${hr}$font
${color5}RAM: ${color4}$mem ${color}/ $memmax ${color4}($memperc%) ${color3}$membar
${color6}${font :size=12}GPU ${hr}$font
${color5}GPU:${color}${alignr}NVIDIA GeForce RTX 3060
${color5}GPU Temp: ${color4}$alignr ${nvidia temp} °C
${color5}GPU Speed: $alignr${color4}${nvidia gpufreq} Mhz
${color5}MEM Speed: $alignr${color4}${nvidia memfreq} Mhz
${color6}${font :size=12}NETWORK ${hr}$font
${color5}IP ADDRESS:${color}${alignr}${addr ens33}
${voffset -5}${if_match "${addr ens33}"!="No Address"}${color1}${downspeedgraph ens33 24,159 00EE6E 00CD5F -l -t} ${color2}${upspeedgraph ens33 24,159 00EE6E 00CD5F -l -t}
${voffset -5}${color5}Download: ${color4}${downspeedf ens33}k/s ${alignr}${color5}Upload: ${color4}${upspeedf ens33}k/s ${font}${endif}
${color6}${font :size=12}FILE SYSTEMS ${hr}$font
${color5}Mountpoints${goto 100}Free / Total${alignr}I/O
${color5}Mount: / ${goto 100}${color4}${fs_free /} ${color}/ ${fs_size /} ${alignr}${color4}${diskio}
${color6}${font :size=12}PROCESSES ${hr}$font
${color5}TOTAL${color4}${alignr}${processes}
${color5}Name ${goto 149}PID${goto 215}MEM${goto 280}CPU
${color6}${top name 1}${color4}${font}${goto 130}${top pid 1}${goto 200}${top mem 1}%${goto 265}${top cpu 1}%
${color6}${top name 2}${color4}${font}${goto 130}${top pid 2}${font}${goto 200}${top mem 2}%${goto 265}${top cpu 2}%
${color6}${top name 3}${color4}${font}${goto 130}${top pid 3}${font}${goto 200}${top mem 3}%${goto 265}${top cpu 3}%
${color6}${top name 4}${color4}${font}${goto 130}${top pid 4}${font}${goto 200}${top mem 4}%${goto 265}${top cpu 4}%
${color6}${top name 5}${color4}${font}${goto 130}${top pid 5}${font}${goto 200}${top mem 5}%${goto 265}${top cpu 5}%
${color6}${top name 6}${color4}${font}${goto 130}${top pid 6}${font}${goto 200}${top mem 6}%${goto 265}${top cpu 6}%
${color6}${top name 7}${color4}${font}${goto 130}${top pid 7}${font}${goto 200}${top mem 7}%${goto 265}${top cpu 7}%
${color6}${top name 8}${color4}${font}${goto 130}${top pid 8}${font}${goto 200}${top mem 8}%${goto 265}${top cpu 8}%
${color6}${top name 9}${color4}${font}${goto 130}${top pid 9}${font}${goto 200}${top mem 9}%${goto 265}${top cpu 9}%
${color6}${top name 10}${color4}${font}${goto 130}${top pid 10}${font}${goto 200}${top mem 10}%${goto 265}${top cpu 10}%${voffset -20}
So very minimal conky.
Took from this conky: eOS Conky by npikill
Summary
conky.config = {
    alignment = 'top_middle',
	background = false,
	border_width = 5,
	default_color = '5A5B3F',  --ffffff # grey 5f5f5f 3F3F3F 183149 3B3B3B 26211F
	gap_x = 30,
	gap_y = 60,
	maximum_width = 550,
    own_window = true,
	own_window_argb_value = 0,
	uppercase = false,
	use_xft = true,
	xftalpha = 1,
	font = 'Raleway:style=Light:pixelsize=16',
	color1 = '505139',
	color2 = '005929',
	color3 = '005929',
conky.text = [[
${font Raleway:weight=Light:size=88}${alignc}${time %I:%M}${font}
${goto 15}${font Raleway:weight=Light:size=32}${alignc} ${time %A %B %d}${font}
${font Signerica Medium:pixelsize=24}${alignc}${color1}Manjaro Linux${color}
Ok so added a little to the last conky I posted in case someone wanted a little more info in the conky.
Summary
conky.config = {
	background = false,
	border_width = 5,
	gap_x = 30,
	gap_y = 60,
	maximum_width = 650,
    own_window = true,
	uppercase = false,
	use_xft = true,
	xftalpha = 1,
	color1 = '505139',
	color2 = '005929',
	color3 = '005929',
conky.text = [[
${font Raleway:weight=Light:size=78}${alignc}${time %I:%M}${font}
${goto 15}${font Raleway:weight=Light:size=28}${alignc} ${time %A %B %d}${font}
${alignc}${voffset 6}${offset 12}${font GE_Inspira:pixelsize=14}${color 86877A}HD ${offset 9}$color${fs_free /} / ${fs_size /}${offset 30}${color 86877A}RAM ${offset 9}$color$mem / $memmax${offset 30}${color 86877A}CPU ${offset 9}$color${cpu cpu0}%
${alignc}       __________________________________________________________________________
${font Signerica Medium:pixelsize=20}${alignc}${color1}Manjaro Linux${color}
Resumen
conky.config = {
  background = true,
  border_width = 0.5,
  cpu_avg_samples = 4,
  default_color = 'white',
  default_outline_color = 'grey',
  default_shade_color = 'black',
  draw_borders = true,
  use_xft = true,
  font = 'OpenSans:size=10',
  gap_x = 1,
  gap_y = 0,
  maximum_width = 400,
  minimum_height = 5,
  minimum_width = 5,
  own_window = true,
  own_window_colour = '000000',
  own_window_hints = 'undecorated,below,sticky,skip_taskbar,skip_pager',
  uppercase = false,
conky.text = [[
${font MesloLGS NF:bold:size=18}$alignc${color Lime} Manjaro ${execi 100000 lsb_release -sc}
${voffset -90}
${color white}
${font}
${font OxygenSans:pixelsize=18}$alignc${time %A} ${color white}${time %b}-${color white}${time  %d}-${color white}${time %Y}${font}
${font OxygenSans:pixelsize=18}$alignc${time %I:%M:%S} ${color white}
#System
${font MesloLGS NF:size=15}${color Tan1} ${font OxygenSans:bold:size=11}${color Tan1}SYSTEM ${color White}${hr 2}
$font${color White}$sysname $kernel $alignr $machine
Hostname: $alignr${nodename}
Uptime: $alignr${uptime}
System Updates: $alignr ${execpi 3600 checkupdates | wc -l}  Updates
Battery: $alignr ${battery_time BAT1}  ${battery_percent BAT1}%
#CPU
${font MesloLGS NF:size=14}${color Tan1} ${font OxygenSans:bold:size=11}${color Tan1}CPU ${color White}${hr 2}
#$font${color White}Temperature: $alignr ${acpitemp} °C
${font OpenSans:bold:size=10}${color White}CPU USAGE: ${cpu cpu0}% $alignr Temp: ${hwmon 4 temp 1}°C
$font${color White}CPU1 ${freq_g 1}Ghz  ${cpubar cpu1}
CPU2 ${freq_g 2}Ghz  ${cpubar cpu2}
CPU3 ${freq_g 3}Ghz  ${cpubar cpu3}
CPU4 ${freq_g 4}Ghz  ${cpubar cpu4}
CPU5 ${freq_g 5}Ghz  ${cpubar cpu5}
CPU6 ${freq_g 6}Ghz  ${cpubar cpu6}
CPU7 ${freq_g 7}Ghz  ${cpubar cpu7}
CPU8 ${freq_g 8}Ghz  ${cpubar cpu8}
${cpugraph} $color
#MEMORY
${font MesloLGS NF:size=14}${color Tan1} ${font OxygenSans:bold:size=11}${color Tan1}MEMORY ${color White}${hr 2}
$font${color White}MEM $alignc $mem / $memmax $alignr $memperc%
$membar
$font${color White}SWAP $alignc $swap / $swapmax $alignr $swapperc%
$swapbar
#HDD
${font MesloLGS NF:size=15}${color Tan1} ${font OxygenSans:bold:size=11}${color Tan1}SSD ${color White}${hr 2}
$font${color White}Boot $alignc ${fs_used /boot} / ${fs_size /boot} $alignr ${fs_used_perc /boot}%
${fs_bar /boot}
$font${color White}Root $alignc ${fs_used /} / ${fs_size /} $alignr ${fs_used_perc /}%
${fs_bar /}
$font${color White}Home $alignc ${fs_used /home} / ${fs_size /home} $alignr ${fs_used_perc /home}%
${fs_bar /home}
#TOP PROCESSES
${font MesloLGS NF:size=15}${color Tan1} ${font OxygenSans:bold:size=11}${color Tan1}TOP PROCESSES ${color White}${hr 2}
${color White}$font${top_mem name 1}${alignr}${top_mem mem 1} %
$font${top_mem name 2}${alignr}${top_mem mem 2} %
$font${top_mem name 3}${alignr}${top_mem mem 3} %
$font${top_mem name 4}${alignr}${top_mem mem 4} %
#NETWORK WLAN0
${if_existing /proc/net/route wlan0}${font MesloLGS NF:size=15}${color Tan1} ${font OxygenSans:bold:size=11}${color Tan1}NETWORK ${color White}${hr 2}
$font${color White}${wireless_essid wlan0} Quality: $alignr ${wireless_link_qual_perc wlan0}%
${wireless_link_bar wlan0}
$font${color White}Local IP: $alignr ${addrs wlan0}
Down Speed: $alignr ${downspeed wlan0}/s
Up Speed: $alignr ${upspeed wlan0}/s
${hr 2}
Downloaded: $alignr ${totaldown wlan0}
Uploaded: $alignr ${totalup wlan0}
#NETWORK ETH0
${else}${if_existing /proc/net/route eth0}${font MesloLGS NF:size=15}${color Tan1} ${font OxygenSans:bold:size=11}${color Tan1}NETWORK ${color White}${hr 2}
$font${color White}Local IP: $alignr ${addrs eth0}
${hr 2}
Down Speed: $alignr ${downspeed eth0}/s
Up Speed: $alignr ${upspeed eth0}/s
${hr 2}
Downloaded: $alignr ${totaldown eth0}
Uploaded: $alignr ${totalup eth0}${endif}${endif}
New custom conky, minimal.
Summary
##Feel free to edit and make your own.
conky.config = {
  background = false,
  border_width = 2,
  -- define colours:
  default_color = '#00C75C',  -- Orange
  color3 = '#717373',         -- Light Green
  color4 = '#3E3E3E',         -- White
  color5 = '#e0c0ad',         -- Black
  font = 'GE Inspira Regular:pixelsize=13',
  gap_x = 10,
  gap_y = 460,
  minimum_width = 120,
  no_buffers = true,
  out_to_x = true,
  own_window = true,
  uppercase = false,
  use_xft = true,
conky.text = [[
${color6}${font Anton, Regular:pixelsize=120}${time %H}${font}
${color4}${voffset -32}${font Anton, Regular:pixelsize=120}${time %M}${font}
${color6}${hr}$font
${color4}${font Anton, Regular:pixelsize=27}${time %A}${font}
${color6}${font Anton, Regular:pixelsize=27}${time %B}${font}
${color6}${hr}$font
${color4}${voffset 4}${font Teko, Light:pixelsize=16}CPU Freq: ${color6}$freq_g GHz
${color4}${font Teko, Light:pixelsize=17}CPU Temp: ${color6}${acpitemp}°C
${color4}${font Teko, Light:pixelsize=17}GPU Speed: ${color6}${nvidia gpufreq} Mhz
${color4}${font Teko, Light:pixelsize=17}MEM Speed: ${color6}${nvidia memfreq} Mhz
${color4}${font Teko, Light:pixelsize=17}GPU Temp: ${color6}${nvidia temp} °C
${color4}${font Teko, Light:pixelsize=17}FS-Max:${goto 50}${color6}${fs_size /}
${color4}${font Teko, Light:pixelsize=17}FS-Free:${goto 50}${color6}${fs_free /}
I am using Conky Grapes, from this repo https://gitlab.nomagic.uk/popi/conky-grapes
I had to do a few tweaks but nothing serious lots of options for colour and all that stuff. Well worth reading the wiki
I tweaked my conky a bit. Made it look more simple.
There are 2 configuration files, named Connection and System.
If you want the whole package including visuals, you can download the ZIP here.
Connection
conky.config = {
	use_xft = true,
	font = '123:size=10',
	xftalpha = 0.1,
	own_window = true,
	own_window_argb_visual = false,
	own_window_argb_value = 102,
	default_shade_color = 'red',
	default_outline_color = 'green',
	gap_x = 40,
	gap_y = 40,
	minimum_width = 950, minimum_height = 300,
	maximum_width = 950,
	no_buffers = true,
	uppercase = false,
	net_avg_samples = 1,
	use_spacer = 'left',
conky.text = [[
${image ~/.conky/Connections.png -p 0,0 -s 950x300}
${color 35805f}${goto 50}IN  $color${tcp_portmon 1 32767 count}${color 35805f}     OUT  $color${tcp_portmon 32768 61000 count}
${color a497a0}${font comic:pixelsize=12}
${offset 50}${tcp_portmon 1 65535 rhost 0}${goto 500}${tcp_portmon 1 65535 rip 0}${goto 700}${tcp_portmon 1 65535 rport 0}${goto 775}${tcp_portmon 1 65535 rservice 0}${goto 850}${tcp_portmon 1 65535 lport 0}
${offset 50}${tcp_portmon 1 65535 rhost 1}${goto 500}${tcp_portmon 1 65535 rip 1}${goto 700}${tcp_portmon 1 65535 rport 1}${goto 775}${tcp_portmon 1 65535 rservice 1}${goto 850}${tcp_portmon 1 65535 lport 1}
${offset 50}${tcp_portmon 1 65535 rhost 2}${goto 500}${tcp_portmon 1 65535 rip 2}${goto 700}${tcp_portmon 1 65535 rport 2}${goto 775}${tcp_portmon 1 65535 rservice 2}${goto 850}${tcp_portmon 1 65535 lport 2}
${offset 50}${tcp_portmon 1 65535 rhost 3}${goto 500}${tcp_portmon 1 65535 rip 3}${goto 700}${tcp_portmon 1 65535 rport 3}${goto 775}${tcp_portmon 1 65535 rservice 3}${goto 850}${tcp_portmon 1 65535 lport 3}
${offset 50}${tcp_portmon 1 65535 rhost 4}${goto 500}${tcp_portmon 1 65535 rip 4}${goto 700}${tcp_portmon 1 65535 rport 4}${goto 775}${tcp_portmon 1 65535 rservice 4}${goto 850}${tcp_portmon 1 65535 lport 4}
${offset 50}${tcp_portmon 1 65535 rhost 5}${goto 500}${tcp_portmon 1 65535 rip 5}${goto 700}${tcp_portmon 1 65535 rport 5}${goto 775}${tcp_portmon 1 65535 rservice 5}${goto 850}${tcp_portmon 1 65535 lport 5}
${offset 50}${tcp_portmon 1 65535 rhost 6}${goto 500}${tcp_portmon 1 65535 rip 6}${goto 700}${tcp_portmon 1 65535 rport 6}${goto 775}${tcp_portmon 1 65535 rservice 6}${goto 850}${tcp_portmon 1 65535 lport 6}
${offset 50}${tcp_portmon 1 65535 rhost 7}${goto 500}${tcp_portmon 1 65535 rip 7}${goto 700}${tcp_portmon 1 65535 rport 7}${goto 775}${tcp_portmon 1 65535 rservice 7}${goto 850}${tcp_portmon 1 65535 lport 7}
${offset 50}${tcp_portmon 1 65535 rhost 8}${goto 500}${tcp_portmon 1 65535 rip 8}${goto 700}${tcp_portmon 1 65535 rport 8}${goto 775}${tcp_portmon 1 65535 rservice 8}${goto 850}${tcp_portmon 1 65535 lport 8}
${offset 50}${tcp_portmon 1 65535 rhost 9}${goto 500}${tcp_portmon 1 65535 rip 9}${goto 700}${tcp_portmon 1 65535 rport 9}${goto 775}${tcp_portmon 1 65535 rservice 9}${goto 850}${tcp_portmon 1 65535 lport 9}
System
conky.config = {
	update_interval = 2.0,
	no_buffers = true,
	use_xft = true,
	font = 'Ubuntu:size=10',
	default_color = '#cccccc',
	color0 = 'darkgrey',
	color1 = '#77507b',
	color2 = 'white',
	color3 = '#35805f',
	color4 = '#4e4141',
	own_window = true,
	own_window_argb_value = 153,
	gap_x = 40,
	gap_y = 40,
	minimum_width = 300, minimum_height = 555,
	maximum_width = 300,
conky.text = [[
${image ~/.conky/System.png -p 0,0 -s 300x555}
${goto 32}${color0}Kernel: ${goto 100}${color2}${kernel}${color}
${image ~/.conky/logo.png -p 200,95 -s 55x55}
${goto 32}${color0}CPU : ${color1}${goto 100}${cpu cpu0}%${color}
${goto 32}${color0}Temp : ${color1}${goto 100}${hwmon acpitz temp 1} °C${color}
${goto 32}${color0}Freq : ${color1}${goto 100}${freq_g cpu0} GHz
${goto 32}${color0}RAM : ${color1}${goto 100}$memperc%${goto 205}${mem}
${goto 32}${color0}Swap : ${goto 100}${color1}${swap}${color0}${color}
${goto 32}${color0}System used :${goto 150}${color1}${fs_used /}${color}
${goto 32}${color0}Backup used : ${goto 150}${color1}${fs_used /run/media/lunix/Backup/}
${goto 32}${color0}SSD Temp : ${goto 150}${color1}${hddtemp /dev/sda}.0 °C
${goto 32}${color0}Up: ${color1}${goto 100}${upspeed wlp3s0}${goto 205}${color2}${execi 30 vnstat -i wlp3s0 | grep "today" | awk '{print $5 $6}'}
${goto 32}${color0}Down: ${color1}${goto 100}${downspeed wlp3s0}${goto 205}${color2}${execi 30 vnstat -i wlp3s0 | grep "today" | awk '{print $2 $3}'}
${goto 32}${color0}WIFI: ${goto 100}${execpi 30 /home/lunix/.conky/conky_scripts/pingtest.sh 192.168.1.101}${color1}${goto 205}${wireless_link_qual_perc wlp3s0}%
${goto 32}${color0}Local IP: ${goto 150}${color2}${addr wlp3s0}
${goto 32}${color0}Public IP: ${goto 150}${color2}${execi 30 wget -q -O - checkip.dyndns.org | sed -e 's/[^[:digit:]\|.]//g'}
${goto 32}${color0}Kabylake:${goto 150}${execpi 30 /home/lunix/.conky/conky_scripts/pingtest.sh 192.168.1.106}
${goto 32}${color0}Nas:${goto 150}${execpi 30 /home/lunix/.conky/conky_scripts/pingtest.sh 192.168.1.102}
${goto 32}${color0}Vero 4k+:${goto 150}${execpi 30 /home/lunix/.conky/conky_scripts/pingtest.sh 192.168.1.103}
Nice simple conky. :smiley:
Made some minor changes from original conky. Added Date and time. Added number of installed packages. Adjusted for 8 cores and added more load and memory services.
Original Conky
Summary
conky.config = {
	background = true,
	use_xft = true,
	font = 'monospace:size=8',
	xftalpha = 0.8,
	update_interval = 0.5,
	own_window = true,
--	own_window_colour = '#2e3436',
--      own_window_argb_value = 120,
	stippled_borders = 1,
	border_width = 1,
	default_color = '#2e3436',
	default_shade_color = 'gray',
	default_outline_color = 'black',
	gap_x = 15,
	gap_y = 145,
-- Misc Console #
   no_buffers = true,
   use_spacer = 'right',
   maximum_width = 700,
   minimum_height = 800,
   uppercase = true,
conky.text = [[
#leet chars: ┤┤└└┴┴┐┐││┘┘┌┌├├┬┬┼┼┴┴── ││ ▽▼△▲▵▴▾▿
${alignc}${offset 41}${font xftfont montserrat:size=10} Garuda Workstation ${font}
${alignr}${offset -6}└──────────┐
${alignr}${offset -6}date/time ─┤
${alignr}${offset -6}< ${time %B %d %Y}${font} > ─┤   │
${alignr}${offset -6}< ${time %I:%M %p}${font} > ─┘   │
${alignr}${offset -6}│
${alignr}${offset -6}${exec lsb_release -si} ${machine} ─┤
${alignr}${offset -6}< ${kernel} > Kernel ─┤   │
${alignr}${offset -6}< ${uptime} > Uptime ─┤   │
${alignr}${offset -6}< ${execi 600 pacman -Q | wc -l} > packages ─┤   │
${alignr}${offset -6}< ${execi 3600 checkupdates | wc -l} > updates ─┘   │
${alignr}${offset -6}system ─┤
${alignr}${offset -6}< ${execi 1000 cat /proc/cpuinfo|grep 'model name'|sed -e 's/model name.*: //'| uniq | cut -c 1-24} > CPU ─┤   │
${alignr}${offset -6}│   │   │
${alignr}${offset -6}used ─┤   │   │
${alignr}${offset -6}< ${cpu cpu 1}% > cpu1 ─┤   │   │   │
${alignr}${offset -6}< ${cpu cpu 2}% > cpu2 ─┤   │   │   │
${alignr}${offset -6}< ${cpu cpu 3}% > cpu3 ─┤   │   │   │
${alignr}${offset -6}< ${cpu cpu 4}% > cpu4 ─┤   │   │   │
${alignr}${offset -6}< ${cpu cpu 5}% > cpu5 ─┤   │   │   │
${alignr}${offset -6}< ${cpu cpu 6}% > cpu6 ─┤   │   │   │
${alignr}${offset -6}< ${cpu cpu 7}% > cpu7 ─┤   │   │   │
${alignr}${offset -6}< ${cpu cpu 8}% > cpu8 ─┘   │   │   │
${alignr}${offset -6}< $loadavg > load ─┤   │   │
${alignr}${offset -6}< ${top name 1} ${top cpu 1} > ─┤   │   │
${alignr}${offset -6}< ${top name 2} ${top cpu 2} > ─┤   │   │
${alignr}${offset -6}< ${top name 3} ${top cpu 3} > ─┤   │   │
${alignr}${offset -6}< ${top name 4} ${top cpu 4} > ─┤   │   │
${alignr}${offset -6}< ${top name 5} ${top cpu 5} > ─┤   │   │
${alignr}${offset -6}< ${top name 6} ${top cpu 6} > ─┤   │   │
${alignr}${offset -6}< ${top name 7} ${top cpu 7} > ─┤   │   │
${alignr}${offset -6}< ${top name 8} ${top cpu 8} > ─┤   │   │
${alignr}${offset -6}< ${top name 9} ${top cpu 9} > ─┤   │   │
${alignr}${offset -6}< ${top name 10} ${top cpu 10} > ─┘   │   │
${alignr}${offset -6}Processes ─┤   │
${alignr}${offset -6}< $processes > ─ < $running_processes > ─┘   │   │
${alignr}${offset -6}Temperatures ─┤   │
${alignr}${offset -6}< ${acpitemp}°C > cpu ─┤   │   │
${alignr}${offset -6}< ${execi 5 nvidia-settings -t -q [gpu]/GPUCoreTemp} °C > gpu ─┘   │   │
${alignr}${offset -6}Memory ─┤   │
${alignr}${offset -6}< $memperc% > used ─┤   │   │
${alignr}${offset -6}< $mem/$memmax > ─┘    │   │   │
${alignr}${offset -6}< ${top name 1} ${top mem 1} > ─┤   │   │
${alignr}${offset -6}< ${top name 2} ${top mem 2} > ─┤   │   │
${alignr}${offset -6}< ${top name 3} ${top mem 3} > ─┤   │   │
${alignr}${offset -6}< ${top name 4} ${top mem 4} > ─┤   │   │
${alignr}${offset -6}< ${top name 5} ${top mem 5} > ─┤   │   │
${alignr}${offset -6}< ${top name 6} ${top mem 6} > ─┤   │   │
${alignr}${offset -6}< ${top name 7} ${top mem 7} > ─┤   │   │
${alignr}${offset -6}< ${top name 8} ${top mem 8} > ─┤   │   │
${alignr}${offset -6}< ${top name 9} ${top mem 9} > ─┤   │   │
${alignr}${offset -6}< ${top name 10} ${top mem 10} > ─┘   │   │
${alignr}${offset -6}Disk Usage ─┘   │
${alignr}${offset -6}< $diskio_read >  read ─┤       │
${alignr}${offset -6}< $diskio_write > write ─┤       │
${alignr}${offset -6}< ${fs_used /}/${fs_size /} > /root ─┤       │
${alignr}${offset -6}< ${fs_bar 5,120 /} > ─┘     │       │
${alignr}${offset -6}< ${fs_used /home}/${fs_size /home} > /home ─┘       │
${alignr}${offset -6}< ${fs_bar 5,120 /home} > ─┘             │
${alignr}${offset -6}Network ─┘
${alignr}${offset -32}< $nodename > hostname ─┤
${alignr}${offset -32}< ${execi 60 wget -qO- ifconfig.co} > Wan ─┤
${alignr}${offset -32}< ${addr enp5s0} > Lan ─┤
${alignr}${offset -32}< ${downspeed enp5s0} k/s > ▼ download ─┤
${alignr}${offset -32}< ${downspeedgraph enp5s0 12,120 c44400 ba8d01} > ─┘    │
${alignr}${offset -32}< ${upspeed enp5s0} k/s >   ▲ upload ─┘
${alignr}${offset -62}< ${upspeedgraph enp5s0 12,120 c44400 ba8d01} > ─┘
Automatik conky Theme
Infofile
double_buffer yes
update_interval 2
background yes
own_window yes
# own_window_type desktop
#own_window_type override
own_window_argb_visual true
own_window_argb_value 160
out_to_console no
own_window_transparent no
own_window_class conky-semi
use_xft yes
xftfont cure:size=10
#use_xft yes
#xftfont Sansation:size=9
xftfont Rounded Elegance:size=10
xftalpha 0
update_interval 2
cpu_avg_samples 2
net_avg_samples 2
double_buffer yes
maximum_width 320
draw_shades no
draw_outline no
draw_borders no
draw_graph_borders yes
stippled_borders 1
border_width 0
default_color white
default_shade_color white
default_outline_color white
alignment top_right
use_spacer left
no_buffers yes
uppercase no
color0 white
color2 white
color3 1793d0
pad_percents 2
top_name_width 10
minimum_size 320 100
gap_x   15
gap_y 50
TEXT
${image img/information.png -p 0,0 -s 30x30}
${offset 35}${font Good Times:size=12}${color Tan1}SYSTEM INFORMATION ${color}${hr 2}${font}
${goto 80}${color red}${font Ubuntu-Title:size=11}"manjaro linux"${font}${color} | X-Cinnamon
${goto 80}gnussbaum@manjaro
${goto 80}Kernel: $kernel $machine
${goto 80}Uptime:$uptime
#${font DJB Get Digital:size=30}${tab 90}${time %H:%M:%S}
${image img/logo-manjaro.png -p 5,40 -s 64x64}
clockfile
double_buffer yes
update_interval 2
background yes
own_window yes
out_to_console no
use_xft yes
#use_xft yes
xftalpha 0
update_interval 2
cpu_avg_samples 2
net_avg_samples 2
double_buffer yes
maximum_width 320
draw_shades no
draw_outline no
draw_borders no
stippled_borders 1
border_width 0
default_color white
alignment top_right
use_spacer left
no_buffers yes
uppercase no
color0 white
color2 white
color3 1793d0
pad_percents 2
top_name_width 10
#                               conkyrc_orange
#  author  : SLK
#  version : v2011011601
#  license : Distributed under the terms of GNU GPL version 2 or later
gap_x 15
gap_y 160
alignment top_right
update_interval 1
lua_load clock.lua
lua_draw_hook_post main
color1 white #Month color
color2 white #Year  color
color3 white #Weekdays color
color4 FFE3A0 #Current weekday color
color5 white  #Days of month color
color6 ff0000 #Current day color
double_buffer true
TEXT
${image img/calendar_clock.png -p 0,0 -s 30x30}#
#${image img/calendar.png -p 10,40 -s 140x120}
${image img/flip_background.png -p 5,40 -s 160x130}
#${image img/background.png -p 5,70 -s 160x100}
${offset 35}${font Good Times:size=12}${color Tan1}TIME - DATE  ${color}${hr 2}${font}
#${goto 20}${voffset 0}${color}${font Rounded Elegance:size=14:weight=bold}${time %B}#
#${alignr 180}${font Rounded Elegance:size=9:weight=normal}${time %Y}
#${voffset 10}${alignc 80}${color 000000}${font Rounded Elegance:size=14}${time %A}
#${alignc 80}${color FF0000}${font Rounded Elegance:size=45:weight=bold}${time %d}${font Rounded Elegance:size=10:weight=normal}
${voffset 0}
${font Liquid Crystal:size=25}${color FF0000}${goto 228}${time %I}${goto 263}${blink :}${goto 272}${time %M}${color}
${font Liquid Crystal:size=15}
${image img/unnamed.png -p 209,41 -s 110x110}
${image img/s.png -p 10,50 -s 19x19}#
${image img/u.png -p 29,50 -s 19x19}#
${image img/n.png -p 48,50 -s 19x19}#
${image img/d.png -p 67,50 -s 19x19}#
${image img/a.png -p 86,50 -s 19x19}#
${image img/y.png -p 105,50 -s 19x19}#
${image img/empty.png -p 124,50 -s 19x19}#
${image img/empty.png -p 143,50 -s 19x19}#
${image img/1.png -p 25,75 -s 60x60}#
${image img/7.png -p 85,75 -s 60x60}#
${image img/a.png -p 10,140 -s 15x15}#
${image img/p.png -p 25,140 -s 15x15}#
${image img/r.png -p 40,140 -s 15x15}#
${image img/i.png -p 55,140 -s 15x15}#
${image img/l.png -p 70,140 -s 15x15}#
${image img/2.png -p 100,140 -s 15x15}#
${image img/0.png -p 115,140 -s 15x15}#
${image img/2.png -p 130,140 -s 15x15}#
${image img/2.png -p 145,140 -s 15x15}#
memfile
double_buffer yes
update_interval 2
background yes
own_window yes
out_to_console no
use_xft yes
#use_xft yes
xftalpha 0
update_interval 2
cpu_avg_samples 2
net_avg_samples 2
double_buffer yes
maximum_width 320
draw_shades no
draw_outline no
draw_borders no
stippled_borders 1
border_width 0
default_color white
alignment top_right
use_spacer left
no_buffers yes
uppercase no
color0 white
color2 white
color3 1793d0
pad_percents 2
top_name_width 10
gap_x 15
gap_y  367
lua_load allcombined.lua
#${lua gradbar {5, 218 "${memperc}" ,100, 80, 2, 10, 1, 0xFFFFFF, 0.25, 0x00FF00, 1, 0xFFFF00, 1, 0xFF0000, 1}}
TEXT
${image img/memory.png -p 0,0 -s 30x30}
${offset 35}${font Good Times:size=12}${color Tan1}MEMORY ${color}${hr 2}${font}
${color}Ram${color}${alignr}$memmax
${lua gradbar {6, 55, "${memperc}", 100, 97, 2, 10, 1, 0xFFFFFF, 0.25, 0x00FF00, 1, 0xFFFF00, 1, 0xFF0000, 1}}
${color}$mem used${alignr}${memfree} free
${image img/trans-bg240.png -p 2,50 -s 290x11}
${color}Swap partition${alignr}${swapmax}
${lua gradbar {6, 115 "${swapperc}", 100, 97, 2, 10, 1, 0xFFFFFF, 0.25, 0x00FF00, 1, 0xFFFF00, 1, 0xFF0000, 1}}
${color}$swap used${alignr}${swapfree} free
${image img/trans-bg240.png -p 2,110 -s 290x11}#
cpufiles
double_buffer yes
update_interval 2
background yes
own_window yes
out_to_console no
use_xft yes
#use_xft yes
xftalpha 0
update_interval 2
cpu_avg_samples 2
net_avg_samples 2
double_buffer yes
maximum_width 320
draw_shades no
draw_outline no
draw_borders no
stippled_borders 1
border_width 0
default_color white
alignment top_right
use_spacer left
no_buffers yes
uppercase no
color0 white
color2 white
color3 1793d0
pad_percents 2
top_name_width 10
gap_x 15
gap_y 520
TEXT
${image img/cpu2.png -p 0,0 -s 30x30}
${offset 35}${font Good Times:size=12}${color Tan1}CPU INFORMATION ${color}${hr 2}
${font}${color}${execi 1000 cat /proc/cpuinfo | grep 'model name' | sed -e 's/model name.*: //'| uniq}
${color lightgrey}Temperature  ${texeci 10 sensors | grep Core | awk '!/-/' | awk '{ print $3}' | sort -r | head -n 1}
${alignc}${color #000000}${cpugraph 20,318 000000 FFFFFF}${color}
# CPU1
Cpu  1${goto 50} : ${cpu cpu1}% ${lua gradbar {100, 110, "${cpu cpu1}", 100, 40, 2, 10, 1, 0xFFFFFF, 0.25, 0x00FF00, 1, 0xFFFF00, 1, 0xFF0000, 1}}${goto 230}${color}${freq 1}
MHz${image img/trans-bg240.png -p 96,105 -s 121x11}
# CPU2
Cpu  2${goto 50} : ${cpu cpu2}% ${lua gradbar {100, 125, "${cpu cpu2}", 100, 40, 2, 10, 1, 0xFFFFFF, 0.25, 0x00FF00, 1, 0xFFFF00, 1, 0xFF0000, 1}}${goto 230}${color}${freq 2}
MHz${image img/trans-bg240.png -p 96,120 -s 121x11}
topfile
double_buffer yes
update_interval 2
background yes
own_window yes
out_to_console no
use_xft yes
#use_xft yes
xftalpha 0
update_interval 2
cpu_avg_samples 2
net_avg_samples 2
double_buffer yes
maximum_width 320
draw_shades no
draw_outline no
draw_borders no
stippled_borders 1
border_width 0
default_color white
alignment top_right
use_spacer left
no_buffers yes
uppercase no
color0 white
color2 white
color3 1793d0
pad_percents 2
top_name_width 10
gap_x 380
gap_y 50
TEXT
${image img/gearwheels.png -p 0,0 -s 30x30}
${offset 35}${font Good Times:size=12}${color Tan1}TASKS AND PROCESSES ${color}${hr 2}${font}
${offset 5}${color}Load: ${loadavg 1}
#${running_processes} ${running_threads} ${processes}
${hr 2}${font}
${color lightgrey}${font Futurist Fixed-width:size=10:bold}${color lightgrey}${offset 5}PROCESS          CPU${alignr}   MEMORY        ${offset -5}PID
${voffset -10}${hr 1}${font}${color}${font monofur:size=11}
${voffset -5}#
${offset 5}${top name 1} ${alignr}${top cpu 1}%      ${top mem_res 1}     ${alignr}${offset -5}${top pid 1}
${offset 5}${top name 2} ${alignr}${top cpu 2}%      ${top mem_res 2}     ${alignr}${offset -5}${top pid 2}
${offset 5}${top name 3} ${alignr}${top cpu 3}%      ${top mem_res 3}     ${alignr}${offset -5}${top pid 3}
${offset 5}${top name 4} ${alignr}${top cpu 4}%      ${top mem_res 4}     ${alignr}${offset -5}${top pid 4}
${offset 5}${top name 5} ${alignr}${top cpu 5}%      ${top mem_res 5}     ${alignr}${offset -5}${top pid 5}
diskfile
double_buffer yes
update_interval 2
background yes
own_window yes
out_to_console no
use_xft yes
#use_xft yes
xftalpha 0
update_interval 2
cpu_avg_samples 2
net_avg_samples 2
double_buffer yes
maximum_width 320
draw_shades no
draw_outline no
draw_borders no
stippled_borders 1
border_width 0
default_color white
alignment top_right
use_spacer left
no_buffers yes
uppercase no
color0 white
color2 white
color3 1793d0
pad_percents 2
top_name_width 10
gap_x 745
gap_y 50
TEXT
${image img/hard_drive.png -p 0,0 -s 30x30}
${offset 35}${font Good Times:size=12}${color Tan1}DISK USAGE ${color}${hr 2}${font}
 ${color}/
${lua gradbar {6, 70, "${fs_used_perc /}" ,100, 75, 2, 10, 1, 0xFFFFFF, 0.25, 0x00FF00, 1, 0xFFFF00, 1, 0xFF0000, 1}}${alignr}${offset -5}${fs_used_perc /}% used
 /dev/sda1 = 20G (${fs_type /})${color}${alignr}${offset -5}${fs_free /} free
${color}${hr 1}
${image img/trans-bg240.png -p 4,65 -s 226x11}
${color lightgrey}Read: $color${diskio_read}${alignr}${color lightgrey}Write: ${color}${diskio_write}
${color #000000}${diskiograph_read 12,145 000000 EEEEEE}${alignr}${color #000000}${diskiograph_write 12,145 000000 EEEEEE}
netfile
double_buffer yes
update_interval 2
background yes
own_window yes
out_to_console no
use_xft yes
#use_xft yes
xftalpha 0
update_interval 2
cpu_avg_samples 2
net_avg_samples 2
double_buffer yes
maximum_width 320
draw_shades no
draw_outline no
draw_borders no
stippled_borders 1
border_width 0
default_color white
alignment top_right
use_spacer left
no_buffers yes
uppercase no
color0 white
color2 white
color3 1793d0
pad_percents 2
top_name_width 10
gap_x 380
gap_y 225
TEXT
${image img/earth_network.png -p 0,0 -s 30x30}
${offset 35}${font Good Times:size=12}${color Tan1}NETWORK DEVICE ${color}${hr 2}${font}
IP address: ${texeci 10000 wget -q -O - checkip.dyndns.org|sed -e 's/.*Current IP Address: //' -e 's/<.*$//'}
${if_match "${addr ens33}"!="No Address"}${goto 14}Interface: ${color3}ens33${color}${goto 160}Local IP:${addr ens33}
${goto 14}${color1}Sending: ${color3}${upspeed ens33}${color1}${alignr}${goto 180}${color1}Receiving:${color1} ${color3}${downspeed ens33}${color}
${goto 14}${color1}Sent :${color1} ${color2}${totalup ens33}${color1}${alignr}${goto 180}${color1}Received :${color}${color2}${totaldown ens33}${color1}
${goto 14}${upspeedgraph ens33  50,140 000000 FF0000}${goto 180}${downspeedgraph ens33 50,140 000000 00FF00}
${voffset -5}${hr 1}
${endif}
thanks, used with some modifications
modified
conky.config = {
  background = true,
  border_width = 0.5,
  use_xft = true,
  gap_x = 6,
  gap_y = 40,
  minimum_height = 5,
  minimum_width = 5,
  own_window = true,
  own_window_argb_value = 100,
  own_window_colour = '#0A0A0A',
  uppercase = false,
conky.text = [[
${voffset -90}
${color white}
${font}
${font OxygenSans:pixelsize=18}$alignc${time %H:%M:%S} ${color white}
#System
${font NotoSansMono Nerd Font:size=13}$font${color White}$sysname $kernel $alignr $machine
#CPU
${font OpenSans:bold:size=10}${color White}CPU USAGE: ${cpu cpu0}% $alignr Temp: ${hwmon 2 temp 2}°C
$font${color White}CPU1 ${freq_g 1}Ghz $alignr CPU2 ${freq_g 2}Ghz
#GPU
${font MesloLGS NF:size=14}${color Tan1} ${font OxygenSans:bold:size=11}${color Tan1}GPU ${color White}${hr 2}
${font OpenSans:bold:size=10}${color White}Temp: ${nvidia temp}°C $alignr Speed: ${nvidia gpufreq} MHz
${font OpenSans:bold:size=10}${color White}Memory: ${nvidia memused}MB/${nvidia memtotal}MB
#MEMORY
$membar
$swapbar
#HDD
${font MesloLGS NF:size=15}${color Tan1} ${font OxygenSans:bold:size=11}${color Tan1}HDD ${color White}${hr 2}
${fs_bar /}
${fs_bar /home}
#TOP PROCESSES
${font MesloLGS NF:size=15}${color Tan1} ${font OxygenSans:bold:size=11}${color Tan1} PROCESSES ${color White}${hr 2}
$font${top_mem name 5}${alignr}${top_mem mem 5} %
my edition
conkyrc
conky.config = {
  alignment = 'middle_right',
  background = true,
  border_width = 0,
  default_color = 'lightgrey',
  use_xft = true,
  font = 'NotoSansDisplayLight:bold:size=11',
  gap_x = 5,
  gap_y = 0,
  minimum_height = 250,
  minimum_width = 250,
  own_window = true,
  uppercase = false,
conky.text = [[
${voffset -50}
${color cyan3}
${font NotoSansMono Nerd Font:size=12}$alignr
${voffset -30}
${font NotoSans:bold:size=22}$alignc${color cyan3}Manjaro ${execi 86400 lsb_release -sc}
$color${font NotoSansMedium:size=16}$alignc${time %a %d %b}
$color${font NotoSansMono:bold:size=16}$alignc${time %H:%M:%S}
#System
${font NotoSansMono Nerd Font:size=18}${color orange} ${color silver}${stippled_hr 1}
${voffset -45}
$font$color$sysname $kernel $alignr $machine
System Updates: $alignr ${execpi 43200 checkupdates | wc -l}  Updates
#CPU
${font NotoSansMono Nerd Font:size=18}${color orange} ${color silver}${stippled_hr 1}
${voffset -45}
$font$color${execi 86400 grep -m1 'model name' /proc/cpuinfo}
Core 1 — ${freq_g 1}Ghz $alignr Core 2 — ${freq_g 2}Ghz
Core 3 — ${freq_g 3}Ghz $alignr Core 4 — ${freq_g 4}Ghz
${font NotoSansMono Nerd Font:size=12}  $font${acpitemp}°C $alignr${cpu cpu0}%${font NotoSansMono Nerd Font:size=12} 爛
${color silver}$cpubar
#MEMORY
${font NotoSansMono Nerd Font:size=18}${color orange} ${color silver}${stippled_hr 1}
${voffset -45}
$font${color}Memory $alignc $mem / $memmax $alignr$memperc%${font NotoSansMono Nerd Font:size=12} 爛
${color silver}$membar
$font${color}Swap Disc $alignc $swap / $swapmax $alignr$swapperc%${font NotoSansMono Nerd Font:size=12} 爛
${color silver}$swapbar
#HDD
${font NotoSansMono Nerd Font:size=18}${color orange} ${color silver}${stippled_hr 1}
${voffset -45}
$font${color}Root $alignc $fs_used / $fs_size $alignr$fs_used_perc%${font NotoSansMono Nerd Font:size=12} 爛
${color silver}$fs_bar
$font${color}Home $alignc ${fs_used /home} / ${fs_size /home} $alignr${fs_used_perc /home}%${font NotoSansMono Nerd Font:size=12} 爛
${color silver}${fs_bar /home}
#PROCESSES
${font NotoSansMono Nerd Font:size=18}${color orange} ${color silver}${stippled_hr 1}
${voffset -45}
${font NotoSansBold:size=11}${color white}Name$alignr CPU ${font NotoSansMono Nerd Font:size=11,5}爛
$font$color${top name 1}${alignr}${top cpu 1} %
${top name 2}${alignr}${top cpu 2} %
${top name 3}${alignr}${top cpu 3} %
${top name 4}${alignr}${top cpu 4} %
${top name 5}${alignr}${top cpu 5} %
fresh template:
conkyrc
conky.config = {
  background = true,
  border_width = 0,
  use_xft = true,
  font = 'NotoSansBold:size=11',
  gap_x = 5,
  gap_y = 0,
  maximum_height = 900,
  minimum_width = 400,
  own_window = true,
  uppercase = false,
conky.text = [[
#Logo
${voffset -40}
${color cyan4}
${font NotoSansMono Nerd Font:size=13}$alignr
${voffset -40}
${font NotoSans:bold:size=22}$alignc${color cyan4}Manjaro ${execi 1000000 lsb_release -sc}
#System
${voffset -45}
$font$color $sysname $kernel $alignr $machine
 Hostname: $alignr$nodename
 Uptime: $alignr$uptime_short
#CPU
${voffset -45}
$font$color ${execi 1000000 grep -m1 'model name' /proc/cpuinfo}
${font NotoSansBold:size=11}${color darkgrey} Core 1 — ${freq_g 1}Ghz $alignr Core 2 — ${freq_g 2}Ghz
${font NotoSansMono Nerd Font:size=12}$color  $font${acpitemp}°C $alignr${cpu cpu0}%${font NotoSansMono Nerd Font:size=12} 爛
#MEMORY
${voffset -45}
$font$color Memory ${color darkgrey}${font NotoSansBold:size=11}$alignc $mem / $memmax $font$color$alignr$memperc%${font NotoSansMono Nerd Font:size=12} 爛
$font$color Swap ${color darkgrey}${font NotoSansBold:size=11}$alignc $swap / $swapmax $font$color$alignr$swapperc%${font NotoSansMono Nerd Font:size=12} 爛
#HDD
${voffset -45}
$font$color ${execi 1000000 lsblk -d -e 8 -o TRAN,REV,MODEL,REV,SERIAL -n}
${font NotoSansMono Nerd Font:size=12}  $font${hwmon temp 1}°C ${color darkgrey}${font NotoSansBold:size=11}$alignc $fs_used / $fs_size $font$color$alignr$fs_used_perc%${font NotoSansMono Nerd Font:size=12} 爛
#NET
${font NotoSansMono Nerd Font:size=18}${color orange} ${color silver}${stippled_hr 1}
${voffset -45}
$font$color ${execi 1000000 ip link show | awk '/state UP/ {print $2}' | sed 's/.$//'}$alignr${wireless_essid wlp3s0}
${font NotoSansMono Nerd Font:size=12} 囹 $font${tcp_portmon 1 65535 count} ${color darkgrey}${font NotoSansBold:size=11}$alignc ${downspeed wlp3s0} / ${upspeed wlp3s0} $font$color$alignr${wireless_bitrate wlp3s0}${font NotoSansMono Nerd Font:size=12} 龍
${color silver}${wireless_link_bar wlp3s0}
#PROCESSES
${voffset -45}
$font$color Name$alignr CPU ${font NotoSansMono Nerd Font:size=11}爛
${font NotoSansBold:size=11}${color darkgrey} ${top name 1}${alignr}${top cpu 1} %
${voffset -10}
$font$color Name$alignr MEM ${font NotoSansMono Nerd Font:size=11}爛
${font NotoSansBold:size=11}${color darkgrey} ${top_mem name 1}${alignr}${top_mem mem 1} %
SysInfo.conkyrc
conky.config = {
  background = true,
  border_width = 0.5,
  use_xft = true,
  gap_x = 1,
  gap_y = 0,
  maximum_width = 240,
  minimum_height = 5,
  minimum_width = 240,
  own_window = true,
  uppercase = false,
conky.text = [[
${voffset -90}
${color white}
${font}
#System
${font MesloLGS NF:size=20}${color Tan1} ${voffset -5}${font OxygenSans:bold:size=11}${color Tan1}SYSTEM ${color White}${hr 2}
$alignc${font OpenSans:bold:size=10}${color White}$sysname $kernel ${font}
#CPU
${font MesloLGS NF:size=20}${color Tan1} ${voffset -5}${font OxygenSans:bold:size=11}${color Tan1}CPU ${color White}${hr 2}
$alignc${font OpenSans:bold:size=10}${color White}CPU Usage: ${cpu cpu0}%   ${font MesloLGS NF:bold:size=10}:${font OpenSans:bold:size=10}${hwmon 4 temp 1}°C
$font${color White}${cpubar cpu1 6,54} ${freq_g 1}GHz ${alignr}${cpubar cpu2 6,54} ${freq_g 2}GHz${alignr}
${cpubar cpu3 6,54} ${freq_g 3}GHz ${alignr}${cpubar cpu4 6,54} ${freq_g 4}GHz${alignr}
${cpubar cpu5 6,54} ${freq_g 5}GHz ${alignr}${cpubar cpu6 6,54} ${freq_g 6}GHz${alignr}
${cpubar cpu7 6,54} ${freq_g 7}GHz ${alignr}${cpubar cpu8 6,54} ${freq_g 8}GHz${alignr}
#GPU
${font MesloLGS NF:size=20}${color Tan1}菉 ${voffset -5}${font OxygenSans:bold:size=11}${color Tan1}GPU ${color White}${hr 2}
${font}${color White}GPU Usage: ${execi 2 cat /sys/class/drm/card0/device/gpu_busy_percent}% ${alignr}${color white}GPU clk:${color} ${execi 5 grep -Po '\d+:\s\K(\d+)(?=.*\*$)' /sys/class/drm/card0/device/pp_dpm_sclk}MHz${font}
${execigraph 2 "cat /sys/class/drm/card0/device/gpu_busy_percent" 20,240 2980b9 e74c3c}
${color white}MEM Usage: ${color}${execi 2 numfmt --to=iec < /sys/class/drm/card0/device/mem_info_vram_used} ${alignr}${color white}MEM clk:${color} ${execi 5 grep -Po '\d+:\s\K(\d+)(?=.*\*$)' /sys/class/drm/card0/device/pp_dpm_mclk}MHz
#MEMORY
${font MesloLGS NF:size=20}${color Tan1} ${voffset -5}${font OxygenSans:bold:size=11}${color Tan1}MEMORY ${color White}${hr 2}
$membar
$swapbar
#HDD
${font MesloLGS NF:size=20}${color Tan1} ${voffset -5}${font OxygenSans:bold:size=11}${color Tan1}SSD ${color White}${hr 2}
${fs_bar /boot}
${fs_bar /}
${fs_bar /home}
#TOP PROCESSES
${font MesloLGS NF:size=20}${color Tan1} ${voffset -5}${font OxygenSans:bold:size=11}${color Tan1}TOP PROCESSES ${color White}${hr 2}
${color White}$font${top name 1}${alignr}${top cpu 1} %
$font${top name 2}${alignr}${top cpu 2} %
$font${top name 3}${alignr}${top cpu 3} %
$font${top name 4}${alignr}${top cpu 4} %
#$font${top name 5}${alignr}${top cpu 5} %
#NETWORK WLAN0
${if_existing /proc/net/route wlan0}${font MesloLGS NF:size=20}${color Tan1}直 ${voffset -5}${font OxygenSans:bold:size=11}${color Tan1}NETWORK ${color White}${hr 2}
Download: ${downspeed wlan0}/s ${alignr}Total: ${totaldown wlan0}
${color}${downspeedgraph wlan0 20,240 2980b9 e74c3c}
Upload: ${upspeed wlan0}/s ${alignr}Total: ${totalup wlan0}
${color}${upspeedgraph wlan0 20,240 2980b9 e74c3c}
${voffset -10}${color Tan1}Inbound:${color white}${tcp_portmon 1 32767 count}${color Tan1}  Outbound:${color white}${tcp_portmon 32768 61000 count}${alignr}${color Tan1}All:${color white}${tcp_portmon 1 65535 count}
#NETWORK ETH0
${else}${if_existing /proc/net/route eth0}${font MesloLGS NF:size=20}${color Tan1} ${voffset -5}${font OxygenSans:bold:size=11}${color Tan1}NETWORK ${color White}${hr 2}
$font${color White}Interface: $alignr eth0
${hr 2}
Download: ${downspeed eth0}/s ${alignr}Total: ${totaldown eth0}
${color}${downspeedgraph eth0 20,240 2980b9 e74c3c}
Upload: ${upspeed eth0}/s ${alignr}Total: ${totalup eth0}
${color}${upspeedgraph eth0 20,240 2980b9 e74c3c}
${voffset -10}${color Tan1}Inbound:${color white}${tcp_portmon 1 32767 count}${color Tan1}  Outbound:${color white}${tcp_portmon 32768 61000 count}${alignr}${color Tan1}All:${color white}${tcp_portmon 1 65535 count}${endif}${endif}
Weather.conkyrc
conky.config = {
    background = true,
    use_xft = true,
    own_window = true,
    alignment = 'bottom_left',
    minimum_width = 220,
    minimum_height = 170,
    gap_x = 3,
    gap_y = 25,
    uppercase = true,
conky.text = [[
#Clima
${font MesloLGS NF:size=15}${color Tan1} ${font OxygenSans:bold:size=11}${color Tan1}WEATHER ${color White}${hr 2}
${font MesloLGS NF:size=10}${texeci 1800 curl -s https://wttr.in/Cabo%20Rojo?u0T&lang=en | sed -n '3,7{s/\d27\[[0-9;]*m//g;s/^..//;s/ *$//;p}'}
Calendar.conkyrc
conky.config = {
    background = true,
    use_xft = true,
    own_window = true,
    minimum_height = 5,
    gap_x = 3,
    gap_y = 1,
    -- no_buffers = yes,
    uppercase = true,
    default_color = 'a8a8a8',
    -- default_shade_color = 'darkgray',
    -- default_outline_color = 'darkgray',
    -- color0 = 'orange', -- naranja
    --color1 = '00ff55', --verde encendido
    --color2 = '0099ff', --azul celeste
    --color3 = '99999f', --gris
    --color4 = 'f4f137', --amarillo
    --color5 = 'f81d1d', --rojo
    --color7 = '35bf5c', -- verde Manjaro
    --color8 = '4285F4', -- azul
    color1 = '#ffffff', -- # Month color
    color2 = 'Lime', -- # Year  color
    color3 = '#004F00', -- # Weekdays lived color
    color4 = 'cornsilk', -- # Current weekday color
    color5 = 'Lime', -- # Weekdays yet to come color
    color6 = '666666', -- # Days of month lived color
    color7 = 'Lime', -- # Current day color
    color8 = 'darkorange', --# Days yet to come color
    color9 = 'white',
    color0 = '',
conky.text = [[
${font MesloLGS NF:size=15}${color Tan1} ${font OxygenSans:bold:size=11}${color Tan1}Calendar ${color White}${hr 2}
${voffset 10}${font LCD2:size=45}${alignc}${color2}${time %Y}
${voffset -40}${font LCD2:size=12}${alignc}${color9}semana ${color7}${time %U}${color9} dia ${color7}${time %j}${color9}${font LCDMono:size=18}
${voffset -25}${color9}${hr 2}
${alignc}${font Courier New:bold:size=16}${voffset -15}${color1}${time %B}${voffset -35}
${voffset 25}${color9}${stippled_hr}
${font Courier New:bold:size=12}${voffset -20}${execp TODAY=`date +%_d`; cal | tail -n+2 | sed \
-e '1 s:.*:\${color3}&\${color6}:' \
-e '1 s:'"$(date +%a |cut -c 1-2)"':\${color4}&\${color5}:' \
-e '0,/'"$TODAY"'/{s/'"$TODAY"'/\${color7}'"$TODAY"'\${color9}/}'}# 1st -e = days of week, 2nd = current day of week, 3rd = current day of month
Aw i really wanted to use this one, it looks amazing but the python script to create the config didn’t work for me. Just spits out errors about being unable to open some file and int object having no replace attribute. :frowning:
I had a pretty decent conky before that was self made but I lost it when my filesystem got corrupted during a shrink a while back, can’t believe i forgot to back it up.
(Edit)
This is what I’m using now
It’s a slightly modified version of seamod.
conkyrc.lua
--                               conkyrc_seamod
-- Date    : 04/23/2016
-- Author  : SeaJey and Maxiwell
-- Conky   : >= 1.10
-- License : Distributed under the terms of GNU GPL version 2 or later
conky.config = {
	background = true,
	temperature_unit = 'celsius',
	no_buffers = true,
	text_buffer_size = 2048,
	gap_x = 20,
	gap_y = 0,
	minimum_width = 300, minimum_height = 900,
	maximum_width = 350,
	own_window = true,
	own_window_hints = 'undecorated,sticky,skip_taskbar,skip_pager,below',
	border_inner_margin = 0,
	border_outer_margin = 0,
	use_xft = true,
	font = 'caviar dreams:size=11',
	xftalpha = 0.5,
	uppercase = false,
-- Defining colors
	default_color = '#FFFFFF',
-- Shades of Gray
	color1 = '#EEEEEE',
	color2 = '#DDDDDD',
	color3 = '#AAAAAA',
-- Orange
	color4 = '#EF5A29',
-- Green
	color5 = '#77DD55',
-- Loading lua script for drawning rings
	lua_load = '~/.conky/mine/seamod_rings.lua',
	lua_draw_hook_pre = 'main',
--${offset 15}${font Ubuntu:size=11:style=normal}${color1}${pre_exec lsb_release -d | cut -f 2} - $sysname $kernel
conky.text = [[
${font Ubuntu:size=11:style=bold}${color4}$kernel${hr 2}
${offset 15}${font Ubuntu:size=11:style=normal}${color1}Uptime: ${color3}$uptime
${offset 15}${font Ubuntu:size=11:style=normal}${color1}Battery: ${color3}${battery_bar 20,120 BAT1}
# Showing CPU Graph
${voffset 30}
${offset 50}${font Ubuntu:size=11:style=bold}${color1}${acpitemp}°C
${voffset -25}
${offset 90}${font Ubuntu:size=11:style=bold}${color5}CPU:${font Ubuntu:size=11:style=bold}${color1} Intel Core i7-8750H @ $freq_g GHz
# Showing TOP 5 CPU-consumers
${offset 105}${font Ubuntu:size=11:style=normal}${color4}${top name 1}${alignr}${top cpu 1}%
${offset 105}${font Ubuntu:size=11:style=normal}${color1}${top name 2}${alignr}${top cpu 2}%
${offset 105}${font Ubuntu:size=11:style=normal}${color2}${top name 3}${alignr}${top cpu 3}%
${offset 105}${font Ubuntu:size=11:style=normal}${color3}${top name 4}${alignr}${top cpu 4}%
${offset 105}${font Ubuntu:size=11:style=normal}${color3}${top name 5}${alignr}${top cpu 5}%
#Showing GPU
${voffset 30}
${offset 50}${font Ubuntu:size=11:style=bold}${color1}${nvidia temp}°C
${voffset -30}
${offset 90}${font Ubuntu:size=11:style=bold}${color5}GPU:${font Ubuntu:size=11:style=bold}${color1} ${nvidia modelname}
${offset 105}${font Ubuntu:size=11:style=bold}${color4}Memory: ${color1}${nvidia memused}MiB / ${nvidia memavail}MiB
#Showing memory part with TOP 5
${voffset 65}
${offset 90}${font Ubuntu:size=11:style=bold}${color5}MEM:${font Ubuntu:size=11:style=bold}${color1} ${memeasyfree} / 32GiB
${offset 105}${font Ubuntu:size=11:style=normal}${color4}${top_mem name 1}${alignr}${top_mem mem_res 1}
${offset 105}${font Ubuntu:size=11:style=normal}${color1}${top_mem name 2}${alignr}${top_mem mem_res 2}
${offset 105}${font Ubuntu:size=11:style=normal}${color2}${top_mem name 3}${alignr}${top_mem mem_res 3}
${offset 105}${font Ubuntu:size=11:style=normal}${color3}${top_mem name 4}${alignr}${top_mem mem_res 4}
${offset 105}${font Ubuntu:size=11:style=normal}${color3}${top_mem name 4}${alignr}${top_mem mem_res 5}
# Network data (my desktop have only LAN). ETHERNET ring is mostly useless but looks pretty, main info is in the graphs
${voffset 25}
${offset 170}${font Ubuntu:size=10:style=bold}${color4}Lan IP: ${alignr}$color1${addr wlo1}
${offset 170}${font Ubuntu:size=10:style=bold}${color4}Ext IP: ${alignr}$color1${execi 600 wget -q -O /dev/stdout http://checkip.dyndns.org/ -o /dev/null | cut -d : -f 2- | cut -d \< -f -1}
${offset 180}${font Ubuntu:size=10:style=bold}${alignr}$color2${execi 600 wget -q -O /dev/stdout https://www.dnsleaktest.com/ -o /dev/null | grep from | grep -o '<p>.*<img' | grep -o '>.*<' | grep -oEi '[a-zA-Z0-9 ,]+'}
${voffset -100}
${offset 100}${font Ubuntu:size=11:style=bold}${color5}WiFi
${voffset 45}
${offset 15}${color1}${font ubuntu:size=10:style=bold}Up: ${alignr}${font Ubuntu:size=10:style=normal}$color2${upspeed wlo1} / ${totalup wlo1}
${offset 15}${upspeedgraph wlo1 40,320 4B1B0C FF5C2B 1280KiB -l}
${offset 15}${color1}${font Ubuntu:size=10:style=bold}Down: ${alignr}${font Ubuntu:size=10:style=normal}$color2${downspeed wlo1} / ${totaldown wlo1}
${offset 15}${downspeedgraph wlo1 40,320 324D23 77B753 1280KiB -l}
seamod_rings.lua
--                            seamod_rings.lua
--  Date    : 05/02/2012
--  Author  : SeaJey
--  Version : v0.1
--  This version is a modification of lunatico_rings.lua wich is modification of conky_orange.lua
--  conky_orange.lua:    http://gnome-look.org/content/show.php?content=137503&forumpage=0
--  lunatico_rings.lua:  http://gnome-look.org/content/show.php?content=142884
require 'cairo'
gauge = {
    name='cpu',                    arg='cpu1',                  max_value=100,
    x=65,                          y=150,
    graph_radius=54,
    graph_thickness=5,
    graph_start_angle=180,
    graph_unit_angle=2.7,          graph_unit_thickness=2.7,
    graph_bg_colour=0xffffff,      graph_bg_alpha=0.1,
    graph_fg_colour=0xFFFFFF,      graph_fg_alpha=0.3,
    hand_fg_colour=0xEF5A29,       hand_fg_alpha=1.0,
    txt_radius=0,
    txt_weight=0,                  txt_size=9.0,
    txt_fg_colour=0xEF5A29,        txt_fg_alpha=1.0,
    graduation_radius=28,
    graduation_thickness=0,        graduation_mark_thickness=1,
    graduation_unit_angle=27,
    graduation_fg_colour=0xFFFFFF, graduation_fg_alpha=0.3,
    caption='',
    caption_weight=1,              caption_size=9.0,
    caption_fg_colour=0xFFFFFF,    caption_fg_alpha=0.3,
    name='cpu',                    arg='cpu2',                  max_value=100,
    x=65,                          y=150,
    graph_radius=48,
    graph_thickness=5,
    txt_radius=0,
    caption='',
    name='cpu',                    arg='cpu3',                  max_value=100,
    x=65,                          y=150,
    graph_radius=42,
    graph_thickness=5,
    txt_radius=0,
    caption='',
    name='cpu',                    arg='cpu4',                  max_value=100,
    x=65,                          y=150,
    graph_radius=36,
    graph_thickness=5,
    txt_radius=0,
    caption='',
    name='cpu',                    arg='cpu5',                  max_value=100,
    x=65,                          y=150,
    graph_radius=30,
    graph_thickness=5,
    txt_radius=0,
    caption='',
    name='cpu',                    arg='cpu6',                  max_value=100,
    x=65,                          y=150,
    graph_radius=24,
    graph_thickness=5,
    txt_radius=0,
    caption='',
    name='nvidia',                arg='gpuutil',                      max_value=100,
    x=65,                          y=360,
    graph_radius=54,
    graph_thickness=10,
    txt_radius=42,
    graduation_radius=23,
    graduation_thickness=0,        graduation_mark_thickness=2,
    graduation_fg_colour=0xFFFFFF, graduation_fg_alpha=0.5,
    caption='',
    caption_weight=1,              caption_size=10.0,
    name='memperc',                arg='',                      max_value=100,
    x=65,                          y=510,
    graph_radius=54,
    graph_thickness=10,
    txt_radius=42,
    caption='',
    name='downspeedf',           arg='wlo1',                     max_value=100,
    x=65,                          y=700,
    graph_radius=54,
    graph_thickness=7,
    hand_fg_colour=0xEF5A29,       hand_fg_alpha=0,
    txt_radius=64,
    caption='Down',
    caption_weight=1,              caption_size=12.0,
    caption_fg_colour=0xFFFFFF,    caption_fg_alpha=0.5,
    name='upspeedf',           arg='wlo1',                     max_value=100,
    x=65,                          y=700,
    graph_radius=42,
    graph_thickness=7,
    txt_radius=30,
    caption='Up',
-- converts color in hexa to decimal
function rgb_to_r_g_b(colour, alpha)
    return ((colour / 0x10000) % 0x100) / 255., ((colour / 0x100) % 0x100) / 255., (colour % 0x100) / 255., alpha
end
-- convert degree to rad and rotate (0 degree is top/north)
function angle_to_position(start_angle, current_angle)
    local pos = current_angle + start_angle
    return ( ( pos * (2 * math.pi / 360) ) - (math.pi / 2) )
end
-- displays gauges
function draw_gauge_ring(display, data, value)
    local max_value = data['max_value']
    local x, y = data['x'], data['y']
    local graph_radius = data['graph_radius']
    local graph_thickness, graph_unit_thickness = data['graph_thickness'], data['graph_unit_thickness']
    local graph_start_angle = data['graph_start_angle']
    local graph_unit_angle = data['graph_unit_angle']
    local graph_bg_colour, graph_bg_alpha = data['graph_bg_colour'], data['graph_bg_alpha']
    local graph_fg_colour, graph_fg_alpha = data['graph_fg_colour'], data['graph_fg_alpha']
    local hand_fg_colour, hand_fg_alpha = data['hand_fg_colour'], data['hand_fg_alpha']
    local graph_end_angle = (max_value * graph_unit_angle) % 360
    -- background ring
    cairo_arc(display, x, y, graph_radius, angle_to_position(graph_start_angle, 0), angle_to_position(graph_start_angle, graph_end_angle))
    cairo_set_source_rgba(display, rgb_to_r_g_b(graph_bg_colour, graph_bg_alpha))
    cairo_set_line_width(display, graph_thickness)
    cairo_stroke(display)
    -- arc of value
    local val = value % (max_value + 1)
    local start_arc = 0
    local stop_arc = 0
    local i = 1
    while i <= val do
        start_arc = (graph_unit_angle * i) - graph_unit_thickness
        stop_arc = (graph_unit_angle * i)
        cairo_arc(display, x, y, graph_radius, angle_to_position(graph_start_angle, start_arc), angle_to_position(graph_start_angle, stop_arc))
        cairo_set_source_rgba(display, rgb_to_r_g_b(graph_fg_colour, graph_fg_alpha))
        i = i + 1
    end
    local angle = start_arc
    -- hand
    start_arc = (graph_unit_angle * val) - (graph_unit_thickness * 2)
    stop_arc = (graph_unit_angle * val)
    cairo_set_source_rgba(display, rgb_to_r_g_b(hand_fg_colour, hand_fg_alpha))
    -- graduations marks
    local graduation_radius = data['graduation_radius']
    local graduation_thickness, graduation_mark_thickness = data['graduation_thickness'], data['graduation_mark_thickness']
    local graduation_unit_angle = data['graduation_unit_angle']
    local graduation_fg_colour, graduation_fg_alpha = data['graduation_fg_colour'], data['graduation_fg_alpha']
    if graduation_radius > 0 and graduation_thickness > 0 and graduation_unit_angle > 0 then
        local nb_graduation = graph_end_angle / graduation_unit_angle
        local i = 0
        while i < nb_graduation do
            cairo_set_line_width(display, graduation_thickness)
            start_arc = (graduation_unit_angle * i) - (graduation_mark_thickness / 2)
            stop_arc = (graduation_unit_angle * i) + (graduation_mark_thickness / 2)
            cairo_arc(display, x, y, graduation_radius, angle_to_position(graph_start_angle, start_arc), angle_to_position(graph_start_angle, stop_arc))
            cairo_set_source_rgba(display,rgb_to_r_g_b(graduation_fg_colour,graduation_fg_alpha))
            i = i + 1
        end
    end
    -- text
    local txt_radius = data['txt_radius']
    local txt_weight, txt_size = data['txt_weight'], data['txt_size']
    local txt_fg_colour, txt_fg_alpha = data['txt_fg_colour'], data['txt_fg_alpha']
    local movex = txt_radius * math.cos(angle_to_position(graph_start_angle, angle))
    local movey = txt_radius * math.sin(angle_to_position(graph_start_angle, angle))
    cairo_select_font_face (display, "ubuntu", CAIRO_FONT_SLANT_NORMAL, txt_weight)
    cairo_set_font_size (display, txt_size)
    cairo_set_source_rgba (display, rgb_to_r_g_b(txt_fg_colour, txt_fg_alpha))
    if txt_radius > 0 then
        cairo_move_to (display, x + movex - (txt_size / 2), y + movey + 3)
        cairo_show_text (display, value)
        cairo_stroke (display)
    end
    -- caption
    local caption = data['caption']
    local caption_weight, caption_size = data['caption_weight'], data['caption_size']
    local caption_fg_colour, caption_fg_alpha = data['caption_fg_colour'], data['caption_fg_alpha']
    local tox = graph_radius * (math.cos((graph_start_angle * 2 * math.pi / 360)-(math.pi/2)))
    local toy = graph_radius * (math.sin((graph_start_angle * 2 * math.pi / 360)-(math.pi/2)))
    cairo_select_font_face (display, "ubuntu", CAIRO_FONT_SLANT_NORMAL, caption_weight);
    cairo_set_font_size (display, caption_size)
    cairo_set_source_rgba (display, rgb_to_r_g_b(caption_fg_colour, caption_fg_alpha))
    cairo_move_to (display, x + tox + 5, y + toy + 5)
    -- bad hack but not enough time !
    if graph_start_angle < 105 then
        cairo_move_to (display, x + tox - 30, y + toy + 1)
    end
    cairo_show_text (display, caption)
end
-- loads data and displays gauges
function go_gauge_rings(display)
    local function load_gauge_rings(display, data)
        local str, value = '', 0
        str = string.format('${%s %s}',data['name'], data['arg'])
        str = conky_parse(str)
        value = tonumber(str)
    end
    for i in pairs(gauge) do
        load_gauge_rings(display, gauge[i])
    end
end
--        MAIN
function conky_main()
    if conky_window == nil then
        return
    end
    local cs = cairo_xlib_surface_create(conky_window.display, conky_window.drawable, conky_window.visual, conky_window.width, conky_window.height)
    local display = cairo_create(cs)
    local updates = conky_parse('${updates}')
    update_num = tonumber(updates)
    if update_num > 5 then
    end
    cairo_surface_destroy(cs)
    cairo_destroy(display)
end
The reason I’m basing it off seamod is because when I want to set up a conky i generally like to have a base to work from, and seamod’s somehow the only one that always works for me, meanwhile most of the conky configs I tried copy pasting from this thread didn’t work at all.
Btw my cpu name is hardcoded, because I was lazy. Also because I care about efficiency, I don’t want conky to consume too much cpu, this setup is fairly efficient, I’m sure it could be optimized further but only by making it less pretty.
One cool feature though is that I make it show the actual CPU frequency next to the cpu name. This is actually useful to me too, but for most people it wouldn’t be i suppose.
