I get the following error
My system uses kde, i am on the testing branch
Refresh your mirror list.
Doing so through the gui and terminal didnt fix anything. But after disabling and re-enabling aur support through the gui, the problem dissapered there, but not when updating from the command line
Problems with the community.db ?
sudo pacman -Syyu
core 169.1 KiB 1581 KiB/s 00:00 [------------------------------------------------] 100%
extra 1854.6 KiB 4.72 MiB/s 00:00 [------------------------------------------------] 100%
community.db failed to download
multilib 182.1 KiB 1182 KiB/s 00:00 [------------------------------------------------] 100%
error: failed retrieving file 'community.db' from mirror.moson.org : The requested URL returned error: 404
error: failed retrieving file 'community.db' from manjaro.moson.eu : The requested URL returned error: 404
error: failed retrieving file 'community.db' from mirror.alpix.eu : The requested URL returned error: 404
error: failed retrieving file 'community.db' from mirrors.xtom.de : The requested URL returned error: 404
error: failed retrieving file 'community.db' from ftp.gwdg.de : The requested URL returned error: 404
error: failed retrieving file 'community.db' from mirror.23m.com : The requested URL returned error: 404
error: failed retrieving file 'community.db' from ftp.tu-chemnitz.de : The requested URL returned error: 403
error: failed retrieving file 'community.db' from ftp.halifax.rwth-aachen.de : The requested URL returned error: 403
error: failed to synchronize all databases (failed to retrieve some files)
I’d rather say it’s a problem with you mirror(s) or something of the sort. Please refresh your mirror list:
sudo pacman-mirrors -f5 --fasttrack
Hi,
Getting exactly the same for ‘community.db’ and refreshing mirrors does not work either. Have even tried with using:
✗ sudo pacman-mirrors -f5 --fasttrack && sudo pacman -Syyu
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using custom mirror file
::INFO Querying mirrors - This may take some time
0.737 Sweden : https://ftp.lysator.liu.se/pub/manjaro/
::INFO Writing mirror list
::Sweden : https://ftp.lysator.liu.se/pub/manjaro/testing/$repo/$arch
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
core 169.1 KiB 534 KiB/s 00:00 [#######################################] 100%
extra 1854.6 KiB 3.40 MiB/s 00:01 [#######################################] 100%
multilib 182.1 KiB 535 KiB/s 00:00 [#######################################] 100%
error: failed retrieving file 'community.db' from ftp.lysator.liu.se : The requested URL returned error: 404
error: failed to synchronize all databases (unexpected error)
Think its been like this for at least since yesterday.
nope … isn´t my mirror problem … Switzerland, Germany, Netherlands …
sudo pacman -Syyu
core 169.1 KiB 546 KiB/s 00:00 [------------------------------------------------] 100%
extra 1854.6 KiB 3.25 MiB/s 00:01 [------------------------------------------------] 100%
multilib 182.1 KiB 607 KiB/s 00:00 [------------------------------------------------] 100%
error: failed retrieving file 'community.db' from mirrors.ft.uam.es : The requested URL returned error: 404
error: failed retrieving file 'community.db' from ftp.caliu.cat : The requested URL returned error: 404
Community-DB are corrupt? …or not available?
sudo pacman -Syyu
core 169.1 KiB 745 KiB/s 00:00 [------------------------------------------------] 100%
extra 1854.6 KiB 4.61 MiB/s 00:00 [------------------------------------------------] 100%
multilib 182.1 KiB 1273 KiB/s 00:00 [------------------------------------------------] 100%
error: failed retrieving file 'community.db' from mirror.init7.net : The requested URL returned error: 404
sudo pacman -Syyu
core 169.1 KiB 1272 KiB/s 00:00 [------------------------------------------------] 100%
extra 1854.6 KiB 340 KiB/s 00:05 [------------------------------------------------] 100%
multilib 182.1 KiB 615 KiB/s 00:00 [------------------------------------------------] 100%
error: failed retrieving file 'community.db' from manjaro.mirrors.lavatech.top : The requested URL returned error: 404
Global-Mirror is reachable
sudo pacman -Syyu
extra 1854.6 KiB 3.16 MiB/s 00:01 [------------------------------------------------] 100%
community 5.7 MiB 4.56 MiB/s 00:01 [------------------------------------------------] 100%
multilib 182.1 KiB 1090 KiB/s 00:00 [------------------------------------------------] 100%
there is nothing to do
Then it might be that the mirrors are busy syncing…
Me too, you are not alone. Using the testing branch:
❯ sudo pacman -Syyu
core 169,1 KiB 2014 KiB/s 00:00 [###################################################################################] 100%
extra 1854,6 KiB 5,79 MiB/s 00:00 [###################################################################################] 100%
If you are using the stable branch, no issue.
But try to switch to the testing branch, you would get the errors 404 and 403.
I can confirm that I tested two different branches in VM. Only testing branch has the problem
That might explain it then…
Same issue here…updating mirrors doesn’t help.
Same issue.
Please have a look at:
hey, run these commands:
sudo rm -f /var/lib/pacman/sync/*
next:
sudo pacman -Syyu
that should fix it
That’s not going to fix anything.
if you have nothing constructive to say, say nothing… and yes, these commands are the simplest solution to fix ‘invalid or corrupted database (PGP signature)’ … if they dont work for OP, then we try different ones…
He’s right though. ![]()
This particular problem with the community repo in the testing branch exists on all mirrors and needs to be fixed on the main mirror (and then propagate down to all syncing mirrors).
There is nothing the user can do about it (well, except of switching branches)
you are correct, i didnt notice that OP is on testing branch, my mistake…
