This is full content of sudo dmesg:
[ 0.000000] microcode: microcode updated early to revision 0xa0b, date = 2010-09-28
[ 0.000000] Linux version 5.15.12-1-MANJARO (builduser@fv-az39-353) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Wed Dec 29 18:08:07 UTC 2021
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=74c2dc48-04db-4c35-897f-55d7e80a0a9a rw quiet apparmor=1 security=apparmor udev.log_priority=3 acpi_enforce_resources=lax
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Enabled xstate features 0x3, context size is 576 bytes, using 'standard' format.
[ 0.000000] signal: max sigframe size: 1520
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000000e4000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000cff7ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000cff80000-0x00000000cff8dfff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000cff8e000-0x00000000cffcffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000cffd0000-0x00000000cfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fff00000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000012fffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: System manufacturer System Product Name/P5P41D, BIOS 0404 03/05/2010
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 2700.129 MHz processor
[ 0.000802] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000806] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000812] last_pfn = 0x130000 max_arch_pfn = 0x400000000
[ 0.001339] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001865] total RAM covered: 4096M
[ 0.002097] Found optimal setting for mtrr clean up
[ 0.002098] gran_size: 64K chunk_size: 64K num_reg: 5 lose cover RAM: 0G
[ 0.002727] e820: update [mem 0xd0000000-0xffffffff] usable ==> reserved
[ 0.002738] last_pfn = 0xcff80 max_arch_pfn = 0x400000000
[ 0.013263] found SMP MP-table at [mem 0x000ff780-0x000ff78f]
[ 0.013572] RAMDISK: [mem 0x36551000-0x3729ffff]
[ 0.013579] ACPI: Early table checksum verification disabled
[ 0.013585] ACPI: RSDP 0x00000000000FB7E0 000024 (v02 ACPIAM)
[ 0.013589] ACPI: XSDT 0x00000000CFF80100 000054 (v01 A_M_I_ OEMXSDT 03001005 MSFT 00000097)
[ 0.013597] ACPI: FACP 0x00000000CFF80290 0000F4 (v03 A_M_I_ OEMFACP 03001005 MSFT 00000097)
[ 0.013604] ACPI: DSDT 0x00000000CFF80440 0082CF (v01 A1416 A1416000 00000000 INTL 20060113)
[ 0.013609] ACPI: FACS 0x00000000CFF8E000 000040
[ 0.013613] ACPI: FACS 0x00000000CFF8E000 000040
[ 0.013617] ACPI: APIC 0x00000000CFF80390 00006C (v01 A_M_I_ OEMAPIC 03001005 MSFT 00000097)
[ 0.013621] ACPI: MCFG 0x00000000CFF80400 00003C (v01 A_M_I_ OEMMCFG 03001005 MSFT 00000097)
[ 0.013625] ACPI: OEMB 0x00000000CFF8E040 000089 (v01 A_M_I_ AMI_OEM 03001005 MSFT 00000097)
[ 0.013630] ACPI: HPET 0x00000000CFF88710 000038 (v01 A_M_I_ OEMHPET 03001005 MSFT 00000097)
[ 0.013634] ACPI: SSDT 0x00000000CFF8E4E0 000363 (v01 DpgPmm CpuPm 00000012 INTL 20060113)
[ 0.013638] ACPI: Reserving FACP table memory at [mem 0xcff80290-0xcff80383]
[ 0.013639] ACPI: Reserving DSDT table memory at [mem 0xcff80440-0xcff8870e]
[ 0.013641] ACPI: Reserving FACS table memory at [mem 0xcff8e000-0xcff8e03f]
[ 0.013642] ACPI: Reserving FACS table memory at [mem 0xcff8e000-0xcff8e03f]
[ 0.013644] ACPI: Reserving APIC table memory at [mem 0xcff80390-0xcff803fb]
[ 0.013645] ACPI: Reserving MCFG table memory at [mem 0xcff80400-0xcff8043b]
[ 0.013646] ACPI: Reserving OEMB table memory at [mem 0xcff8e040-0xcff8e0c8]
[ 0.013648] ACPI: Reserving HPET table memory at [mem 0xcff88710-0xcff88747]
[ 0.013649] ACPI: Reserving SSDT table memory at [mem 0xcff8e4e0-0xcff8e842]
[ 0.013709] No NUMA configuration found
[ 0.013710] Faking a node at [mem 0x0000000000000000-0x000000012fffffff]
[ 0.013714] NODE_DATA(0) allocated [mem 0x12fff8000-0x12fffbfff]
[ 0.013744] Zone ranges:
[ 0.013745] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.013747] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.013749] Normal [mem 0x0000000100000000-0x000000012fffffff]
[ 0.013751] Device empty
[ 0.013753] Movable zone start for each node
[ 0.013753] Early memory node ranges
[ 0.013754] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.013756] node 0: [mem 0x0000000000100000-0x00000000cff7ffff]
[ 0.013758] node 0: [mem 0x0000000100000000-0x000000012fffffff]
[ 0.013760] Initmem setup node 0 [mem 0x0000000000001000-0x000000012fffffff]
[ 0.013767] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.013821] On node 0, zone DMA: 97 pages in unavailable ranges
[ 0.045535] On node 0, zone Normal: 128 pages in unavailable ranges
[ 0.045697] ACPI: PM-Timer IO Port: 0x808
[ 0.045721] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.045727] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.045730] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.045734] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.045736] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.045744] smpboot: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.045763] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.045766] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.045767] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000e3fff]
[ 0.045768] PM: hibernation: Registered nosave memory: [mem 0x000e4000-0x000fffff]
[ 0.045770] PM: hibernation: Registered nosave memory: [mem 0xcff80000-0xcff8dfff]
[ 0.045772] PM: hibernation: Registered nosave memory: [mem 0xcff8e000-0xcffcffff]
[ 0.045773] PM: hibernation: Registered nosave memory: [mem 0xcffd0000-0xcfffffff]
[ 0.045774] PM: hibernation: Registered nosave memory: [mem 0xd0000000-0xfedfffff]
[ 0.045775] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.045776] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xffefffff]
[ 0.045777] PM: hibernation: Registered nosave memory: [mem 0xfff00000-0xffffffff]
[ 0.045779] [mem 0xd0000000-0xfedfffff] available for PCI devices
[ 0.045781] Booting paravirtualized kernel on bare hardware
[ 0.045785] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.052650] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[ 0.053251] percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u524288
[ 0.053262] pcpu-alloc: s212992 r8192 d28672 u524288 alloc=1*2097152
[ 0.053266] pcpu-alloc: [0] 0 1 2 3
[ 0.053302] Built 1 zonelists, mobility grouping on. Total pages: 1031810
[ 0.053307] Policy zone: Normal
[ 0.053309] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=74c2dc48-04db-4c35-897f-55d7e80a0a9a rw quiet apparmor=1 security=apparmor udev.log_priority=3 acpi_enforce_resources=lax
[ 0.053437] Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64", will be passed to user space.
[ 0.054905] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.055683] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.056516] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[ 0.151284] Memory: 3996764K/4193400K available (14344K kernel code, 2097K rwdata, 10884K rodata, 1864K init, 3784K bss, 196376K reserved, 0K cma-reserved)
[ 0.151299] random: get_random_u64 called from __kmem_cache_create+0x2a/0x540 with crng_init=0
[ 0.151507] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.151530] Kernel/User page tables isolation: enabled
[ 0.151562] ftrace: allocating 44515 entries in 174 pages
[ 0.168821] ftrace: allocated 174 pages with 5 groups
[ 0.169064] rcu: Preemptible hierarchical RCU implementation.
[ 0.169067] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.169068] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[ 0.169069] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.169071] Trampoline variant of Tasks RCU enabled.
[ 0.169072] Rude variant of Tasks RCU enabled.
[ 0.169072] Tracing variant of Tasks RCU enabled.
[ 0.169074] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.169075] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.174359] NR_IRQS: 20736, nr_irqs: 456, preallocated irqs: 16
[ 0.174675] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.174743] Console: colour dummy device 80x25
[ 0.174758] printk: console [tty0] enabled
[ 0.174792] ACPI: Core revision 20210730
[ 0.174885] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.174901] APIC: Switch to symmetric I/O mode setup
[ 0.175273] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.191566] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x26ebb84696f, max_idle_ns: 440795283990 ns
[ 0.191573] Calibrating delay loop (skipped), value calculated using timer frequency.. 5402.26 BogoMIPS (lpj=9000430)
[ 0.191576] pid_max: default: 32768 minimum: 301
[ 0.191604] LSM: Security Framework initializing
[ 0.191614] landlock: Up and running.
[ 0.191615] Yama: becoming mindful.
[ 0.191657] AppArmor: AppArmor initialized
[ 0.191694] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.191718] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.192073] CPU0: Thermal monitoring enabled (TM2)
[ 0.192086] process: using mwait in idle threads
[ 0.192090] Last level iTLB entries: 4KB 128, 2MB 4, 4MB 4
[ 0.192092] Last level dTLB entries: 4KB 256, 2MB 0, 4MB 32, 1GB 0
[ 0.192097] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.192099] Spectre V2 : Mitigation: Full generic retpoline
[ 0.192100] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.192101] Speculative Store Bypass: Vulnerable
[ 0.192105] MDS: Vulnerable: Clear CPU buffers attempted, no microcode
[ 0.195132] Freeing SMP alternatives memory: 36K
[ 0.306751] smpboot: CPU0: Intel Pentium(R) Dual-Core CPU E5400 @ 2.70GHz (family: 0x6, model: 0x17, stepping: 0xa)
[ 0.307020] Performance Events: PEBS fmt0+, Core2 events, 4-deep LBR, Intel PMU driver.
[ 0.307031] ... version: 2
[ 0.307032] ... bit width: 40
[ 0.307034] ... generic registers: 2
[ 0.307034] ... value mask: 000000ffffffffff
[ 0.307036] ... max period: 000000007fffffff
[ 0.307037] ... fixed-purpose events: 3
[ 0.307038] ... event mask: 0000000700000003
[ 0.307177] rcu: Hierarchical SRCU implementation.
[ 0.307985] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.308073] smp: Bringing up secondary CPUs ...
[ 0.308237] x86: Booting SMP configuration:
[ 0.308237] .... node #0, CPUs: #1
[ 0.311651] smp: Brought up 1 node, 2 CPUs
[ 0.311651] smpboot: Max logical packages: 2
[ 0.311651] smpboot: Total of 2 processors activated (10804.53 BogoMIPS)
[ 0.313217] devtmpfs: initialized
[ 0.313217] x86/mm: Memory block size: 128MB
[ 0.313217] ACPI: PM: Registering ACPI NVS region [mem 0xcff8e000-0xcffcffff] (270336 bytes)
[ 0.313217] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.313217] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.313217] pinctrl core: initialized pinctrl subsystem
[ 0.313217] PM: RTC time: 10:04:12, date: 2022-01-09
[ 0.313217] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.313217] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[ 0.315008] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.315164] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.315187] audit: initializing netlink subsys (disabled)
[ 0.315218] audit: type=2000 audit(1641722652.139:1): state=initialized audit_enabled=0 res=1
[ 0.315218] thermal_sys: Registered thermal governor 'fair_share'
[ 0.315218] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.315218] thermal_sys: Registered thermal governor 'step_wise'
[ 0.315218] thermal_sys: Registered thermal governor 'user_space'
[ 0.315218] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.315218] cpuidle: using governor ladder
[ 0.315218] cpuidle: using governor menu
[ 0.315243] ACPI: bus type PCI registered
[ 0.315246] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.315353] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf0000000-0xf3ffffff] (base 0xf0000000)
[ 0.315360] PCI: not using MMCONFIG
[ 0.315366] PCI: Using configuration type 1 for base access
[ 0.317280] Kprobes globally optimized
[ 0.317295] HugeTLB: can free 6 vmemmap pages for hugepages-2048kB
[ 0.317295] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.318393] ACPI: Added _OSI(Module Device)
[ 0.318396] ACPI: Added _OSI(Processor Device)
[ 0.318397] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.318398] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.318400] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.318404] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.318405] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.327404] ACPI: 2 ACPI AML tables successfully acquired and loaded
[ 0.329079] ACPI: Dynamic OEM Table Load:
[ 0.329079] ACPI: SSDT 0xFFFF97DB4092D800 000406 (v01 DpgPmm P001Ist 00000011 INTL 20060113)
[ 0.329865] ACPI: Interpreter enabled
[ 0.329891] ACPI: PM: (supports S0 S1 S3 S4 S5)
[ 0.329893] ACPI: Using IOAPIC for interrupt routing
[ 0.329935] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf0000000-0xf3ffffff] (base 0xf0000000)
[ 0.332616] PCI: MMCONFIG at [mem 0xf0000000-0xf3ffffff] reserved in ACPI motherboard resources
[ 0.332630] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.332970] ACPI: Enabled 15 GPEs in block 00 to 1F
[ 0.341778] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.341788] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.341795] acpi PNP0A08:00: _OSC: platform retains control of PCIe features (AE_NOT_FOUND)
[ 0.341805] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.342151] PCI host bridge to bus 0000:00
[ 0.342154] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.342157] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.342159] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.342161] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000dffff window]
[ 0.342163] pci_bus 0000:00: root bus resource [mem 0xd0000000-0xefffffff window]
[ 0.342165] pci_bus 0000:00: root bus resource [mem 0xf4000000-0xffffffff window]
[ 0.342167] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.342219] pci 0000:00:00.0: [8086:2e30] type 00 class 0x060000
[ 0.342243] pci 0000:00:00.0: DMAR: Disabling IOMMU for graphics on this chipset
[ 0.342245] pci 0000:00:00.0: DMAR: Forcing write-buffer flush capability
[ 0.342419] pci 0000:00:01.0: [8086:2e31] type 01 class 0x060400
[ 0.342461] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.342615] pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300
[ 0.342631] pci 0000:00:1b.0: reg 0x10: [mem 0xfcffc000-0xfcffffff 64bit]
[ 0.342701] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.342880] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400
[ 0.342950] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.343125] pci 0000:00:1c.1: [8086:27d2] type 01 class 0x060400
[ 0.343194] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.343367] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
[ 0.343405] pci 0000:00:1d.0: reg 0x20: [io 0xc480-0xc49f]
[ 0.343576] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300
[ 0.343614] pci 0000:00:1d.1: reg 0x20: [io 0xc800-0xc81f]
[ 0.343781] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300
[ 0.343819] pci 0000:00:1d.2: reg 0x20: [io 0xc880-0xc89f]
[ 0.343995] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300
[ 0.344033] pci 0000:00:1d.3: reg 0x20: [io 0xcc00-0xcc1f]
[ 0.344209] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
[ 0.344224] pci 0000:00:1d.7: reg 0x10: [mem 0xfcffbc00-0xfcffbfff]
[ 0.344296] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.344453] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.344654] pci 0000:00:1f.0: [8086:27b8] type 00 class 0x060100
[ 0.344727] pci 0000:00:1f.0: quirk: [io 0x0800-0x087f] claimed by ICH6 ACPI/GPIO/TCO
[ 0.344732] pci 0000:00:1f.0: quirk: [io 0x0480-0x04bf] claimed by ICH6 GPIO
[ 0.344736] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0294 (mask 0003)
[ 0.344926] pci 0000:00:1f.1: [8086:27df] type 00 class 0x01018a
[ 0.344941] pci 0000:00:1f.1: reg 0x10: [io 0x0000-0x0007]
[ 0.344949] pci 0000:00:1f.1: reg 0x14: [io 0x0000-0x0003]
[ 0.344957] pci 0000:00:1f.1: reg 0x18: [io 0x08f0-0x08f7]
[ 0.344965] pci 0000:00:1f.1: reg 0x1c: [io 0x08f8-0x08fb]
[ 0.344973] pci 0000:00:1f.1: reg 0x20: [io 0xffa0-0xffaf]
[ 0.344990] pci 0000:00:1f.1: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7]
[ 0.344992] pci 0000:00:1f.1: legacy IDE quirk: reg 0x14: [io 0x03f6]
[ 0.344994] pci 0000:00:1f.1: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177]
[ 0.344996] pci 0000:00:1f.1: legacy IDE quirk: reg 0x1c: [io 0x0376]
[ 0.345152] pci 0000:00:1f.2: [8086:27c0] type 00 class 0x01018f
[ 0.345165] pci 0000:00:1f.2: reg 0x10: [io 0xc400-0xc407]
[ 0.345172] pci 0000:00:1f.2: reg 0x14: [io 0xc080-0xc083]
[ 0.345179] pci 0000:00:1f.2: reg 0x18: [io 0xc000-0xc007]
[ 0.345186] pci 0000:00:1f.2: reg 0x1c: [io 0xbc00-0xbc03]
[ 0.345193] pci 0000:00:1f.2: reg 0x20: [io 0xb880-0xb88f]
[ 0.345226] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.345339] pci 0000:01:00.0: [10de:0a23] type 00 class 0x030000
[ 0.345351] pci 0000:01:00.0: reg 0x10: [mem 0xfd000000-0xfdffffff]
[ 0.345360] pci 0000:01:00.0: reg 0x14: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.345370] pci 0000:01:00.0: reg 0x1c: [mem 0xde000000-0xdfffffff 64bit pref]
[ 0.345376] pci 0000:01:00.0: reg 0x24: [io 0xdc00-0xdc7f]
[ 0.345383] pci 0000:01:00.0: reg 0x30: [mem 0xfea00000-0xfea7ffff pref]
[ 0.345389] pci 0000:01:00.0: enabling Extended Tags
[ 0.345494] pci 0000:01:00.1: [10de:0be2] type 00 class 0x040300
[ 0.345506] pci 0000:01:00.1: reg 0x10: [mem 0xfeafc000-0xfeafffff]
[ 0.345540] pci 0000:01:00.1: enabling Extended Tags
[ 0.345631] pci 0000:00:01.0: ASPM: current common clock configuration is inconsistent, reconfiguring
[ 0.345652] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.345655] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.345657] pci 0000:00:01.0: bridge window [mem 0xfd000000-0xfeafffff]
[ 0.345661] pci 0000:00:01.0: bridge window [mem 0xde000000-0xefffffff 64bit pref]
[ 0.345697] pci 0000:00:1c.0: PCI bridge to [bus 03]
[ 0.345742] pci 0000:00:1c.1: PCI bridge to [bus 02]
[ 0.345764] pci_bus 0000:04: extended config space not accessible
[ 0.345787] pci 0000:04:01.0: [1106:3106] type 00 class 0x020000
[ 0.345804] pci 0000:04:01.0: reg 0x10: [io 0xe800-0xe8ff]
[ 0.345813] pci 0000:04:01.0: reg 0x14: [mem 0xfebffc00-0xfebffcff]
[ 0.345881] pci 0000:04:01.0: supports D1 D2
[ 0.345882] pci 0000:04:01.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.345959] pci 0000:00:1e.0: PCI bridge to [bus 04] (subtractive decode)
[ 0.345963] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff]
[ 0.345967] pci 0000:00:1e.0: bridge window [mem 0xfeb00000-0xfebfffff]
[ 0.345972] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.345974] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.345976] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.345978] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000dffff window] (subtractive decode)
[ 0.345980] pci 0000:00:1e.0: bridge window [mem 0xd0000000-0xefffffff window] (subtractive decode)
[ 0.345982] pci 0000:00:1e.0: bridge window [mem 0xf4000000-0xffffffff window] (subtractive decode)
[ 0.346996] ACPI: PCI: Interrupt link LNKA configured for IRQ 10
[ 0.347086] ACPI: PCI: Interrupt link LNKB configured for IRQ 5
[ 0.347175] ACPI: PCI: Interrupt link LNKC configured for IRQ 10
[ 0.347263] ACPI: PCI: Interrupt link LNKD configured for IRQ 5
[ 0.347351] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.347352] ACPI: PCI: Interrupt link LNKE disabled
[ 0.347440] ACPI: PCI: Interrupt link LNKF configured for IRQ 3
[ 0.347528] ACPI: PCI: Interrupt link LNKG configured for IRQ 11
[ 0.347616] ACPI: PCI: Interrupt link LNKH configured for IRQ 6
[ 0.347763] iommu: Default domain type: Translated
[ 0.347765] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.347789] pci 0000:01:00.0: vgaarb: setting as boot VGA device
[ 0.347789] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.347789] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.347789] vgaarb: loaded
[ 0.347789] SCSI subsystem initialized
[ 0.347789] libata version 3.00 loaded.
[ 0.347789] ACPI: bus type USB registered
[ 0.347789] usbcore: registered new interface driver usbfs
[ 0.347789] usbcore: registered new interface driver hub
[ 0.347789] usbcore: registered new device driver usb
[ 0.347789] pps_core: LinuxPPS API ver. 1 registered
[ 0.347789] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.347789] PTP clock support registered
[ 0.348243] EDAC MC: Ver: 3.0.0
[ 0.348447] NetLabel: Initializing
[ 0.348448] NetLabel: domain hash size = 128
[ 0.348450] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.348476] NetLabel: unlabeled traffic allowed by default
[ 0.348481] PCI: Using ACPI for IRQ routing
[ 0.349754] PCI: pci_cache_line_size set to 64 bytes
[ 0.349795] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
[ 0.349798] e820: reserve RAM buffer [mem 0xcff80000-0xcfffffff]
[ 0.349805] hpet: 3 channels of 0 reserved for per-cpu timers
[ 0.349805] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.349805] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.352704] clocksource: Switched to clocksource tsc-early
[ 0.366379] VFS: Disk quotas dquot_6.6.0
[ 0.366406] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.366573] AppArmor: AppArmor Filesystem Enabled
[ 0.366603] pnp: PnP ACPI init
[ 0.366732] system 00:00: [mem 0xfed14000-0xfed19fff] has been reserved
[ 0.367370] pnp 00:02: [dma 3]
[ 0.367600] system 00:03: [io 0x0290-0x0297] has been reserved
[ 0.367823] system 00:04: [io 0x0400-0x041f] has been reserved
[ 0.367826] system 00:04: [io 0x04d0-0x04d1] has been reserved
[ 0.367828] system 00:04: [io 0x0800-0x087f] has been reserved
[ 0.367830] system 00:04: [io 0x0480-0x04bf] has been reserved
[ 0.367833] system 00:04: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.367836] system 00:04: [mem 0xfed20000-0xfed8ffff] has been reserved
[ 0.367998] system 00:05: [mem 0xffc00000-0xffefffff] has been reserved
[ 0.368338] pnp 00:06: [dma 0 disabled]
[ 0.368609] system 00:07: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.368613] system 00:07: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.368760] system 00:08: [mem 0xf0000000-0xf3ffffff] has been reserved
[ 0.369032] system 00:09: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.369035] system 00:09: [mem 0x000c0000-0x000cffff] could not be reserved
[ 0.369037] system 00:09: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.369040] system 00:09: [mem 0x00100000-0xcfffffff] could not be reserved
[ 0.369042] system 00:09: [mem 0xf0000000-0xffffffff] could not be reserved
[ 0.369247] pnp: PnP ACPI: found 10 devices
[ 0.375443] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.375525] NET: Registered PF_INET protocol family
[ 0.375701] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.376789] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.376893] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.377125] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.377194] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.377352] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[ 0.377401] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.377437] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.377499] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.377508] NET: Registered PF_XDP protocol family
[ 0.377522] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 03] add_size 1000
[ 0.377530] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03] add_size 200000 add_align 100000
[ 0.377534] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 03] add_size 200000 add_align 100000
[ 0.377537] pci 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 02] add_size 1000
[ 0.377540] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[ 0.377543] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff] to [bus 02] add_size 200000 add_align 100000
[ 0.377562] pci 0000:00:1c.0: BAR 14: assigned [mem 0xd0000000-0xd01fffff]
[ 0.377568] pci 0000:00:1c.0: BAR 15: assigned [mem 0xd0200000-0xd03fffff 64bit pref]
[ 0.377571] pci 0000:00:1c.1: BAR 14: assigned [mem 0xd0400000-0xd05fffff]
[ 0.377575] pci 0000:00:1c.1: BAR 15: assigned [mem 0xd0600000-0xd07fffff 64bit pref]
[ 0.377579] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.377581] pci 0000:00:1c.1: BAR 13: assigned [io 0x2000-0x2fff]
[ 0.377587] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.377591] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.377594] pci 0000:00:01.0: bridge window [mem 0xfd000000-0xfeafffff]
[ 0.377597] pci 0000:00:01.0: bridge window [mem 0xde000000-0xefffffff 64bit pref]
[ 0.377600] pci 0000:00:1c.0: PCI bridge to [bus 03]
[ 0.377603] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 0.377607] pci 0000:00:1c.0: bridge window [mem 0xd0000000-0xd01fffff]
[ 0.377610] pci 0000:00:1c.0: bridge window [mem 0xd0200000-0xd03fffff 64bit pref]
[ 0.377615] pci 0000:00:1c.1: PCI bridge to [bus 02]
[ 0.377618] pci 0000:00:1c.1: bridge window [io 0x2000-0x2fff]
[ 0.377621] pci 0000:00:1c.1: bridge window [mem 0xd0400000-0xd05fffff]
[ 0.377625] pci 0000:00:1c.1: bridge window [mem 0xd0600000-0xd07fffff 64bit pref]
[ 0.377630] pci 0000:00:1e.0: PCI bridge to [bus 04]
[ 0.377633] pci 0000:00:1e.0: bridge window [io 0xe000-0xefff]
[ 0.377637] pci 0000:00:1e.0: bridge window [mem 0xfeb00000-0xfebfffff]
[ 0.377644] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.377646] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.377648] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.377650] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000dffff window]
[ 0.377652] pci_bus 0000:00: resource 8 [mem 0xd0000000-0xefffffff window]
[ 0.377653] pci_bus 0000:00: resource 9 [mem 0xf4000000-0xffffffff window]
[ 0.377655] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
[ 0.377657] pci_bus 0000:01: resource 1 [mem 0xfd000000-0xfeafffff]
[ 0.377659] pci_bus 0000:01: resource 2 [mem 0xde000000-0xefffffff 64bit pref]
[ 0.377661] pci_bus 0000:03: resource 0 [io 0x1000-0x1fff]
[ 0.377663] pci_bus 0000:03: resource 1 [mem 0xd0000000-0xd01fffff]
[ 0.377664] pci_bus 0000:03: resource 2 [mem 0xd0200000-0xd03fffff 64bit pref]
[ 0.377666] pci_bus 0000:02: resource 0 [io 0x2000-0x2fff]
[ 0.377668] pci_bus 0000:02: resource 1 [mem 0xd0400000-0xd05fffff]
[ 0.377670] pci_bus 0000:02: resource 2 [mem 0xd0600000-0xd07fffff 64bit pref]
[ 0.377672] pci_bus 0000:04: resource 0 [io 0xe000-0xefff]
[ 0.377674] pci_bus 0000:04: resource 1 [mem 0xfeb00000-0xfebfffff]
[ 0.377676] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7 window]
[ 0.377678] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff window]
[ 0.377679] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.377681] pci_bus 0000:04: resource 7 [mem 0x000d0000-0x000dffff window]
[ 0.377683] pci_bus 0000:04: resource 8 [mem 0xd0000000-0xefffffff window]
[ 0.377685] pci_bus 0000:04: resource 9 [mem 0xf4000000-0xffffffff window]
[ 0.378536] pci 0000:01:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.378590] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.378645] PCI: CLS 32 bytes, default 64
[ 0.378658] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.378660] software IO TLB: mapped [mem 0x00000000cbf80000-0x00000000cff80000] (64MB)
[ 0.378754] Trying to unpack rootfs image as initramfs...
[ 0.379420] Initialise system trusted keyrings
[ 0.379443] Key type blacklist registered
[ 0.383005] workingset: timestamp_bits=41 max_order=20 bucket_order=0
[ 0.384811] zbud: loaded
[ 0.396277] Key type asymmetric registered
[ 0.396284] Asymmetric key parser 'x509' registered
[ 0.396344] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.399635] io scheduler mq-deadline registered
[ 0.399638] io scheduler kyber registered
[ 0.399703] io scheduler bfq registered
[ 0.400132] pcieport 0000:00:1c.0: enabling device (0104 -> 0107)
[ 0.400238] pcieport 0000:00:1c.1: enabling device (0104 -> 0107)
[ 0.400405] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.400549] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.400578] ACPI: button: Power Button [PWRB]
[ 0.400624] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.406344] ACPI: button: Power Button [PWRF]
[ 0.407030] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.407164] 00:06: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 0.409327] Non-volatile memory driver v1.3
[ 0.409332] Linux agpgart interface v0.103
[ 0.409333] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ 0.409902] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.409909] ehci-pci: EHCI PCI platform driver
[ 0.410066] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 0.410078] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 0.410093] ehci-pci 0000:00:1d.7: debug port 1
[ 0.414027] ehci-pci 0000:00:1d.7: irq 23, io mem 0xfcffbc00
[ 0.426247] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 0.426356] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 0.426360] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.426362] usb usb1: Product: EHCI Host Controller
[ 0.426364] usb usb1: Manufacturer: Linux 5.15.12-1-MANJARO ehci_hcd
[ 0.426366] usb usb1: SerialNumber: 0000:00:1d.7
[ 0.426511] hub 1-0:1.0: USB hub found
[ 0.426520] hub 1-0:1.0: 8 ports detected
[ 0.426765] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.426770] ohci-pci: OHCI PCI platform driver
[ 0.426783] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.426942] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 0.426950] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.426957] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 0.426978] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000c480
[ 0.427042] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 0.427045] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.427047] usb usb2: Product: UHCI Host Controller
[ 0.427049] usb usb2: Manufacturer: Linux 5.15.12-1-MANJARO uhci_hcd
[ 0.427050] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.427142] hub 2-0:1.0: USB hub found
[ 0.427150] hub 2-0:1.0: 2 ports detected
[ 0.427350] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 0.427356] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 0.427362] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 0.427388] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000c800
[ 0.427441] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 0.427444] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.427446] usb usb3: Product: UHCI Host Controller
[ 0.427448] usb usb3: Manufacturer: Linux 5.15.12-1-MANJARO uhci_hcd
[ 0.427449] usb usb3: SerialNumber: 0000:00:1d.1
[ 0.427542] hub 3-0:1.0: USB hub found
[ 0.427550] hub 3-0:1.0: 2 ports detected
[ 0.427746] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 0.427751] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 0.427757] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 0.427782] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000c880
[ 0.427834] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 0.427837] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.427839] usb usb4: Product: UHCI Host Controller
[ 0.427840] usb usb4: Manufacturer: Linux 5.15.12-1-MANJARO uhci_hcd
[ 0.427842] usb usb4: SerialNumber: 0000:00:1d.2
[ 0.427931] hub 4-0:1.0: USB hub found
[ 0.427939] hub 4-0:1.0: 2 ports detected
[ 0.428123] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 0.428128] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 0.428134] uhci_hcd 0000:00:1d.3: detected 2 ports
[ 0.428158] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000cc00
[ 0.428216] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[ 0.428219] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.428221] usb usb5: Product: UHCI Host Controller
[ 0.428222] usb usb5: Manufacturer: Linux 5.15.12-1-MANJARO uhci_hcd
[ 0.428224] usb usb5: SerialNumber: 0000:00:1d.3
[ 0.428311] hub 5-0:1.0: USB hub found
[ 0.428318] hub 5-0:1.0: 2 ports detected
[ 0.428472] usbcore: registered new interface driver usbserial_generic
[ 0.428479] usbserial: USB Serial support registered for generic
[ 0.428565] rtc_cmos 00:01: RTC can wake from S4
[ 0.428787] rtc_cmos 00:01: registered as rtc0
[ 0.428818] rtc_cmos 00:01: setting system clock to 2022-01-09T10:04:12 UTC (1641722652)
[ 0.428838] rtc_cmos 00:01: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.428927] intel_pstate: CPU model not supported
[ 0.428955] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.429233] vesafb: mode is 640x480x32, linelength=2560, pages=0
[ 0.429235] vesafb: scrolling: redraw
[ 0.429236] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.429249] vesafb: framebuffer at 0xdf000000, mapped to 0x(____ptrval____), using 1216k, total 1216k
[ 0.429304] fbcon: Deferring console take-over
[ 0.429305] fb0: VESA VGA frame buffer device
[ 0.429323] hid: raw HID events driver (C) Jiri Kosina
[ 0.429425] ashmem: initialized
[ 0.429532] drop_monitor: Initializing network drop monitor service
[ 0.429624] Initializing XFRM netlink socket
[ 0.429743] NET: Registered PF_INET6 protocol family
[ 0.530517] Freeing initrd memory: 13628K
[ 0.537766] Segment Routing with IPv6
[ 0.537771] RPL Segment Routing with IPv6
[ 0.537790] In-situ OAM (IOAM) with IPv6
[ 0.537826] NET: Registered PF_PACKET protocol family
[ 0.538080] microcode: sig=0x1067a, pf=0x1, revision=0xa0b
[ 0.538088] microcode: Microcode Update Driver: v2.2.
[ 0.538096] IPI shorthand broadcast: enabled
[ 0.538110] sched_clock: Marking stable (537614323, 329282)->(551779697, -13836092)
[ 0.538257] registered taskstats version 1
[ 0.538313] Loading compiled-in X.509 certificates
[ 0.543992] Loaded X.509 cert 'Build time autogenerated kernel key: 9612dc616146eeaafd46db77e26f033f23e1efc3'
[ 0.545411] zswap: loaded using pool zstd/z3fold
[ 0.545794] Key type ._fscrypt registered
[ 0.545796] Key type .fscrypt registered
[ 0.545797] Key type fscrypt-provisioning registered
[ 0.545867] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.546206] PM: Magic number: 6:217:72
[ 0.546507] RAS: Correctable Errors collector initialized.
[ 0.548312] Freeing unused decrypted memory: 2036K
[ 0.549236] Freeing unused kernel image (initmem) memory: 1864K
[ 0.562934] Write protecting the kernel read-only data: 28672k
[ 0.564097] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 0.564813] Freeing unused kernel image (rodata/data gap) memory: 1404K
[ 0.616339] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.616348] rodata_test: all tests were successful
[ 0.616361] x86/mm: Checking user space page tables
[ 0.666398] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.666408] Run /init as init process
[ 0.666410] with arguments:
[ 0.666412] /init
[ 0.666413] with environment:
[ 0.666414] HOME=/
[ 0.666415] TERM=linux
[ 0.666416] BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64
[ 0.676231] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 0.815821] ata_piix 0000:00:1f.1: version 2.13
[ 0.817258] scsi host0: ata_piix
[ 0.817441] scsi host1: ata_piix
[ 0.817485] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 0.817488] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 0.817624] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 0.819091] scsi host2: ata_piix
[ 0.819230] scsi host3: ata_piix
[ 0.819276] ata3: SATA max UDMA/133 cmd 0xc400 ctl 0xc080 bmdma 0xb880 irq 22
[ 0.819279] ata4: SATA max UDMA/133 cmd 0xc000 ctl 0xbc00 bmdma 0xb888 irq 22
[ 0.823429] usb 1-1: New USB device found, idVendor=214b, idProduct=7250, bcdDevice= 1.00
[ 0.823435] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 0.823437] usb 1-1: Product: USB2.0 HUB
[ 0.823726] hub 1-1:1.0: USB hub found
[ 0.823800] hub 1-1:1.0: 4 ports detected
[ 0.986336] ata3.00: ATA-8: ST3500418AS, CC38, max UDMA/133
[ 0.986348] ata3.00: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 0.993197] scsi 2:0:0:0: Direct-Access ATA ST3500418AS CC38 PQ: 0 ANSI: 5
[ 0.993524] sd 2:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[ 0.993538] sd 2:0:0:0: [sda] Write Protect is off
[ 0.993541] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.993560] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.042199] sda: sda1 sda2 sda3 sda4 < sda5 >
[ 1.056092] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.152461] usb 2-2: new full-speed USB device number 2 using uhci_hcd
[ 1.330155] usb 2-2: New USB device found, idVendor=24ae, idProduct=1100, bcdDevice= 1.10
[ 1.330167] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.330172] usb 2-2: Product: Rapoo 2.4G Wireless Device
[ 1.330176] usb 2-2: Manufacturer: RAPOO
[ 1.344686] input: RAPOO Rapoo 2.4G Wireless Device as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.0/0003:24AE:1100.0001/input/input2
[ 1.344785] hid-generic 0003:24AE:1100.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-0000:00:1d.0-2/input0
[ 1.346573] hid-generic 0003:24AE:1100.0002: hiddev96,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-0000:00:1d.0-2/input1
[ 1.346609] usbcore: registered new interface driver usbhid
[ 1.346611] usbhid: USB HID core driver
[ 1.401589] tsc: Refined TSC clocksource calibration: 2699.999 MHz
[ 1.401602] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x26eb3d7f706, max_idle_ns: 440795268188 ns
[ 1.401627] clocksource: Switched to clocksource tsc
[ 1.748769] random: fast init done
[ 1.791602] usb 1-1.4: new high-speed USB device number 4 using ehci-pci
[ 1.889399] usb 1-1.4: New USB device found, idVendor=14cd, idProduct=125d, bcdDevice= 1.00
[ 1.889407] usb 1-1.4: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[ 1.889409] usb 1-1.4: Product: Mass Storage Device
[ 1.889411] usb 1-1.4: Manufacturer: Generic
[ 1.889413] usb 1-1.4: SerialNumber: 125D20140310
[ 2.144920] usb 3-1: new low-speed USB device number 2 using uhci_hcd
[ 2.341950] usb 3-1: New USB device found, idVendor=0518, idProduct=0001, bcdDevice= 1.00
[ 2.341958] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.341963] usb 3-1: Product: USB-compliant keyboard
[ 2.341966] usb 3-1: Manufacturer: Plus More Enterprise LTD.
[ 2.360510] input: Plus More Enterprise LTD. USB-compliant keyboard as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.0/0003:0518:0001.0003/input/input3
[ 2.415209] hid-generic 0003:0518:0001.0003: input,hidraw2: USB HID v1.10 Keyboard [Plus More Enterprise LTD. USB-compliant keyboard] on usb-0000:00:1d.1-1/input0
[ 2.431608] input: Plus More Enterprise LTD. USB-compliant keyboard Mouse as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.1/0003:0518:0001.0004/input/input4
[ 2.431692] input: Plus More Enterprise LTD. USB-compliant keyboard Consumer Control as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.1/0003:0518:0001.0004/input/input5
[ 2.488380] input: Plus More Enterprise LTD. USB-compliant keyboard System Control as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.1/0003:0518:0001.0004/input/input6
[ 2.488504] hid-generic 0003:0518:0001.0004: input,hidraw3: USB HID v1.10 Mouse [Plus More Enterprise LTD. USB-compliant keyboard] on usb-0000:00:1d.1-1/input1
[ 2.918527] usb-storage 1-1.4:1.0: USB Mass Storage device detected
[ 2.918723] scsi host4: usb-storage 1-1.4:1.0
[ 2.918824] usbcore: registered new interface driver usb-storage
[ 2.925397] usbcore: registered new interface driver uas
[ 3.039765] fbcon: Taking over console
[ 3.040033] Console: switching to colour frame buffer device 80x30
[ 3.240599] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 3.935565] scsi 4:0:0:0: Direct-Access Mass Storage Device PQ: 0 ANSI: 0 CCS
[ 3.936415] sd 4:0:0:0: [sdb] Media removed, stopped polling
[ 3.937439] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 4.284838] systemd[1]: systemd 250-5-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 4.301747] systemd[1]: Detected architecture x86-64.
[ 4.327060] systemd[1]: Hostname set to <phree-sys>.
[ 4.909415] random: crng init done
[ 6.741304] systemd[1]: Queued start job for default target Graphical Interface.
[ 6.742649] systemd[1]: Created slice Slice /system/getty.
[ 6.743153] systemd[1]: Created slice Slice /system/modprobe.
[ 6.743478] systemd[1]: Created slice User and Session Slice.
[ 6.743598] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 6.743672] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.743880] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.743914] systemd[1]: Reached target Local Encrypted Volumes.
[ 6.743939] systemd[1]: Reached target Login Prompts.
[ 6.743963] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 6.744001] systemd[1]: Reached target Remote File Systems.
[ 6.744020] systemd[1]: Reached target Slice Units.
[ 6.744061] systemd[1]: Reached target Local Verity Protected Volumes.
[ 6.744163] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 6.744325] systemd[1]: Listening on LVM2 poll daemon socket.
[ 6.746221] systemd[1]: Listening on Process Core Dump Socket.
[ 6.746445] systemd[1]: Listening on Journal Audit Socket.
[ 6.746592] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.746749] systemd[1]: Listening on Journal Socket.
[ 6.755490] systemd[1]: Listening on udev Control Socket.
[ 6.755630] systemd[1]: Listening on udev Kernel Socket.
[ 6.756938] systemd[1]: Mounting Huge Pages File System...
[ 6.758200] systemd[1]: Mounting POSIX Message Queue File System...
[ 6.759573] systemd[1]: Mounting Kernel Debug File System...
[ 6.760894] systemd[1]: Mounting Kernel Trace File System...
[ 6.762510] systemd[1]: Starting Load AppArmor profiles...
[ 6.764221] systemd[1]: Starting Create List of Static Device Nodes...
[ 6.765941] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 6.767622] systemd[1]: Starting Load Kernel Module configfs...
[ 6.770872] systemd[1]: Starting Load Kernel Module drm...
[ 6.772560] systemd[1]: Starting Load Kernel Module fuse...
[ 6.772736] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 6.843277] systemd[1]: Starting Load Kernel Modules...
[ 6.844626] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 6.844775] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[ 6.846197] systemd[1]: Starting Coldplug All udev Devices...
[ 6.848734] systemd[1]: Mounted POSIX Message Queue File System.
[ 6.848893] systemd[1]: Mounted Kernel Trace File System.
[ 6.849180] systemd[1]: Finished Create List of Static Device Nodes.
[ 6.849620] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 6.849801] systemd[1]: Finished Load Kernel Module configfs.
[ 6.850149] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 6.850320] systemd[1]: Finished Load Kernel Module drm.
[ 6.851751] systemd[1]: Mounting Kernel Configuration File System...
[ 6.854383] systemd[1]: Mounted Kernel Configuration File System.
[ 6.860412] systemd[1]: Mounted Kernel Debug File System.
[ 6.863022] systemd[1]: Mounted Huge Pages File System.
[ 6.890679] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
[ 6.892139] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 6.893408] systemd[1]: Activating swap /swapfile...
[ 6.893542] systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 6.957643] fuse: init (API version 7.34)
[ 7.030185] systemd[1]: Rebuild Hardware Database was skipped because all trigger condition checks failed.
[ 7.031605] systemd[1]: Starting Load/Save Random Seed...
[ 7.033053] systemd[1]: Starting Create System Users...
[ 7.034503] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 7.034766] systemd[1]: Finished Load Kernel Module fuse.
[ 7.203261] Adding 4194300k swap on /swapfile. Priority:-2 extents:9 across:7274496k FS
[ 7.203403] systemd[1]: Activated swap /swapfile.
[ 7.203515] systemd[1]: Reached target Swaps.
[ 7.375782] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 7.375831] sd 4:0:0:0: Attached scsi generic sg1 type 0
[ 7.403317] systemd[1]: Finished Coldplug All udev Devices.
[ 7.417386] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 7.479488] systemd[1]: Finished Load/Save Random Seed.
[ 7.479705] systemd[1]: First Boot Complete was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 7.500804] IPMI message handler: version 39.2
[ 7.521424] ipmi device interface
[ 7.552888] ipmi_si: IPMI System Interface driver
[ 7.552974] ipmi_si: Unable to find any System Interface(s)
[ 7.644423] systemd[1]: Finished Load Kernel Modules.
[ 7.646005] systemd[1]: Starting Apply Kernel Variables...
[ 7.793755] systemd[1]: Finished Apply Kernel Variables.
[ 7.850149] systemd[1]: Mounting FUSE Control File System...
[ 7.870094] audit: type=1400 audit(1641722659.936:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=229 comm="apparmor_parser"
[ 7.878297] systemd[1]: Mounting Temporary Directory /tmp...
[ 7.879322] systemd[1]: Mounted FUSE Control File System.
[ 7.910193] systemd[1]: Mounted Temporary Directory /tmp.
[ 7.917204] audit: type=1400 audit(1641722659.982:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=230 comm="apparmor_parser"
[ 7.918356] audit: type=1400 audit(1641722659.986:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=230 comm="apparmor_parser"
[ 7.946200] systemd[1]: Finished Create System Users.
[ 7.947604] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 8.241714] audit: type=1400 audit(1641722660.309:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=235 comm="apparmor_parser"
[ 8.356402] audit: type=1400 audit(1641722660.422:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=233 comm="apparmor_parser"
[ 8.572548] audit: type=1400 audit(1641722660.639:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=237 comm="apparmor_parser"
[ 8.572558] audit: type=1400 audit(1641722660.639:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=237 comm="apparmor_parser"
[ 8.574066] systemd[1]: Finished Load AppArmor profiles.
[ 8.575476] systemd[1]: Starting Load AppArmor profiles managed internally by snapd...
[ 8.784291] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 8.784448] systemd[1]: Reached target Preparation for Local File Systems.
[ 8.784499] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of a failed condition check (ConditionPathExists=/var/lib/machines.raw).
[ 8.784522] systemd[1]: Reached target Local File Systems.
[ 8.784561] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of a failed condition check (ConditionKernelVersion=<5.6).
[ 8.785885] systemd[1]: Starting Rebuild Dynamic Linker Cache...
[ 8.815272] systemd[1]: Starting Set Up Additional Binary Formats...
[ 8.815347] systemd[1]: Store a System Token in an EFI Variable was skipped because of a failed condition check (ConditionPathExists=/sys/firmware/efi/efivars/LoaderFeatures-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
[ 8.818065] systemd[1]: Starting Journal Service...
[ 8.818171] systemd[1]: Commit a transient machine-id on disk was skipped because of a failed condition check (ConditionPathIsMountPoint=/etc/machine-id).
[ 8.820453] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 8.821296] systemd[1]: Finished Load AppArmor profiles managed internally by snapd.
[ 8.831675] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 244 (systemd-binfmt)
[ 8.833665] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ 8.837601] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ 8.872050] systemd[1]: Finished Set Up Additional Binary Formats.
[ 9.017193] systemd[1]: Started Journal Service.
[ 9.017315] audit: type=1130 audit(1641722661.082:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 9.074524] systemd-journald[245]: Received client request to flush runtime journal.
[ 10.153172] audit: type=1130 audit(1641722662.222:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ldconfig comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 10.261750] audit: type=1130 audit(1641722662.329:11): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 10.634823] input: PC Speaker as /devices/platform/pcspkr/input/input7
[ 10.881270] intel_rng: FWH not detected
[ 10.970236] parport_pc 00:02: reported by Plug and Play ACPI
[ 10.970334] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,EPP,ECP,DMA]
[ 11.012189] asus_atk0110: Resources not safely usable due to acpi_enforce_resources kernel parameter
[ 11.282795] via-rhine 0000:04:01.0 eth0: VIA Rhine III at 000000004b155571, 34:08:04:2a:59:51, IRQ 21
[ 11.283580] via-rhine 0000:04:01.0 eth0: MII PHY found at address 1, status 0x786d advertising 05e1 Link c5e1
[ 11.374957] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000800-0x000000000000084F (\PMRG) (20210730/utaddress-204)
[ 11.374970] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 11.374972] ACPI: OSL: Resource conflict: System may be unstable or behave erratically
[ 11.374979] ACPI Warning: SystemIO range 0x00000000000004B0-0x00000000000004BF conflicts with OpRegion 0x0000000000000480-0x00000000000004BF (\GPS0) (20210730/utaddress-204)
[ 11.374985] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 11.374987] ACPI: OSL: Resource conflict: System may be unstable or behave erratically
[ 11.374989] ACPI Warning: SystemIO range 0x0000000000000480-0x00000000000004AF conflicts with OpRegion 0x0000000000000480-0x00000000000004BF (\GPS0) (20210730/utaddress-204)
[ 11.374996] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 11.374997] ACPI: OSL: Resource conflict: System may be unstable or behave erratically
[ 11.381118] via-rhine 0000:04:01.0 enp4s1: renamed from eth0
[ 11.414191] leds_ss4200: no LED devices found
[ 11.487905] iTCO_vendor_support: vendor-support=0
[ 11.503697] ppdev: user-space parallel port driver
[ 11.506300] asus_atk0110: Resources not safely usable due to acpi_enforce_resources kernel parameter
[ 11.545401] gpio_ich gpio_ich.2.auto: GPIO from 974 to 1023
[ 12.387460] iTCO_wdt iTCO_wdt.1.auto: Found a ICH7 or ICH7R TCO device (Version=2, TCOBASE=0x0860)
[ 12.387701] iTCO_wdt iTCO_wdt.1.auto: initialized. heartbeat=30 sec (nowayout=0)
[ 12.516969] mousedev: PS/2 mouse device common for all mice
[ 12.562968] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 12.562981] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 12.732753] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input8
[ 12.732852] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input9
[ 12.732941] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10
[ 12.733031] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input11
[ 12.871505] intel_powerclamp: No package C-state available
[ 12.875783] checking generic (df000000 130000) vs hw (fd000000 1000000)
[ 12.875791] checking generic (df000000 130000) vs hw (e0000000 10000000)
[ 12.875793] checking generic (df000000 130000) vs hw (de000000 2000000)
[ 12.875795] fb0: switching to nouveau from VESA VGA
[ 12.875947] Console: switching to colour dummy device 80x25
[ 12.876009] nouveau 0000:01:00.0: vgaarb: deactivate vga console
[ 12.876059] nouveau 0000:01:00.0: NVIDIA GT216 (0a5180a2)
[ 12.925886] intel_powerclamp: No package C-state available
[ 13.004155] nouveau 0000:01:00.0: bios: version 70.16.4f.00.05
[ 13.004881] nouveau 0000:01:00.0: fb: 1024 MiB DDR2
[ 13.067695] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC887: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
[ 13.067705] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 13.067708] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 13.067710] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 13.067712] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x11/0x1e
[ 13.067714] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 13.067716] snd_hda_codec_realtek hdaudioC0D0: Front Mic=0x19
[ 13.067718] snd_hda_codec_realtek hdaudioC0D0: Rear Mic=0x18
[ 13.067720] snd_hda_codec_realtek hdaudioC0D0: Line=0x1a
[ 13.083466] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 13.083530] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input13
[ 13.083584] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input14
[ 13.083638] input: HDA Intel Line Out Front as /devices/pci0000:00/0000:00:1b.0/sound/card0/input15
[ 13.083691] input: HDA Intel Line Out Surround as /devices/pci0000:00/0000:00:1b.0/sound/card0/input16
[ 13.083748] input: HDA Intel Line Out CLFE as /devices/pci0000:00/0000:00:1b.0/sound/card0/input17
[ 13.083800] input: HDA Intel Line Out Side as /devices/pci0000:00/0000:00:1b.0/sound/card0/input18
[ 13.083852] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input19
[ 14.002821] nouveau 0000:01:00.0: DRM: VRAM: 1024 MiB
[ 14.002832] nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
[ 14.002839] nouveau 0000:01:00.0: DRM: TMDS table version 2.0
[ 14.002844] nouveau 0000:01:00.0: DRM: DCB version 4.0
[ 14.002848] nouveau 0000:01:00.0: DRM: DCB outp 00: 01022310 00020030
[ 14.002855] nouveau 0000:01:00.0: DRM: DCB outp 01: 01000302 00020030
[ 14.002860] nouveau 0000:01:00.0: DRM: DCB outp 02: 02011362 00020010
[ 14.002864] nouveau 0000:01:00.0: DRM: DCB outp 03: 02000300 00000000
[ 14.002869] nouveau 0000:01:00.0: DRM: DCB conn 00: 00001030
[ 14.002874] nouveau 0000:01:00.0: DRM: DCB conn 01: 00002261
[ 14.002878] nouveau 0000:01:00.0: DRM: DCB conn 02: 00000200
[ 14.006001] nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
[ 14.006064] nouveau 0000:01:00.0: disp: conn 01:0261: func 08 lookup failed, -2
[ 14.062231] nouveau 0000:01:00.0: DRM: allocated 1280x1024 fb: 0x70000, bo 000000000c72934a
[ 14.062311] fbcon: nouveaudrmfb (fb0) is primary device
[ 14.103683] Console: switching to colour frame buffer device 160x64
[ 14.104622] nouveau 0000:01:00.0: [drm] fb0: nouveaudrmfb frame buffer device
[ 14.118691] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 0
[ 14.151626] audit: type=1130 audit(1641722666.216:12): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.360711] audit: type=1130 audit(1641722666.426:13): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.364346] audit: type=1334 audit(1641722666.429:14): prog-id=9 op=LOAD
[ 14.397143] audit: type=1127 audit(1641722666.462:15): pid=326 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[ 14.417362] audit: type=1130 audit(1641722666.482:16): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.441040] audit: type=1130 audit(1641722666.506:17): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.448481] audit: type=1130 audit(1641722666.516:18): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.469277] audit: type=1130 audit(1641722666.536:19): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-done comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.481313] audit: type=1130 audit(1641722666.546:20): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.488944] audit: type=1130 audit(1641722666.556:21): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 14.765545] w83627ehf: Found W83627DHG-P chip at 0x290
[ 14.765557] ACPI Warning: SystemIO range 0x0000000000000295-0x0000000000000296 conflicts with OpRegion 0x0000000000000290-0x0000000000000299 (\_SB.PCI0.SBRG.SIOR.HWRE) (20210730/utaddress-204)
[ 14.765564] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 14.765565] ACPI: OSL: Resource conflict: System may be unstable or behave erratically
[ 19.193295] kauditd_printk_skb: 16 callbacks suppressed
[ 19.193300] audit: type=1130 audit(1641722671.259:38): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.760639] audit: type=1130 audit(1641722671.826:39): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 19.765658] audit: type=1130 audit(1641722671.832:40): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 20.659203] loop: module loaded
[ 20.659767] loop0: detected capacity change from 0 to 8
[ 20.757715] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 21.454300] audit: type=1130 audit(1641722673.519:41): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.658494] audit: type=1334 audit(1641722673.726:42): prog-id=16 op=LOAD
[ 21.658809] audit: type=1334 audit(1641722673.726:43): prog-id=17 op=LOAD
[ 21.658985] audit: type=1334 audit(1641722673.726:44): prog-id=18 op=LOAD
[ 21.847660] audit: type=1130 audit(1641722673.912:45): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 21.970747] NET: Registered PF_QIPCRTR protocol family
[ 21.978574] audit: type=1130 audit(1641722674.042:46): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 22.022933] audit: type=1325 audit(1641722674.056:47): table=filter family=2 entries=0 op=xt_register pid=584 subj==unconfined comm="iptables"
[ 25.676607] kauditd_printk_skb: 41 callbacks suppressed
[ 25.676614] audit: type=1100 audit(1641722677.746:61): pid=626 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 25.676720] audit: type=1101 audit(1641722677.746:62): pid=626 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 25.690170] audit: type=1103 audit(1641722677.759:63): pid=626 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 25.757549] audit: type=1130 audit(1641722677.822:64): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 25.786902] audit: type=1101 audit(1641722677.852:65): pid=631 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 25.787100] audit: type=1103 audit(1641722677.852:66): pid=631 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 25.787107] audit: type=1006 audit(1641722677.852:67): pid=631 uid=0 subj==unconfined old-auid=4294967295 auid=963 tty=(none) old-ses=4294967295 ses=1 res=1
[ 25.787110] audit: type=1300 audit(1641722677.852:67): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7ffde0b2bea0 a2=3 a3=3c3 items=0 ppid=1 pid=631 auid=963 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
[ 25.787114] audit: type=1327 audit(1641722677.852:67): proctitle="(systemd)"
[ 25.819144] audit: type=1105 audit(1641722677.886:68): pid=631 uid=0 auid=963 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 31.538572] kauditd_printk_skb: 8 callbacks suppressed
[ 31.538579] audit: type=1130 audit(1641722683.602:75): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 31.584173] audit: type=1334 audit(1641722683.649:76): prog-id=20 op=LOAD
[ 31.584580] audit: type=1334 audit(1641722683.649:77): prog-id=21 op=LOAD
[ 31.808513] audit: type=1130 audit(1641722683.876:78): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 42.391933] audit: type=1100 audit(1641722694.459:79): pid=678 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="phree" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 42.392165] audit: type=1101 audit(1641722694.459:80): pid=678 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="phree" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 42.392722] audit: type=1103 audit(1641722694.459:81): pid=678 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="phree" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 42.392831] audit: type=1006 audit(1641722694.459:82): pid=678 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 42.392836] audit: type=1300 audit(1641722694.459:82): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffc648073c0 a2=4 a3=3e8 items=0 ppid=509 pid=678 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" subj==unconfined key=(null)
[ 42.392841] audit: type=1327 audit(1641722694.459:82): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746831623666353963372D613666352D343865322D396635392D316333376232633265383266002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
[ 42.432711] audit: type=1130 audit(1641722694.496:83): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 42.442703] audit: type=1101 audit(1641722694.509:84): pid=680 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="phree" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 42.442785] audit: type=1103 audit(1641722694.509:85): pid=680 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="phree" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 42.442888] audit: type=1006 audit(1641722694.509:86): pid=680 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 51.857929] kauditd_printk_skb: 15 callbacks suppressed
[ 51.857934] audit: type=1131 audit(1641722703.922:98): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 52.516408] audit: type=1334 audit(1641722704.582:99): prog-id=0 op=UNLOAD
[ 52.516420] audit: type=1334 audit(1641722704.582:100): prog-id=0 op=UNLOAD
[ 52.516427] audit: type=1334 audit(1641722704.582:101): prog-id=0 op=UNLOAD
[ 53.347640] audit: type=1130 audit(1641722705.412:102): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 53.669465] audit: type=1131 audit(1641722705.736:103): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 53.692380] audit: type=1131 audit(1641722705.759:104): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 68.163606] audit: type=1334 audit(1641722720.229:105): prog-id=23 op=LOAD
[ 68.164848] audit: type=1334 audit(1641722720.229:106): prog-id=24 op=LOAD
[ 68.165235] audit: type=1334 audit(1641722720.232:107): prog-id=25 op=LOAD
[ 68.246965] audit: type=1130 audit(1641722720.312:108): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 68.450850] audit: type=1111 audit(1641722720.516:109): pid=334 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics interface="enp4s1" ifindex=2 args=500 pid=1074 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 98.259882] audit: type=1131 audit(1641722750.326:110): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 98.388382] audit: type=1334 audit(1641722750.456:111): prog-id=0 op=UNLOAD
[ 98.388434] audit: type=1334 audit(1641722750.456:112): prog-id=0 op=UNLOAD
[ 98.388459] audit: type=1334 audit(1641722750.456:113): prog-id=0 op=UNLOAD
[ 128.450883] audit: type=1100 audit(1641722780.516:114): pid=1253 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="phree" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 128.451910] audit: type=1101 audit(1641722780.519:115): pid=1253 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="phree" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 128.453697] audit: type=1110 audit(1641722780.519:116): pid=1253 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 128.457775] audit: type=1105 audit(1641722780.522:117): pid=1253 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
