Cant mount secondary HDD
I just installed manjaro, however I am unable to mount my secondary HDD. When attempting to access the drive, dolphin gives me the following error:
An error occurred while accessing ‘New Volume’, the system responded: The requested operation has failed: Error mounting /dev/md126p1 at /run/media/dylanm/New Volume: Unknown error when mounting /dev/md126p1
Any help would be greatly appreciated!
Hello @Warp :wink:
Looks like a RAID Device… how did you create it? With mdadm?
sudo mdadm --detail /dev/md126p1
No idea what mdadm is. I just opened Dolphin, and tried to access the drive. Anyways, here the output of
the detail command:
/dev/md126p1:
         Container : /dev/md/ddf0, member 7
        Raid Level : raid0
        Array Size : 976223232 (931.00 GiB 999.65 GB)
      Raid Devices : 1
     Total Devices : 1
             State : clean
    Active Devices : 1
   Working Devices : 1
    Failed Devices : 0
        Chunk Size : 64K
Consistency Policy : none
    Container GUID : 44656C6C:20202020:10000073:10281F51:4AF30405:C62ACCFB
                  (Dell     11/05/19 10:57:41)
               Seq : 00000020
     Virtual Disks : 9
    Number   Major   Minor   RaidDevice State
       0       8       16        0      active sync   /dev/sdb
It is a Raid0 with FakeRaid (BIOS Raid). Raid0 must have at least 2 drives, but there is only one drive:
Where does this disk come from? If there is no second drive, then the files are gone, since RAID0.
Is it probably an Intel Optane Cache?
Not sure, I’ll check when I get home from work in the evening. If it is Optane, I turned off UEFI and switched to legacy, (only Windows Boot Manager and network boot would show up in boot sequence) would that have an effect?
You’ll have to provide more information about your system and setup, otherwise we’ll just end up going off on unrelated tangents and wild goose chases.
You haven’t even said if this is a laptop. If this is a new purchase. If this “secondary” drive was included with the computer or installed afterwards.
Were you successfully using this drive prior to installing Manjaro? Was it gifted from a friend? Is there valuable data on it?
We’re going in blind here.
I’m using an upgraded Optiplex 3010, which I’ve had for 2 years and has ran fine. (except for windows, of course) The HDD in question was working normally before I switched to Manjaro, and there is valuable data on it. The HDD is a Hitachi HUA722010CLA330, and my boot drive is a PNY CS900 240GB SSD. Looking up the specs of the Optiplex 3010, it appears these drives were installed afterwards. It doesnt appear that I have Optane, though I’m not completely sure how to check. My general system specs are the following:
Processors: 4 × Intel® Core™ i5-3470 CPU @ 3.20GHz
Memory: 15.6 GiB of RAM
Graphics Processor: AMD Radeon RX 470 Graphics
Manufacturer: Dell Inc.
Product Name: OptiPlex 3010
System Version: 01
Here is a common list of what needs to be changed on the BIOS/UEFI Settings:
My guess is that RAID is enabled on your UEFI and you need to switch to AHCI.
As stated in the forth reply,
I tried to follow the UEFI install guide on the wiki, and if all went well, I would have had UEFI working right now. However, Gparted says on my SSD, I only have 2mb of space to resize.
I don`t know how to proceed. Could anyone kindly help?
Yes, but what about the other points in @megavolt’s post?
Such as: RAID → AHCI
Working normally under Windows? Do you remember how you initially configured it or formatted it?
You’re not using an Intel Optane drive, evident from the specs you shared (Hitatch 2.5" HDD and PNY SSD).
You’re treading into precarious grounds now. Be careful. Are you able to access the data on the Hitachi HDD from within Windows? If so, I’d backup everything for peace of mind.
@winnie
No, I have not configured or formatted the drive since I first installed Windows.
The Windows installation is completely gone, I intentionally formatted the drive with the Windows installation.
But did it work normally under Windows? And does it still work normally under Windows in which you can access the data?
:point_down:
Because…
@winnie Edited my last reply right as you sent yours, check mine again.
I guess it is ext4 file system. Therefore you can only grow the partition when mounted. To move or shrink it, it have to be unmounted. If it is the system partition, so the root directory, it have to be done on a live session.
You still have the option to test out the other changes mentioned by @megavolt. (AHCI mode for SATA, for example.)
An “inxi dump” would really help as well:
inxi --full --admin --verbosity=7 --filter --no-host
SATA was already set to AHCI before I installed Manjaro, and still is. Here’s the output of the dump command:
  Kernel: 5.15.71-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=206c8d41-a472-47ba-b70d-5a64b7e9c848 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1
  Type: Desktop System: Dell product: OptiPlex 3010 v: 01
    serial: <superuser required> Chassis: type: 6 serial: <superuser required>
  Mobo: Dell model: 042P49 v: A01 serial: <superuser required> BIOS: Dell
    v: A09 date: 01/31/2013
  RAM: total: 15.6 GiB used: 1.53 GiB (9.8%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: Intel Core i5-3470 bits: 64 type: MCP arch: Ivy Bridge
    gen: core 3 level: v3 built: 2012-15 process: Intel 22nm family: 6
    model-id: 0x3A (58) stepping: 9 microcode: 0x21
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 2512 high: 3193 min/max: 1600/3200 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1597 2: 3193 3: 2067
    4: 3193 bogomips: 25554
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
    lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
    x2apic xsave xsaveopt xtopology xtpr
    disabled
    prctl and seccomp
    STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
  Type: srbds status: Vulnerable: No microcode
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] vendor: PC
    Partner / Sapphire driver: amdgpu v: kernel arch: GCN-4
    code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
    speed: 8 GT/s lanes: 16 ports: active: DP-2 empty: DP-1, DVI-D-1,
    HDMI-A-1, HDMI-A-2 bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
    display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: DP-2 mapped: DisplayPort-1 model: Viewteck GFV24C built: 2019
    res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2 size: 530x280mm (20.87x11.02")
    diag: 599mm (23.6") modes: max: 1920x1080 min: 720x400
  OpenGL: renderer: AMD Radeon RX 470 Graphics (polaris10 LLVM 14.0.6 DRM
    3.42 5.15.71-1-MANJARO) v: 4.6 Mesa 22.1.7 direct render: Yes
    vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 1-1.1:3
    bus-ID: 00:1b.0 chip-ID: 0d8c:0134 chip-ID: 8086:1c20 class-ID: 0300
    class-ID: 0403
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: PC Partner / Sapphire driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
  Device-3: C-Media TONOR TC-777 Audio Device type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  Sound Server-1: ALSA v: k5.15.71-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.58 running: yes
    vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 2-1.4:3 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
  Supported mdraid levels: raid0
  Device-1: md126 maj-min: 9:126 type: mdraid level: raid-0 status: active
  Info: report: N/A blocks: 976224256 chunk-size: 64k
  Components: Online:
  0: sdb maj-min: 8:16 size: 931.51 GiB
  Device-2: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
  Info: report: N/A blocks: 538328 chunk-size: N/A
  Components: Online: N/A Spare:
  0: sdb maj-min: 8:16 size: 931.51 GiB state: S
  Local Storage: total: raw: 1.13 TiB usable: 223.06 GiB used: 53.22 GiB
    (23.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 240GB SSD
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: SSD serial: <filter> rev: 0BB3 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HUA722010CLA330
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 7200 serial: <filter> rev: A3EA
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GHA2N rev: A103
    dev-links: cdrom
  ID-1: / raw-size: 223.57 GiB size: 219 GiB (97.96%) used: 53.22 GiB (24.3%)
    fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 206c8d41-a472-47ba-b70d-5a64b7e9c848
  ID-1: /dev/md126p1 maj-min: 259:0 size: 931 GiB fs: ntfs label: New Volume
    uuid: AE0C6A050C69C8C3
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
    speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.1:3 info: C-Media TONOR TC-777 Audio Device type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
    speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0134 class-ID: 0300
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Device-1: 2-1.4:3 info: Realtek Bluetooth Radio type: Bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
  Device-2: 2-1.5:4 info: USB OPTICAL MOUSE type: Mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
    power: 100mA chip-ID: 0000:0538 class-ID: 0301
  Device-3: 2-1.6:5 info: China Resource Semico USB Keyboard
    type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s power: 500mA chip-ID: 1a2c:4b81 class-ID: 0301
  System Temperatures: cpu: 32.0 C mobo: N/A gpu: amdgpu temp: 26.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 1679
  Processes: 220 Uptime: 2m wakeups: 0 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
  Packages: pm: pacman pkgs: 1349 libs: 406 tools: pamac pm: flatpak pkgs: 0
  Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
The heck is going on here? There are references to TWO different RAID arrays; both apparently using /dev/sdb as an underlying device.
MDADM software RAID… NTFS… level 0… only one drive?
Were you the original owner of this computer and its components, including the drives? This is non-standard. Someone has to go out of there way to do this.
Your BIOS settings are supposedly fine: SATA mode is AHCI. No Intel Optane.
Did you use some sort of RAID feature while under Windows? Dynamic storage? Something? Since you completely removed Windows altogether, it makes it more tricky to backtrack on what you did.
No, I received it as a gift from my uncle, who made the modifications to the hardware. No modifications have been made since I began to daily-drive it. There is no way of contacting him, as he passed away 2 years ago.
No idea.
I’m sorry to hear.
The data might be lost, if it is in fact from a two-drive RAID-0 array.
However, you can try a last ditch shot. (Since “RAID-0” might mean something different in this case, such as a single drive “stripe” array.)
Try to forcefully start the array and mount it as a read-only NTFS filesystem in a temporary mount point. If it’s accessible, you can copy all the data to another drive, such as an external USB.
I tried a live session and found I have no MBR or GPT on /dev/sda1. I’d rather not completely reinstall manjaro, as I’ve already taken up 25% of the available storage. Any ideas?
