Hello people, I updated Manjaro Gnome and by some reason… you guys switched from Bash to Zsh in some moment, then I was kind of lost, tried to customize it with oh-my-zsh and it went worse… now I can’t even launch Alacritty or the Gnome-Console
I get this on top of the Gnome-Terminal (since Alacritty doesn’t even launch)
There was an error creating the child process for this terminal
Failed to execute child process “zsh”: Failed to execve: Permission denied
It then shows me “Preferences” and “Relaunch” but nothing is useful.
I tried so many stuff I am worse than when I started, sometimes I delete config folders and seems to work only to later show me the same problem.
The PC is this one:
I tried checking obviously when I make it work:
chsh -l
chsh -s /urs/share/bash
It never works… also I am not sure if the list is really updated, I mean, I can edit it with
gedit /etc/shells
But that isn’t a lot of help, also for some reason with the root I was able to set it to bash at some point, but I thought “Ok, let’s accept this move from Manjaro to Zsh”
I read so many guides about Zsh, Oh-My-Zhs and installed/uninstalled that I am thinking of simply formatting the PC at this point
Can someone please help me telling me what to do, and what not to do, so I can try it and post here the results? I noticed sometimes the changes seem to work and oh-my-zsh is working only to reboot and see the same error again:
