In general fans have speed controls on their pedestals.
Unless…
Unless you mean your computer’s fans…in which case, we need to knows more. Please see here:
Tip:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
If your motherboard support PWM, then you should be able to use pwmconfig to configure it and fanspeed to manipulate it, however in most cases it is only controlled by your UEFI and you can only change such things there. Sometimes you can disable automatic fanspeed in the UEFI and manage it by the OS, but that are rare cases where it is possible.
pwmconfig is an outdated tool. It can’t detect some new sensors.
I had the same problem as you. sensors output only contained information from acpitz-acpi-0 and coretemp-isa-0000.
In my motherboard’s manual I found that it was equipped with Nuvoton NCT6687D-M sensor. Then i installed kernel module nct6687d-dkms-git for that sensor. And now sensors provide a lot more information including fan speed, which in turn enables utilities such as fanspeed to be used for fan RPM control.
