Hi everyone I am a noib in manjaro so please do not use concepts that a chils will not understand. The problem is that recently while I was on the browser my laptop got frozen I wait for a while and nothing happened so I forced a shutdown pressing the power off button after that y restarted the laptop and I found that I was umable to connect to the wifi. Any idea why? Is there a way to restore the network? Is there any command for activate wifi again or check if it is worling?. I really appreciate your help thanks
Hi @MRBomberman,
I could be able to help you whether you can give me some useful information from your system. It is not so hard to learn how to do it, the only way to post the information is reading how to do it well. I think you should understand after the reading.
‘How to provide good information - #39 by Fabby’
You could also try to run the following terminal commands and put the output here( between three backticks )
inxi -Fazy
rfkill list all
journalctl -f -t NetworkManager
dmesg | grepNetworkManager
Maybe, the only problem is that you have to reinstall the wifi driver.
Hope this help, regards
How do I reinstall the drivers?
Normally you don’t re-install the drivers as they are built into the kernel.
Please read this:
and then provide the information @j8a is asking.
Hi @MRBomberman ,
You have a kernel linux58 installed that is not longer supported and maybe it is the only problem you have. Linux58 is EOL ( no more support )
You also have a Qualcom Atheros QCA9565 wifi adapter installed.
Could you try to install another kernel, for example linux510 or linux54?
Try to add the linux54 kernel from the following terminal command.
sudo mhwd-kernel -i linux54
You can also install this from the status notification bar in the top right desktop of your XFCE Manjaro environment. You can recognize this bar because is an inverted triangle.
Then, reboot and in the grub menu choose the linux54 kernel on boot.
I assume you have the grub menu installed.
After you’ve verified the 5.4 Kernel works, I also suggest you to remove the linux58 kernel and install another LTS kernel in the case you have problems with the linux54 kernel. It is recommended by the Manjaro Team to keep two kernels installed because it is a good practice in the rolling release model.
Then you should install another kernel with the terminal command:
sudo mhwd-kernel -i linux510
And only then should you try to remove the linux58 kernel from the terminal with:
sudo mhwd-kernel -r linux58
Since I have no access to internet I cannot download that kernel from my laptop, I put the commands that you said, and then says: Error: Please make sure if the given kernel(s) exist(s).
Please also read this:
- Use your phone’s USB tethering
- Go to a cybercafé / friend / family member and ask for an Ethernet cable and hook that up to your Ethernet port.
Unfortunately we cannot help you without any Internet connectivity.
That’s the thing that I want to ssolve my internet conection, but I need internet connection in orderto solve my internet connection. And I also connected an ethernet cable but it does not work either
What i did then is that i tried downloading the kernel from kernel.org and i found the steps to build it but it is required to use the command “make“ but it says “make: command not found“, is there anyway for me to download “make“ from another device and then copy to my laptop and installed from tjere. Please help me i will really appreciate it
Go to Settings- Manjaro Settings Manager-Kernel and install the kernel from there. You really want the Manjaro kernel in this case. Alternatively. you can get the kernel as j8a suggested in his post above.
Please read again " How to Provide good information" as inxi output in text format is the preferred way on this forum. How to provide good information
update.
i am finally able to connect internet via my cellphone with usb internet thetering.
i put inxy -Fazy and it shows:
Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=74396440-57cd-486c-8dcd-dbcf87702b94 rw quiet apparmor=1
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: TOSHIBA product: CA10AB v: xxxxxx-xxxxxx
serial:
Mobo: AMD model: CA10AB serial: UEFI [Legacy]: Insyde v: 1.00
date: 03/28/2014
ID-1: BAT0 charge: 2.3 Wh condition: 15.3/33.0 Wh (46%) volts: 15.5/14.8
model: TKBSS G71C000HS110 type: Li-ion serial: N/A status: Charging
cycles: -2
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial:
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Topology: Quad Core model: AMD A8-6410 APU with AMD Radeon R5 Graphics
bits: 64 type: MCP arch: Puma family: 16 (22) model-id: 30 (48) stepping: 1
microcode: 7030104 L2 cache: 2048 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 15976
Speed: 998 MHz min/max: 1000/2000 MHz boost: enabled Core speeds (MHz):
1: 1096 2: 998 3: 1000 4: 1057
Type: spectre_v2
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Toshiba driver: radeon
v: kernel alternate: amdgpu bus ID: 00:01.0 chip ID: 1002:9851
Device-2: Chicony type: USB driver: uvcvideo bus ID: 4-1.2:4
chip ID: 04f2:b446
Display: x11 server: X.Org 1.20.9 driver: ati,radeon unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 112 size: 310x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.8.16-2-MANJARO LLVM 10.0.1)
v: 4.5 Mesa 20.1.8 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: Toshiba driver: snd_hda_intel
v: kernel bus ID: 00:01.1 chip ID: 1002:9840
Device-2: AMD FCH Azalia vendor: Toshiba driver: snd_hda_intel v: kernel
bus ID: 00:14.2 chip ID: 1022:780d
Sound Server: ALSA v: k5.8.16-2-MANJARO
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: XAVi driver: ath9k v: kernel port: 3100 bus ID: 01:00.0
chip ID: 168c:0036
IF: wlp1s0 state: down mac:
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Toshiba
driver: r8169 v: kernel port: 2000 bus ID: 02:00.0 chip ID: 10ec:8136
IF: enp2s0 state: down mac:
IF-ID-1: enp0s16u2 state: unknown speed: N/A duplex: N/A mac:
Local Storage: total: 931.51 GiB used: 6.44 GiB (0.7%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: rev: 4M scheme: MBR
ID-1: / raw size: 931.51 GiB size: 915.89 GiB (98.32%) used: 6.44 GiB (0.7%)
fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 45.0 C mobo: N/A gpu: radeon temp: 45 C
Processes: 173 Uptime: 10m Memory: 4.78 GiB used: 1010.0 MiB (20.6%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1057 lib: 311
flatpak: 0 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.05
And then when i try mhwd-kernel shows:
[anferneefc@anferneefc-ca10ab ~]$ sudo mhwd-kernel -i linux54
warning: database file for ‘core’ does not exist (use ‘-Sy’ to download)
warning: database file for ‘extra’ does not exist (use ‘-Sy’ to download)
warning: database file for ‘community’ does not exist (use ‘-Sy’ to download)
warning: database file for ‘multilib’ does not exist (use ‘-Sy’ to download)
available kernels:
Hi @MRBomberman ,
Well, you have the problem almost solved.
Could you try the following commands under the terminal:
This is necessary to update the mirrors in order to download the correct and as fast as you could from the repositories.
sudo pacman-mirrors -f10
This command for installing the new kernel.
sudo pacman -Sy linux54 linux54-headers
I personally suggest to run
sudo pacman -Syyu
before the last command but as you are using your phone it will be painful because the upgrades are huge.
i use the comand sudo pacman -syu i took like 3 hours but the kernel got updated:
i rebooted the system but still i am unable to use wifi or ethernet.
if i use inxi -fazy i got;
Kernel: 5.10.30-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
serial:
Mobo: AMD model: CA10AB serial: UEFI-[Legacy]: Insyde v: 1.00
date: 03/28/2014
ID-1: BAT0 charge: 15.2 Wh (100.0%) condition: 15.2/33.0 Wh (46.0%)
volts: 16.1 min: 14.8 model: TKBSS G71C000HS110 type: Li-ion serial: N/A
status: Full cycles: -2
Info: Quad Core model: AMD A8-6410 APU with AMD Radeon R5 Graphics bits: 64
microcode: 7030104 cache: L2: 2 MiB
bogomips: 15970
1: 998 2: 1000 3: 1056 4: 1090
Type: spectre_v2
v: kernel alternate: amdgpu bus-ID: 00:01.0 chip-ID: 1002:9851
class-ID: 0300
Device-2: Chicony TOSHIBA Web Camera - HD type: USB driver: uvcvideo
bus-ID: 2-1.2:4 chip-ID: 04f2:b446 class-ID: 0e02
Display: x11 server: X.Org 1.20.11 driver: loaded: ati,radeon
unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
diag: 355mm (14")
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.10.30-1-MANJARO LLVM 11.1.0)
v: 4.5 Mesa 21.0.2 direct render: Yes
v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.10.30-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.25 running: no
vendor: XAVi driver: ath9k v: kernel port: 3100 bus-ID: 01:00.0
chip-ID: 168c:0036 class-ID: 0280
driver: r8169 v: kernel port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:8136
class-ID: 0200
Local Storage: total: 931.51 GiB used: 9.55 GiB (1.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
ID-1: / raw-size: 931.51 GiB size: 915.89 GiB (98.32%) used: 9.55 GiB (1.0%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 54.0 C mobo: N/A gpu: radeon temp: 51.0 C
Processes: 170 Uptime: 2m wakeups: 3 Memory: 4.78 GiB
used: 822.5 MiB (16.8%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: N/A Packages: pacman: 1140 lib: 376 flatpak: 0 Shell: Bash v: 5.1.0
running-in: xfce4-terminal inxi: 3.3.04.
Hi @MRBomberman,
You did a great job!
Please ensure your wifi connection is not block running this command
rfkill list all
The output in my computer, which is similar to yours shows:
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
None either the wifi or the bluethoot adapter are blocked in my computer.
Then, put the output with your text in the answer. Whether you see something blocked you could run the following terminal command:
rfkill list all
Maybe you could solve the problem so easy.
The other outputs I needed in order to see what is working wrong are these two from the terminal command are the following:
dmesg | grep NetworkManager
You can also read what @jr
‘Slow internet: WiFi Atheros QCA9565 / AR9565 Wireless Adapter - #20 by jrichard326’
I think we are closer, regards.
[anferneefc@anferneefc-ca10ab ~]$ rfkill list all
0: Toshiba Bluetooth: Bluetooth
Soft blocked: yes
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
[anferneefc@anferneefc-ca10ab ~]$ journalctl -f -t NetworkManager
Journal begins at Fri 2021-04-09 17:34:26 CDT. –
Apr 21 15:53:37 anferneefc-ca10ab NetworkManager[563]: [1619038417.8738] dhcp4 (enp0s16u2): activation: beginning transaction (timeout in 45 seconds)
Apr 21 15:53:38 anferneefc-ca10ab NetworkManager[563]: [1619038418.0735] dhcp4 (enp0s16u2): state changed unknown → bound, address=192.168.42.5
Apr 21 15:53:38 anferneefc-ca10ab NetworkManager[563]: [1619038418.0758] device (enp0s16u2): state change: ip-config → ip-check (reason ‘none’, sys-iface-state: ‘managed’)
Apr 21 15:53:38 anferneefc-ca10ab NetworkManager[563]: [1619038418.1700] device (enp0s16u2): state change: ip-check → secondaries (reason ‘none’, sys-iface-state: ‘managed’)
Apr 21 15:53:38 anferneefc-ca10ab NetworkManager[563]: [1619038418.1706] device (enp0s16u2): state change: secondaries → activated (reason ‘none’, sys-iface-state: ‘managed’)
Apr 21 15:53:38 anferneefc-ca10ab NetworkManager[563]: [1619038418.1716] manager: NetworkManager state is now CONNECTED_LOCAL
Apr 21 15:53:38 anferneefc-ca10ab NetworkManager[563]: [1619038418.1737] manager: NetworkManager state is now CONNECTED_SITE
Apr 21 15:53:38 anferneefc-ca10ab NetworkManager[563]: [1619038418.1742] policy: set ‘Wired connection 2’ (enp0s16u2) as default for IPv4 routing and DNS
Apr 21 15:53:38 anferneefc-ca10ab NetworkManager[563]: [1619038418.2526] device (enp0s16u2): Activation: successful, device activated.
Apr 21 15:53:38 anferneefc-ca10ab NetworkManager[563]: [1619038418.7592] manager: NetworkManager state is now CONNECTED_GLOBAL
[anferneefc@anferneefc-ca10ab ~]$ dmesg | grep NetworkManager
dmesg: read kernel buffer failed: Operation not permitted
Hi @MRBomberman ,
Good!
Please run this commands:
rfkill unblock all
and to verify that the wifi adapters are up please run again
rfkill list all
I forgot to tell that the other command needs the sudo privilege
sudo dmesg | grep NetworkManager
Regards,
[anferneefc@anferneefc-ca10ab ~]$ sudo rfkill unblock all
Soft blocked: no
Hard blocked: no
Soft blocked: no
Hard blocked: yes
2: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
[anferneefc@anferneefc-ca10ab ~]$ sudo dmesg | grep NetworkManager
[ 35.420849] audit: type=1130 audit(1619038258.235:43): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=NetworkManager-dispatcher comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
[ 46.059433] audit: type=1131 audit(1619038268.875:48): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=NetworkManager-dispatcher comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
[ 166.041960] audit: type=1111 audit(1619038388.855:97): pid=563 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘op=radio-control arg=“wireless-enabled” pid=1300 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success’
[ 195.273567] audit: type=1130 audit(1619038418.085:98): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=NetworkManager-dispatcher comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
[ 206.008260] audit: type=1131 audit(1619038428.825:99): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=‘unit=NetworkManager-dispatcher comm=“systemd” exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success’
Hi, do you have a FN key which enables and disables the wifi?
If the answer is yes try to turn the wifi off and on and see whether the icon of the network manager can see your internet ssid.
Also try to run
systemctl status NetworkManager
and
lspci -k
post the result here.
You are very close !!
Regards,
NetworkManager.service - Network Manager
Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; v>
Drop-In: /usr/lib/systemd/system/NetworkManager.service.d
└─NetworkManager-ovs.conf
Active: active (running) since Wed 2021-04-21 16:24:59 CDT; 4min 43s ago
Docs: man:NetworkManager(8)
Main PID: 639 (NetworkManager)
Tasks: 3 (limit: 5859)
Memory: 12.6M
CGroup: /system.slice/NetworkManager.service
└─639 /usr/bin/NetworkManager --no-daemon
Apr 21 16:27:15 anferneefc-ca10ab NetworkManager[639]: [1619040435.0767>
Apr 21 16:27:15 anferneefc-ca10ab NetworkManager[639]: [1619040435.5771>
Apr 21 16:28:56 anferneefc-ca10ab NetworkManager[639]: [1619040536.1354>
Apr 21 16:28:56 anferneefc-ca10ab NetworkManager[639]: [1619040536.4930>
Apr 21 16:28:56 anferneefc-ca10ab NetworkManager[639]: [1619040536.4932>
Apr 21 16:28:56 anferneefc-ca10ab NetworkManager[639]: [1619040536.4937>
Apr 21 16:28:56 anferneefc-ca10ab NetworkManager[639]: [1619040536.4942>
Apr 21 16:28:56 anferneefc-ca10ab NetworkManager[639]: [1619040536.4954>
Apr 21 16:28:56 anferneefc-ca10ab NetworkManager[639]: [1619040536.4971>
Apr 21 16:28:56 anferneefc-ca10ab NetworkManager[639]: [1619040536.5001>
…skipping…
● NetworkManager.service - Network Manager
Memory: 12.6M
…skipping…
Memory: 12.6M
…skipping…
Memory: 12.6M
lines 1-22/22 (END)
[anferneefc@anferneefc-ca10ab ~]$ lspci -k
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h (Models 30h-3fh) Processor Root Complex
Subsystem: Advanced Micro Devices, Inc. [AMD] Family 16h (Models 30h-3fh) Processor Root Complex
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Mullins [Radeon R4/R5 Graphics] (rev 05)
Subsystem: Toshiba Corporation Device f90e
Kernel driver in use: radeon
Kernel modules: radeon, amdgpu
00:01.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Kabini HDMI/DP Audio
Subsystem: Toshiba Corporation Device f900
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h (Models 30h-3fh) Host Bridge
00:02.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Functions 5:1
Kernel driver in use: pcieport
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Functions 5:1
DeviceName: CX20752 HD AUDIO CODEC
00:02.5 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 16h Processor Functions 5:1
00:08.0 Encryption controller: Advanced Micro Devices, Inc. [AMD] Kabini/Mullins PSP-Platform Security Processor
Kernel driver in use: ccp
Kernel modules: ccp
00:10.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB XHCI Controller (rev 11)
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode]
Kernel driver in use: ahci
00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 39)
Kernel driver in use: ehci-pci
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 39)
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 42)
Kernel modules: i2c_piix4, sp5100_tco
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD] FCH Azalia Controller (rev 02)
Subsystem: Toshiba Corporation Device f906
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 11)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h (Models 30h-3fh) Processor Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h (Models 30h-3fh) Processor Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h (Models 30h-3fh) Processor Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h (Models 30h-3fh) Processor Function 3
Kernel driver in use: k10temp
Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h (Models 30h-3fh) Processor Function 4
Kernel driver in use: fam15h_power
Kernel modules: fam15h_power
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 16h (Models 30h-3fh) Processor Function 5
01:00.0 Network controller: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter (rev 01)
Subsystem: XAVi Technologies Corp. Device 28a2
Kernel driver in use: ath9k
Kernel modules: ath9k
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller (rev 07)
Kernel driver in use: r8169
Kernel modules: r8169
03:00.0 Unassigned class [ff00]: Alcor Micro AU6601 PCI-E Flash card reader controller
Kernel driver in use: alcor_pci
Kernel modules: alcor_pci
