I was trying to turn on my Bluetooth from the top right corner, and it was turned off. I clicked the drop-down and there it said it was turned off instead of turn on. Furthermore, I then went into settings and tried to toggle the Bluetooth, but it wasn’t turning on.
Additional issue: I tried to screen record by using Ctrl+Shift+Alt+R, but it was also not turning on.
I have Manjaro with gnome desktop. Please help.
Provide basic Information:
Similar bluetooth issue:
You can see your gnome screen recorder (screencast) shortcut keys with:
gsettings get org.gnome.settings-daemon.plugins.media-keys screencast
If it still doesn’t work then try installing gstreamer:
https://askubuntu.com/questions/1161668/gnome-screencast-not-working
sudo pacman -S gstreamer
Hey buddy, when I typed the command sudo rfkill, it showed that
ID TYPE DEVICE SOFT HARD
0 bluetooth hci0 blocked unblocked
I guess it says my software is blocked. How to unblock it?
sudo rfkill unblock bluetooth && sudo systemctl restart bluetooth
Thanks m8. It worked
ok sir
