Hey guys. I’m very new to Manjaro. Spent a couple months on Pop OS before I decide to try out an Arch based system instead.
My eithernet worked perfectly fine over on Pop, so I know my hardware is supported.
My wireless works fine btw, but pretty useless with VPN as it keeps disconnecting for whatever reason.
The “ip link show” command says it’s a Realtek Semiconductor Co., Ltd. Killer E3000 2.5GbE Controller (rev 06)
I’ve tried a few things, such as “ip link set enp110s0 up”. And enp110s0 being the name of my wired connection according to command “nmcli connection show”.
I have no idea what the issue can be. Maybe it’s driver related. And if that’s the case, how do I find and install this driver?
Btw. “Wired connection” is not listed in the Networks applet. Only wireless connections.
Also. The fact that my wireless works fine leads me to believe that this is driver related.
Please help. Thank you.
Please read and post a full inxi output. Also please tell us which VPN you are using if it is a commercial VPN. Are you dual-booting Windows?
The VPN has nothing to do with the issue at hand I think. Although, it’s ExpressVPN. So I’m using their Arch app provided on their website. I’ve never connected VPN through wireless internet before, so I’m sure it’s just not stable on a wireless connection.
Anyway, I am not dual booting. And as far as the other PC specs, I provided those when I signed up to the forum.
this is what we can see of those specs
Branch: Stable
Desktop Environment: KDE
CPU: GenuineIntel Model: 6.165.5 "Intel(R) Core(TM) i9-10900K CPU @ 3.70GHz
GPU: Nvidia 3080
GPU Driver: Nvidia-470
Kernel: 5.15.12-1-MANJARO
and it’s not enough
That is why @jrichard326 asked you to do what he asked you do.
@Nachlese No need to be rude. Attitude like that is what gives the Linux community a bad rep.
And FYI, I provided all the info he asked about in my reply to him.
What other information should I provide?
Kernel 5.15 is at 5.15.16. Please update your system if you have not already.
@jrichard326 Thanks, but I went to the Kernels settings and it says that 5.16 is a release candidate. So it says Experimental. What does that mean in terms of stability? How alpha or beta is “rc”?
It was not my intention to be perceived as such.
Just stated facts.
… inxi …
Be well!
@Nachlese Well. Okay then. Water under the bridge.
So, what info did I forget to post?
@jrichard326 Btw. I don’t a newer kernel is gonna help me here. As I said earlier, ethernet worked fine on Pop OS which uses a much older kernel.
Manjaro is a curated rolling release. If not updated regularly, it will break sooner than later. Since you have not posted an inxi output, I am going by your profile information which indicates Kernel 5.15.12 which is not updated on the stable branch as 5.15 is currently at 5.15.16-1. System updates are far more than just the kernel.
The 5.16.2-1 is available on Stable branch as well. It is pretty unusual for Ethernet not to work. Did it work in the Live environment? Yesterday there was a Linux Firmware update here on Unstable, so that will be coming down to Stable at some point soon.
The following may be of some help:
Thanks @jrichard326 . I just upgrade the kernel as well as the entire system.
Still no eithernet though.
inxi
CPU: 10-core Intel Core i9-10900K (-MT MCP-) speed/min/max: 1100/800/5300 MHz
Kernel: 5.16.2-1-MANJARO x86_64 Up: 0m Mem: 3341.5/128686.2 MiB (2.6%)
Storage: 5.59 TiB (23.7% used) Procs: 469 Shell: Zsh inxi: 3.3.12
Oh, and I did not test eithernet in live mode because I didn’t have it plugged in, so I connected to Wifi prior to installing the system.
This still does not provide information about your network. Please read the “How to Provide Good Information” link in my first response and post a full inxi output ( whether you think it is necessary or not) as specified in the link. I am not a Network expert, but surely somebody here is, and it is doubtful you will get help without providing information.
Also, please read:
Sorry. I thought I provided enough info in the first post.
This should cover everything:
❯ hwinfo --network
50: None 00.0: 10701 Ethernet
[Created at net.126]
Unique ID: 63Vg.ndpeucax6V1
Parent ID: Dhtl.YPKdJUFpjD6
SysFS ID: /class/net/wlp0s20f3
SysFS Device Link: /devices/pci0000:00/0000:00:14.3
Hardware Class: network interface
Model: “Ethernet network interface”
Driver: “iwlwifi”
Driver Modules: “iwlwifi”
Device File: wlp0s20f3
HW Address: dc:21:48:5c:6f:f2
Permanent HW Address: dc:21:48:5c:6f:f2
Link detected: yes
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #12 (Ethernet controller)
51: None 00.0: 10701 Ethernet
Unique ID: 7s3+.ndpeucax6V1
Parent ID: aylZ.H9sutq2C068
SysFS ID: /class/net/enp110s0
SysFS Device Link: /devices/pci0000:00/0000:00:1d.5/0000:6e:00.0
Driver: “r8169”
Driver Modules: “r8169”
Device File: enp110s0
HW Address: d4:93:90:01:7f:9d
Permanent HW Address: d4:93:90:01:7f:9d
Link detected: no
Attached to: #17 (Ethernet controller)
52: None 00.0: 10700 Loopback
Unique ID: ZsBS.GQNx7L4uPNA
SysFS ID: /class/net/lo
Model: “Loopback network interface”
Device File: lo
Link detected: yes
deleted
@jrichard326 huh?
from the first few lines of the contents of the (twice) provided link
(partly paraphrased):
export LANG=C
(to make sure the output is not in your native language)always, always provide the output of:
inxi --admin --verbosity=7 --filter --width
even if you think it’s not relevant.
Also try to care about formatting the output to make it more readable.
@Nachlese Well. I’m kinda new to this. Wasn’t sure what info to provide.
But here you go. Here’s the output:
❯ inxi --admin --verbosity=7 --filter --width
Kernel: 5.16.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
root=UUID=5beee92d-e9a6-4f09-be6b-5195e860c154 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Notebook product: X170KM-G v: N/A
Mobo: Notebook model: X170KM-G serial: <superuser required> UEFI: INSYDE
v: 1.07.04HID01 date: 01/11/2020
ID-1: BAT0 charge: 95.4 Wh (100.0%) condition: 95.4/96.5 Wh (98.9%)
volts: 16.2 min: 14.4 model: Notebook BAT type: Li-ion serial: <filter>
status: Full
RAM: total: 125.67 GiB used: 5.09 GiB (4.1%)
RAM Report:
Info: model: Intel Core i9-10900K bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 5 microcode: 0xEC
Topology: cpus: 1x cores: 10 tpc: 2 threads: 20 smt: enabled cache:
L1: 640 KiB desc: d-10x32 KiB; i-10x32 KiB L2: 2.5 MiB desc: 10x256 KiB
L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 1241 high: 3222 min/max: 800/5300 scaling:
driver: intel_pstate governor: powersave cores: 1: 1099 2: 1100 3: 1100
4: 1100 5: 1100 6: 1100 7: 1100 8: 1100 9: 1090 10: 1100 11: 1100 12: 1101
13: 1100 14: 1100 15: 1100 16: 1100 17: 1100 18: 1809 19: 3222 20: 1100
bogomips: 148040
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand rdseed
rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Device-1: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
vendor: CLEVO/KAPOK driver: nvidia v: 470.94 alternate: nouveau,nvidia_drm
bus-ID: 01:00.0 chip-ID: 10de:24dc class-ID: 0300
Device-2: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 1-8:4
chip-ID: 5986:9102 class-ID: 0e02
Display: x11 server: X org 1.21.1.3 compositor: kwin_x11 driver:
loaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: NVIDIA GeForce RTX 3080 Laptop GPU/PCIe/SSE2
v: 4.6.0 NVIDIA 470.94 direct render: Yes
Device-1: Intel vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:f0c8 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:228b
class-ID: 0403
Sound Server-1: ALSA v: k5.16.2-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
Device-2: Realtek Killer E3000 2.5GbE vendor: CLEVO/KAPOK driver: r8169
v: kernel port: 3000 bus-ID: 6e:00.0 chip-ID: 10ec:3000 class-ID: 0200
IF: enp110s0 state: down mac: <filter>
bus-ID: 1-14:7 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 5.59 TiB used: 1.32 TiB (23.7%)
ID-1: /dev/nvme0n1 maj-min: 259:2 model: T-FORCE TM8FP8002T size: 1.86 TiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: VC0S032M temp: 45.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 model: T-FORCE TM8FP8002T size: 1.86 TiB
type: SSD serial: <filter> rev: VC0S032M temp: 36.9 C
ID-3: /dev/nvme2n1 maj-min: 259:1 model: T-FORCE TM8FP8002T size: 1.86 TiB
ID-1: / raw-size: 1.86 TiB size: 1.83 TiB (98.37%) used: 1.32 TiB (72.3%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:4 label: N/A
uuid: 5beee92d-e9a6-4f09-be6b-5195e860c154
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
label: NO_LABEL uuid: 4993-9287
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-1:2
info: SHARKOON 2.4GHz Wireless rechargeable vertical mouse [More&Better]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
Device-2: 1-5:3 info: Integrated Express ITE Device(829x) type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:8910 class-ID: 0300
Device-3: 1-8:4 info: Acer BisonCam NB Pro type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:9102
class-ID: 0e02
Device-4: 1-9:5 info: Integrated Express IT8297 RGB LED Controller
type: Keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 048d:8297 class-ID: 0301
Device-5: 1-10:6 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00a8
class-ID: ff00 serial: <filter>
Device-6: 1-14:7 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 42.0 C mobo: N/A gpu: nvidia temp: 39 C
Processes: 396 Uptime: 4h 2m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1397 pacman: 1367 lib: 370
flatpak: 30 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.12
mod note : formatted text for you
This might sound funny, but did you check that the Ethernet cable is fully plugged in and that the router/switch led is on to signal that there is connectivity on the hardware layer?
@seb Of course.
