This thread is obsolete. The new COSMIC Desktop Environment is currently in alpha and available in the repos.
It is not compatible with GNOME 42. ![]()
You may remember System76 announcing COSMIC earlier this year with the release of Pop!_OS 21.04:
https://blog.system76.com/post/655369428109869056/popos-2104-a-release-of-cosmic-proportions
Since then, I’ve been testing packaging the COSMIC experience for Manjaro. Now with Pop!_OS 21.10, COSMIC is finally compatible with GNOME 40.
Install
ONLY FOR GNOME 41
- Install the
cosmicpackage group:pamac install cosmic - Enable the Cosmic Dock, Pop Cosmic and Pop Shell GNOME Shell Extensions. Optionally enable Cosmic Workspaces if you want a vertical overview.
There are also optional dependencies, be sure and check those if you want the full Pop!_OS experience.
If you want the Pop! Dark Cyan folder color while using papirus-icon-theme, install papirus-folders and run the following command.
Replace Papirus-Dark with whichever Papirus variant you might be using:
papirus-folders -t Papirus-Dark -C darkcyan
The Manjaro GNOME logo that appears in the bottom right-hand corner of the first screenshot below is gnome-shell-extension-background-logo (Background Logo). Thanks to @anon89812132 for making the logo.
Preview
