how to change the icon themes
can the app dragged to the home screen (widget)
like other DE
Under settings, customize look and feel, changing icon theme might lead to legability issues.
There is no desktop widget, the application view replaces it.
If can drag favourite apps to the dock.
how to change the app scrolling to horizontal
Iâve tried it on css but it doesnât work
If you want to modify default behaviour and theme then you have to make yourself familiar with CSS and JavaScript as I am not going to have time to make those modifications and present you with the code, there is many ways you can achieve that, but in this case you can look at flexbox horizontal scrolling.
itâs been successful Iâve done it
Simple replace one of the videos for the one you want and give it the same name.
I changed it with the same name but the video doesnât work
as seen in the picture above there is a video marked X
I donât see the same names on the picture above, it has to be same name as a existent video, also it has to be mp4 format having just mp4 extension wonât work.
Not working
how to change the video background. Iâve changed it to the same name but it doesnât even work
If is not working itâs because your videos are not in MP4 format, however this section is for bug reports.
can you take a little time to try to replace the video background with the same video name. the video I changed was in mp4 format.
Open one of the videos with Pitivi or Hanbrake check what codec is using and transcode your videos to the same codec, it works on my end.
IMHO is faster to check using mediainfo (also for avoiding to install heavy applications)
mediainfo ~/Videos/myvideo.mp4 | grep "Codec ID"
Codec ID : isom (isom/iso2/avc1/mp41)
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Codec ID : mp4a-40-2
how to use
are you not interested in adding the dark mode feature. not html and css can do it
I want to color the background of the .app css elements
and I want the color to be different in each app. What should I do?
