I have checked two posts about buzzing sound in the forum (seems could not copy link in the post) Probably the same issue, but after trying those, it is still not working. Those buzzing sounds will automatically output when opening some software with sounds, or even notifications with sounds. It will also happen when I open the audio mixer. It did not happen before, but I just found this today.
Device-1: Intel Alder Lake PCH-P High Definition Audio
driver: sof-audio-pci-intel-tgl
Device-2: NVIDIA driver: N/A
Sound Server-1: ALSA v: k5.17.9-1-MANJARO running: yes
Sound Server-2: PipeWire v: 0.3.51 running: yes
it is also wired that I did have file for cat /sys/module/snd_hda_intel/parameters/power_save.
Could anyone provide help? Thank you so much!!!
provide output from:
inxi -Fazy
Kernel: 5.17.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=17a57bc5-4569-4d1b-8454-2c7d491f058c rw quiet apparmor=1
security=apparmor udev.log_priority=3 snd_hda_intel.power_save=0
button.lid_init_state=open
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel, plank
wm: xfwm v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Razer product: Blade 15 (2022) - RZ09-0421 v: 8.04
Mobo: Razer model: CH580 v: 4 serial: <superuser required> UEFI: Razer
v: 1.09 date: 02/22/2022
ID-1: BAT0 charge: 83.1 Wh (100.0%) condition: 83.1/80.2 Wh (103.6%)
volts: 17.5 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
status: full
ID-2: hidpp_battery_0 charge: 37% condition: N/A volts: 3.8 min: N/A
model: Logitech G903 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: <filter> status: discharging
Info: model: 12th Gen Intel Core i7-12800H bits: 64 type: MST AMCP
arch: Alder Lake family: 6 model-id: 0x9A (154) stepping: 3 microcode: 0x41C
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 831 high: 2310 min/max: 400/2400:1800 scaling:
driver: intel_pstate governor: powersave cores: 1: 416 2: 768 3: 1448 4: 847
5: 395 6: 872 7: 2310 8: 712 9: 519 10: 598 11: 400 12: 705 13: 470
14: 744 15: 773 16: 1628 17: 400 18: 897 19: 800 20: 927 bogomips: 112160
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Razer USA
driver: i915 v: kernel ports: active: eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA103M [GeForce RTX 3080 Ti Laptop GPU] vendor: Razer USA
driver: nvidia v: 510.73.05 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Ampere pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:2460 class-ID: 0300
Device-3: IMC Networks Integrated RGB Camera type: USB driver: uvcvideo
bus-ID: 1-2:2 chip-ID: 13d3:5279 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 4608x1985 s-dpi: 96 s-size: 1219x525mm (47.99x20.67")
s-diag: 1327mm (52.25")
Monitor-1: HDMI-1-0 pos: primary,top-right res: 2560x1440 hz: 60 dpi: 108
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
Monitor-2: eDP-1 pos: bottom-l res: 2048x1152 hz: 60 dpi: 151
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Razer USA
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA vendor: Razer USA driver: N/A alternate: snd_hda_intel
pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2288 class-ID: 0403
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:6
chip-ID: 8087:0033 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 968.49 GiB used: 75.71 GiB (7.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: NVMe CA6-8D1024 size: 953.87 GiB
block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
type: SSD serial: <filter> rev: ERA0902 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Lexar model: USB Flash Drive
size: 14.62 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw-size: 672.78 GiB size: 661.15 GiB (98.27%)
used: 75.66 GiB (11.4%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
used: 50.7 MiB (52.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 52.0 C mobo: N/A
Processes: 456 Uptime: 44m wakeups: 7 Memory: 31.04 GiB
used: 4.85 GiB (15.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: 1388 pacman: 1371 lib: 326 flatpak: 8
snap: 9 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.16
thx!
install sof-firmware package:
sudo pacman -S sof-firmware
then reboot and test
error appeared:
error: extract: not overwriting dir with file /usr/lib/firmware/intel/sof-tplg
error: problem occurred while upgrading sof-firmware
error: could not commit transaction
error: failed to commit transaction (transaction aborted)
seems installed before
warning: sof-firmware-2.1.1-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) sof-firmware-2.1.1-1
Total Installed Size: 14.04 MiB
Net Upgrade Size: 0.00 MiB
(1/1) checking keys in keyring [######################] 100%
(1/1) checking package integrity [######################] 100%
(1/1) loading package files [######################] 100%
(1/1) checking for file conflicts [######################] 100%
(1/1) checking available disk space [######################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/1) reinstalling sof-firmware [######################] 100%
ok so its installed already… so install the 5.15 LTS and the 5.10LTS kernels from system settings/kernel, reboot, select the 5.15 in grub menu, and test with it, if it doesnt work, do the same with the 5.10
I updated from 5.15 to 5.17 before due to the wifi issues from the forum. do you mean to just test in 5.15 live boot?
no just install the 5.15 and 5.10 and reboot and select them in the grub menu and test if the audio wokrs with the LTS kernels
try with
sudo pacman -S sof-firmware --overwrite="/usr/lib/firmware/intel/sof-tplg"
or
sudo pacman -S sof-firmware --overwrite="*"
cczzz
25 May 2022 08:08
11
I tried 5.15, same problem. And I can’t boot into 5.10. maybe because of the new hardware and drivers?
cczzz
25 May 2022 08:09
12
tried both, still same output and error
all right so install the latest kernel 5.18 and try with it, if it doesnt work, we try pulse/pipewire install/uninstall
cczzz
25 May 2022 08:11
14
btw I could not find the password of this account before, so I registered new one. Now I recovered this…
you cant boot on older kernel 5.10 , remove
keep 5.15 LTS and 5.17 , may be add 5.18 coming ( in state this is RC , Release Candidate , coming in stable )
good damn, i just realized that youre not OP …
cczzz
25 May 2022 08:16
17
a quick question before moving forward, if I had to switch 5.17 back later, will I just need to
sudo pacman -S linux517-headers linux517-nvidia
sudo mkinitcpio -P
and reboot?
why do you want to install headers and nvidia?
post output from:
mhwd-kernel -li
cczzz
25 May 2022 08:21
19
5.18 has the same problem . And I install those before based on my another question here . And I found while installing new kernels, old nvidia and headers will be removed and instead install those with corresponding kernel version
Currently running: 5.18.0-1-MANJARO (linux518)
* linux517
* linux518
you have already installed the 517 kernel, so you dont need to install again headers, just reboot and switch to it in grub menu
