System Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
ManjaroLinux 23.0.0 UltimaThule (KDE Plasma, wayland)
CPU Vendor ID: GenuineIntel
CPU Model name: Intel(R) Core(TM) i5-7300HQ CPU @ 2.50GHz
lspci -k | grep VGA returns: 1 ✘
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 630 (rev 04)
01:00.0 VGA compatible controller: NVIDIA Corporation GP107M [GeForce GTX 1050 Mobile] (rev a1)
relevant would be:
nvidia-dkms 530.41.03-4 ✔
nvidia-utils 530.41.03-4
mesa 23.0.4-1
vulkan-intel 23.0.4-1
envycontrol 3.2.0-2
But, here’s a problem, my nvidia card seems to be running through noveau for some reason:
01:00.0 VGA compatible controller: NVIDIA Corporation GP107M [GeForce GTX 1050 Mobile] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Acer Incorporated [ALI] GP107M [GeForce GTX 1050 Mobile]
Flags: bus master, fast devsel, latency 0, IRQ 255
Memory at a3000000 (32-bit, non-prefetchable) [size=16M]
Memory at 90000000 (64-bit, prefetchable) [size=256M]
Memory at a0000000 (64-bit, prefetchable) [size=32M]
I/O ports at 4000 [disabled] [size=128]
Expansion ROM at a4080000 [disabled] [size=512K]
Capabilities: <access denied>
Kernel modules: nouveau
Also did a full system upgrade last night hoping that would fix something. Seems it didn’t.
also this, if it’s any help:
> All PCI configs:
NAME VERSION FREEDRIVER TYPE
video-virtualmachine 2021.07.26 true PCI
video-voodoo 2017.03.12 true PCI
video-sisusb 2020.01.18 true PCI
video-hybrid-amd-nvidia-prime 2023.03.23 false PCI
video-openchrome 2020.01.18 true PCI
video-nvidia 2023.03.23 false PCI
video-modesetting 2020.01.13 true PCI
video-nvidia-390xx 2023.03.23 false PCI
video-hybrid-amd-nvidia-470xx-prime 2023.03.23 false PCI
video-s3 2020.01.18 true PCI
video-vesa 2017.03.12 true PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2023.03.23 false PCI
video-hybrid-intel-nvidia-prime 2023.03.23 false PCI
video-hybrid-intel-nvidia-470xx-prime 2023.03.23 false PCI
video-nvidia-470xx 2023.03.23 false PCI
video-rendition 2020.01.18 true PCI
network-rt3562sta 2013.12.07 true PCI
network-slmodem 2013.12.07 true PCI
network-r8168 2016.04.20 true PCI
network-broadcom-wl 2018.10.07 false PCI
normally doing glxinfo | grep “OpenGL renderer” returns:
OpenGL renderer string: Mesa Intel(R) HD Graphics 630 (KBL GT2)
And found an error here I think (?), running it with prime render offload:
prime-run glxinfo | grep "OpenGL renderer"
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 150 (GLX)
Minor opcode of failed request: 24 (X_GLXCreateNewContext)
Value in failed request: 0x0
Serial number of failed request: 50
Current serial number in output stream: 51
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
